| LG Oled UHD TV 2016 - european models |
Product
Serie | UHD
Premium
Certificate
_____ | Dolby
Vision
Certificate
__________ | HDR ________________ | Videopanel ______________________ | Backlight
___________________
Dimming | Color Space ____________________________ | Contrast ,
White & Black level
__________________ | Viewing Angle
_____________ | Input Lag
__________ | Networks __________________ | Ports ___________________________ | SoC
Platform
Software
OS _________ | Tuner _________________ | Product |
G6V 77", 65" | Yes | Dynamic optimization scenes via Dolby Vision technology VS10 | HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
77" - max 744cd/m2
65" - max 640cd/m2 | OLED (WRGB 10bit)
LG Display
(Triple anti-reflective coating) | No | 77"DCI P3 - 9 %
65"DCI P3 - 94.14% | 75" -
65" - 10000000:1
150cd/m2 / 0.00cd/m2 | 77" -
65" - | 77"- 3
65"- 33.6ms | Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
DLNA | 4 x HDMI2.0 (ARC,CEC,MHL)
1 x Satelite in(Main:F-type,female)
1 x AV Composite In 3.5mm jack
1 x Component in(shared with composite)
1 x RS232C(Mini Jack)
1 x Antena (RF) (Female)
1 x Optical Audio Out
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x USB 3.1 HID controller
Compatibility-mouse/keyboard | -
Quad Core
webOS 3.0 | Dual tuners
DVB -T/ T2/C/S/S2
with PVR and PIP function
Analog (PAL,SECAM)
HEVC | G6V |
E6V 65", 55" | Yes | Dynamic optimization scenes via Dolby Vision technology VS10 | HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
65" - max 640cd/m2
55" - max 596cd/m2 | OLED (WRGB 10bit)
LG Display
(Double anti-reflective coating) | No | 65" DCI P3 - 9 %
55" DCI P3 - 96.46% | 65" -
55" - | 65" -
55" - 166°(cone) | 65"- 3
55"- 34.1ms | Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
DVB - T/T2/C/S/S2
Analog (PAL,SECAM)
HEVC | E6V |
C6V
(curved) 65", 55" | ? | Dynamic optimization scenes via Dolby Vision technology VS10 | HDR10 compatble
(SMPTE-Standards
ST2084 и ST2086)
65" - max
55" - max | OLED (WRGB 10bit)
Curved
LG Display | No | 65" DCI P3 - 9 %
55" DCI P3 - 9 % | 65" -
55" - | 65" -
55" - | 65"-
55"- | Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
DLNA | 3 x HDMI2.0 (ARC,CEC,MHL)
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
webOS 3.0 | DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
HEVC | C6V |
B6V 65", 55" | No | Dynamic optimization scenes via Dolby Vision technology VS10 | HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
65" - max
55" - | 65" -
55" - | 65"-
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
Analog (PAL,SECAM)
HEVC | B6V |
| LG LCD Super UHD TV 2016 - european models |
| Product | UHD
Premium
_____ | Dolby
Vision
_____ | HDR
___________________
____________________________ | Contrast &
Black level
