| Panasonic UHD TV 2016 - european models |
 | Series Model
 __________________
 | UHD _____Premium
 | Dolby Vision____
 | Hybrid Log Gamma_____(HLG)
 | HDR 103 fundamental HDR
 building blocks:
 ST2084 (EOTF PQ),
 ST2086 (static metadata)
 ST2094 (dynamic metadata)
 _________________
 The measured values of the brightness in Windows
 2/5/10/15/20/100%
 | Videopanel _______________________
 Type LCD matrix, Bits of color,
 (Operating frequency of T-Con board of the panel)
 Curvature,
 Index,
 Screen Uniformity
 Anti-reflective filter
 | Supported Resolutions____________________________________
 Frame per seconds24, 25, 30, 50, 60, 100, 120 p/i
 Chroma subsampling
 4:4:4
 4:2:2
 4:2:0
 | Backlight Unit____________________
 Type backlight(Local Dimming zone)
 Type LED
 MEMC
 Backlight Scanning
 Black Frame Insertion
 Pulsе Wide Modulation
 | Measurements_______________________________
 DCI P3Rec.2020
 Delta E
 Gamma
 Color Temperature
 ANSI ContrastWith local dimming
 Without local dimming
 White level
 Black level
 | Viewing angle__________
 Horizontal & Vertical (°cone)
 | Motion resolution _____________________
 | Product _____________
 | Input Lag_____________________________
 | Audio___________________ | Built in Media Player_____________________________Supported file systems
 Image file formats
 Audio file formats/codecs
 Video file formats
 Soub-Titres
 | Hardware & Software____________________
 Operating System
 Board
 Central Processing Unit
 System on Chip
 Instruction set
 Graphic Processor Unit
 RAM
 Total memory
 | Conectors_____________________
 | Networks__________________________ | Tuners__________________ | Opportunities for _________________________calibration
 | Note__________________________________________________________________________________
 Pros & Cons | Product |
 | CZ950 (Oled) TX-65CZ950
 TX-65CZW954 ()
 TX-65CZ952B (only in UK)
 | Yes | No | No | 65" - max 450cd/m2 Yes
 SMPTE standarts
 ST2084, ST 2086
 | Oled, WRGB(LG Display), 10bit, 120/100Hz
 |  | No backlight | DCI-P3 - 86% Rec.2020 - 70%
 Gama - 2.44 - 2.38
 | 65" - ∞ / 151cd/m2 / 0.00cd/m2 | 65" - 45° |  | CZ950 65"
 OLED
 | 65" - Game mode - 74ms |  |  |  |  |  |  |  |  | CZ950 |
 | DX900 (Flat - Active 3D)
 TX-65DX900E
 TX-65DXC904
 TX-65DXW904
 TX-65DX902B (only in UK)
 TX-58DX900E
 TX-58DXC904
 TX-58DXW904
 TX-58DX902B (only in UK)
 | Yes | No | Yes | 65"- max 1250cd/m2 100% - 885cd/m2
 58"- max 1430cd/m2
 Yes HDR10
 SMPTE standards
 ST2084, ST2086
 | 65"- SMVA, 10-bit, 120/100Hz 58"- SMVA, 10-bit, 120/100Hz
 Motion Clarity Frame Interpolation (IFC)
 Black Frame Insertion (Clear Motion)
 Active 3D
 | 4:4:4 / 4:2:2 - 30p, 25p, 24p 4:4:4 / 4:2:2 / 4:2:0 - 60p, 50p
 4096x2160 - 60p (displayed as 3840x2160)
 4096x2160 - 50p (displayed as 3840x2160)
 4096x2160 - 30p (displayed as 3840x2160)
 4096x2160 - 25p/4:4:4 (10, 12 bit) (displayed as 3840x2160)
 4096x2160 - 24p/4:4:4 (10, 12 bit) (displayed as 3840x2160)
 3840x2160 - 60p
 3840x2160 - 50p
 3840x2160 - 30p
 3840x2160 - 25p/4:4:4 (10, 12 bit)
 3840x2160 - 24p/4:4:4 (10, 12 bit)
 HDR 3840x2160 – 10 bit colors – BT.2020 color space – 4:2:0 – 75.6 Mbps bitrate – 59.940fps – HEVC (Main10@L5.1) - .mp4 file
 HDR 3840x2160 – 10 bit colors – BT.2020 color space – 4:2:0 – 56.4 Mbps bitrate – 23.976fps – HEVC (Main10@L5) - .mp4 file
 HDR 3840x2160 – 10 bit colors – BT.2020 color space – 4:2:0 – 60.3 Mbps bitrate – 23.976fps – HEVC (Main10@L5) - .mp4 file
