Страница 1 от 15 12311 ... ПоследноПоследно
Резултати от 1 до 15 от общо 219
Like Tree89Одобрявам
От 17-ти октомври всички канали на Нова в HD - паката Диема Спорт в 4К
    Apr 2020
    На 17-ти този месец, започва тестовото излъчване.
    NOVA
    Distributed resolutions: HD HDR 50p; HD SDR 50i; SD AVC 50i; SD MP2 50i;
    (UHD HDR 50p – for future use);
    Audio Channels: 2 x Stereo Pairs (BG Audio / Original Audio)
    Kino NOVA
    DIEMA Sport
    Distributed resolutions: UHD HDR 50p; HD HDR 50p; HD SDR 50i; SD AVC 50i; SD MP2 50i
    DIEMA Sport 2
    Distributed resolutions: UHD HDR 50p; HD HDR 50p; HD SDR 50i; SD AVC 25i; SD MP2 50i
    DIEMA Sport 3
    DIEMA
    Distributed resolutions: HD SDR 50i; SD AVC 50i; SD MP2 50i
    DIEMA Family
    NOVA Sport
    NOVA News
    Audio Channels: 2 x Stereo Pairs (BG Audio / BG Audio)
    Magic TV
    Audio Channels: 1 x Stereo Pair
    The Voice
    UHD HDR 50p / Transport Stream bitrate – 24 Mbit/s
    Video
    Resolution: 3840 x 2160
    Frame rate: 50 fps
    Scan Type: Progressive
    Croma Subsampling: 4:2:0
    Color Space: Rec. 2020 / 10-bit
    Dynamic Range: HDR
    Transfer Function: HLG
    GOP Length: 100 frames (2 sec)
    GOP Cadence: Closed
    B-frames: 2
    Video Encoding: H.265
    Audio
    Sampling: 48 kHz
    Audio Encoding: AAC-LC
    Bitrate: 128 kbps / channel
    Ancillary Data*
    SCTE-35
    Teletext/DVB-Subtitling
    HD HDR 50p / Transport Stream bitrate – 18 Mbit/s
    Video
    Resolution: 1920 x 1080
    Frame rate: 50 fps
    Color Space: Rec. 2020 / 10bit
    Dynamic Range: HDR
    GOP Cadence: Closed
    B-frames: 3
    Video Encoding: H.264
    Audio
    Sampling: 48 kHz
    Bitrate: 128 kbps /channel
    Ancillary Data*
    SCTE-35
    HD SDR 50i / Transport Stream bitrate – 12 Mbit/s
    Video
    Frame rate: 25 fps
    Scan Type: Interlaced
    Color Space: Rec. 709 / 8-bit
    Dynamic Range: SDR
    Transfer Function: Gamma (none)
    GOP Length: 50 frames (2 sec)
    GOP Cadence: Closed
    B-frames: 3
    Audio
    Sampling: 48 kHz
    Audio Encoding: MP1-L2
    Bitrate: 256 kbps / channel
    Ancillary Data*
    SCTE-35
    SD AVC 50i / Transport Stream bitrate – 4 Mbit/s
    Video
    Resolution: 720 x 576
    Aspect Ratio: 16:9
    Frame rate: 25 fps
    Color Space: Rec. 601 / 8-bit
    Dynamic Range: SDR
    GOP Cadence: Closed
    B-frames: 3
    Audio
    Sampling: 48 kHz
    Bitrate: 256 kbps /channel
    Ancillary Data*
    SCTE-35
    SD MP2 50i / Transport Stream bitrate – 6 Mbit/s
    Video
    Aspect Ratio: 16:9
    Frame rate: 25 fps
    Dynamic Range: SDR
    GOP Length: 12 frames
    GOP Cadence: Closed
    B-frames: 2
    Video Encoding: MPEG-2
    Audio
    Sampling: 48 kHz
    Ancillary Data*
    SCTE-35
    Rumb@ta и iveto харесват това.
  3. Infraction Users
    Sep 2011
    Отговор: От 17-ти октомври всички канали на Нова в HD - паката Диема Спорт в 4К
    Ти да видиш... не мога да повярвам, ама..... ако е като сегашното "HD" в кавички по-добре не!
    Откъде е инфото?
  4. Super Moderator
    Dec 2000
    Sofia
    Офффф и докато операторите го имплементират ...ще стане след 100 години. Поне е добро начало и другите ще трябва да се включат в надпреварата.
  5. Infraction Users
    Sep 2011
    Цитат Първоначално публикувано от stenly Виж публикацията
    Дано от Tivi.bg се включат първи както предния път, тогава ще има по-бърза реакция, но все пак откъде е инфото, че в нета нищо не пише.
