Телевизорите са два вида 60 и 120 херца.
Този е 60 херца.
200-400-800 Hz Motionflow тези са съвсем други, в линка по горе прочети за значението или в нета.
Аз ти препоръчвам този размер 43 за да извадиш най добрата картина от този телевизор.
Rehwaz
Какво разбираш под динамична подсветка?
8-ма серия(8602, 8102)
https://www.tehnomix.bg/cherna-tehni...55-pus-8602-12
European TV 2017 - Tuners Tuners Samsung Sony Panasonic LG Philips Double Tuners
DVB-T/T2/C/S/S2QE**Q9F
QE**Q8C
QE**Q8F
QE**Q7C
QE**Q7F
QE**Q6F
UE**MU900x
UE**MU80xx
UE**MU70xx
UE**LS003KD-**A1
KD-75XE9405
KD-**XE9305
KD-**XE9005
KD-**XE8505TX-**EZ1000E
TX-**EZ950E
TX-**EX780E
TX-**EX730EOLED**W7V
OLED**G7V
OLED**E7N
OLED**E7V**POS9002 DVB-T/T2/C/S/S2 UE-**MU6645
UE-**MU6505
UE-**MU6502
UE-**MU6452
UE-**MU6405
UE-**MU6175KD-**XE8005
KD-**XE7005TX-**EX703E
TX-**EX603E
TX-**ES513E
TX-**ES403EOLED**C7V
OLED**B7V
**SJ957V
**SJ955V
**SJ950V
**SJ850V
**SJ810V
**SJ800V
**UJ750V
**UJ701V
**UJ700V
**UJ675V
**UL670V
**UJ651V
**UJ650V
**UJ630V
**UJ620V
**LJ610V
**LJ594V
**LJ590U
**LJ510U
**LJ500V
**LJ500U**PUS9602
**PUS8102
**PUS7502
**PUS7202
**PUS6482
**PUS6453
**PUS6432
**PUS6412
**PHS5362
**PFS5362
**PFS5302
**PHS5302DVB-T/T2/C UE-**MU6305
UE-**MU6205
UE-**MU6202
UE-**MU6125
UE-**MU6122
UE-**MU6105
UE-**M560x
UE-**M550x
UE-**M500x
UE-**M400xKDL-**WE750
KDL-**WE660
KDL-**WE610
KDL-**R450
KDL-**R400TX-**EX700E
TX-**EX600E
TX-**ES500E
TX-**ES400E**LJ5150
**LJ500B**PUT7032
**PUT6002
**PFT5362
**PHT5362
**PFT5302
**PHT5102
**PFT5102
Nanosys and DIC Announce Inkjet-Printed Quantum-Dot Process - AVSForum.com
Printed Quantum Dot display breakthrough makes tomorrow’s low cost, ultra-thin, and flexible displays possible — Quantum Dot Pioneers
https://www.oled-info.com/joled-star...monitor-panels
Mini LEDs to be used in backlighting in 2018
Klein ChromaSurf — Klein Instruments
Ted's LightSpace CMS Calibration Disk / eeColor / LightSpace - Main Menu
Благодаря за таблицата! Явно няма да се класирам с моите 2000 лв...
Макар сега видях – UE**MU80xx / UE**MU70xx – предполагам тук ще „вляза“.
Под динамична подсветка разбирам, когато на екрана има небе и поляна, процесорът да се „засилва“ и да прави небето по-ярко. Не знам дали го обяснявам правилно и дали ще ме разберете...
И все пак – PIP?
Процесът се нарича - локално затъмняване.
Според реализацията на подсветката, то бива 2 типа
- Edge Led Local Dimming
- Direct Led Local Dimming (по-добрият вариант)
За PIP виж в спецификациите на моделите на официалните страници.
50EX780 отговаря на условията, само дето ще трябва да имаш два СА модула и две карти ако каналите са кодирани.
nasko_g1 - взимай го , по-добър е от тия дето си ги гледал и на тая цена е идеален .Цитат:
Сега виждам че в Емаг този Samsung UE49MU7002 е на цена 1460 лв.
... и си разчисти кутията , че не може да получаваш ЛС. :Drinks:
Това е линка с тв който получих от EMAG и дават 13 % отстъпка с код: eMAG5....Пробвах го само за споменатия 55''SAMSUNG MU6102,работи(но на снимка,че има отстъпка е само той,за другите не знам...за SONYXE9005 не дава)...Като гледам горе Svetlio има такъв тв,така,че ако има желание да каже дали наистина е direct led и отзиви щото цената е супер.
https://www.emag.bg/televizori/vendo...al&cmpid=71836
Да , с директЛЕД е, но аз имам 50" и е възможно в 55"-та версия да не е, както и голяма вероятност 55" да е с PLS/IPS панел, което променя тотално някои параметри в картината - мини ревю на модела съм писал в темата за Самсунг, пост 1003 .
