Отговор: Panasonic телевизори 2020 / (често задавани въпроси на първа страница)
Panasonic TX-58HX800B review
https://www.avforums.com/reviews/pan...v-review.18013
https://www.avforums.com/image.php?i...406.jpg|1280|0
Verdict
There is no major performance change with the new HX800 over last year’s GX800 and no added features either, but it is still a strong and able TV for normal living room TV duties. Despite Panasonic’s Hollywood branding for their OLED TV line-up, the HX800 is not as well suited to darkroom viewing and critical movie watching. The use of edge-lit VA LCD technology gets in the way of producing cinematic images in the dark and there are issues visible in such environments and use. However, the Panasonic HX800 is really rather good at the traditional job of a living room workhorse with SDR TV and film content.
Image accuracy out of the box in the True Cinema image preset is very good with strong Rec.709 colour performance for SD and HD TV and film content, with decent image sharpness and depth, and strong skin tones along with adequate black levels. There is a little black crush visible in some scenes, but nothing that will impact too much within a well-lit viewing environment. Gaming performance is also decent with a good low input lag of 15ms for SDR and HDR gaming which should be fine for all console gamers.
HDR is a little disappointing on the HX800, but this is due to a lack of peak brightness capabilities and the use of edge-lit technology. Most of the competition is identical with reduced brightness capabilities for peak brightness performance, but colours are wide-ish and the image performance is balanced. Just don’t expect specular highlights to pop as they do on an OLED or FALD LCD (at a much higher cost).
The Panasonic TX-58HX800B is a well made and competitive edge-lit LCD TV that is designed to be used in normal well-lit living room environments and used for TV shows, gaming and movies. It doesn’t have the brightest or most dynamic HDR performance and watching in the dark is a challenge due to the edge-lit technology, but for everything else, it manages to put in a well rounded and compelling performance that will suit the mainstream audience looking for a mid-level LCD TV at this price point. The Panasonic will also have to compete a little harder this year in a more competitive sector of the market and it does seem a little bit expensive compared to the direct rivals. Plus, rivals now offer the same multi-HDR support, image accuracy and slightly better Smart TV systems, such as Android TV on the TCL with more screen real estate for similar money. Overall, the Panasonic is a solid TV for everyday living room use and if that is what you are looking for, it is worthy of a demo.
Panasonic TX-55HZ980 review
https://www.homecinemamagazine.nl/20...serie-oled-tv/
https://www.homecinemamagazine.nl/wp...600x338@2x.jpg
Picture mode: True Cinema
Illuminance: 30-70
Contrast: 90
Brightness: 0
Color: 50
Tint: 0
Sharpness: 30-50
Heat Color: Warm2
Vivid Colors: Off
Color Remaster: Off
Ambient Sensor: On
Noise Reduction: Min
MPEG Remaster: Min-Mid
Resolution Remaster: Mid
Dynamic Range Remaster: Off
Intelligent Frame Creation: Minimum or higher
Contrast Control: Off / Auto
Gamma: 2.4 / 2.2
Picture Settings Aspect Ratio: 16: 9
Image Scan: Off
Panasonic TX-65HZ2000E test,calibration
https://prohardver.hu/teszt/panasoni...ic_hz2000.html
Ideal settings:
Brightness level: 55
Contrast: 90
Brightness: 2
Saturation: 50
Hue: 0
Color temperature:warm 2
Bright colors: No
Color transformation: Maximum
Environmental sensor: No
Environment sensor: No
Noise abatement: No
MPEG correction: No
Resolution correction: No
Din. domain conversion: No
Intelligent Frame Creation: No
Contrast control: No
Gamma: 2.2
Pixel shift: yes
| Профил / настройка | Dynamic | Filmmaker | Real Cinema | Game | Cinema |
| Яркост (бяла точка) | 214,2 cd / m² | 161,3 cd / m² | 84,1 cd / m² | 173,4 cd / m² | 193,5 cd / m² |
| Яркост (черна точка) | 0 cd / m² | 0 cd / m² | 0 cd / m² | 0 cd / m² | 0 cd / m² |
| Контрастно съотношение | Безкраен | Безкраен | Безкраен | Безкраен | Безкраен |
| Най-голямата делта Е | 8.28 | 5.03 | 3.2 | 6.61 | 5.2 |
| Средна делта E | 3.97 | 1.51 | 1.52 | 2.2 | 1.82 |
| Цветна температура | 11 500 K | 6400 K | 6700 K | 9000 K | 7700 К. |
| Профил / настройка | Normal | Professional 1. | Professional 2. | Professional photo | Sport |
| Яркост (бяла точка) | 204,1 cd / m² | 153,9 cd / m² | 82,9 cd / m² | 84,8 cd / m² | 186,1 cd / m² |
| Най-голямата делта Е | 6.25 | 2.02 | 12.73 | 0,62 | 5.06 |
| Средна делта E | 2.39 | 0,58 | 4.2 | 0,62 | 5.06 |
| Цветна температура | 9000 K | 6400 K | 6600 K | 6400 K | 12 600 K |
Как да проверим за инсталираният процесор в нашият телевизор ?
