| Panasonic TV 2017 - european models / Panasonic TV 2017 - european models / Panasonic TV 2017 - european models |
| Series | Certificates | HDR | Hardware & Software | Calibration | Picture Quality | Other | Series |
Series & Model ________________ | UHD Premium _____ | ISF ccc ________ ISFccc -
Certified
Calibration
Configuration | THX ________ Accurate Color
Reproduction
Sharper Pictures
THX Cinema & THX 4K Cinema modes | Automation System IP Home Control __________ | HDR 10 ST2084
(EOTF PQ),
ST2086
(static metadata)
ST2094
(dynamic metadata) ________ | Hybrid
Log Gamma
(HLG) _____ | Dolby Vision
VS10 ____ | Advanced HDR Technicolor _______ | SoC / GPU / RAM ____________________ Plattform,
Central Processing Unit,
System on Chip,
Instruction set,
Graphic Processor Unit,
RAM,
Total memory | Software ____________ Operating System,
Firmware version,
Apps program languages, | Videopanel ____________________Size class,
Type LCD/Oled matrix,
Resolution,
Pixel structure,
Bits of color,
Quantum dots,
Frequency of T-Con board,
Curvature,
Screen Uniformity,
Anti-reflective filter | Backlight Unit ______________Type backlight,
Local Dimming zone,
Type LED,
MEMC,
Backlight Scanning,
Black Frame Insertion,
Pulsе Wide Modulation | Opportunities for calibration _____________________ ISF ccc,
3D LUT,
-Color Menagment System,
Technicolor Expert Mode,
White balance,
Gamma, | Internal Processing _______________________Motion Processing Settings,
Scaling,
Interpolation,
Overscaninng,
Digital Noise reduction,
Deinterlacing (Video mode, Film mode),
-, | Color _________________DCI P3 coverage (xy / uv),
Rec.2020 coverage (xy / uv),
White balance dE,
Color Delta E,
Gamma,
Color Temperature, | Brightness _______________________Peak in HDR
Peak in SDR,
Average Picture Level,
Automatic Brightness Limiter, | Contrast ______________ANSI Contrast,
With local dimming,
Without local dimming,
Static contrast,
Dinamic contrast,
White level,
Black level | Viewing angle _____________ Horizontal & Vertical
(°cone) | Motion resolution ______________ | Input Lag ______________ | Audio _____________________________ Total power,
speakers,
Surround,
Sound mode, | Built in Media Player Supported file systems
Image file formats
Audio file formats/codecs
Video file formats
Subtitles _______________________________________________ | Connectivity __________________ | Supported Resolutions __________________________Resolution / Frame per seconds
24, 25, 30, 50, 60, 100, 120fps
Progresive / Interleased
Chroma subsampling
4:4:4
4:2:2
4:2:0 | Conectors __________________________________ | Tuners ______________________________ Tuners,
Teletext reception,
Multi window,
Timeshift,
PVR, | Note _________________________________Pros & Cons | Series & Model
EZ1000 (Oled) TX-77EZ1000E
TX-65EZ1000E (Continental Europe)
EZW1004 (for Germany, Niderland)
EZC1004 (for Switzerland)
EZ1002B (for United Kingdom)
EZR1000 - ? (for Russia)
no 3D
no HFR (High Frame Rate) available in Europe from June 2017 | Yes | Yes | Yes - ensuring that you experience the filmmaker's vision exactly as it was intended. THX Cinema THX Bright room THX 4K Cinema | Crestron / Control4 | Yes - in TV, Internet video services, HDMI, USB port. | Yes - in terrestrial and satellite TV,
Internet video services, HDMI, USB port. | No | No | Plattform:
SoC: MediaTek MT5597
Core Architecture: 4 cores
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
Internal storage total space:
Internal storage free space: E | OS: Firefox 2.5 - HTML5 v.2.0 SDK | 76,5" - AM-OLED(Triple Stacked), 3840x2160, WRGB, 10-bit, No, 120/100Hz, Flat 64.5" - AM-OLED(Triple Stacked), 3840x2160, WRGB,
10-bit, No, 120/100Hz, Flat Model: LC650LQD (LG Display) No vignetting;
PWM - No
BFI - No | No backlight,
Yes - IFC,
-, | ISF Professional
(expert mode - Day & Night)
Compatibility with Portrait Display's CalMAN calibration software.
