rodir
Без съмнение ks7002
https://www.avforums.com/review/samsung-ks7000-ue55ks7000-uhd-4k-tv-review.12659
Чети,в заглавието си го пише : If you're looking for great Ultra HD performance at an equally great price then look no further
rodir
Без съмнение ks7002
LG 55 UH950V video review
https://www.youtube.com/watch?v=zZ8yYv40TiI
source video: [youtube.com - digitalfernsehende]
Серии - UH61, UH62 - промени в софтуера Changelog
Release History
[03.20.05]
1. To apply Netflix promotion
2. To imporve 'No signal' problem happening upon HDCP 2.2 certification
3. To improve HDR performance with 4K Blu-Ray player connection
4. Extend Universal Control for STB
5. Support Hikari IPTV TEE
6. Screen Capture
7. WOWL quick return to standby
8. Add JP Customer Center Call Number
9. To apply MR minor2 feature
[04.30.02]
1. Change on Volume UI location
2. YouTube requirement for certification (When the network is not connected)
3. Russia Magadan /Sakhalin timezone offset change
4. FHD BT application (Voice Search/Universal Control)
[04.30.03]
1. Change the OTAU SO satellite (Intelsat904 to Kazsat3)
[04.30.70]
1. Improve the Sony PS4 Pro no signal issue (HDCP fail)
2. Improve the Tricolor satellite channel crash. (Russia)
Серии - UH63, UH65, UH66, UH67, UH75 SW information
[04.30.40]
Improvement
1) Freeview Play Support in UK
2) Apply the DVB-T2 system in Czech
3) To Improve auto-reboot problem with "This app will now restart to free up more memory" phrases during watching Live TV in Spain
4) To Improve automatic channel number changes(over 850 channel) problem during watching Italy Rai channel
5) Fix Video Skip Issue in 4K HDR Content
6) Fix MRCU Pairing Failure Issue
7) Fix RF-DTV Lip Sync Mismatch Issue
Серия - UH85
[04.30.65] - Improvement
5) Fix MRCU Pairing Failure Issue
Ето какви формати и кодеци възпроизвежда вграденият плейър
Help - LG Smart TV Document
List of Supported Codecs and Containers
The following table specifies all the supported codecs and containers by emulator and real TV in more detail.
Common
File
Extensions Media
Container A/V Codec FourCC DTV Target Supported? Emulator
Supported? Target
Description Profile/Level Support Emulator
Description .asf
.wmv
.wma ASF Video VC-1 Advanced Profile WVC1 YES YESOnly streams compliant to SMPTE 421M VC-1 standard are supported. Advanced Profile @ Level 3
(e.g. 720p60, 1080i60, 1080p30) WMVA YES
(ReadDescription) YESOnly streams compliant to SMPTE 421M VC-1 standard are supported. Some WMVA streams were developed before the VC-1 specification was finalized.
These non-compliant streams are considered deprecated by the industry and are not supported.Advanced Profile @ Level 3
(e.g. 720p60, 1080i60, 1080p30) VC-1 Simpleand Main Profiles WMV3 YES YESOnly streams compliant to SMPTE 421M VC-1 standard are supported. Simple Profile @ Medium Level
(e.g. CIF, QVGA)
Main Profile @ High Level
(e.g. 1080p30) Other videoCodecs like MPEG-1/2/4 NO NOASF is a MS container format. Anything other than MS Codecs should not be found within an ASF file. Non MS Codecs within ASF are not supported. Audio WMA Standard 0x0161 YES YES WMA 9 Professional 0x0162 YES NO.wma format notSupported on emulator. WMA Lossless NO NO Other audio Codecs likeAC-3, AAC, MP3,
MPEG Audio Layer I/II NO NOASF is a MS container format. Anything other than MS Codecs should not be found within an ASF file. Non MS Codecs within ASF are not supported. .divx
.avi AVI /DivX Media Format Video Divx3.11 DIV3
DIV4 YES YESPlease note that a FourCC value of DIV4 is not a DivX 4 stream, but in fact, a DivX 3.11 stream. DivX 4 streams have a FourCC value of DIVX. Divx4
Divx5
Divx6 divx
DIVX
DIV5
DIV6
DX50 YES YESMPEG-4 ASP support does not include global motion compensation or quarterpel motion estimation. Streams using this syntax are not supported. Advanced Simple Profile.