_____ | Networks
Platform
Software
OS
_____ | Tuner
UH980V 95" | No | Yes
VS10 | HDR10 | 95"- IPS, 10-bit, 120/100Hz
Quantum Dots | Direct Led (W-Led)
Local Dimming | 95" - | 95" - | 95" - | 95" - | Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
Analog (PAL,SECAM)
HEVC | UH950V 95" |
| LG LCD UHD TV 2016 - european models |
| Product | UHD
Premium
_____ | Dolby
Vision
_____ | HDR
Black level
_____ | Networks
Platform
Software
OS
_____ | Tuner
UH950V 86", 65", 55" | No | Yes
VS10 | HDR10 | AS-IPS, 10-bit (true) , 120/100Hz + BLS
Quantum Dots | 86" - Edge Led (W-Led)
65" - Edge Led (W-Led)
55" - Edge Led (W-Led)
Local Dimming | 86"- DCI P3 - /Rec.2020 -
65" -
55" - | 86" -
65" -
55" - | 86" -
65" -
55" - | 86" -
65" -
55" - | Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
WebOS 3.0 | DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
HEVC | UH950V 86", 65", 55" |
UH850V 75", 65", 60", 55", 49" | No | Yes
VS10 | HDR10
65"- max - 315cd/m2
55"- max - 360cd/m2 | 75"- AS-IPS, 8-bit+Hi-FRC
65"- AS-IPS, 8-bit+Hi-FRC
60"- AS-IPS, 8-bit+Hi-FRC
55"- AS-IPS, 8-bit+Hi-FRC
120/100Hz + BLS
Quantum Dots | 75" -
65" - Edge Led below(W-Led)
60" - Edge Led below(W-Led)
55" - Edge Led below(W-Led)
49" -
Vertical Dimming
55" - 12 zones | 75" -
65" -
60" -
55"- DCI P3 - 85% /Rec.2020 - 62%
49" - | 75" -
65" -
60" -
55"- native - 920:1
ANSI 1188:1,
white-99.8cd/m2
black-0.084cd/m2 | 75" -
65" -
60" -
55" - 35° (cone)
49" - | -
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
M16+F16
Quad Core
Analog (PAL,SECAM)
HEVC | UH850V 75", 65", 60", 55", 49" |
UH780V
UH770V 65", 60", 55", 49" | No | Yes
VS10 | HDR10
max - 287cd/m2 | 65"- AS-IPS, 8-bit+FRC
60"- AS-IPS, 8-bit+FRC
55"- AS-IPS, 8-bit+FRC
49"- AS-IPS, 8-bit
43"- AS-IPS, 8-bit
120/100Hz + BLS
Quantum Dots | 65" - Edge Led below(W-Led)
49" -
Vertical Dimming | 65" -
60" -
55"- DCI P3- 77.6% /Rec.2020-58%
49" - | 65" -
60" -
55"- ANSI 1153:1,
white-101.5cd/m2
black-0.088cd/m2 | 65" -
60" -
55" - 35°(cone)
49" - | 65" -
60" -
55" - 57ms
49" - | Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Compatibility-mouse/keyboard | K2L
Quad Core
Analog (PAL,SECAM)
HEVC | UH770V 65", 60", 55", 49" |
UH750V 65", 55", 49", 43" | No | No | HDR processing (missing hardware for playback HDR) | 65"- AS-IPS, 8-bit+FRC
49"- AS-IPS, 8-bit
43"- AS-IPS, 8-bit
WRGB structure
60/50Hz | 65" - Edge Led (W-Led)
49" -
43" -
Local Dimming | 65" -
55" - DCI P3 - 84%
49" -
43" - | 65" -
55" -
49" -
43" - | 65" -
55" -
49" -
43" - | 65" -
55" -
49" -
43" - | Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
Analog (PAL,SECAM)
HEVC | UH750V 65", 55", 49", 43" |
UH700V 70" | No | No | HDR processing (missing hardware for playback HDR) | 70"- AS-IPS, 8-bit+FRC WRGB structure ??????