Direct Display Control mode to allow to adjust settings directly from the Calman software (professional edition) by connecting screen to a PC via Ethernet. 3D LUT (look-up tables)
- 8000 points
For instance, the EZ1002 allows professional users to upload their own colour 3D LUTs by SD/USB memory, if required. CMS - RGBCYM No White balance - 2/20 points Gamma gray scale of 10 points
Rec.2020
Rec.709 | Anti-Blur: ?
Anti-Judder: ?
Led motion: No Very Good for HD, -, -, -, -, | 77" - DCI/P3 - 97% / 98%
77" - BT.2020 - 73% / 76%
77" -
77" -
77" - 2.2
77" - 65" - DCI/P3 - 97% / 98%
65" - BT.2020 - 73% / 76%
65" -
65" -
65" - 2.2
65" -
| 65" - max 800cd/m2 in HDR
65" - max 430cd/m2 in SDR APL - ABL - full-field peak white came in at:
5% - 900cd/m2 (Vivid mode) - in HDR
10% - 700cd/m2 (Vivid mode) - in HDR | 77" -
77" - x
77" - Inf.:1
77" -
77" -
77" -
77" - 0cd/m2 65" -
65" - x
65" - Inf.:1
65" -
65" -
65" - cd/m2
65" - 0cd/m2
| 77" -
65" - 65°(h)/ °(v) Color shift - 26°
Brightness - 69°
Black Level - 75°
| 77" - ? horizontal lines
65" - ? horizontal lines
| 77" - in HDR
77" - in Game mode
77" - by default 65"- HDR - ms
65"- Game mode
65"- by default
| 80W (RMS)
Dynamic Blade Speaker:
Tweeter x 2, Squaker x 4, Woofer x 8,
Quad Passive Radiator Reference Surround Sound Pro
VR-Audio True Surround+ Dolby Digital Plus ?
Dolby Puls,
No - DTS Standard/Music/Ambience/User | FAT16, FAT 32, NTFS and exFAT Image file formats JPEG 4K, GIF, PNG, MPO, JPG, Audio file formats/codecs AAC (Advanced Audio Coding)
FLAC (Free Lossless Audio Codec, .flac)
MP3 (MPEG-2 Audio Layer II, .mp3)
WMA Pro (Windows Media Audio, .wma)
WAV (Waveform Audio File Format, .wav, .wave)
Apple Lossless Video file formats
AVCHD/Progressive,
3GPP (3rd Generation Pertnership Project, .3gp)
AVI (Audio Video Interleaved, .avi)
DivX (.avi, divx,, .mkv)
H.263
H.264 / MPEG-4 Part 10 / AVC Video
H.265 / MPEG-H Part 2 / HEVC
MKV (Matroska Multimedia Container, .mkv, .mk3d, .mka, .mks)
Quik Time (.mov,. qt)
WMV (Windows Media Video, .wmv)
MP4 (MPEG-4 Part 14, .mp4, .m4a,. m4p, .m4b, .m4r, .m4v)
MPEG-4
TS (MPEG Transport Stream, .ts, .tsv, .tsa)
FLV
VRO (DVD-VR, .VRO)
VOB (Video Object, .vob)
PS
VP9, profile ?