 3840x2160 – 23.976fps – 10 bit colors - BT.709 color space – 4:2:0 – 51.4 Mbps bitrate – HEVC - .ts file
 3840x2160 – 8 bit colors – YUV color space – 4:2:0 – 50.0 Mbps bitrate – 29.970fps - AVC - .mp4 file
 3840x2160 – 10 bit colors – YUV color space – 4:2:0 – 23.1 Mbps bitrate – 50fps - HEVC - .ts file
 2560x1440 – BT.709 color space – 4:2:0 – 6.54 Mbps bitrate – VP9 - .mkv file
 3840x2160 – BT.709 color space – 4:2:0 – 12.71 Mbps bitrate – VP9 - .mkv file
 1920x1080 – 8 bit colors - YUV color space – 4:2:0 – 2.5 Mbps bitrate – 60fps - HEVC - .ts file
 1920x1080 – 8 bit colors - YUV color space – 4:2:0 – 60fps - 2.2 Mbps bitrate – HEVC - .mkv file
 1920x1080 – 8 bit colors – BT.709 color space – 4:2:0 – 98.3 Mbps bitrate – AVC - .mkv file
 | 65" - FALD, 512 zones (32 x 16) 58" - FALD, 512 zones (32 x 16)
 Honeycomb backlight structure
 Blue Leds - PFS (potassium-fluorosilicate) phosphor featuring an extremely narrow red peak
 MEMC - Intelligent Frame Creation
 BLS - Backlight Scaning
 BFI - Clear Motion
 6 cooling fan backlight
 | 65"- DCI-P3 - 98.03%
 Rec.2020 - 78%
 Gama - 2.41 - 2.4 /
 58"-
 DCI-P3 - 96%
 Rec.2020 - 74%
 dE - 1.02
 Gama - 2.41 - 2.4
 | 65" - ANSI (4x4) - 5360:1 Pre - 134cd/m2 (white)
 Pre - 0.025cd/m2 (black)
 Post - 0.019cd/m2 (black)
 Dynamic - 50000:1
 58" - ANSI (4x4) - 4600:1
 without - 0.025 cd/m2 (black)
 with - 0.023cd/m2 (black)
 Dynamic - 50000:1
 Static - 5400:1
 Local Dimming Down: White 123 cd / m² - Black at 0.026 cd / m² = Contrast 4730: 1 (linear gamma, black legible)
 Local Dimming to Medium: White 122 cd / m² - Black at 0.020 cd / m² = Contrast 6100: 1 (linear gamma, black legible)
 Local Dimming high: White 119 cd / m² - Black at 0.006 cd / ² = Contrast 19,800: 1 (linear gamma, black neighborhood a bit stuffy, but less stuffy than the Edge LED)
 | 65" - 46°(cone) 58" - 46°(conе)
 | 65" - 1080 lines with[IFC]“Custom“; 300 “Off“
 58" - 1080 lines
 | DX900 58", 65"
 | 65"- 65" - Normal: 51.2ms HDR + Game mode - 38.8ms [Adaptive Backlight Control - OFF]
 Normal + Game mode: 40.7ms
 THX cinema + Game mode: 42.7ms
 Professional 1 + Game mode: 42.8ms
 58" - Game mode- 40ms / by default - 50ms
 | 40Watt (10W+10W+10W+10W) integrated subwoofer
 Dolby Digital
 Dolby Plus
 No DTS
 VR-Audio Master Surround 2.1
 That said, there is still a 2.1 system with 2 x 10 watts with a wooffer 20 Watts, all support by 4 passive radiators and a lot of settings to optimize the sound reproduction, volume level changes in a channel to another, offer more serious, a 7-band EQ, etc.
 | FAT16, FAT32, NTFS and exFAT
 JPEG 4K, JPG, GIF, PNG, MPO 3D
 MP3, AAC, WMA Pro, FLAC 44.1 kHz and downmix of 192 kHz Flac, Apple Lossless (ALAC), WAV / LPCM
 MKV, 3G2, 3GP, 3GPP, ASF, AVCHD, AVCHD/MVC (3D), AVI, F4V, FLV, H.264 BP, H.264 HP, H.264 MP, H.265 (HEVC), VP9, M2TS, M4V, MKV, MOD, MP4, MPEG, MPEG-1, MPEG-2, MPEG4 ASP, MPEG4 SP, MPG, MTS, PS, TP, TRP, TS, TTS, VC-1, VOB, VRO, WMV (Windows Media Video), WMV9 (Windows Media Video 9)
 Micro DVD, SRT, SUB, SubRip, TMPlayer, TXT
 Obviously not playing DTS-HD tracks or TrueHD or ISO or Blu-ray folders (BDMV) and like all televisions, 24p videos are played in 60 im / s, but converting the framerate is well managed, with smooth playback without jerkiness and a picture of beauty. The reading is also interesting audio files with management Flac, WAV and ALAC, the ability to display album art or tags, but no native playback of files called "HiRes" all files in 88.2, 96, 176.4 or 192 kHz are downmixes in 48 kHz / 24 bits.