120/100Hz - ??? | 70" - Edge Led (W-Led)
Local Dimming | 70"- DCI P3 - 84% | 70" - | 70" - | 70" - | Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
Analog (PAL,SECAM)
HEVC | UH700V 65", 55", 49", 43" |
UH660V 65", 55", 49", 43" | No | No | HDR processing (missing hardware for playback HDR) | 65"- AS-IPS, 8-bit+FRC
49"- AS-IPS, 8-bit+FRC
43"- AS-IPS, 8-bit+FRC WRGB structure
49" - Direct Led (W-Led)
43" - Direct Led (W-Led)
Local Dimming | 65"- DCI P3 - 84%
55"- DCI P3 - 84%
49"- DCI P3 - 84%
43"- | 65" -
55" -
49" -
43" - | 65" -
55" -
49" -
43" - | 65" -
55" -
49" -
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
DLNA | 3 x HDMI2.0 (ARC,CEC)
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
Analog (PAL,SECAM)
HEVC | UH660V 65", 55", 49", 43" |
UH650V 65", 60", 55", 49", 43" | No | No | HDR processing (missing hardware for playback HDR) | 65"- AS-IPS, 8-bit
60"- AS-IPS, 8-bit
55"- AS-IPS, 8-bit
49"- AS-IPS, 8-bit
60" - Edge Led (W-Led)
43" - Direct Led (W-Led) | 65"-
60"-
55"- DCI P3 - 84%
49"- DCI P3 - 84%
43"- | 65" -
60" -
55" -
49" -
43" - | 65" -
60" -
55" -
49" -
43" - | 65" -
60" -
55" -
49" -
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 ac
WiDi / Miracast
DLNA
Bluetooth | 3 x НDМІ2.0 (ARC,CEC,MHL)
Соmроnеnt іn 1 (ѕhаrеd wіth соmроѕіtе)
1 x RЅ232С (Міnі Јасk)
USB 2.0 x 2
1 x Antena (RF)
1 x CI+ 1.3 | -
Quad Core
Analog (PAL,SECAM)
HEVC | UH650V 65", 60", 55", 49", 43" |
UH630V 58", 50", 40" | No | No | HDR processing (missing hardware for playback HDR) | 58"- MVA, 8-bit
50"- MVA, 8-bit
40"- MVA, 8-bit 60/50Hz | 58" - Edge Led (W-Led)
50" - Edge Led (W-Led)
40" - Edge Led (W-Led) | 58" -
50" -
40" - | 58" -
50" -
40" - | 58" -
50" -
40" - | 58" -
50" -
40" - | Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 ac
WiDi / Miracast
DLNA
1 x Соmроnеnt іn(ѕhаrеd wіth соmроѕіtе)
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3 | -
Quad Core
Analog (PAL,SECAM)
HEVC | UH630V 58", 50", 40" |
UH620V 65", 60", 55", 49", 43" | No | No | HDR processing (missing hardware for playback HDR) | 65"- S-IPS, 8-bit
60"- S-IPS, 8-bit
55"- S-IPS, 8-bit
49"- S-IPS, 8-bit
43"- S-IPS, 8-bit WRGB structure 60/50Hz | 60" - Edge Led (W-Led)
43" - Direct Led (W-Led) | 65" -
55" -
49" -
43" - | 65" -
55" -
49" -
43" - | 65" -
55" -
49" -
43" - | 65" -
55" -
49" -
Wi-Fi (only 802.11 n)
WiDi / Miracast
WiFi Direct
DLNA | HDMI x (HDCP2.2)
1- ARC,
1 - Compatible 4K@60p and HDR 422
1 x USB 2.0 | -
Analog (PAL,SECAM)
HEVC | UH620V 65", 60", 55", 49", 43" |
UH610V 65", 55", 49", 43" | No | No | HDR processing (missing hardware for playback HDR) | 65"-
55"-
49"-
43"- S-IPS, 8-bit WRGB structure 60/50Hz | 65" -
49" -
43" - | 65" -
55" -
49" -
43" - | 65" -
55" -
49" -
43" - | 65" -
55" -
49" -
43" - | 65" -
55" -
49" -
Wi-Fi (only 802.11.n)
WiDi / Miracast
DLNA | 3 x НDМІ2.0 (ARC,CEC,MHL)
RЅ232С (Міnі Јасk)
2 x USB 2.0 | -
Analog (PAL,SECAM)
HEVC | UH610V 65", 55", 49", 49", 43" |
UH600V 65", 60", 55", 49", 43" | No | No | No | S-IPS, 8-bit WRGB structure 60/50Hz | 65" - Edge Led (W-Led)