The resolution supported is chip dependent with earlier chips supporting up to SD resolutions (480i) and newer chips supporting up to HD (720p/1080i). XViD XVID YES YESMPEG-4 ASP support does not include global motion compensation or quarterpel motion estimation. Streams using this syntax are not supported. Advanced SimpleProfile.
The resolution supported is chip dependent with earlier chips supporting up to SD resolutions (480i) and newer chips supporting up to HD (720p/1080i) Other video Codecs likeMPEG-1/2 NO NO H.264 / AVC vssh
VSSH
AVC
avc
AVC1
avc1
h264
H264 NOT OFFICIALLY SUPPORTED
(ReadDescription) NOAVC within AVI files is not officially supported. It is well known in the industry that there are technical issues which make AVC is ill-suited for AVI encapsulation. This creates problems for compliance and interoperability. That is why it is known and recommended for AVC content to be put into other file containers such MP4 and MKV. There isCode to attempt to handle AVC within AVI files but some streams will work and others will not. Main Profile @ Level 4.1
High Profile @ Level 4.1
(e.g. 720p60, 1080i60, 1080p30) Audio MPEG-1 Layer I, II 0x0050 YES YES MPEG-1 Layer III (MP3) 0x0055 YES YES AC-3 0x2000 YES YES WMA Standard 0x0161 YES YES WMA 9 Professional 0x0162 YES NO Other audio Codecs likeAAC, DTS, PCM NO NO .mkv MKV Video H.264 / AVC V_MPEG4/ISO/AVC YES YESMost of the MKV content available is encoded by the open source x264 Codec, the default configuration labels streams as Level 5.0 (e.g. highest level), the video decoder only supports up to Level 4.1 and does it isbest to decode Level 5.0 streams Main Profile @ Level 4.1
(e.g. 720p60, 1080i60, 1080p30).Mkv format is not supported in emulator. Other video Codecs like MPEG-1/2/4 NO NONeed sample streams to test Audio AAC A_AAC YES YESAAC-LC and AAC-HE AC-3 A_AC3 YES YES MPEG-1 Layer III (MP3) A_MPEG/L3 YES YES MPEG-1 Layer I, II A_MPEG/L1
A_MPEG/L2 YES YES .ts
.trp
.tp
.m2ts MPEG-2
TS(Transport Stream),
standard 188 byte TS and time-stamped 192 byte TS Video H.264 / AVC YES YESMain Profile @ Level 4.1
(e.g. 720p60, 1080i60,1080p30).ts,.trp,.tp
and .m2ts formats are not supported on emulator. MPEG-2 YES YESMain Profile @ High Level
(e.g. 720p60, 1080i60) VC-1 YES NOOnly streams compliant to SMPTE 421M VC-1 standard are supported. Encapsulation must abide by SMPTE RP227 specification. Simple Profile @ Medium Level
(e.g. CIF, QVGA)
(e.g. 1080p30)
(e.g. 720p60, 1080i60,1080p30) Audio MPEG-1 Layer I, II YES YES MPEG-1 Layer III (MP3) YES YES AC-3 YES NO DDP (Enhanced AC-3) YES NO AAC YES YESAAC-LC and AAC-HE .vob MPEG-2
PS(Program Stream),
VOB,
SVCD Video MPEG-1 YES NO.vob is not supported in emulator. MPEG-2 YES YESMain Profile @ High Level
(e.g. 720p60, 1080i60) Audio AC-3 YES NO MPEG-1 Layer I, II YES YES DVD-LPCM YES NO .mpg
.dat MPEG-1 Systems,
VCD Video MPEG-1 YES YES.mpg, .datare not supported in emulator. Audio MPEG-1 Layer I, II YES YES .mpg
.mpe
.mpeg UnknownNote that these file extensions do not uniquely specify whether the contents are TS, PS or ES. These files are supported only if the decoder is configured properly for TS, PS or ES. The decoder needs to know this information and will not determine it on its own. See other rows for support information. .mp4
.m4a
.m4v MP4 Video H.264 / AVC avc1 YES YESMain Profile @ Level 4.1
(e.g. 720p60, 1080i60,1080p30) MPEG-4 Part 2 mp4v YES YESMPEG-4 ASP support does not include global motion compensation or quarterpel motion estimation. Streams using this syntax are not supported.
Motion compensation describes a picture in terms of the transformation of a reference picture to the current picture. The reference picture may be previous in time or even from the future. When images can be accurately synthesized from previously transmitted/stored images, the compression efficiency can be improved.