 | - Quad Core
 Chassis P163
 Firefox 2.5
 | 1 x Ethernet RJ45 2 x USB 2.0 (max 500mA/5V)
 1 x USB 3.0 (max 900mA/5V)
 4 x HDMI 2.0a HDCP2.2 (ARC,CEC)
 1 x Satelite In (Main: F-type female)
 1 x Satelite In (Sub: F-type female)
 1 x AV Composite In
 1 x AV Component In
 1 x Optical Audio Out
 1 x 3.5mm Audio Out
 1 x Antena (RF)female
 1 x CI+ 1.3
 1 x Card reader SD/SDHC/SDXC
 | Lan Wi-Fi
 802.11 a
 802.11 b
 802.11 g
 802.11 n
 802.11 n 5GHz
 Bluetooth ver.4.0(for keyboard and mouse, no Bluetooth audio)
 Wi-Fi Direct
 DLNA (RUI2.0/DTCP-IP/DMP/DMR/DMS)
 | 2x DVB-C/T2/S2, 1 x SAT>IP Client & Server
 DiSEqC (Digital Satellite Equipement Control) version 1.0
 DVB-T2: HEVC H.264 и H.265
 Analog (PAL,SECAM)
 2 x CI+1.3
 PVR, Time Shifting
 HEVC, VP9
 | ISF ProfessionalTHX Bright Room 3D LUT - 8000 points
 CMS - RGBCYM
 gray scale of 10 points
 Rec.2020
 Rec.709
 direct Display Control mode to allow to adjust settings directly from the Calman software (professional edition) by connecting screen to a PC via Ethernet
 | Although the Panasonic DX902 features a high number of FALD zones, in certain low-APL scenes the dimming algorithm in HDR mode could be too aggressive even with [Automatic Backlight Control] set to the lowest value of “Min“, spoiling the original creative intent of the movie. One such instance was during the opening space sequence in The Martian: the Viera TX-65DX902B was darkening several dark patches excessively, resulting in a blotchy “reverse clouding” effect. The DX900′s sharply-defined backlight algorithm also had a tendency to show up the FALD grid structure of the television. As the title “The Martian” appeared on the aforementioned space scene, the bright letters were accompanied by square-shaped haloing/ blooming against the dark backdrop. The same phenomenon could be observed in timecode 00:19:56 of The Revenant where Hugh is reassuring his son Hawk at night, with the silhouettes being displayed in rectangular halos.
 + The Full LED backlight with honeycomb structure and 512 zones Local Dimming+ A record for a contrast LED TV, visually very close to the OLED+ An ultra high light pic!+ A 10-bit panel+ An exceptional rendering HDR+ A rich spectrum of stunning colors and balanced+ Colorimetry output of cardboard near-perfect in Rec.709 and DCI (Delta E 1)+ A high-performance video processing, including SD content with a very natural picture+ Several algorithms with efficient remastering yet made once natural+ Ultra settings to complete color management level and HDMI+ The efficiency of HCX + processor: magnificent display UHD upscaling and great+ Rendering fluid, even without IFC+ Complete network management, Samba, DLNA / UPnP, multiroom client / server, sharing of tuners on the networkinteresting multimedia management (UHD video playback and HDR, VP9 and HEVC, MKV, TS, Flac, ALAC, etc.), but no DTS decoding that just spoils the fun!
+ A good anti-reflective coating+ Very good record audio+ The best current LED TV, a reference!- IFC made too which generates a digital camcorder- The very average 3D or not good (blocked backlight, gray and black marked ghosting)- The absence of DTS support, multimedia playback 24p, or playback HD audio tracks- A very directive slab (loss of contrast and color beyond 20 °)- A filter detail enhancement and / or contours would have been welcome for picture lovers scalpel- No compatibility Dolby Vision- The inclination of the slab to 6, no interest and can be binding- A cover 100% of the DCI would have been welcome at this price!- The price, too high for a LED TV, whatever its quality!- many users have encountered the vertical banding worries with the 58 "(65" offers however excellent homogeneity)
 | DX900 |
 | DX800 (Flat)
 TX-58DX800E
 TX-58DXW804
 TX-58DX802B
 TX-50DX800E
 TX-50DXW804
 TX-50DX802B
 | No | No | Yes | 58" - max 553cd/m, 10% - 458cd/m2
 50" - 10% - 545cd/m2
 Yes HDR10
 SMPTE standards
 ST2084, ST2086
 | 58"- Super-MVA, 8-bit+FRC, 120/100Hz 50"- Super-MVA, 8-bit+FRC, 120/100Hz
 Panasonic have done an excellent job of ensuring the backlight is suitably uniform. There was no apparent dirty screen effect or any obvious bright edges and overall with normal viewing material the backlight performance was very good. At night in a dark room you could see some minor backlight issues but those were rare and easily mitigated with some bias lighting.
