Series & Model  ___________________ |  UHD Premium  _____ |  ISF ccc ________  ISFccc -
Certified
Calibration
Configuration |  THX ________  Accurate Color
Reproduction
Sharper Pictures
THX Cinema & THX 4K Cinema modes |  Automation System  IP Home Control __________ |  HDR 10  ST2084
(EOTF PQ),
ST2086
(static metadata)
ST2094
(dynamic metadata)  ________    |  Hybrid
Log Gamma
(HLG) _____ |  Dolby Vision
VS10 ____ |  Advanced HDR Technicolor  _______  |  SoC / GPU / RAM   _________________________  Plattform,
Central Processing Unit,
System on Chip,
Instruction set,
Graphic Processor Unit,
RAM,
Total memory  |  Software  ____________  Operating System,
Firmware version,
Apps program languages,  |  Videopanel  _________________________Size class,
Type LCD/Oled matrix,
Resolution,
Pixel structure,
Bits of color,
Quantum dots,
Frequency of T-Con board,
Curvature,
Screen Uniformity,
Anti-reflective filter  |  Backlight Unit ______________Type backlight,
Local Dimming zone,
Type LED,
MEMC,
Backlight Scanning,
Black Frame Insertion,
Pulsе Wide Modulation  |  Opportunities for calibration _____________________  ISF ccc,
3D LUT,
-Color Menagment System,
Technicolor Expert Mode,
White balance,
Gamma,  |  Internal Processing _____________________________Scaling,
Interpolation,
Overscaninng,
Digital Noise reduction,
Deinterlacing (Video mode, Film mode),
-,  |  Color _______________________________DCI P3 coverage (xy / uv),
Rec.2020 coverage (xy / uv),
White balance dE,
Color Delta E,
Gamma,
Color Temperature,  |  Brightness _______________________________Peak in HDR
Peak in SDR,
Average Picture Level,
Automatic Brightness Limiter,        |  Contrast ______________ANSI Contrast,
With local dimming,
Without local dimming,
Static contrast,
Dinamic contrast,
White level,
Black level  |  Viewing angle  _____________ Horizontal & Vertical
(°cone)  |  Motion resolution ______________ |  Input Lag ______________ |  Audio _____________________________  Total power,
speakers,
Surround,
Sound mode,  |  Built in Media Player  Supported file systems
Image file formats
Audio file formats/codecs
Video file formats
Subtitles _______________________________________________ |  Connectivity __________________ |  Supported Resolutions __________________________Resolution / Frame per seconds
24, 25, 30, 50, 60, 100, 120fps
Progresive / Interleased
Chroma subsampling
4:4:4
4:2:2
4:2:0  |  Conectors __________________________________ |  Tuners ___________________  HD tuner,
Teletext reception,
Multi window,
Timeshift,
PVR,  |  Note _____________________________________Pros & Cons  |  Series & Model
 EZ1000 (Oled)
TX-65EZ1000E
TX-65EZW1004 (in DACH)
TX-65EZ1002B (in UK)
no 3D
no HFR (High Frame Rate)   available in Europe from end of May 2017 |  Yes |  Yes  |  Yes - ensuring that you experience the filmmaker's vision exactly as it was intended.   THX Cinema   THX Bright room   THX 4K Cinema |  Crestron / Control4 |  Yes - in TV, Internet video services, HDMI, USB port. |  Yes - in terrestrial and satellite TV,
 Internet video services, HDMI, USB port. |  No |  No |  Plattform:
SoC: MediaTek MT5597
Core Architecture: 4 cores
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
Internal storage total space:
Internal storage free space:   E   |  OS: Firefox 2.5   -   HTML5 v.2.0 SDK     |  64.5" - AM-OLED(Triple Stacked), 3840x2160, WRGB,
10-bit, No, 120/100Hz, Flat
Model: LC650LQD (LG Display)   54.6" - AM-OLED(Triple Stacked), 3840x2160, WRGB,
Model: LC550LQD (LG Display)   No vignetting;
PWM - No
BFI - No |  No backlight     |  ISF Professional
(expert mode - Day & Night)
Compatibility with Portrait Display's CalMAN calibration software.
Direct Display Control mode to allow to adjust settings directly from the Calman software (professional edition) by connecting screen to a PC via Ethernet.   3D LUT (look-up tables)
- 8000 points
For instance, the EZ1002 allows professional users to upload their own colour 3D LUTs by SD/USB memory, if required.   CMS - RGBCYM    No   White balance - 2/20 points   Gamma   gray scale of 10 points
Rec.2020
Rec.709   |  Very Good for HD,
-,   |  65" - DCI/P3 - 97% / 98%
65" - BT.2020 - 73% / 76%
65" -
65" -
65" - 2.2
65" -   55" - DCI/P3 - 98% / 99%
55" - BT.2020 - 73% / 76%
55" -
55" -
55" - 2.2
55" -
  |  65" - max 800cd/m2 in HDR
65" - max 430cd/m2 in SDR   55" - max 800cd/m2 in HDR
55" - max 430cd/m2 in SDR   APL -   ABL - full-field peak white came in at:
5% - 900cd/m2 (Vivid mode) - in HDR
10% - 700cd/m2 (Vivid mode) - in HDR   |  65" -
65" - x
65" - Inf.:1
65" -
65" -
65" - cd/m2
65" - 0cd/m2   55" -
55" - x
55" - Inf.:1
55" -
55" -
55" -
55" - 0cd/m2 |  65" - 65°(h)/ °(v)   55" - 65°(h)/ °(v)   Color shift - 26°
Brightness - 69°
Black Level - 75°
  |  77" -  horizontal lines 65" -  horizontal lines
  |  65"- HDR - ms
65"- Game mode -
65"- by default   55"- HDR - ms
55"- Game mode -
55"- by dafault
  |  80W (RMS)
Dynamic Blade Speaker:
Tweeter x 2, Squaker x 4, Woofer x 8,
Quad Passive Radiator   Reference Surround Sound Pro
VR-Audio True Surround+   Dolby Digital Plus ?