To playback HDR, a HDR source is required (H.264 or H.265(ST2084 or HLG format) Subtitles
Micro DVD, SRT, SUB, SubRip, TMPlayer, TXT Obviously not playing DTS-HD tracks or TrueHD or ISO or Blu-ray folders (BDMV) and like all televisions, 24p videos are played in 60 im / s, but converting the framerate is well managed, with smooth playback without jerkiness and a picture of beauty. The reading is also interesting audio files with management Flac, WAV and ALAC, the ability to display album art or tags, but no native playback of files called "HiRes" all files in 88.2, 96, 176.4 or 192 kHz are downmixes in 48 kHz / 24 bits. | Lan (100BASE-TX/10BASE-T)
Wi-Fi,
802.11 a,
802.11 b,
802.11 g,
802.11 n,
802.11 n 5GHz,
802.11 ac,
Wi-Fi Direct,
DLNA 3.0,(DTCP-IP/DMP/DMR/DMS)
Bluetooth(NFC) Ver.4.1 HID/HOGP/3DSP/SPP(for keyboard and mouse, no Bluetooth audio) Miracast, | 4096x2160 - 60p (displayed as 3840x2160)
4096x2160 - 50p (displayed as 3840x2160)
4096x2160 - 30p (displayed as 3840x2160)
4096x2160 - 25p/4:4:4 (10, 12 bit) (displayed as 3840x2160)
4096x2160 - 24p/4:4:4 (10, 12 bit) (displayed as 3840x2160) 3840x2160 - 120- No
3840x2160 - 60p /4:4:4, 8bit
3840x2160 - 60p/4:2:2 (8,10,12-bit)
3840x2160 - 60p/4:2:0 (8,10-bit)
3840x2160 - 50p
3840x2160 - 30p
3840x2160 - 25p /4:4:4 (10, 12 bit)
3840x2160 - 24p /4:4:4 (10, 12 bit) 1920 x 1080 / 120Hz - ?
1920 x 1080 / 60p (HDMI 1/2 / Component)
1920 x 1080 / 50p (HDMI / Component)
1920 x 1080 / 30p (Only HDMI 3/4)
1920 x 1080 / 24p (Only HDMI) 1920 x 1080 / 60i
1920 x 1080 / 50i
1366 x 720 / 24p (Only HDMI)-Up to 18Gbps HDR included in HDMI ?? | 2 x USB 2.0 (DC 5V MAX 500mA)
1 x USB 3.0 (DC 5V MAX 900mA)
1 x Ethernet RJ45
4 x HDMI 2.0a - (ARC(input 2), CEC, MHL 3.0)
with HDCP (High-bandtwidth Digital Content protection) 2.2
1 x AV Composite in 3.5mm jack
1 x Video Component In 3.5mm jack
1 x Optical Audio Out (AAC/PCM/AC3)- 18 dBm, 660 nm
1 x Hedphone output (16-32Ω recommended)
1 x SD Memory Card Slot (SDXC memory card compatible)
1 x Antena (RF) (female)
2 x CI + (ver. 1.3)
1 x Satelite In (Main; F-type female)
1 x Satelite In (Sub: F-type female)
BS·110 degree CS-IF input terminal (75 Ω) and satellite antenna power supply (DC 15 V) output Compatible Rec.2020 input | Analog (NTSC, PAL, SECAM)
B/G,D/K,I (45,25MHz–863,25MHz) 2x DVB-T/T2 (H.264) -T2 HD (H.265) (VHF/UHF) 2x DVB-S/S2 (950-2150MHz) (DiSEqC version 1.0) 2x DVB-C (VHF/UHF) 1x TV>IP Server & Client Teletext - 2000 Pages (TOP & List) 2T
PAP (Picture and picture)
PIP (Picture in picture)
PAT (Picture and text) Timeshift & PVR
(USB-HDD Recording) MPEG2,
MPEG4,
HEVC H.265 (to 3840x2160/60p, 10bit)
VP9 ProFile.2 | | EZ1000 (Oled) TX-77EZ1000E
EZW1004 (for Germany)
no 3D
EZ950 (Oled)
TX-77EZ950E
TX-65EZX50E (Continental Europe)
EZW954 (for Germany, Niderland)
EZC954 (for Switzerland)
- EZ952B (for United Kingdom)
EZR950 - ? (for Russia)
no 3D
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
Internal storage free space: E | OS: Firefox 2.5 - HTML5 v.2.0 SDK | 64.5" - AM-OLED(Triple Stacked), 3840x2160, WRGB,
PWM - No
Yes - IFC,
- 8000 points
Rec.2020
Anti-Judder: ?
Led motion: ? Very Good for HD, -, -, -, -, | 65" - DCI/P3 - 97% / 98%
65" -
65" -
65" - 2.2
65" -
77" -
77" - Inf.:1
77" -
77" - ? cd/m2
77" - 0cd/m2 65" -
65" - x
65" - Inf.:1
65" -
65" -
65" - cd/m2
65" - 0cd/m2
| 77" - 65" - 65°(h)/ °(v) Color shift - 26°
Brightness - 69°
Black Level - 75°
| 77" - horizontal lines 65" - horizontal lines
| 77" - in HDR mode
77" - in Game mode
77" - by default 65"- in HDR - ms
65"- in Game mode -
65"- by default
| 80W (RMS)
Dolby Puls,
AVCHD/Progressive,
H.263
MPEG-4
FLV
VRO (DVD-VR, .VRO)
PS
VP9, profile ?
