От 17-ти октомври всички канали на Нова в HD - паката Диема Спорт в 4К
На 17-ти този месец, започва тестовото излъчване.
NOVA
Distributed resolutions: HD HDR 50p; HD SDR 50i; SD AVC 50i; SD MP2 50i;
(UHD HDR 50p – for future use);
Audio Channels: 2 x Stereo Pairs (BG Audio / Original Audio)
Kino NOVA
DIEMA Sport
Distributed resolutions: UHD HDR 50p; HD HDR 50p; HD SDR 50i; SD AVC 50i; SD MP2 50i
DIEMA Sport 2
Distributed resolutions: UHD HDR 50p; HD HDR 50p; HD SDR 50i; SD AVC 25i; SD MP2 50i
DIEMA Sport 3
DIEMA
Distributed resolutions: HD SDR 50i; SD AVC 50i; SD MP2 50i
DIEMA Family
NOVA Sport
NOVA News
Audio Channels: 2 x Stereo Pairs (BG Audio / BG Audio)
Magic TV
Audio Channels: 1 x Stereo Pair
The Voice
UHD HDR 50p / Transport Stream bitrate – 24 Mbit/s
Video
Resolution: 3840 x 2160
Frame rate: 50 fps
Scan Type: Progressive
Croma Subsampling: 4:2:0
Color Space: Rec. 2020 / 10-bit
Dynamic Range: HDR
Transfer Function: HLG
GOP Length: 100 frames (2 sec)
GOP Cadence: Closed
B-frames: 2
Video Encoding: H.265
Audio
Sampling: 48 kHz
Audio Encoding: AAC-LC
Bitrate: 128 kbps / channel
Ancillary Data*
SCTE-35
Teletext/DVB-Subtitling
HD HDR 50p / Transport Stream bitrate – 18 Mbit/s
Video
Resolution: 1920 x 1080
Frame rate: 50 fps
Color Space: Rec. 2020 / 10bit
Dynamic Range: HDR
GOP Cadence: Closed
B-frames: 3
Video Encoding: H.264
Audio
Sampling: 48 kHz
Bitrate: 128 kbps /channel
Ancillary Data*
SCTE-35
HD SDR 50i / Transport Stream bitrate – 12 Mbit/s
Video
Frame rate: 25 fps
Scan Type: Interlaced
Color Space: Rec. 709 / 8-bit
Dynamic Range: SDR
Transfer Function: Gamma (none)
GOP Length: 50 frames (2 sec)
GOP Cadence: Closed
B-frames: 3
Audio
Sampling: 48 kHz
Audio Encoding: MP1-L2
Bitrate: 256 kbps / channel
Ancillary Data*
SCTE-35
SD AVC 50i / Transport Stream bitrate – 4 Mbit/s
Video
Resolution: 720 x 576
Aspect Ratio: 16:9
Frame rate: 25 fps
Color Space: Rec. 601 / 8-bit
Dynamic Range: SDR
GOP Cadence: Closed
B-frames: 3
Audio
Sampling: 48 kHz
Bitrate: 256 kbps /channel
Ancillary Data*
SCTE-35
SD MP2 50i / Transport Stream bitrate – 6 Mbit/s
Video
Aspect Ratio: 16:9
Frame rate: 25 fps
Dynamic Range: SDR
GOP Length: 12 frames
GOP Cadence: Closed
B-frames: 2
Video Encoding: MPEG-2
Audio
Sampling: 48 kHz
Ancillary Data*
SCTE-35
Отговор: От 17-ти октомври всички канали на Нова в HD - паката Диема Спорт в 4К
tvbox
Ти да видиш... не мога да повярвам, ама..... ако е като сегашното "HD" в кавички по-добре не!
Откъде е инфото?
Офффф и докато операторите го имплементират ...ще стане след 100 години. Поне е добро начало и другите ще трябва да се включат в надпреварата.
stenly
Дано от Tivi.bg се включат първи както предния път, тогава ще има по-бърза реакция, но все пак откъде е инфото, че в нета нищо не пише.
Благодаря!
tvbox
UHD HDR 50p / Transport Stream bitrate – 24 Mbit/s (много малко, за качество са нужни над 60)
Video
Frame rate: 50 fps (реални 25fps с дублиране на всеки кадър)
Croma Subsampling: 4:2:0 (нужно е 4:4:4 , но това покачва битрейта - поне да го бяха направили 4:2:2)
https://en.wikipedia.org/wiki/Chroma_subsampling
Color Space: Rec. 2020 / 10-bit (според мен си е лъжа, всички пускат Rec.709 или DCI-P3 в контейнер Rec.2020)
Dynamic Range: HDR
Transfer Function: HLG (а могат в Dolby Visison)
GOP Cadence: Closed
B-frames: 2
Audio
Sampling: 48 kHz
Ancillary Data*
SCTE-35
Мениджмънта им не става за нищо. Още преди 15 години трябваше да си подменят камерите и да трупат материал в HD, а от 2-3 години и в UHD...
Последни минаха в HD , при това половината им предавания са в SD. От години имат проблеми с някои камери в студията, а на ги оправят или сменят.
Репортерите им в страната още снимат с допотопни любителски камери...включително Василковски.
Радакторите са под всяккава критика - отразяват само едната страна.
Aма пускат разни забавни халтурки като "Игрите на Гла... Волята" и "Рачков",
та народецът рипа да ги гледа на 65+ тАлАвизорите си, мхм...
Ако пуснат трасе за 4К спорт на живо, таксата ще им стане 20-30лв на месец. За един български коментар не си заслужава. Има къде да ги гледаме и без комендар :)
Нова Броудкастинг Груп, правят пълен ъпгрейд. Местят се в нова сграда с нови студиа, нова апаратура, камери... Относно цената на спортният пакет, аз също мисля, че ще стане значително по-висока спрямо сегашната.
brotzki
По-тъпото е, че и 50 лв да стане ще има кой да плаща. И тези същите ще обясняват на другите кви ганьовци и бедняци са. В същото време тарикати като домус ага ги пускат във Форбс.........
tvbox
За цената можем да мислим много неща.Ако остават 2 дни,ще я видим.DE мисля сега можеш да я включваш и изключваш всеки месец,така че ако е мого скъпо,поне за световното.
Но не намерих подобно нещо с търсачката онзи ден,та ако кажеш от къде го знаеш.няма да е зле.
И все пак не искам да спамя темата, но откъде е сорса на информацията?
Никъде в Google няма инфо за това, дори по ключови думи.
Благодаря!
Видлял го е в dtv форума, но по някаква причина не ще да каже (не знам защо не е цитирал източника, при положение, че го взима от друго място). Щом са го пуснали там значи е леджит.
Не знам кой от къде,ама днес сме 17....
И дори ми попада тази статия,някъде UHD/4K?
https://www.vesti.bg/lyubopitno/nova...chvane-6153328
''И това ще стане.Някога,но не сега''
Мда.... не 4К, ами направо 16К са ги пуснали.... Годината обаче не беше уточнена!
Търпеливо ще чакам да влезе направо 8к, освен ако дотогава не умра от старост де .....................