 |  | 58" - Edge Led 50" - Edge Led
 Dimming - 4 Vertical zones
 Blue Leds - with red phosphorus)
 BFI - Clear Motion
 | 58"- 95% / 72% 50"- 86% / 67% / DeltaE 2.3 / Gamma 2.4
 phosphorus-based diodes for a wide gamut close to the DCI 4K(Blue Led + Red/Green phosphorus)
 | 58" - ANSI 3500:1 / 0.0 50" - ANSI 5310:1 / 0.02cd/m2
 with Adaptive Backlight Control (local dimming) 0.002cd/m2,
 | 58" - 50" -
 | 58" -
 50" - with IFC - 1080 / without - 350
 | DX800 58", 50"
 | 58" - Game mode 43ms / by default 110ms 50" - Game mode 44ms / by default 110ms
 The DX802 delivered an input lag of 44ms in Game Mode, which whilst not as low as some of the competition, should be good enough for all but the most demanding of gamers. We certainly had no problems with lag when gaming and found the overall performance to be very good with our PS4. One interesting thing to note is that you can select the Game Mode when watching HDR content, which means that when HDR games are released you should still be able to enjoy the benefits of a lower input lag.
 | 2 x 10 Watt RMS + Subwoofer 20 Watt VR-Audio Master Surround 2.1
 12 Train Prismatic Speaker (2 tweeters, 4 médiums et 6 woofers)
 Dolby Digital Plus
 No DTS
 The soundbar includes a 12 train prismatic speaker, a quad passive radiator and 40W of amplification, whilst there are holes at the back so that it can, along with the TV, also be wall mounted. The fact that you can detach the soundbar completely means you also have the option to not use it at all and simply use your DX802 with a third-party audio solution.
 | - Quad Core
 Chassis P163
 Firefox 2.5
 1 x AV Composite In
 1 x AV Component In
 1 x 3.5mm Audio Out
 1 x CI+ 1.3
 | Lan Wi-Fi
 802.11 a
 802.11 b
 802.11 g
 802.11 n
 802.11 n 5GHz
 Wi-Fi Direct
 | 2 x DVB-C/T2/S2, 1 x SAT>IP Client & Server
 Analog (PAL,SECAM)
 2 x CI+1.3
 PVR, Time Shifting HEVC, VP9
 | As with all Panasonic TVs, the DX800 comes with an excellent set of calibration controls, including 2- and 10-point white balance controls, a separate gamma control and a full Colour Management System (CMS),ISF Professional, THX Bright Room, 3D LUTCMS - RGBCYM gray scale of 10 points. Rec.2020, Rec.709 direct Display Control mode to allow to adjust settings directly from the Calman software (professional edition) by connecting screen to a PC via Ethernet | The colour accuracy of the DX802 wasn't as good as we would expect from a Panasonic TV | DX800 |
 | DX780 (Flat)
 TX-65DX780E
 TX-65DXW784
 TX-58DX780E
 TX-58DXW784
 TX-58DXX789
 TX-58DXN788
 TX-58DXF787
 TX-58DXT786
 TX-50DX780E
 TX-50DXW784
 TX-50DXT786
 TX-50DXF787
 | No | No | No | 65" - max......cd/m2 55" - max 577cd/m2
 50" - max 5....cd/m2
 Compatible
 HDR processing (but no hardware for HDR)
 | 65" - Super-MVA, 8-bit+Hi-FRC, 120/100Hz 58" - Super-MVA, 8-bit+Hi-FRC, 120/100Hz
 50" - Super-MVA, 8-bit+Hi-FRC, 120/100Hz
 |  | 65" - Direct Led, Local Dimming - 32 zones (8 x 4) 58" - Edge Led (below) Vertical Dimming
 50" - Edge Led (below) Vertical Dimming
 BFI - Clear Motion
 | 65" - DCI P3 X,Y - 58" - DCI P3 X,Y -
 50" - DCI P3 X,Y - 89% / Rec.2020 - 66%
 | 65" - 58" -
 50" -
 | 65" - 58" -
 50" -
 |  | DX780 65", 58", 50"
 | 65" - Game mode 58" - Game mode
 50" - Game mode
 | 2x10 Watt RMS Dolby Digital Plus
 No DTS
 VR-Audio Surround True
 JPEG, GIF, PNG, MPO
 AAC, FLAC, MP3, WMA Pro, WAV, Apple Lossless
 AVCHD 3D / Progressive
 3GPP (3rd Generation Partnership Project, .3gp)
 AVI (Audio Video Interleaved, .avi)
 MKV (Matroska Multimedia Container, .mkv, .mk3d, .mka, .mks)
 Flash Video (.flv, .f4p, .f4a, .f4b)
 H.263
 H.264 / MPEG4 Part 10 / AVC Video
 H.265 / MPEG-H Part 2 / HEVC
 Quick Time (mov, .qt)
 MP4 (MPEG-4 Part 14, .mp4, .m4a, .m4p, .m4b, .m4r, .m4v)
 VRO
 VOB (Video Object)