Wi-Fi,
802.11 a,
802.11 b,
802.11 g,
802.11 n,
802.11 n 5GHz,
802.11 ac,
Wi-Fi Direct,
3840x2160 - 50p
3840x2160 - 30p
1920 x 1080 / 50i
1 x Ethernet RJ45
2 x CI + (ver. 1.3)
MPEG4,
VP9 ProFile.2 | | EZ950 (Oled)
TX-77EZ950E
EZW954 (for Germany)
no 3D
EX780 (LCD) TX-75EX780E
TX-65EX780E
TX-58EX780E
TZ-50EX750E (Continental Europe)
EXW784 (for
Germany,
Switzerland,
Niderland) -
EX752B (for United Kingdom)
EXR780 - ? (for Russia)
no 3D
no HFR (High Frame Rate) available in Europe from -April 2017 | No | Yes | No | Crestron / Control4 | Yes - in TV, Internet video services, HDMI, USB port. | Yes - in terrestrial and satellite TV,
SoC: MediaTek MT5
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
Internal storage free space: E | OS: Firefox 2.5 - HTML5 v.2.0 SDK | 75" - S-MVA(Innolux), 3840x2160, RGB, 10-bit, ?, 120/100Hz, Flat 65" - S-MVA(Innolux), 3840x2160, RGB, 10-bit, ?, 120/100Hz, Flat 58" - S-MVA(Innolux), 3840x2160, RGB, 10-bit, ?, 120/100Hz, Flat 50" - S-MVA(Innolux), 3840x2160, RGB, 10-bit, ?, 120/100Hz, Flat Index - 2400 BMR IFC | Edge Led (Down),
Local Dimming (4 x 3)
12 sections,
W-Led,
Yes - IFC(MCFI),
-, | | Anti-Blur: ?
Anti-Judder: ?
| 75" - max 550 nit in HDR
65" - max 550 nit in HDR
58" - max 550 nit in HDR
50" - max 550 nit in HDR | | | | | | FAT16, FAT 32, NTFS and exFAT Image file formats JPEG 4K, GIF, PNG, MPO, JPG, Audio file formats/codecs AAC (Advanced Audio Coding)
AVCHD/Progressive,
H.263
MPEG-4
FLV
VRO (DVD-VR, .VRO)
PS
VP9, profile ?
Wi-Fi,
802.11 a,
802.11 b,
802.11 g,
802.11 n,
802.11 n 5GHz,
802.11 ac,
Wi-Fi Direct,
Bluetooth(NFC) Ver.4.1 HID/HOGP/3DSP/SPP(for keyboard and mouse, no Bluetooth audio) Miracast, | | 2 x USB 2.0 (DC 5V MAX 500mA)
1 x Ethernet RJ45
2 x CI + (ver. 1.3)
B/G,D/K,I (45,25MHz–863,25MHz) 2x DVB-T/T2 (H.264) -T2 HD (H.265) (VHF/UHF) 2x DVB-S/S2 (950-2150MHz) (DiSEqC version 1.0) 2x DVB-C (VHF/UHF) 1x TV>IP Server & Client Teletext - 1500 Pages (TOP & List) 2T
MPEG4,
VP9 ProFile.2 | | EX780 (LCD) TX-75EX780E
TX-65EX780E
TX-58EX780E
EXW784 (for Germany & Switxerland) -
EX782B (for United Kingdom)
no 3D
no HFR (High Frame Rate) available in Europe from ---- 2017 |
EX730 (LCD) TX-65EX730E
TX-58EX730E
TX-50EX730E
TX-40EX730E (Continental Europe)
EXW734 (for Germany,
Switzerland,
Niderland) -
EX732B (for United Kingdom)
EXR730 - ? (for Russia)
no 3D
no HFR (High Frame Rate) available in Europe from --- 2017 | No | Yes | No | Crestron / Control4 | Yes - in TV, Internet video services, HDMI, USB port. | Yes - in terrestrial and satellite TV,
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
Internal storage free space: E | OS: Firefox 2.5 - HTML5 v.2.0 SDK | 65" - S-MVA(Innolux), 3840x2160, RGB, 8-bit + FRC, 60/50Hz, Flat 58" - S-MVA(Innolux), 3840x2160, RGB, 8-bit + FRC, 60/50Hz, Flat 50" - S-MVA(Innolux), 3840x2160, RGB, 8-bit + FRC, 60/50Hz, Flat 40" - S-MVA(Innolux), 3840x2160, RGB, 8-bit + FRC, 60/50Hz, Flat | Edge Led (Down),
Local Dimming,
W-Led,
Yes - IFC,
-, | | Anti-Blur: ?
