Страница 3 от 8 ПърваПърва 12345 ... ПоследноПоследно
Резултати от 31 до 45 от общо 118
Like Tree52Одобрявам
Panasonic телевизори 2020 / (често задавани въпроси на първа страница)
    #31
    Отговор: Panasonic телевизори 2020 / (често задавани въпроси на първа страница)
    Panasonic TX-55HX940 review
    https://www.homecinemamagazine.nl/20...ie-lcd-led-tv/
    Edge LED with local dimming 8 x 1 zones
    IPS panel
    100/120Hz panel
    Main settings:
    Picture mode: True Cinema
    Backlight: 20-80 *
    Contrast: 90
    Brightness: 0
    Color: 50
    Tint: 0
    Sharpness: 30-50
    Heat Color: Warm2
    Vivid Colors: Off
    Color Remaster: Off
    Adaptive Backlight Control: Middle
    Ambient Sensor: Off / On
    Noise Reduction: Min
    MPEG Remastering: Min
    Resolution Remastering: Middle
    Dynamic Range Remastering: Off
    Intelligent Frame Creation: Minimum
    Sharp Movements: Off
    Contrast Control: Off / Auto
    Gamma: 2.4
    Picture Settings Aspect Ratio: 16: 9 Picture Scan: Off
    #32
    We review the Panasonic HZ2000 4K OLED TV which features a Custom Professional Edition OLED panel, allowing the television to achieve higher peak brightness and APL (Average Picture Level) than conventional OLEDs.
    Topics covered include near-black performance, colour accuracy, motion handling including 120Hz black frame insertion, video processing, HDR including Dolby Vision, as well as input lag for gaming. Unfortunately the HDMI inputs are still 2.0b, with two HDMI 2.1 features (ALLM and eARC) implemented.
    Our review sample is the 65-inch Panasonic TX-65HZ2000B which is the 3-pin-plug UK version with Freeview Play.
    Като всички останали тази година, яркостта(осветеността) е малко по-ниска, отколкото беше миналата година и с пик от 895 нита, при средно 135 нита.
    Този пост е редактиран от hristoslav2; 24-07-20 в 16:58.
    #33
    Panasonic HZ1500 OLED Review
    https://www.avforums.com/reviews/pan...v-review.17726
    We do an OLED vs plasma TV comparison using a Panasonic HZ2000 OLED & a ZT65 plasma.
    Picture quality topics covered include contrast performance, colour accuracy, motion clarity & smoothness, video processing, HDR vs SDR, gaming including input lag, as well as bright-room performance for daytime viewing.
    Our review sample is the 65-inch Panasonic TX-65HZ2000B and the 60-inch Panasonic TX-60ZT65B.
    Този пост е редактиран от hristoslav2; 04-08-20 в 21:53.
    #34
    #35
    Panasonic TX-65HZ2000 review
    https://www.lesnumeriques.com/tv-tel...6583/test.html
    Независимо дали е в режим True True Cinema или Filmmaker (светлината е изключена), Panasonic TV просто показва перфектни цветове. Средната делта Е, измерена на 0.9, е много по-ниска от стойността на 3, под която окото вече не може да различава колориметрични дрейфове. Никой оттенък не надвишава тази стойност от 3.
    С такава крива бързо разбираме, че гамата е просто перфектна. Нивата на сивото се управляват перфектно със средно 2,4, зададени на референтната стойност.
    Същото важи и за управлението на цветовата температура, което е перфектно. Температурната крива е перфектно стабилна за целия спектър и средната стойност, измерена при 6560 К, съвпада с референтната стойност (6500 К). Отново е безупречен за Panasonic, който предлага отлично фабрично калибриране.
    С максимален HDR сигнал при 10 000 cd / m², картографирането на тона на дисплея, използвано от Panasonic, перфектно следва референтната крива EOTF и дори малко прекалено много, което може да доведе до явление на изрязване .от 75% яркост. Panasonic много леко изглажда сигнала над 900 cd / m² до максималния капацитет на телевизора, но той все още е твърде лек. Обекти, показващи яркост по-голяма от 900 cd / m², не могат непременно да бъдат разграничени един от друг; в замяна телевизията напълно използва капацитета си, но ние предпочитаме по-плавно управление на Display Tone Mapping, подобно на това, което LG предлага, като изгладим кривата от 60% до максимума на капацитета на телевизията, за да да бъде в състояние да различи детайлите в най-ярките части на изображението.