Quarter Pixel Motion Search Precision (QPEL): Basically most MPEG-4 Codecs by default detect motion between two frames down to half a pixel (HalfPel). Now with QuarterPel you can detect motion that is only a quarter of a pixel per frame, effectively doubling precision!
practically this means that you will get a much sharper image with QPEL.
Global Motion Compensation (GMC):
GMC detects if there is an amount of motion big parts of the frame have in common. If that’s the case GMC kicks in, using a single motion vector for all similar parts of the frame instead of multiple ones. Practically this helps saving bits when panning, zoom or rotation occurs (depending on how good the GMC implementation is/offered warp points), bits which than can be used somewhere else, for example where they bring more sharpness.Advanced Simple Profile
The resolution supported is chip dependent with earlier chips supporting up to SD resolutions (480i) and newer chips supporting up to HD (720p/1080i) H.263 s263 YES NOProfile 0, Level 70. No Annex supported Other video Codecs likeMPEG-1/2, VC-1 NO NONo standard specifying header.
No sample files. Audio AAC mp4a YES YESAAC-LC and AAC-HE Other audio Codecs like AC3, DTS, MP3 NO NONo standard specifying header.
No sample files. .mov QT Audio/Video NO NOMost QuickTime streams appear to be MPEG-4 Part 12. Please see MP4 section of list supported audio/video Codecs. .mov format is not supported in emulator. .f4v
.f4a
.flv Flash formats Audio/Video YES YESPlease see MP4 section of list supported audio/video Codecs Support limited to LPCM Flash engine supports flash playback such asas .f4v, .f4a and .flv.
These formats are not supported using open API. (e.g., playClipFile) .wav WAV Audio LPCM 0x0001 NO NO.wav format is not supported in emulator. .mp3 MP3 Audio MPEG-1 Layer III YES YES
Някой може ли да ми каже как функционира MULTIVIEW режима на LG UHD 6-та серия ? От колко източника може да се гледа ? Как се дели екрана и други подробности ? Предварително благодаря .
Телевизора е LG-UF8507 според вас за гледане вечер кой режим е по-подходящ експерт 1, експерт 2 или кино?
LG [V10] How to use multi-view recording? | LG Sri Lanka
https://www.youtube.com/watch?v=n2d7k5OsfHY
index
Welcome to webOS TV | Ръководство на потребителя
Кино!
Режимите ISF Експерт 1 или ISF Експерт 2 са идентични един с друг, така че няма значение, кой си избрал, за да гледаш. Тяхното присъствие свидетелства за факта, че телевизорът е сертифициран от организацията ISF. Напомням, че това ти дава:
ISF сертификацията гарантира, че телевизорът има две банки за памет, които може да бъдат променени за всеки конектор, и след това да го заключиш срещу случайни промени. След професионално калибриране от експерт и последвало заключване на тези режими, телевизора им дава нови имена - ISF ден и ISF нощ.
При въвеждане на ISF-Expert също предлагам следните промени в основната картина:
Aspect Ratio -> Scan, така изображението е с правилният размера на екрана, без да се отрязват краищата
Опции за изображението -> Noise Reduction -> Off, така изображението не се размива в местата, където телевизорът автоматично определил и открил шум
Опции за изображението -> MPEG Noise Reduction -> Off, така изображението не се размива в местата, където телевизорът автоматично е открил шум
Нещо не ми се връзва...да е на 100%
Там не пипаш нищо- просто превключваш на режима и гледаш. При някои марки има даже два такива режима Cinema и True Cinema.
пробваи тези
https://www.youtube.com/watch?v=Lt1J0kEJs0U
На българския сайт на LG има нова версия на FW за LG 42LF652V - 4.05.45.
Интересното е, че няма Change log, А и самия телевизор казва, че няма намерен update или поне за БГ.
Предишната версия 4.05.30 беше за Казахстан - някаква промяна на въведените спътници. Телевизорът и нея не отрази.
Колега Аз съм точно с този модел LG 42LF652V,тв ми показа съобщение че има нова версия,пуснах и ъпдейтнах до 4.05.45 без проблем,само не знам какво има в тази актуализация,някой ако намери инфо да пише.
43LH6047 е с IPS панел, успях да направя снимка
https://forum.setcombg.com/attachmen...id=21515&stc=1
Ако външния ми хард диск е включен в тв-то мога ли по мрежа с компютъра да му качвам филми, да не се налага да го разкачам всеки път.
