А някой да знае как да подкарам външен HDD през USB на G20? Казва ми, че иска да го форматира, за да прави записи на него, които нямало да могат да се четат от друг тв? С флаш-памет няма проблем.
Външният хард трябва да е форматиран в FAT32
два минуса
- aspect ratio не работи пълноцено (понякога може да изберете само 16:9 - 4:3 или 4:3 - 4:3full)
- всички подкаталози са изнесени на 1-о ниво - получава се мешаница.
А защо чете флашката,която е под NTFS?
Грешка, FAT32 e. Мамка му как се обърках.
Ето в тази тема колегите от Германия обсъждат панелите
http://www.hifi-forum.de/index.php?a...49&thread=8313
Превод
http://translate.google.com/translat...6thread%3D8313
промяната в нивото на черното
http://s5b.directupload.net/file/d/2...ymqj72_png.htm
http://img37.imageshack.us/img37/757...klevelsver.jpg
I have been corresponding with a friend who has knowledge of the situation: he gave me permission to post some of our discussions noting he is not a spokesman for Panasonic or any company, and these are not official statements: so take it for what it is worth:
What I can confirm is that it [black level changing issue] is not being ignored by upper management on both sides of the Pacific, but there will not be any further word until the next actions, if any, are confirmed, checked, and approved by all sales markets worldwide.
Seems this is an issue in Europe as well.
Of note is the standard practice of P (and other vendors) to take MLL readings in "black caves" with the front glass removed, 30 minute warm-up with no signal, and laptops located in adjacent rooms so there will be no ambient light contamination from the computer screen.
I doubt members can meet these conditions or measure accurately with the economy light meters they are using.
The point is that black levels are still very low, lower than most of the competition, even after the pre-programmed MLL increases.
The BL thread is trying to conclude that there is more of a problem with smaller (42, 50) models than with 58 or 65 models.
1.) You sit further away from larger sizes.
2.) They are usually in larger rooms with more ambient light leaks.
There may be quotes citing lower P sales this week, which is true but it is not due to BL concerns.
New models are due out soon and sales normally fall slightly as potential buyers wait for new models.
The competition did a lot of severe price-cutting around Super-Bowl through Olympics time but that only leads to short term gains for them. P has been #1 in Plasma sales 42 and up for 80 of the last 82 weeks.
The Pro side is booming with more than 50% of sales at 65 inches +. The new 85 inch is backordered until NAB in April. The 152 inch has been starring behind Bob Costas every night of the last 11 days.
Most Pro sales are not in black caves which is why there are almost no reported BL problems. The Pro firmware is different, but I'm not sure how. The Home Theater VX series uses a custom PDP and internal scaler which I believe function differently as well.
What I do know is that phone campaigns to clog up the call center do nothing, letters and e-mails to company presidents will do nothing because they are in the same boat wondering what the Factory is going to do if anything.
Our marketing studies show that others' defect ratios are nearly double what P has, typically 5% vs. 2% or less. Pro models are just a few tenths of a percent helped by the higer technical levels of the end-users, more concern for mounting and environmental conditions, etc.
end
Здравейте.
Става въпрос за плазма s10 42''. Може ли от сервизното меню да се намали прага на чувствителност към силата на сигнала. Имам впредвид следното:
Ползвам цифрова тв от близуу с КА модул, обаче сигнала явно е слаб при мен и от време на време прекъсва картината и изписва "няма сигнал". Проблема е че докато изпише няма сигнал и после да се възстаови картината минават 2-3-4 сек, а с техен бокс само за секунда замръзва картината. Имам ли някакви варианти? Разбира се работя и по варианта за подобряване на сигнала - ще сменям единият от вградените в сградата кабели с нов защото уж там намалявал сигнала.
Не-няма такава възможност. Проблема е в инсталацията у дома ти. Провери и ако трябва подмени кабела и сплитерите.Цитат:
Първоначално публикувано от jovko
https://forum.setcombg.com/index.php...html#msg366059
С цел да допълним поста във FAQ и да сме полезни на всички, които са пробвали и ползват вграденият USB плейър в телевизорите. Моля напишете подробно:
- модел телевизор
- използван носител-модел/флашка, хард диск/
- възпроизвеждани формати /по-подробно/
- субтитри /проблеми и тяхното решаване/
Забелязани от вас особенности-ограничения и проблеми с възпроизвеждането.
Днес идваха момчетата от близуу и подмениха вътрешната инсталация, оказа се че проблема остана. Сега получавам 60дб сигнал на телевизора включих сеттоп-а и там нямах никакви проблеми никакво прекъсване сега остава драмата може ли да е от КА модула проблемът с прекъсването на сигнала. Сила на сигнала си стой 100% а качеството на сигнала пада за секунда до 0.
Ако искаш пробвай и с друг кам модул. Кабелните техници на Близуу дадоха ли ти някакво обяснение ,защо качеството на сигнала им на моменти пада до 0 ? Това означава ,че проблема не е в телевизора ти ,а е при тях. Коментирали сме ,защо с приемниците на кабелните оператори няма проблеми-защото те им пишат софтуера и си го напасват към апаратурата с която предават сигнала в централният си офис. Повечето от операторите не спазват точно стандартите.
Ами и те се изненадаха и ми казаха да пробвам и с тяхнното устройство. Но казаха че ще търсят проблема. ще се чуя с тях след няколко дена. Със същата карта и ка модул но на друг адрес в града нямах никакви проблеми. Мога ли да върна Ка модула В БЛИЗУ да ми го сменят с нов. на 11 месеца е модула
Качеството с сеттоп-а е по-лошо! проверено :)
Продължавай да ги тормозиш и да отстояваш правата си. Не спирай да ги викаш ,докато не оправят проблема със сигнала. За връщането на модема -попитай в офиса им. Щом работи без проблем на друг телевизор-значи си е наред.
Това последното ,за качеството на сет-топ -боксовете ,всички сме го научили от личен опит. :)
Тв и Ка модул са същите но адреса е другЦитат:
Проблема със сигурност е в тях или по точно в мрежата .Имал съм същия проблем многократно точно На Близу-уууууу . Накрая се оказа корозирала връзка на един от сплитерите отвън на фасадата , разбира се сам го установих и оправих, защото те така и не дойдоха никога. Ако САМодула е повреден няма да отваря нищо -черен екран само с информацията. Така че не не си губи времето с него , ами ги наритвай, защото такива михлюзи няма никъде.Цитат:
Това означава ,че проблема е в кабелната мрежа на Близуу. Някъде по трасето от централният им офис.....до твоят адрес.Цитат:
Panasonic Viera TX-P42VT20E Review
http://www.fullhd.gr/2008-03-14-21-3...0e-review.html
Има ли PANASONIC TX-P50X20E вентилатори?
Въобще има ли PANASONIC плазми 50" без вентилатори?
Вентилаторите почват от v20.