    Подобно на миналата година с GZ2000 (952 cd / m²), пиковата светимост, измерена на 951 cd / m², е просто най-доброто, записано в телевизия Oled през 2020 г. Нека си припомним, че други телевизии Oled, всички марки комбинирани, имат таван при 750 cd / m². В абсолютно изражение светещият пик е по-нисък от този, измерен на LCD телевизори с Full Led като Sony 75XG9505 от 2019 г. (1110 cd / m²) и особено далеч зад моделите от висок клас като Sony 65ZF9 (1 ​​940 cd / m² ) от 2019 г. и Samsung 75Q900R ( 2280 cd / m²), но контрастът, осигурен от Oled, позволява да се покаже динамика на екрана, която е просто зашеметяваща, без разцъфналите проблеми, срещани на висок клас LCD телевизори.
    Както в SDR, и този телевизор е перфектно калибриран в HDR. Измервахме средна Delta E от едва 2,1 в режим Filmmaker. Измерването е идентично в режим True Cinema. Следователно показаните цветове се считат за верни на изпратените от източника. Един цвят свижда, че Delta E надвишава 4.
    Ефектите от бандинга (хоризонтални или вертикални ивици) също липсват на нашия тестов модел. Измерихме средното отклонение на хомогенността на бялото през цялата 65-инчов панел само 6%. Този много добър резултат може да се обясни с използването на технологията Oled. Не забравяйте, че окото започва да вижда разлика от 20% от средното отклонение.
    Този пост е редактиран от hristoslav2; 10-08-20 в 16:36.
    #36
    #37
    Този пост е редактиран от hristoslav2; 23-08-20 в 21:51.
    #38
    Panasonic TX-55HZW2004 review
    https://www.homecinemamagazine.nl/20...serie-oled-tv/
    Illuminance: 30-70
    Contrast: 90
    Brightness: 0
    Color: 50
    Tint: 0
    Sharpness: 30-50
    Heat Color: Warm2
    Vivid Colors: Off
    Color Remaster: Off
    Ambient Sensor: On
    MPEG Remaster: Min
    Resolution Remaster: Mid
    Dynamic Range Remaster: Off
    Sharp Motion: Off
    Insert Black Frame: Minimum
    Gamma: 2.4 / 2.2
    Picture Settings
    Aspect Ratio: 16: 9
    Image Scan: Off
    #39
    #40
    Panasonic представи първите си телевизори с Android за Европа
    С HX700 и HX710, Panasonic за първи път в Европа ще предложи телевизори, базирани на Android TV платформата на Google, вместо собствена платформа Firefox (MyHomeScreen).
    HX700 вероятно ще са първите телевизори на Panasonic с Disney +. От друга страна няма да усъвършенствате разширените функции на тунера на Panasonic като TV Anywhere и вътрешно стрийминг.
    Дистанционното управление разчита на Bluetooth и има вграден микрофон за Google Assistant.
    HX700 има черна рамка, докато HX710 има сребърна рамка. Двата ще се предлагат в Европа с размери 43, 50, 55 и 65 инча, считано от октомври / ноември, в зависимост от региона.
    https://www.panasonic.com/it/consume...-55hx700e.html
    TX-55HX700E/TX-55HX710E
    TX-55HX702E/TX-55HX712E
    Според Google Play Console, Android TV Panasonic се продават само в Азия...
    https://play.google.com/apps/publish/signup/
    Нов фирмуер за OLED моделите
    https://av.jpn.support.panasonic.com...20/europe.html
    Update Version Version 3.653
    Update File Name / Size P202_3653.zip / 294,846,894 bytes
    Update Date Sep. 8, 2020
    1. Improve network applications.
    2. Improve system stability.
    Нов фирмуер за LCD моделите
    https://av.jpn.support.panasonic.com...uk_cis_01.html
    Update Version Version 3.353
    Update File Name / Size P202_3353.zip / 294,817,918 bytes
    1, Improve network applications.
    2, Improve system stability.
    Този пост е редактиран от hristoslav2; 10-09-20 в 22:18.
    svetlio1 одобрява това.