Anti-Judder: ?
| 65" - max 350cd/m2 in HDR
65" - max 350cd/m2 in SDR APL - ABL - | 65" -
65" -
65" -
65" -
65" -
65" - cd/m2
65" - cd/m2
| 65" - °(h)/ °(v) Color shift - °
Brightness - °
Black Level - °
| 65"- HDR - ms
65"- Game mode -
65"- by default
| 2 x 10W (RMS) | FAT16, FAT 32, NTFS and exFAT Image file formats JPEG 4K, GIF, PNG, MPO, JPG, Audio file formats/codecs AAC (Advanced Audio Coding)
AVCHD/Progressive,
H.263
MPEG-4
FLV
VRO (DVD-VR, .VRO)
PS
VP9, profile ?
Micro DVD, SRT, SUB, SubRip, TMPlayer, TXT Obviously not playing DTS-HD tracks or TrueHD or ISO or Blu-ray folders (BDMV) and like all televisions, 24p videos are played in 60 im / s, but converting the framerate is well managed, with smooth playback without jerkiness and a picture of beauty. The reading is also interesting audio files with management Flac, WAV and ALAC, the ability to display album art or tags, but no native playback of files called "HiRes" all files in 88.2, 96, 176.4 or 192 kHz are downmixes in 48 kHz / 24 bits. | | UltraHD for HDMi 1 & 2
Regime1: 4:4:4, 4:2:2(30p, 25p, 24p), 4:2:0(60p, 50p)
Regime2: 4:4:4, 4:2:2(30p, 25p, 24p), 4:4:4, 4:2:2, 4:2:0(60p, 50p) | 2 x USB 2.0 (DC 5V MAX 500mA)
1 x Ethernet RJ45
2 x CI + (ver. 1.3)
MPEG4,
VP9 ProFile.2 | | EX730 (LCD) TX-65EX730E
TX-58EX730E
TX-50EX730E
EXW734 (for Germany & Switzerland) -
no 3D
EX700 (LCD) TX-65EX700E (703)
TX-58EX700E (703)
TX-50EX700E (703)
TX-40EX700E (703) 703/700-> difference in built-in tuners
EXW704 (for Germany & Switzerland)
EX700B (for United Kingdom)
EXR700 - ? (for Russia)
no 3D
no HFR (High Frame Rate) available in Europe from ---- 2017 | No | Yes | No | Crestron / Control4 | Yes - in TV, Internet video services, HDMI, USB port. | Yes - in terrestrial and satellite TV,
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
Internal storage free space: E | OS: Firefox 2.5 - HTML5 v.2.0 SDK | 65" - S-MVA(Innolux), 3840x2160, RGB, 8-bit + FRC, 60/50Hz, Flat 58" - S-MVA(Innolux), 3840x2160, RGB, 8-bit + FRC, 60/50Hz, Flat 50" - S-MVA(Innolux), 3840x2160, RGB, 8-bit + FRC, 60/50Hz, Flat 40" - S-MVA(Innolux), 3840x2160, RGB, 8-bit + FRC, 60/50Hz, Flat Index 1600 BMR IFC | Edge Led,
Local Dimming ?,
W-Led,
-, | | Anti-Blur: ?
Anti-Judder: ?
