Страница 32 от 36 ПърваПърва ... 223031323334 ... ПоследноПоследно
Резултати от 466 до 480 от общо 535
Like Tree48Одобрявам
LG телевизори 2016
  1. Senior Member Аватара на cable
    Dec 2010
    #466
    Отговор: LG телевизори 2016
    rodir
    Без съмнение ks7002
    https://www.avforums.com/review/samsung-ks7000-ue55ks7000-uhd-4k-tv-review.12659
    Чети,в заглавието си го пише : If you're looking for great Ultra HD performance at an equally great price then look no further
    Този пост е редактиран от cable; 04-12-16 в 21:35.
    #467
    LG 55 UH950V video review
    source video: [youtube.com - digitalfernsehende]
    Серии - UH61, UH62 - промени в софтуера Changelog
    Release History
    [03.20.05]
    1. To apply Netflix promotion
    2. To imporve 'No signal' problem happening upon HDCP 2.2 certification
    3. To improve HDR performance with 4K Blu-Ray player connection
    4. Extend Universal Control for STB
    5. Support Hikari IPTV TEE
    6. Screen Capture
    7. WOWL quick return to standby
    8. Add JP Customer Center Call Number
    9. To apply MR minor2 feature
    [04.30.02]
    1. Change on Volume UI location
    2. YouTube requirement for certification (When the network is not connected)
    3. Russia Magadan /Sakhalin timezone offset change
    4. FHD BT application (Voice Search/Universal Control)
    [04.30.03]
    1. Change the OTAU SO satellite (Intelsat904 to Kazsat3)
    [04.30.70]
    1. Improve the Sony PS4 Pro no signal issue (HDCP fail)
    2. Improve the Tricolor satellite channel crash. (Russia)
    Серии - UH63, UH65, UH66, UH67, UH75 SW information
    [04.30.40]
    Improvement
    1) Freeview Play Support in UK
    2) Apply the DVB-T2 system in Czech
    3) To Improve auto-reboot problem with "This app will now restart to free up more memory" phrases during watching Live TV in Spain
    4) To Improve automatic channel number changes(over 850 channel) problem during watching Italy Rai channel
    5) Fix Video Skip Issue in 4K HDR Content
    6) Fix MRCU Pairing Failure Issue
    7) Fix RF-DTV Lip Sync Mismatch Issue
    Серия - UH85
    [04.30.65] - Improvement
    5) Fix MRCU Pairing Failure Issue
    Този пост е редактиран от hristoslav2; 09-12-16 в 20:58.
    #468
    Ето какви формати и кодеци възпроизвежда вграденият плейър
    Help - LG Smart TV Document
    List of Supported Codecs and Containers
    The following table specifies all the supported codecs and containers by emulator and real TV in more detail.
    Common
    File
    Extensions
    Media
    Container
    A/V
    Codec
    FourCC
    DTV Target Supported?
    Emulator
    Supported?
    Target
    Description
    Profile/Level Support
    Emulator
    Description
    .asf
    .wmv
    .wma
    ASF
    Video
    VC-1 Advanced Profile
    WVC1
    YES
    YES
    Only streams compliant to SMPTE 421M VC-1 standard are supported. Advanced Profile @ Level 3
    (e.g. 720p60, 1080i60, 1080p30)
    WMVA
    YES
    (ReadDescription)
    YES
    Only streams compliant to SMPTE 421M VC-1 standard are supported. Some WMVA streams were developed before the VC-1 specification was finalized.
    These non-compliant streams are considered deprecated by the industry and are not supported.
    VC-1 Simpleand Main Profiles
    WMV3
    YES
    YES
    Only streams compliant to SMPTE 421M VC-1 standard are supported. Simple Profile @ Medium Level
    (e.g. CIF, QVGA)
    Main Profile @ High Level
    (e.g. 1080p30)
    Other videoCodecs like MPEG-1/2/4
    NO
    NO
    ASF is a MS container format. Anything other than MS Codecs should not be found within an ASF file. Non MS Codecs within ASF are not supported.