    #41
    Време им беше да зарежат Май хоум-а - не че беше лош, но не можаха да накарат никой да пише приложения за нея.
    Сега и ако моднат допълнително Андроид-а и вкарат техните си неща (като TV Anywhere) ще си допълнителен +
    #42
    Друго ме притеснява - производителят на модела..
    Като му гледам дизайна(същият като на турските Sharp преди няколко години)+ комбинацията и разположението на портовете отзад си мисля, че е турски Индекса на картината също е по-нисък от този на HX600.
    Европейското ръковоство на компанията е сбирщина от късогледи...куцо планиране, маркетинг, реклама...
    Нужна е чистка и смяна на значителна част от ръководният екип..
    Panasonic TV 2020
    HX580 HX600 HX700
    HX710
    HX800
    HX810
    HX820
    HX830
    HX900 HX940 HZ980 HZ1000 HZ1500 HZ2000
    43, 50, 55, 65" 43,50, 55" 43, 50, 55, 65" 40, 50, 58, 65" 43, 49, 55, 65" 43, 49, 55, 65, 75" 55, 65" 55, 65" 55, 65" 55, 65"
    Ultra HD 3840x2160
    LED
    1200 Hz RMR
    Vivid Dimming Classic
    HDR10/HLG/Dolby Vision
    HDR Brightness Enhancer
    1 x DVB-T/T2/C/S/S2
    Audio 2.0 / 2 x 10 W
    Surround
    Dolby Atmos
    EPG
    TV Anywhere
    In-House TV Streaming (client)
    Hbb TV 2.0.2
    3x HDMI 2.0b / ARC /
    2x USB 2.0
    1x Headset Out
    1x Optical Out
    1x PC in (VGA)
    1x Component/Composit In(RCA)
    Wifi
    1x CI+ 1.4, ECP
    Central leg
    Ultra HD 3840x2160
    Direct LED
    1200 Hz RMR
    Adaptive Backlight Dimming
    1 x DVB-T/T2/C/S/S2
    Surround
    Dolby Atmos
    Google Assistant
    Amazone Alexa
    EPG
    TV Anywhere
    Hbb TV 2.0.2
    2x USB 2.0
    1x Headset Out
    1x Optical Out
    1x PC in (VGA)
    Wifi
    1x CI+ 1.4, ECP
    Bipolar feet
    Ultra HD 3840x2160
    Direct LED
    1000 Hz RMR
    1 x DVB-T/T2/C/S/S2
    Surround
    Android 9,0 Pie
    Google Assistant
    Chromecast
    Amazone Alexa
    EPG
    Hbb TV 2.0.2
    4x HDMI 2.0b / ARC /
    2x USB 2.0
    1x Headset Out
    1x Optical Out
    1x PC in (VGA)
    Wifi
    Bluetooth
    1x CI+ 1.4, ECP
    Central leg
    Ultra HD 3840x2160
    Edge LED Bright Panel Plus
    HCX processor
    1600 Hz BMR IFC
    Local Dimming Classic
    HDR10+/HLG/Dolby Vision/HDR Photo
    Dynamic HDR Effect
    Brilliant Contrast
    Wide Colour Spectrum
    1x DVB-T/T2/C/S/S2
    PVR + Timeshift
    Cinema Surround
    Dolby Atmos
    My Home Screen 5.0
    Google Assistant
    Amazone Alexa
    Voice Guidance
    EPG
    Swipe & Share
    Easy Mirroring
    TV Anywhere
    Hbb TV 2.0.2
    PIP / PAP / PAT
    3x HDMI 2.0b / ARC
    2x USB (1x 3.0 / 1x 2.0)
    1x Headset Out
    1x Optical Out
    1x Component/Composit In (RCA)
    Wifi
    Bluetooth HID/HOGP/A2DP
    Bluetooth Audio Link
    1x CI+, ECP
    Ultra HD 3840x2160
    LED Cinema Display Pro
    HCX processor
    1600 Hz BMR IFC
    Dynamic HDR Effect
    Brilliant Contrast
    1x DVB-T/T2/C/S/S2
    PVR + Timeshift
    Cinema Surround
    Dolby Atmos
    My Home Screen 5.0
    Google Assistant
    Amazone Alexa
    Voice Guidance
    EPG
    Swipe & Share
    Easy Mirroring
    TV Anywhere
    Hbb TV 2.0.2
    PIP / PAP / PAT
    3x HDMI 2.0b / ARC
    3x USB (1x 3.0 / 2x 2.0)
    1x Headset Out
    1x Optical Out
    Wifi
    1x CI+ 1.4, ECP
    Lat feet. 2 Pos. [43 "1 Pos.]