49" - Edge Led (W-Led)
60" -
55" -
49" -
43" - | 65" -
60" -
55" -
49" -
43" - | 65" -
60" -
55" -
49" -
43" - | 65" -
60" -
55" -
49" -
WiDi / Miracast
DLNA
Bluetooth (only 49-65") | 3 x НDМІ2.0 (ARC,CEC,MHL)
1 x Соmроnеnt іn (ѕhаrеd wіth соmроѕіtе)
1 x USB 2.0 | -
WebOS 2.0 | DVB-T/T2/C/S/S2
Analog (PAL,SECAM) HEVC - only in 49-65" | UH600V 65", 60", 55", 49" |
| LG FHD & HDReady TV 2016 - european models |
| Product | UHD
Premium
_____ | Dolby
Vision
__________ | HDR
___________________
Black level
_____ | Networks
Platform
Software
OS
_________ | Tuner
LH660 55", 49", 43" | No | No | No | 55"- IPS, 8-bit, 120/100Hz | 55" - Edge Led (W-Led)
49" -
43" - Direct Led (W-Led) | 55" -
49" -
43" - | 55" -
49" -
43" - | 55" -
49" -
43" - | 55" -
49" -
43" - | Lan
WiDi / Miracast
DLNA | x HDMI 1.4
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3 | -
Analog (PAL,SECAM)
HEVC | LH660 55", 49", 43", |
LH640 55", 49", 43" | No | No | No | 55"- IPS, 8-bit, ? Hz | 55" - Edge Led (W-Led)
49" -
43" - | 55" -
49" -
43" - | 55" -
49" -
43" - | 55" -
49" -
43" - | Lan
WiDi / Miracast
DLNA | x HDMI 1.4
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3 | -
Analog (PAL,SECAM)
HEVC | LH640 55", 49", 43" |
LH600 55", 49", 43", 32" | No | No | No | IPS,
8-bit
32" - Direct Led (W-Led) | 55" -
49" -
43" -
32" - | 55" -
49" -
43" -
32" - | 55" -
49" -
43" -
32" - | -
- | Lan
WiDi / Miracast
DLNA | x HDMI 1.4
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3 | -
Analog (PAL,SECAM)
HEVC | LH600 55", 49", 43", 32" |
LH590 49", 43", 32" | No | No | No | IPS,
8-bit
60/50Hz | | | | | -
- | Lan
WiDi / Miracast
DLNA | x HDMI 1.4
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3 | -
Analog (PAL,SECAM) | LH590 49", 43", 32" |
LH570 49", 43", 32" | No | No | No | IPS,
8-bit
32" - 100Hz ??
60/50Hz | 32" - Direct Led (W-Led) | | | | -
- | Lan
WiDi / Miracast
DLNA | x HDMI 1.4
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3 | WebOS 3.0 | DVB-T/T2/C/S/S2
Analog (PAL,SECAM) | LH570 49", 43", 32" |
| LH560 | No | No | No | IPS,
8-bit
60/50Hz | | | | | - | Lan
WiDi / Miracast
DLNA | x HDMI 1.4
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3 | -
Analog (PAL,SECAM) | LH560 |
LH540
LH541 49", 43", 32" | No | No | No | IPS,
60/50Hz | 55" - Edge Led (W-Led)
43" - Edge Led (W-Led) | | | | - | | x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3 | -
No | DVB-T/T2/C/S/S2
Analog (PAL,SECAM) | LH540 49", 43", 32" |
LH530 | No | No | No | IPS,
8-bit
60/50Hz | 49" - Direct Led (W-Led) | | | | - | | 1 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3 | | | LH530 |
LH510
(LH5100) 49", 43", 32" | No | No | No | IPS,
8-bit
60/50Hz | 49"- Direct Led (W-Led)
43"- Direct Led (W-Led)
32"- Direct Led (W-Led) | | | | - | | 1 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3 | -
No | DVB-T/C
Analog (PAL,SECAM)
(43, 49" + T2/S2) | LH510 |
LH500 43", 32" | No | No | No | IPS,
8-bit
60/50Hz | 43"- Direct Led (W-Led)
1 x Antena (RF)
1 x CI+ 1.3 | -
No | DVB- T2/C | LH500 |