Led motion: ? Very Good for HD, -, -, -, -, | 65" - DCI/P3 - % / %
65" - BT.2020 - % / %
65" -
65" -
65" -
65" -
| 65" - max cd/m2 in HDR
65" - max cd/m2 in SDR APL - ABL - | 65" -
65" -
65" -
65" -
65" -
65" - cd/m2
65" - cd/m2
| 65" - 65°(h)/(v) Color shift -
Brightness -
Black Level -
| 65"- HDR - ms
65"- Game mode -
65"- by default
| 2 x 10W (RMS) VR-Audio True Surround Dolby Digital Plus ?
Dolby Puls,
AVCHD/Progressive,
H.263
MPEG-4
FLV
VRO (DVD-VR, .VRO)
PS
VP9, profile ?
Wi-Fi,
802.11 a,
802.11 b,
802.11 g,
802.11 n,
802.11 n 5GHz,
802.11 ac,
Wi-Fi Direct,
No - Bluetooth Miracast,
HbbTV | UltraHD for HDMI 1 & 2
1 x Ethernet RJ45
3 x HDMI 2.0a - (ARC(input 2), CEC, MHL 3.0)
1 x CI + (ver. 1.3)
1 x Satelite In (Main; F-type female) only in EX703
No Bluetooth | Analog (NTSC, PAL, SECAM)
B/G,D/K,I (45,25MHz–863,25MHz) EX700 - DVB-T/T2/C
EX703 - DVB-T/T2/C/S2
EX700B - DVB-T/T2/S2 DVB-T/T2 (H.264) -T2 HD (H.265) (VHF/UHF) DVB-S/S2 (950-2150MHz) (DiSEqC version 1.0) DVB-C (VHF/UHF) TV>IP Client Teletext - 1000 Pages (TOP & List) 2T
(USB-HDD Recording) with Rewind Live TV MPEG2,
MPEG4,
VP9 ProFile.2 | | EX703 (LCD) TX-65EX700E (703)
TX-58EX700E (703)
TX-50EX700E (703)
EXW704 (for Germany & Switzerland) -
EX702B (for United Kingdom)
no 3D
EX600 (LCD) TX-65EX600E (603)
TX-55EX600E (603)
TX-49EX600E (603)
TX-43EX600E (603)
TX-40EX600E (603) 603/600->difference in built-in tuners
EXW604 (for Germany & Switzerland) -
EX602B (for United Kingdom)
EXR600 - ? (for Russia)
no 3D
SoC: MediaTek MT5
Instruction set:
Operating at up to:
GPU:
Open GL
RAM:
Total memory:
Available memory:
Internal storage free space: E | OS: Firefox 2.5 - HTML5 v.2.0 SDK | 65" - S-MVA(Innolux), 3840x2160, RGB, 8-bit + FRC 55" - IPS(), 3840x2160, RGB, 8-bit 49" - IPS(), 3840x2160, RGB, 8-bit 43" - IPS(), 3840x2160, RGB, 8-bit 40" - S-MVA(Innolux), 3840x2160, RGB, 8-bit | Edge Led | | Anti-Blur: ?
Anti-Judder: ?
Led motion: ? Very Good for HD, -, -, -, -, | | | | | | | 2 x 10W (RMS) | FAT16, FAT 32, NTFS and exFAT Image file formats JPEG 4K, GIF, PNG, MPO, JPG, Audio file formats/codecs AAC (Advanced Audio Coding)
AVCHD/Progressive,
H.263
MPEG-4
FLV
VRO (DVD-VR, .VRO)
PS
VP9, profile ?
Wi-Fi,
802.11 a,
802.11 b,
802.11 g,
802.11 n,
802.11 n 5GHz,
802.11 ac,
Wi-Fi Direct,
1 x Ethernet RJ45
1 x CI + (ver. 1.3)
1 x Satelite In (Main; F-type female) only in EX603
B/G,D/K,I (45,25MHz–863,25MHz) EX600 - DVB-T/T2/C
EX603 - DVB-T/T2/C/S2 DVB-T/T2 (H.264) -T2 HD (H.265) (VHF/UHF) DVB-S/S2 (950-2150MHz) (DiSEqC version 1.0) DVB-C (VHF/UHF) IP>TV Client Teletext - 1000 Pages (TOP & List) 2T
MPEG4,
VP9 ProFile.2 | | EX600 (LCD) TX-65EX600E (603)
TX-55EX600E (603)
TZ-49EX600E (603)
no 3D