 TS (MPEG Transport Stream, .ts, .tsv, .tsa)
 PS
 VP9
 WMV (Windows Media Video, .wmv)
 | - Quad Core
 Chassis P163
 Firefox 2.5
 | 1 x Ethernet RJ45 2 x USB 2.0 (max500mA)
 1 x USB 3.0 (max900mA)
 2 x HDMI 2.0a HDCP2.2 (ARC,CEC)
 2 x HDMI 1.4 (CEC)
 1 x AV Composite In
 1 x AV Component In
 1 x 3.5mm Audio Out
 1 x Antena (RF)female1 x CI+ 1.3
 | Lan (10BASE-T/100BASE-TX) Wi-Fi 802.11 a
 802.11 b
 802.11 g
 802.11 n
 802.11 n 5GHz
 Bluetooth Ver.4.0(for keyboard and mouse, no Bluetooth audio)
 Wi-Fi Direct
 Analog (PAL,SECAM)
 2 x CI+1.3
 PVR, Time Shifting
 HEVC, VP9
 |  |  | DX780 |
 | DX750 (Flat)
 (TX-65DX750E
 TX-65DX750B
 TX-58DX750E
 TX-58DX750F
 TX-50DX750E
 TX-50DX750F
 TX-50DX750B
 | No | No | No | 65" - max 435cd/m2 58" - 100% max 550cd/m2
 50" - 10% max 529cd/m2/
 SDR max 500cd/m2
 Compatible
 50" - Super-MVA, 8-bit+HI-FRC, 120/100Hz
 50"- panel Innolux V500DK4-KS7-Rev.R24
 very glossy panel
 The Adaptive Backlight Control (local dimming) on the DX750 was a little disappointing, especially compared to the sophisticated system employed by Samsung, and even in the low mode we saw artefacts that were quite obvious at times. Although it was less an issue of haloing and more of a problem of the entire image obviously dimming in certain scenes. However since the native blacks and backlight uniformity are good, if you sit central to the screen there is very little difference with the local dimming on or off and at least when it's off you avoid any issues.
 | HDR 3840x2160 – 10 bit colors – BT.2020 color space – 4:2:0 subsampling – 75.6 Mbps bitrate – 59.940fps – HEVC (Main10@L5.1) - .mp4 file HDR 3840x2160 – 10 bit colors – BT.2020 color space – 4:2:0 subsampling – 60.3 Mbps bitrate – 23.976fps – HEVC (Main10@L5) - .mp4 file
 HDR 3840x2160 – 10 bit colors – BT.2020 color space – 4:2:0 subsampling – 56.4 Mbps bitrate – 23.976fps – HEVC (Main10@L5) - .mp4 file
 3840x2160 – 10 bit colors – YUV color space – 4:2:0 subsampling – 23.1 Mbps bitrate – 50fps - HEVC - .ts file
 3840x2160 – 10 bit colors - BT.709 color space – 4:2:0 subsampling – 51.4 Mbps bitrate – 23.976fps – HEVC - .ts file
 3840x2160 – 8 bit colors – YUV color space – 4:2:0 subsampling – 50.0 Mbps bitrate – 29.970fps - AVC - .mp4 file
 3840x2160 – BT.709 color space – 4:2:0 subsampling – 12.71 Mbps bitrate – VP9 - .mkv file
 2560x1440 – BT.709 color space – 4:2:0 subsampling – 6.54 Mbps bitrate – VP9 - .mkv file
 1920x1080 – 8 bit colors - YUV color space – 4:2:0 subsampling – 2.5 Mbps bitrate – 60fps - HEVC - .ts file
 1920x1080 – 8 bit colors - YUV color space – 4:2:0 subsampling – 60fps - 2.2 Mbps bitrate – HEVC - .mkv file
 1920x1080 – 8 bit colors – BT.709 color space – 4:2:0 subsampling – 98.3 Mbps bitrate – AVC - .mkv file
 | 65" - Direct Led, No Dimming 58" - Edge Led (below), Vertical Dimming
 50" - Edge Led (below), Vertical Dimming
 BMR 1800
 | 65" - 90% / 70% 58" - 90% / 70%
 50" - 86% / 66%
 | 65" - ANSI 4300:1 / 123cd/m2 / 0.03cd/m2 58"- ANSI 4313:1 /120cd/m2 / 0.017cd/m2
 50" - ANSI 3795:1 / 0.023cd/m2
 with Adaptive Backlight Control(Local Dimming) 0.001cd/m2
 Static  4800:1/ 120 cd/m2 / 0.025cd/m2
 Dynamic 5000:1 / 625cd/m2 / 0.10cd/m2
 | 65" - 42° (cone) 58" - 44° (cone)
 50" - 46° (cone)
 | 65" -
 58" - with IFC 1080 / without - 350
 50" - with IFC 1080 / without - 350
 | DX750 65", 58", 50"
 | 65"- Game mode-46ms / by default-106ms 58"- Game mode-47ms / by default-105ms
 50"- Game mode-47ms / by default-105ms
 No DTS
 The rendering is still acceptable, average with perfectly intelligible dialogue, but rather limited power with 2 x 10 Watts and no Subwoofer output as Sony. no one still finds a lot of settings to optimize the sound rendering, level the volume changes from one channel to another, a 7-band EQ, a surround mode, etc.