    Audio
    WMA Standard
    0x0161
    YES
    YES
    WMA 9 Professional
    0x0162
    YES
    NO
      .wma format notSupported on emulator.
    WMA Lossless
    NO
    NO
    Other audio Codecs likeAC-3, AAC, MP3,
    MPEG Audio Layer I/II
    NO
    NO
    .divx
    .avi
    AVI /DivX Media Format
    Video
    Divx3.11
    DIV3
    DIV4
    YES
    YES
    Please note that a FourCC value of DIV4 is not a DivX 4 stream, but in fact, a DivX 3.11 stream. DivX 4 streams have a FourCC value of DIVX.
    Divx4
    Divx5
    Divx6
    divx
    DIVX
    DIV5
    DIV6
    DX50
    YES
    YES
    MPEG-4 ASP support does not include global motion compensation or quarterpel motion estimation. Streams using this syntax are not supported. Advanced Simple Profile.
    The resolution supported is chip dependent with earlier chips supporting up to SD resolutions (480i) and newer chips supporting up to HD (720p/1080i).
    XViD
    XVID
    YES
    YES
    MPEG-4 ASP support does not include global motion compensation or quarterpel motion estimation. Streams using this syntax are not supported. Advanced SimpleProfile.
    Other video Codecs likeMPEG-1/2
    NO
    NO
    H.264 / AVC
    vssh
    VSSH
    AVC
    avc
    AVC1
    avc1
    h264
    H264
    NOT OFFICIALLY SUPPORTED
    (ReadDescription)
    NO
    AVC within AVI files is not officially supported. It is well known in the industry that there are technical issues which make AVC is ill-suited for AVI encapsulation. This creates problems for compliance and interoperability. That is why it is known and recommended for AVC content to be put into other file containers such MP4 and MKV. There isCode to attempt to handle AVC within AVI files but some streams will work and others will not. Main Profile @ Level 4.1
    High Profile @ Level 4.1
    Audio
    MPEG-1 Layer I, II
    0x0050
    YES
    YES
    MPEG-1 Layer III (MP3)
    0x0055
    YES
    YES
    AC-3
    0x2000
    YES
    YES
    WMA Standard
    0x0161
    YES
    YES
    WMA 9 Professional
    0x0162
    YES
    NO
    Other audio Codecs likeAAC, DTS, PCM
    NO
    NO
    .mkv
    MKV
    Video
    H.264 / AVC
    V_MPEG4/ISO/AVC
    YES
    YES
    Most of the MKV content available is encoded by the open source x264 Codec, the default configuration labels streams as Level 5.0 (e.g. highest level), the video decoder only supports up to Level 4.1 and does it isbest to decode Level 5.0 streams Main Profile @ Level 4.1
    .Mkv format is not supported in emulator.
    Other video Codecs like MPEG-1/2/4
    NO
    NO
    Need sample streams to test
    Audio
    AAC
    A_AAC
    YES
    YES
    AAC-LC and AAC-HE
    AC-3
    A_AC3
    YES
    YES
    A_MPEG/L3
    YES
    YES
    MPEG-1 Layer I, II
    A_MPEG/L1
    A_MPEG/L2
    YES
    YES
    .ts
    .trp
    .tp
    .m2ts
    MPEG-2
    TS(Transport Stream),
    standard 188 byte TS and time-stamped 192 byte TS
    Video
    H.264 / AVC
    YES
    YES
    (e.g. 720p60, 1080i60,1080p30)
    .ts,.trp,.tp
    and .m2ts formats are not supported on emulator.