    Ultra HD 3840x2160
    HCX Pro Intelligent Processor
    2200 Hz BMR IFC
    Local Dimming Pro Intelligent
    Dynamic HDR Effect
    Supreme Contrast
    2x DVB-T/T2/C/S/S2
    PVR + Timeshift
    Cinema Surround
    Dolby Atmos
    My Home Screen 5.0
    Google Assistant
    Amazone Alexa
    Voice Guidance
    EPG
    Swipe & Share
    Easy Mirroring
    TV Anywhere
    In-House TV Streaming (client / server)
    Hbb TV 2.0.2
    2T PIP / PAP / PAT
    4x HDMI 2.0b / ARC
    1x Headset Out
    1x Optical Out
    Wifi
    1x CI+ 1.4, ECP
    Lat feet. 2 Pos. [43" 1 Pos. / 75" Cent.]
    Ultra HD Premium 3840x2160
    Ultra HD OLED
    Smooth Motion Drive
    HDR10+/HLG/Dolby Vision IQ/HLG Photo
    Dynamic HDR Effect
    Ultimate Contrast
    FilmMaker Mode
    ISF Mode
    Netflix Calibrated Mode
    2x DVB-T/T2/C/S/S2
    PVR +Timeshift
    Audio 2.0 / 30 W
    Cinema Surround Pro
    Dolby Atmos
    My Home Screen 5.0
    Google Assistant
    Amazone Alexa
    Voice Guidance
    EPG
    Swipe & Share
    Easy Mirroring
    TV Anywhere
    Hbb TV 2.0.2
    2T PIP / PAP / PAT
    4x HDMI 2.0b / eARC
    1x Headset Out
    1x Optical Out
    Wifi
    1x CI+ 1.4, ECP
    Central leg
    Master HDR OLED
    Smooth Motion Drive Pro
    Dynamic HDR Effect
    Ultimate Contrast
    FilmMaker Mode
    ISF Mode
    2x DVB-T/T2/C/S/S2
    PVR + Timeshift
    Audio 2.0 / 30 W
    Cinema Surround Pro
    Dolby Atmos
    My Home Screen 5.0
    Google Assistant
    Amazone Alexa
    Voice Guidance
    EPG
    Swipe & Share
    Easy Mirroring
    TV Anywhere
    Hbb TV 2.0.2
    2T PIP / PAP / PAT
    4x HDMI 2.0b / eARC
    1x Headset Out
    1x Optical Out
    Wifi
    1x CI+ 1.4, ECP
    Swivel round central leg
    Master HDR OLED
    Dynamic HDR Effect
    Ultimate Contrast
    FilmMaker Mode
    ISF Mode
    2x DVB-T/T2/C/S/S2
    PVR + Timeshift
    Audio 2.1.2 / 80W
    360 ° SoundScape
    Dolby Atmos
    My Home Screen 5.0
    Google Assistant
    Amazone Alexa
    Voice Guidance
    EPG
    Swipe & Share
    Easy Mirroring
    TV Anywhere
    Hbb TV 2.0.2
    2T PIP / PAP / PAT
    4x HDMI 2.0b / eARC
    1x Headset Out
    1x Optical Out
    Wifi
    1x CI+ 1.4, ECP
    Master HDR OLED Professional
    Dynamic HDR Effect
    Ultimate Contrast
    FilmMaker Mode
    ISF Mode
    CalMAN Ready calibration
    2x DVB-T/T2/C/S/S2
    PVR + Timeshift
    Audio 3.0.2 Technics / 140W
    360 ° SoundScape Pro
    Dolby Atmos
    My Home Screen 5.0
    Google Assistant
    Amazone Alexa
    Voice Guidance
    EPG
    Swipe & Share
    Easy Mirroring
    TV Anywhere
    Hbb TV 2.0.2
    2T PIP / PAP / PAT
    4x HDMI 2.0b / eARC
    1x Headset Out
    1x Optical Out
    Wifi
    1x CI+ 1.4, ECP
    Solid rectangular central leg
    Variations:
    HX600: Black
    HX603: Silver
    HX700: Black frame
    HX702:
    HX710: Silver frame
    HX712:
    HX800: Bipolar feet + Cinema Surround
    HX810: Flat U-shaped central leg + Cinema Surround Pro
    HX820: Solid rectangular central leg + Cinema Surround Pro
    HX830: Round U-shaped central leg + Cinema Surround Pro
    Този пост е редактиран от hristoslav2; 11-09-20 в 21:02.