 JPEG, JPG, MPO
 AAC, ADPCM, Dolby Digital (AC-3), Dolby Digital Plus (E-AC-3), DTS Core, FLAC, HE-AAC, LPCM, M4A, MP3, MPEG Audio, WAV, WMA, WMA Pro
 3G2, 3GP, 3GPP, ASF, AVCHD, AVCHD/MVC (3D), AVI, F4V, FLV, H.264 BP, H.264 HP, H.264 MP, H.265 (HEVC), M2TS, M4V, MKV, MOD, MP4, MPEG, MPEG-1, MPEG-2, MPEG4 ASP, MPEG4 SP, MPG, MTS, PS, TP, TRP, TS, TTS, VC-1, VOB, VRO, WMV (Windows Media Video), WMV9 (Windows Media Video 9)
 | - Quad Core
 Chassis P163
 Firefox 2.5
 2 x HDMI 1.4 (CEC)
 1 x AV Composite In
 1 x AV Component In
 1 x 3.5mm Audio Out
 802.11 b
 802.11 g
 802.11 n
 802.11 n 5GHz
 Wi-Fi Direct
 | DVB- C/T2/S2 with PIP functions, PAP, PAT,
 Analog (PAL,SECAM)
 PVR, Time Shifting
 HEVC H.265, VP9
 | Accurate Colour Drive technology with 3D LUT conversion table with 8 000 points correction and the ability to calibrate 6 primary and secondary colors within a CMS on 3 axes. Or Black Gradation Drive that can provide more gradations in dark scenes through treatment with 12 bit color.To adjust the colorimetry, the DX750 offers all the necessary settings with the choice of gamut used (Rec.601, Rec.709, EBU, DCI / P3 or Rec.2020), gamma used (with varying gamma whose BT.1886 with compensation of black, 2.2 used in lit room, the 2.4 used in dark room). You can edit each Gamma to correct on 10 points. Each gamut can be calibrated from a CMS (Color Management System) 3-axis (luminance, saturation and hue) with opportunity to correct 6 primary and secondary colors (RGBCMY). Finally, we also find a Balance Whites 2P and 10P (10 points) to adjust the color temperature.THX - NoISF - No | As for upscaling UHD Panasonic, there is no doubt he has made great progress. It's quite different from what Samsung offers, closer to what Sony offers, that is to say a very natural image, less chiseled than on the Samsung TV, but very precise and with a sumptuous quilted. The upscaling provides an image with rich texture and greatly improves accuracy without displaying traces of upscaling. So it is very comprehensive, especially for network management, but lacks however DisplayPort who was present on the AX900, or aptX Bluetooth and a Subwoofer output like what Sony offers. Standard remote control, without micro or backlit button. A good remote control, solid but rather plain .., and no possibility to calibrate the TV for a tablet like the DX900 as the DX750 is not certified ISF.