Трябва да се провери на място в някое "техно", особено за панела.
Май така излиза...Отиваш в магазина и томбола,къвто панел ти се падне.Хората се сърдят ,че прах за пране в Западна Европа бил друг,при тв не друго ,ами чак и матриците в един и същ модел разични.И hz също....Малко ми прилича на ''Тука има,тука,нема''.
след като филтрирах избора до Sony KD55XE9005BAEP се появиха още две алтернативи: SONY KD55XE9305BAEP и LG OLED55C7V (защо не и LG OLED55B7V- нямам идея каква е разликата с C7).
Кой от всички препоръчвате ?
Мерси sony 1! Други мнения колеги?
Колега cable, виждам от подписа ти, че е си с LG B6- какво по-добро от лични впечатления и мнения за OLED-а?!
https://www.displayspecifications.co...ison/36362b9d3
Оказва се че 50-та е с VA панел и Direct LED докато 55-та е PLS/IPS Direct LED:confused:
Да,различни панели,различни подсветки.49''-edge led,50 и 55 direct led.Честно казано за този PLS не съм се заглеждал,щото си мисля,че с LED тв-те съм приключил.Вероятно от сега нататък всичко ново при тях ще е с цел поевтиняване.
Ама стойката е еднаква:)
>silver1
колега,за мен най-важните показатели за тв са контраст и движение(при цветовете във високите серии не намирам особенни разлиия,не че няма сигурно).Не използвам OLED тв си за монитор,а пък и времето когато си играех игрички отдавна ми е минало,за съжаление.Така,че лично за мен с контраста си OLED няма конкуренция.Разбира се има и други мнения,но това са моите предпочитания.Няма да е коректно аз да сравнявам тв-ри,тъй като за да правиш такива сравнения трябва да си ги гледал с един и същ сигнал,един и същ материал,еднакво осветление,да си правил замервания ит.н.
И си мисля,че ако SONY напр. беше направил някакъв супер led тв щеше ли да купува OLED панели от LG и да казва,че това е най-високия клас тв-ри?
Затова няколко пъти показвам таблиците с оценки на rtings и flatpanels(които са горе долу еднакви).Ето напр. подреждането което се дава от flatpanels по картина(не по тотал)което най -много ме интересува,защото напр.за качествен звук си има други устройства и.т.н..https://forum.setcombg.com/attachmen...id=25281&stc=1
cable
...изненадва ме, че Sony са потънали в тази класация
тук пък не е така: https://www.rtings.com/tv/tests/pict...eak-brightness
Искам да кажа, че мнението на реален потребител в реални условия е безценно за мен. Класациите малко или много са доста синтетични. Относно начина на преценка- несъмнено си прав!
В моя случай, TV-то ще се ползва основно за гледане на TV (mtel) и филми (главно през USB флашка); за PC монитор няма да се ползва, единствено ако не плейва нещо вградения плеър ще се наложи да използвам PC-то за тези цели (от това най-вече искам да избягам, че в момента с тези кабели е ужас). Последното споменато ме разколеба от избора ми на 55XE9005- до колкото четох Android TV не е най-хубавото, което може да ти се случи; дори и да кача kodi, хардуера на TV не е достатъчен за него; да слагам външно устройство (minix, raspberry и др.) и да плейвам от него- ааа не, мерси! поредното дистанционно, кабели и т.н.т.
(вчера бях заредил поръчката на един 55XE9005+minix U9, когато се осъзнах какво правя). Търся удобство и качество на картината, а до колкото е възможно и добър звук.
Всъщност тук е момента някой да разсее впечатленията ми за недъгавия Android и да каже няколко добри думи за него.
Определено 55XE9305 има прекрасна картина, от друга страна LG C7 е впечатляващ и той (както спомена не случайно A1 е със същия панел)!
....помагайте!
SONY не са потънали в тази класация,а са номер 1 с А1.Това което даваш е класиране по peak brightnes,а не за картина,филми или спорт.Освен това когато контраста е равен на безкрайност не знам защо ти трябва много светла картина,аз при hdr даже ми идват много ярки някои сцени.Виж добре оценките за hdr movies.Трябва да гледаш това:
https://www.rtings.com/tv/reviews/best/by-size/55-inch
и ако искаш по-голяма точност си направи средно между двете.Истината винаги е посредата.И даже в САЩ прибавят и цената и се получава това:
:https://forum.setcombg.com/attachmen...id=25282&stc=1
https://forum.setcombg.com/attachmen...id=25283&stc=1