Dolby Puls,
No - DTS Standard/Music/Ambience/User |  FAT16, FAT 32, NTFS and exFAT   Image file formats  JPEG 4K, GIF, PNG, MPO, JPG, Audio file formats/codecs  AAC (Advanced Audio Coding)
FLAC (Free Lossless Audio Codec, .flac)
MP3 (MPEG-2 Audio Layer II, .mp3)
WMA Pro (Windows Media Audio, .wma)
WAV (Waveform Audio File Format, .wav, .wave)
Apple Lossless Video file formats
AVCHD/Progressive,
3GPP (3rd Generation Pertnership Project, .3gp)
AVI (Audio Video Interleaved, .avi)
DivX (.avi, divx,, .mkv)
H.263
H.264 / MPEG-4 Part 10 / AVC Video
H.265 / MPEG-H Part 2 / HEVC
MKV (Matroska Multimedia Container, .mkv, .mk3d, .mka, .mks)
Quik Time (.mov,. qt)
WMV (Windows Media Video, .wmv)
MP4 (MPEG-4 Part 14, .mp4, .m4a,. m4p, .m4b, .m4r, .m4v)
MPEG-4
TS (MPEG Transport Stream, .ts, .tsv, .tsa)
FLV
VRO (DVD-VR, .VRO)
VOB (Video Object, .vob)
PS
VP9, profile ?
To playback HDR, a HDR source is required (H.264 or H.265(ST2084 or HLG format)   Subtitles
Micro DVD, SRT, SUB, SubRip, TMPlayer, TXT   Obviously not playing DTS-HD tracks or TrueHD or ISO or Blu-ray folders (BDMV) and like all televisions, 24p videos are played in 60 im / s, but converting the framerate is well managed, with smooth playback without jerkiness and a picture of beauty. The reading is also interesting audio files with management Flac, WAV and ALAC, the ability to display album art or tags, but no native playback of files called "HiRes" all files in 88.2, 96, 176.4 or 192 kHz are downmixes in 48 kHz / 24 bits. |  Lan (100BASE-TX/10BASE-T)
Wi-Fi,
802.11 a,
802.11 b,
802.11 g,
802.11 n,
802.11 n 5GHz,
802.11 ac,
Wi-Fi Direct,
DLNA 3.0,(DTCP-IP/DMP/DMR/DMS)
Bluetooth (HID)
 (NFC) Ver.4.1(Keyboard/Mouse)    Miracast,      |  4096x2160 - 60p (displayed as 3840x2160)
4096x2160 - 50p (displayed as 3840x2160)
4096x2160 - 30p (displayed as 3840x2160)
4096x2160 - 25p/4:4:4 (10, 12 bit) (displayed as 3840x2160)
4096x2160 - 24p/4:4:4 (10, 12 bit) (displayed as 3840x2160)   3840x2160 - 120-  No
3840x2160 - 60p /4:4:4, 8bit
3840x2160 -  60p/4:2:2 (8,10,12-bit)
3840x2160 -  60p/4:2:0 (8,10-bit)
3840x2160 - 50p
3840x2160 - 30p
3840x2160 - 25p /4:4:4 (10, 12 bit)
3840x2160 - 24p /4:4:4 (10, 12 bit)   1920 x 1080 / 120Hz - ?
1920 x 1080 / 60p (HDMI 1/2 / Component)
1920 x 1080 / 50p (HDMI / Component)
1920 x 1080 / 30p (Only HDMI 3/4)
1920 x 1080 / 24p (Only HDMI)   1920 x 1080 / 60i
1920 x 1080 / 50i
1366 x 720 / 24p (Only HDMI)-Up to 18Gbps   HDR included in HDMI ?? |  2 x USB 2.0 (DC 5V MAX 500mA)
1 x USB 3.0 (DC 5V MAX 900mA)
1 x Ethernet RJ45
4 x HDMI 2.0b - (ARC(input 2), CEC, MHL 3.0)
with HDCP (High-bandtwidth Digital Content protection) 2.2
1 x AV Composite in 3.5mm jack
1 x Video Component In 3.5mm jack
1 x Optical Audio Out (AAC/PCM/AC3)- 18 dBm, 660 nm
1 x Hedphone output (16-32Ω recommended)
1 x SD Memory Card Slot (SDXC memory card compatible)
1 x Antena (RF) (female)
2 x CI + (ver. 1.3)
1 x Satelite In (Main; F-type female)
1 x Satelite In (Sub: F-type female)
BS·110 degree CS-IF input terminal (75 Ω) and satellite antenna power supply (DC 15 V) output   Compatible Rec.2020 input |  Double tuners
2 x DVB-T/T2/C/S/S2
(DiSEqC version 1.0)
Analog (NTSC, PAL, SECAM)
1 x TV IP Server & Client   Yes - 2000 Pages (TOP & List)   2T
PAP (Picture and picture)
PIP (Picture in picture)
 PAT (Picture and text)   Timeshift & PVR
(USB-HDD Recording)   MPEG2, MPEG4, HEVC H.265, VP9 ver.2 |   |  EZ1000 (Oled)
TX-65EZ1000E
TX-65EZ1004 (in DACH)
no 3D
no HFR (High Frame Rate) |