 + Design, build quality, the possibility of multiple foot positions+ A powerful contrast to an Edge LED (4800: 1 ANSI)+ A bright peak in HDR pretty good (625 nits)+ System of internal gradation great despite the slab 8 bit+ HDR rendering of very good quality+ A rich spectrum of beautiful, balanced colors, a wide gamut (91.2% of DCI)+ Colorimetry output very correct card (delta E less than 3)+ A high-performance video processing, including SD content with a very natural picture+ Several algorithms with efficient remastering yet made once natural+ Ultra settings to complete color management level and HDMI+ IFC made without a fluid including 24P+ Complete network management, Samba, DLNA / UPnP, multiroom client / server, sharing the tuner on the network+ interesting multimedia management (UHD video playback and HDR, VP9 and HEVC, MKV, TS, Flac, ALAC, etc.), but no DTS decoding that just spoils the fun!+ A good quality 3D rendering, although some ghosting+ The best quality / price ratio in 2016, certainly!- The anti-reflection treatment of limited- A slab 8 bit (although fnally we do not notice it)- IFC made too which generates a digital or video camera (main fault)- Lack of support DTS multimedia- A single HD tuner (DVB-C / T2 compliant HEVC and MPEG4)- A slightly Directive slab contrast term as all VA panels- A detail enhancement filter and / or contours would have been welcome for more chiseled picture lovers- No compatibility Dolby Vision- Local Dimming that a mouth too black to Medium or High- The edges of the slab clearer in some dark scenes
 | DX750 |
 | DX730 (Flat)
 TX-58DX730E
 TX-50DX730E
 TX-40DX730E
 TX-40DXW735
 TX-40DXW734
 | No | No | No | 58"- max....cd/m2 50"- max 317cd/m2
 40" - max...cd/m2
 Compatible
 | 58" - Super-MVA, 8-bit+FRC, 60/50Hz 50" - Super-MVA, 8-bit+FRC, 60/50Hz
 40" - Super-MVA, 8-bit+FRC, 60/50Hz
 Black Frame Interpolation
 4K Backlight Motion Rate IFC 1400
 very glossy panel
 |  | 58" - Edge Led (below) Vertical Dimming 50" - Edge Led (below) Vertical Dimming
 40" - Edge Led (below) Vertical Dimming
 | 58" - DCI P3 - 50" - DCI P3 -
 40" - DCI P3 -
 | 58" - 50" - 4824:1 / 0.04cd/m2
 40" -
 | 58" - 50" - 42° (cone)
 40" -
 |  | DX730 58", 50", 40"
 | 58" - Game mode 50" - Game mode
 40" - Game mode
 No DTS
 VR-Audio Surround
 True
 JPEG, JPG, MPO
 | - Quad Core
 Chassis P193
 Firefox 2.5
 1 x HDMI 1.4 (CEC)
 2 x HDMI 2.0a (ARC,CEC)
 1 x AV Composite In
 1 x AV Component In
 1 x 3.5mm Audio Out
 1 x CI+ 1.3
 802.11 a
 802.11 b
 802.11 g
 802.11 n
 802.11 n 5GHz
 Wi-Fi Direct
 | DVB-T/T2/C/S/S2 Double Tuner
 Analog (PAL,SECAM)
 PVR, Time Shifting
 HEVC, VP9
 |  |  | DX730 |
 | DX720 (Flat)
 TX-58DX720E
 TX-50DX720E
 TX-40DX720E
 | No | No | No | 58"- max....cd/m2 50"- max ....cd/m2
 40" - max...cd/m2
 Compatible
 4K Backlight Motion Rate IFC 1600
 very glossy panel
 |  | 58" - Led, Local Dimming 50" - Led, Local Dimming
 40" - Led, Local Dimming
 40" - DCI P3 -
 40" -
 40" -
 |  | DX720 58", 50", 40"
 40" - Game mode
 No DTS
 |  | - Quad Core
 Chassis P193
 Firefox 2.5
 1 x HDMI 1.4 (CEC)
 1 x AV Composite In
 1 x AV Component In
 1 x 3.5mm Audio Out
 1 x CI+ 1.3
 802.11 a
 802.11 b
 802.11 g
 802.11 n
 802.11 n 5GHz
 Wi-Fi Direct
 | DVB-T/T2/C Analog (PAL,SECAM)
 PVR, Time Shifting
 HEVC, VP9
 |  |  | DX720 |
 | DX700 (Flat)
 TX-58DX700E
 TX-58DX700F
 TX-58DXW704
 TX-50DX700E
 TX-50DX703E
 TX-50DXU701
 TX-40DX700E
 TX-40DX703E
 TX-40DX700F
 TX-40DXU701