    #43
    М-да , сега му видях и дистанционното - няма как да е Панасоник това
    #44
    От две години чрез OEM производители, Panasonic предлага модели с Андроид на някои азиатски пазари(5, 6, 7 серии) - Малайзия, Виетнам, Индонезия, Индия
    https://www.panasonic.com/my/consume...levisions.html
    https://www.panasonic.com/vn/consume.../viera-tv.html
    https://www.panasonic.com/id/consume...ns/led-tv.html
    https://www.panasonic.com/in/consume...ndroid-tv.html
    на следните платформи
    Panasonic Android TV R1 PANASONIC TV Realtek RTD2841
    Panasonic Android TV R2 PANASONIC TV Realtek RTD2851
    Panasonic Asia globe_ap PanasonicTV Mediatek MT5596
    Panasonic GS655 shibuya GS655 Mstar T16
    Panasonic GX655 SW3_ATV GX655 Mediatek MT5597
    Panasonic GX655 SW3_ATV PanasonicTV Mediatek MT5597
    Panasonic Panasonic TV SW3H_ATV GX655 Mediatek MT5597
    http://bestandroidtoroot.com/post/pa...-gs655-shibuya
    http://anpsedic.org/article-frp/panasonic-gs655-shibuya
    http://gofirmware.com/post/panasonic-gs655-shibuya
    https://docs.google.com/spreadsheets...2839&range=A:F
    Този пост е редактиран от hristoslav2; 12-09-20 в 20:43.
    #45
    Panasonic TX-55HZ1000B review
    https://www.avforums.com/reviews/pan...v-review.17917
    Verdict
    As you would imagine the HZ1000 is exactly the same TV as the HZ1500 minus the Atmos speakers attached. Image quality is identical which means this is the perfect ‘monitor only’ option for those who can’t stretch to the flagship, but still want superb image accuracy right out of the box. It should be pointed out that the HZ980 is not the same panel or processor package, so will not match the HZ1000/HZ1500.
    I’m always asked what the best picture settings are on TVs I review and with the Panasonics, this year, it has to be Filmmaker Mode. The accuracy on offer will have professional calibrators anxious.
    There is no such thing as the perfect TV, a mantra I have used for nearly 20 years now, and with the HZ1000 there are features and options missing. There are no HDMI 2.1 inputs but it does support eARC and ALLM HDMI 2.1 features via its HDMI 2.0b ports and with a decent 22ms input lag it does well with console gaming in HDR, but it is not the most advanced in terms of gaming compatibility like the LG CX. It also has My Home Screen V5.0 for its smart platform which isn’t as slick as the WebOS of LG, (however, it does have Freeview Play, unlike the CX). Plus, we really do not like the Dolby Vision IQ preset with image manipulation features switched on and greyed out. That doesn’t follow the creator’s intent message and needs to be fixed.
    However, with all that said, the Panasonic HZ1000 is an excellent OLED TV for critical movie and TV viewing with superb image accuracy to the industry standards. Watch it in Filmmaker Mode and you can be certain that you are seeing content as it was intended to be seen, and who wouldn’t want that from their TV?
    Only the flagship HZ2000 will best the HZ1000 (and HZ1500) for movie fans, but that also comes with a flagship price tag. The HZ1000 is an excellent entry point to cinematic OLED for those who already have the home cinema sound system. It comes highly recommended.
  1. Отговори: 185
    Последно: 26-11-21, 00:33
  2. Отговори: 608
    Последно: 04-05-15, 23:14
  3. Отговори: 2279
    Последно: 04-02-15, 10:01
  4. Отговори: 1579
    Последно: 07-11-13, 19:57
  5. Отговори: 1138
    Последно: 03-01-13, 19:35