    MPEG-2
    YES
    YES
    (e.g. 720p60, 1080i60)
    VC-1
    YES
    NO
    Only streams compliant to SMPTE 421M VC-1 standard are supported. Encapsulation must abide by SMPTE RP227 specification. Simple Profile @ Medium Level
    (e.g. CIF, QVGA)
    (e.g. 1080p30)
    Audio
    MPEG-1 Layer I, II
    YES
    YES
    YES
    YES
    AC-3
    YES
    NO
    DDP (Enhanced AC-3)
    YES
    NO
    AAC
    YES
    YES
    AAC-LC and AAC-HE
    .vob
    MPEG-2
    PS(Program Stream),
    VOB,
    SVCD
    Video
    MPEG-1
    YES
    NO
      .vob is not supported in emulator.
    MPEG-2
    YES
    YES
    Audio
    AC-3
    YES
    NO
    MPEG-1 Layer I, II
    YES
    YES
    DVD-LPCM
    YES
    NO
    .mpg
    .dat
    MPEG-1 Systems,
    VCD
    Video
    MPEG-1
    YES
    YES
      .mpg, .datare not supported in emulator.
    Audio
    MPEG-1 Layer I, II
    YES
    YES
    .mpg
    .mpe
    .mpeg
    Unknown
    Note that these file extensions do not uniquely specify whether the contents are TS, PS or ES. These files are supported only if the decoder is configured properly for TS, PS or ES. The decoder needs to know this information and will not determine it on its own. See other rows for support information.
    .mp4
    .m4a
    .m4v
    MP4
    Video
    H.264 / AVC
    avc1
    YES
    YES
    MPEG-4 Part 2
    mp4v
    YES
    YES
    Motion compensation describes a picture in terms of the transformation of a reference picture to the current picture. The reference picture may be previous in time or even from the future. When images can be accurately synthesized from previously transmitted/stored images, the compression efficiency can be improved.
    Quarter Pixel Motion Search Precision (QPEL): Basically most MPEG-4 Codecs by default detect motion between two frames down to half a pixel (HalfPel). Now with QuarterPel you can detect motion that is only a quarter of a pixel per frame, effectively doubling precision!
    practically this means that you will get
    a much sharper image with QPEL.
    Global Motion Compensation (GMC):
    GMC detects if there is an amount of motion big parts of the frame have in common. If that’s the case GMC kicks in, using a single motion vector for all similar parts of the frame instead of multiple ones. Practically this helps saving bits when panning, zoom or rotation occurs (depending on how good the GMC implementation is/offered warp points), bits which than can be used somewhere else, for example where they bring more sharpness.
    H.263
    s263
    YES
    NO
    Profile 0, Level 70. No Annex supported
    Other video Codecs likeMPEG-1/2, VC-1
    NO
    NO
    No standard specifying header.
    No sample files.
    Audio
    AAC
    mp4a
    YES
    YES
    AAC-LC and AAC-HE
    Other audio Codecs like AC3, DTS, MP3
    NO
    NO
    No sample files.
    .mov
    QT
    Audio/Video
    NO
    NO
    Most QuickTime streams appear to be MPEG-4 Part 12. Please see MP4 section of list supported audio/video Codecs.   .mov format is not supported in emulator.
    .f4v
    .f4a
    .flv
    Flash formats
    Audio/Video
    YES
    YES
    Please see MP4 section of list supported audio/video Codecs Support limited to LPCM   Flash engine supports flash playback such asas .f4v, .f4a and .flv.
    These formats are not supported using open API. (e.g., playClipFile)
    .wav
    WAV
    Audio
    LPCM
    0x0001
    NO
    NO
    .wav format is not supported in emulator.
    .mp3
    MP3
    Audio
    MPEG-1 Layer III
    YES
    YES
    Този пост е редактиран от hristoslav2; 09-12-16 в 20:59.
    Dec 2003
    #469
    Някой може ли да ми каже как функционира MULTIVIEW режима на LG UHD 6-та серия ? От колко източника може да се гледа ? Как се дели екрана и други подробности ? Предварително благодаря .