Отворете своят YouTube на ТВ и влезте в Настройки -> Версия на приложения.
В дясно на ред Устройство, ще видите версията на процесора, фирмуера.
https://forum.ixbt.com/post.cgi?id=a...369:1315:1.jpg
https://forum.ixbt.com/post.cgi?id=a...369:1316:1.jpg
Модел на телевизора / процесор / година
платформа, процесор, версия на фирмуера
Чакам вашите снимки :)
Panasonic 2019
SoC: MediaTek MT5813QFIQ (variant of MT559x)
Таблица с използваните матрици в телевизори Panasonic модели 2020
| Серия / диагонал | 32" | 40" | 43" | 49" | 50" | 55" | 58" | 60" | 65" | 70" | 75" | 80" | 82" | 85" | 86" | 90" |
| HX940 | | | IPS | IPS | | IPS | | | IPS | | MVA | | | | | |
| HX900 | | | IPS | IPS | | IPS | | | IPS | | | | | | | |
| HX830/820/810/800 | | MVA | | | MVA | | MVA | | MVA | | | | | | | |
| HX700/710 (Vestel) | | | MVA | | MVA | MVA | | | MVA | | | | | | | |
| HX600 (Vestel) | | | MVA | | MVA | MVA | | | MVA | | | | | | | |
| HX580/585 (Vestel) | | MVA | | MVA | MVA | | | MVA | | | | | | | | |
| HS400 (Hisense ?) | - | | - | | | | | | | | | | | | | |
HX700 - Android
HS400 - Android
Появиха се първите два Wi-Fi сертификата на модели телевизори 2021
https://www.wi-fi.org/product-finder...&companies=292
JZ - OLED
JH - LCD Android
За по ясно, моделният код ще изглежда нещо такова
TX-55JZ1000E
TX-65JZ1000E
TX-50JH800E
Panasonic обяви два прозрачни OLED дисплея, премиера през декември.
Японската компания от много години развива идеята за почти напълно прозрачен екран.
https://news.panasonic.com/global/pr...n201120-3.html
Прозрачният OLED дисплеен модул, както производителят нарече устройството му, планиран за декември 2020 г., всъщност е по-скоро монитор и обикновен дисплей, отколкото телевизор. Той ще бъде пуснат в два варианта, с етикети TP-55ZT100 и TP-55ZT110, и ще бъде предназначен строго за бизнес пазара - за използване във фоайета на хотели, витрини или музеи. OLED панелите и в двата варианта ще показват изображението в резолюция 1080p и ще бъдат оборудвани с много скромни комплекти конектори: един HDMI 1.4 порт и порт за слушалки (3.5 мм) . Те също няма да получат никакви функции на Smart TV или операционна система за управление на съдържанието. Моделът TP-55ZT110 ще получи специален потъмняващ слой , който -намалява пропускането на светлина през панела отзад, като прави прожектираното изображение ясно видимо дори в среда, осветена от външна светлина Фонът не е прозрачен, така че прожектираното изображение е ясно видимо, с висок контраст и дълбоки черни цветове и без смущаващи отражения или отблясъци.
Очаква се прозрачните OLED дисплеи на Panasonic да се предлагат през декември в Австралия, Нова Зеландия и Сингапур. Те ще струват $ 7 200. Все още няма информация за наличието на тези интригуващи устройства на други пазари.
https://www.youtube.com/watch?v=JM01...ture=emb_title
След седмица настройки (ползвам от видео на един хърватин с различни дребни вариации, който иначе ги продава за по 5 евро) и различни режими на ползване с новозакупения Panasonic TX-50HX830E (1199лв. 5г. гаранция) мога да кажа, че за момента съм много доволен. Доста приемлива картина дори и на най-лошите СД канали от СТБ на местния доставчик, напълно прилична картина, като за местна ТВ на т.н. HD канали. Спорт (футбол, тенис, хокей, баскетбол, снукър, ски) изглеждат приятно, само Ф1 остана да гледам тези дни. Филмите от НТРС (за момента имам останало само 1080р съдържание) са отлични след ъпскейл от ТВ. 4K от youtube вече е супер. Това разбира се от моята гледна точка. Не претендирам, че е общовалидно. Може и изискванията ми да не са много големи. ОС на ТВ е бърз и стабилен за сега. За хората, които ползват много приложения за андроид от гугъл стор няма да им хареса.
Отговор: 5 години гаранция
https://www.panasonic.com/bg/consume...A4g1Ntiv0mznEo
Това вече си е новина:)Само заради системата им не си взимах Panasonic, защото дори един филм не може да изгледаш.