    Благодаря!
    UHD HDR 50p / Transport Stream bitrate – 24 Mbit/s (много малко, за качество са нужни над 60)
    Video
    Frame rate: 50 fps (реални 25fps с дублиране на всеки кадър)
    Croma Subsampling: 4:2:0 (нужно е 4:4:4 , но това покачва битрейта - поне да го бяха направили 4:2:2) https://en.wikipedia.org/wiki/Chroma_subsampling
    Color Space: Rec. 2020 / 10-bit (според мен си е лъжа, всички пускат Rec.709 или DCI-P3 в контейнер Rec.2020)
    Dynamic Range: HDR
    Transfer Function: HLG (а могат в Dolby Visison)
    GOP Cadence: Closed
    B-frames: 2
    Audio
    Sampling: 48 kHz
    Ancillary Data*
    SCTE-35
    Мениджмънта им не става за нищо. Още преди 15 години трябваше да си подменят камерите и да трупат материал в HD, а от 2-3 години и в UHD...
    Последни минаха в HD , при това половината им предавания са в SD. От години имат проблеми с някои камери в студията, а на ги оправят или сменят.
    Репортерите им в страната още снимат с допотопни любителски камери...включително Василковски.
    Радакторите са под всяккава критика - отразяват само едната страна.
    svetlio1, djsmiley, brotzki и 4 други харесват това.
  7. Member Аватара на Shimbadze
    Sep 2004
    Aма пускат разни забавни халтурки като "Игрите на Гла... Волята" и "Рачков",
    та народецът рипа да ги гледа на 65+ тАлАвизорите си, мхм...
    Dominator и CubanLinx харесват това.
    Ако пуснат трасе за 4К спорт на живо, таксата ще им стане 20-30лв на месец. За един български коментар не си заслужава. Има къде да ги гледаме и без комендар
    Apr 2020
    Нова Броудкастинг Груп, правят пълен ъпгрейд. Местят се в нова сграда с нови студиа, нова апаратура, камери... Относно цената на спортният пакет, аз също мисля, че ще стане значително по-висока спрямо сегашната.
    Jan 2017
    По-тъпото е, че и 50 лв да стане ще има кой да плаща. И тези същите ще обясняват на другите кви ганьовци и бедняци са. В същото време тарикати като домус ага ги пускат във Форбс.........
    Gena_bs и djsmiley харесват това.
  12. Banned
    Aug 2020
    За цената можем да мислим много неща.Ако остават 2 дни,ще я видим.DE мисля сега можеш да я включваш и изключваш всеки месец,така че ако е мого скъпо,поне за световното.
    Но не намерих подобно нещо с търсачката онзи ден,та ако кажеш от къде го знаеш.няма да е зле.
    Dominator одобрява това.
  13. Infraction Users
    Sep 2011
    И все пак не искам да спамя темата, но откъде е сорса на информацията?
    Никъде в Google няма инфо за това, дори по ключови думи.
    Благодаря!
    Jan 2017
    Видлял го е в dtv форума, но по някаква причина не ще да каже (не знам защо не е цитирал източника, при положение, че го взима от друго място). Щом са го пуснали там значи е леджит.
    Този пост е редактиран от CubanLinx; 16-10-22 в 15:59.
  16. Banned
    Aug 2020
    Не знам кой от къде,ама днес сме 17....
    И дори ми попада тази статия,някъде UHD/4K?
    https://www.vesti.bg/lyubopitno/nova...chvane-6153328
    ''И това ще стане.Някога,но не сега''
  17. Infraction Users
    Sep 2011
    Мда.... не 4К, ами направо 16К са ги пуснали.... Годината обаче не беше уточнена!
    Asen Ikonomov одобрява това.
    Feb 2017
    Търпеливо ще чакам да влезе направо 8к, освен ако дотогава не умра от старост де .....................
  1. Отговори: 3
    Последно: 05-08-21, 09:43
  2. Отговори: 0
    Последно: 03-12-20, 19:50
  3. Samsung ue-32j4500aw-не намира всички канали
    От ssamm22 във форум Samsung телевизори
    Отговори: 18
    Последно: 10-04-17, 17:12
  4. Октомври 2010
    От kod във форум Дъра-Бъра
    Отговори: 11
    Последно: 15-10-10, 12:42
  5. Честита Нова Година на всички...
    От hihimor във форум Дъра-Бъра
    Отговори: 17
    Последно: 02-01-09, 18:15