    May 2015
    #470
    Телевизора е LG-UF8507 според вас за гледане вечер кой режим е по-подходящ експерт 1, експерт 2 или кино?
    #471
    Цитат Първоначално публикувано от mig31 Виж публикацията
    LG ​[V10] How to use multi-view recording? | LG Sri Lanka
    index
    Welcome to webOS TV | Ръководство на потребителя
    Цитат Първоначално публикувано от artttty Виж публикацията
    Кино!
    Режимите ISF Експерт 1 или ISF Експерт 2 са идентични един с друг, така че няма значение, кой си избрал, за да гледаш. Тяхното присъствие свидетелства за факта, че телевизорът е сертифициран от организацията ISF. Напомням, че това ти дава:
    ISF сертификацията гарантира, че телевизорът има две банки за памет, които може да бъдат променени за всеки конектор, и след това да го заключиш срещу случайни промени. След професионално калибриране от експерт и последвало заключване на тези режими, телевизора им дава нови имена - ISF ден и ISF нощ.
    При въвеждане на ISF-Expert също предлагам следните промени в основната картина:
    Aspect Ratio -> Scan, така изображението е с правилният размера на екрана, без да се отрязват краищата
    Опции за изображението -> Noise Reduction -> Off, така изображението не се размива в местата, където телевизорът автоматично определил и открил шум
    Опции за изображението -> MPEG Noise Reduction -> Off, така изображението не се размива в местата, където телевизорът автоматично е открил шум
    Този пост е редактиран от hristoslav2; 11-12-16 в 12:03.
    May 2015
    #472
    Кино!
    В режим кино подсветката е на 100% на колко долу горе е добре да се сложи?
    #473
    Нещо не ми се връзва...да е на 100%
    Там не пипаш нищо- просто превключваш на режима и гледаш. При някои марки има даже два такива режима Cinema и True Cinema.
    May 2015
    #474
    Подсветка100%
    Контраст 80%
    Цвят 50%
    Рязкост 10%
    Нюанс 0
    Дълги години бях плазма и от година съм с LED така и не мога да го наглася
    Jan 2015
    #475
    Подсветка100%
    Контраст 80%
    Цвят 50%
    Рязкост 10%
    Нюанс 0
    пробваи тези
    https://www.youtube.com/watch?v=Lt1J0kEJs0U
    #476
    На българския сайт на LG има нова версия на FW за LG 42LF652V - 4.05.45.
    Интересното е, че няма Change log, А и самия телевизор казва, че няма намерен update или поне за БГ.
    Предишната версия 4.05.30 беше за Казахстан - някаква промяна на въведените спътници. Телевизорът и нея не отрази.
  15. Novice Аватара на Joro Zefirov
    Sep 2016
    #477
    Колега Аз съм точно с този модел LG 42LF652V,тв ми показа съобщение че има нова версия,пуснах и ъпдейтнах до 4.05.45 без проблем,само не знам какво има в тази актуализация,някой ако намери инфо да пише.
    Feb 2015
    #478
    43LH6047 е с IPS панел, успях да направя снимка
    #479
    Цитат Първоначално публикувано от mitaknika Виж публикацията
    Поздравлениямного добра снимка.
    Този пост е редактиран от hristoslav2; 14-12-16 в 18:45.
    May 2015
    #480
    Ако външния ми хард диск е включен в тв-то мога ли по мрежа с компютъра да му качвам филми, да не се налага да го разкачам всеки път.
  1. Левски - Завръщане | А ПФГ 2015 / 2016
    От kod във форум Спорт
    Последно: 13-11-17, 18:52
  2. Избор на климатик 2016 г.
    Отговори: 3492
    Последно: 01-01-17, 18:50
  3. Квалификации Евро 2016
    От iihtiandar във форум Спорт
    Последно: 10-06-16, 09:03
  4. Телевизори DSM, NEO?
    Последно: 19-01-16, 23:27
  5. телевизори
    Последно: 31-08-12, 07:46