 | No | No | No | 58" - HDR max 350cd/m2 50" - HDR max 350cd/m2
 40" -
 Compatible
 | 58" - Super-MVA, 8-bit, 60/50Hz 50" - Super-MVA, 8-bit, 60/50Hz
 40" - Super-MVA, 8-bit, 60/50Hz
 very glossy panel
 |  | 58" - Edge Led (below), Vertical Dimming 50" - Edge Led (below), Vertical Dimming
 40" - Edge Led(below), Vertical Dimming
 | 58" - DCI P3 - / Rec.2020 - 68.27% 50" - DCI P3 -
 40" - DCI P3 -
 | 58"- 5736:1 / 153cd/m2 / 0.03cd/m23184:1 / 0.038cd/m2ANSI - 2304:1 / 0.046cd/m2 50" - 4700:1 /
 40" -
 | 58" - 40°(conе) 50" -
 40" -
 |  | DX700 58", 50"'40"
 | 58"- Game mode-49.8ms / by default-69.7ms 50"- Game mode
 40" - Game mode
 No DTS
 VR-Audio True Surround
 |  | - Quad Core
 Chassis P193
 Firefox 2.5
 | 1 x Ethernet RJ45 1 x USB 2.0 (max 500mA)
 1 x USB 3.0 (max 900mA)
 1 x HDMI 1.4 (CEC)
 2 x HDMI 2.0 (ARC,CEC)
 1 x AV Composite in
 1 x AV Component in
 1 x 3.5mm Audio Out
 1 x Antena (RF) female
 1 x CI+ 1.3
 | Lan (10BASE-T/100BASE-TX) WiFi
 802.11 a
 802.11 b
 802.11 g
 802.11 n
 802.11 n 5GHz
 Bluetooth ver. 4.0
 Wi-Fi Direct
 | DVB-C/T2/S/S2 Analog (PAL,SECAM)
 HEVC,
 |  |  | DX700 |
 | DX650 (Flat)
 TX-55DX650E
 TX-55DX653E
 TX-55DXW654
 TX-49DX650E
 TX-49DX653E
 TX-40DX650E
 TX-40DX653E
 | No | No | No | 55" - 49" -
 40" -
 No
 | 58"- Super-MVA, 8-bit, 60/50Hz 49"- Super-MVA, 8-bit, 60/50Hz
 40"- Super-MVA, 8-bit, 60/50Hz
 4K Backlight Motion Rate IFC 1000
 |  | 55" - Edge Led, (below) 49" - Edge Led, (below)
 40" - Edge Led, (below)
 MEMC - Inteligent Frame Creation
 | 55"- DCI P3 - 49"- DCI P3 -
 40"- DCI P3 -
 | 55"- 49"-
 40"-
 | 55"- 49"-
 40"-
 |  | DX650 55", 49",40"
 | 55" - Game mode 49" - Game mode
 40" - Game mode
 No DTS
 JPEG, JPG, MPO
 | - Quad Core
 Chassis -Firefox 2.5
 1 x HDMI 1.4 (CEC)
 1 x AV Composite in
 1 x AV Component in
 1 x 3.5mm Audio Out
 1 x Antena (RF) female1 x CI+ 1.3
 | Wi-Fi 802.11 a
 802.11 b
 802.11 g
 802.11 n
 802.11 n 5GHz
 Wi-Fi Direct
 |  |  | DX650 |
 | DX600 (Flat)
 TX-55DX600E
 TX-55DX603E
 TX-55DXW604
 TX-55DXU601
 TX-49DX600E
 TX-49DX603E
 TX-49DXU601
 TX-49DXW604
 TX-40DX600E
 TX-40DX603E
 TX-40DXW604
 TX-40DXU601
 | No | No | No | 55" - max 294cd/m2 49" - max...cd/m2
 40" - max...cd/m2
 No
 | 55"- Super-IPS, 8-bit, 60/50Hz + BLB 49"- Super-IPS, 8-bit, 60/50Hz + BLB
 40"- Super-MVA, 8-bit, 60/50Hz + BLB
 4K Backlight Motion Rate IFC 800
 40" - Edge Led
 40"- DCI P3 -
 | 55"- 49"-
 40"-
 | 55"- 78° (cone) 49"-
 40"-
 |  | DX600 55", 49", 40"
 40" - Game mode
 | 2x10 Watt RMS Compatible
 Dolby Digital Plus
 No DTS
 JPEG, JPG, MPO
 Chassis
 Firefox 2.5
 1 x HDMI 1.4 (CEC)
 1 x AV Composite in
 1 x AV Component in
 1 x 3.5mm Audio Out
 | Wi-Fi 802.11 a
 802.11 b
 802.11 g
 802.11 n
 802.11 n 5GHz
 Wi-Fi Direct
 |  |  | DX600 |
 | Series Model
 ________________
 | UHD _____Premium
 | Dolby Vision____
 | HDR 10_______________
 In Windows2/5/10/20/100%
 Curvature,
 Index,
 Screen Uniformity
 | Supported Resolutions____________________ | Backlight____________________
 Type LED
 MEMC
 Backlight Scanning
 | Color Space ___________________
 DCI P3 / Rec.2020 / Delta E | Contrast ________________________White & Black level
 ANSIWith local dimming
 ( ° cone) | Motion resolution _____________________
 | Audio___________________ | Built in Media Player_____________________________ | SoC____________________CPU
 GPU
 Software
 OS
 | Conectors______________________ | Tuners______________ | Opportunities for _________________________calibration
