| Philips TV 2017 - european models |
Model Size-Series __________ | Panel Type
(vendor) __________________ | bit of
_________ | Panel
Resolution
_________ | Subpixel structure
_______ | Panel frequency | Local Dimming
___________ | MCFI Motion Clarity Frame Interpolation (Piqture Natural Motion) | BFI (black frame insertion)
blinking backlight | Type backlight
_________ | HDR
______________ | Gammut
DCI-P3
_______ | Series
Model ________ |
65POS9603 | AM-OLED (LG Display) | 10-bit | 3840x2160 | WRGB | 120/100Hz | No | x 4 (100Hz) | 100Hz | - | 780 cd/m2
HDR10, HLG | 99% | 65" 9603 |
| 9002 series |
65POS9002 | AM-OLED (LG Display) | 10-bit | 3840x2160 | WRGB | 120/100Hz | No | x 4 (100Hz) | 100Hz | - | 750 cd/m2
HRD10, HLG | 99% | 55" 9002 |
55POS9002 | AM-OLED (LG Display) | 10-bit | 3840x2160 | WRGB | 120/100Hz | No | x 4 (100Hz) | 100Hz | - | 750 cd/m2
| 8602 series |
65PUS8602 | a-si TFT MVA QDCF (Samsung Display Corporation) | 8-bit+FRC | 3840x2160 | RGB | 120/100Hz | Yes | x 4 (100) | 100Hz | Edge LED | max 1000 cd/m2
HDR10, HLG | 97% | 65" 8602 |
55PUS8602 | a-si TFT MVA QDCF (Samsung Display Corporation) | 8-bit+FRC | 3840x2160 | RGB | 120/100Hz | Yes | x 4 (100) | 100Hz | Edge LED | 700 cd/m2
HDR10, HLG | 97% | 55" 8602 |
| 8102 series |
65"PUS8102 | a-si TFT MVA (Samsung Display Corporation) | 8-bit+FRC | 3840x2160 | RGB | 120/100Hz | Yes 128 Dimming Zone | x 4 (100) | 100Hz | FALD | 1100 cd/m2
HDR 10, HLG | 85% | 65" 8102 |
| 7502 series |
65PUS7502 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 3840x2160 | RGB | 120/100Hz | Yes
Vertical | x 4 (100) | 100Hz | Edge LED | 400 cd/m2
HDR 10, HLG | 85% | 65" 7502 |
55PUS7502 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 3840x2160 | RGB | 120/100Hz | Yes
HDR 10, HLG | 85% | 55" 7502 |
49PUS7502 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 3840x2160 | RGB | 120/100Hz | Yes
HDR 10, HLG | 85% | 49" 7502 |
| 7272 series |
55PUS7272 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 3840x2160 | RGB | 120/100Hz | Yes | x 2 (50) | - | Edge LED | 400 cd/m2
HDR 10, HLG | 72% | 55" 7272 |
49PUS7272 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 3840x2160 | RGB | 120/100Hz | Yes | x 2 (50) | - | Edge LED | 400 cd/m2
HDR 10, HLG | 72% | 49" 7272 |
43PUS7202 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 3840x2160 | RGB | 120/100Hz | Yes | x 2 (50) | - | Edge LED | HDR 10, HLG | 72% | 43" 7202 |
| 6482 series |
55" 6482 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 3840x2160 | RGB | 60/50Hz | Yes | x 2 (50) | - | Direct LED | 400 cd/m2
HDR 10, HLG | 85% | 55" 6482 |
49" 6482 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 3840x2160 | RGB | 60/50Hz | Yes | x 2 (50) | - | Direct LED | 400 cd/m2
HDR 10, HLG | 85% | 49" 6482 |
| 6432 series |
55" 6432 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 3840x2160 | RGB | 60/50Hz | Yes | x 2 (50 | - | Direct LED | 350 cd/m2
HDR 10, HLG | 72% | 55" 6432 |
49" 6432 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 3840x2160 | RGB | 60/50Hz | Yes | x 2 (50) | - | Direct LED | 350 cd/m2
HDR 10, HLG | 72% | 49" 6432 |
43" 6432 | a-si TFT S-IPS (LG Display) | 8-bit | 3840x2160 | RGB | 60/50Hz | Yes | x 2 (50) | - | Direct LED | 350 cd/m2
HDR 10, HLG | 72% | 43" 6432 |
| 6412 series |
65" 6412 | a-si TFT A-MVA (Acer Unipac Optronics) | 8-bit+FRC | 3840x2160 | RGB | 60/50Hz | Yes | x 2 (50) | - | Direct LED | 370 cd/m2
HDR 10, HLG | 72% | 65" 6412 |
55" 6412 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 3840x2160 | RGB | 60/50Hz | Yes | x 2 (50) | - | Direct LED | 350 cd/m2
HDR 10, HLG | 72% | 55" 6412 |
49" 6412 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 3840x2160 | RGB | 60/50Hz | Yes | x 2 (50) | - | Direct LED | 350 cd/m2
HDR 10, HLG | 72% | 49" 6412 |
43" 6412 | a-si TFT H-IPS (Beijing Opto electronics) | 8-bit | 3840x2160 | RGB | 60/50Hz | Yes | x 2 (50) | - | Direct LED | 350 cd/m2
HDR 10, HLG | 72% | 43" 6412 |
| 6402 series |
| 32" 6402 | a-si TFT IPS (Beijing Opto Electronics) | 8-bit | - | RGB | 60/50Hz | Frame Dimming | x 2 (50) | - | Direct LED | 350 cd/m2
HDR 10, HLG | 72% | 32" 6402 |
| 6262 series |
| 65" 6262 | a-si TFT A-MVA (Acer Unipac Optronics) | 8-bit+FRC | 3840x2160 | RGB | 60/50Hz | Frame Dimming | x 2 (50) | - | Direct LED | 370 cd/m2
HDR 10, HLG | 72% | 65" 6262 |
| 55" 6262 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 3840x2160 | RGB | 60/50Hz | Frame Dimming | x 2 (50) | - | Direct LED | 350 cd/m2
HDR 10, HLG | 72% | 55" 6262 |
| 50" 6262 | a-si TFT A-MVA (Acer Unipac Optronics) | 8-bit+FRC | 3840x2160 | RGB | 60/50Hz | Frame Dimming | x 2 (50) | - | Direct LED | 350cd/m2
HDR 10, HLG | 72% | 50" 6262 |
| 49" 6262 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 3840x2160 | RGB | 60/50Hz | Frame Dimming | x 2 (50) | - | Direct LED | 350cd/m2
HDR 10, HLG | 72% | 49" 6262 |
43" 6262 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 3840x2160 | RGB | 60/50Hz | Frame Dimming | x 2 (50) | - | Direct LED | 350 cd/m2
HDR 10, HLG | 72% | 43" 6262 |
| 6162 series |
| 65" 6162 | a-si TFT A-MVA (Acer Unipac Optronics) | 8-bit+FRC | 3840x2160 | RGB | 60/50Hz | Frame Dimming | - | - | Direct LED | 350 cd/m2
HDR 10, HLG | 72% | 65" 6162 |
| 55" 6162 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 3840x2160 | RGB | 60/50Hz | Frame Dimming | - | - | Direct LED | 350 cd/m2
HDR 10, HLG | 72% | 55" 6162 |
| 50" 6162 | a-si TFT A-MVA (Acer Unipac Optronics) | 8-bit+FRC | 3840x2160 | RGB | 60/50Hz | Frame Dimming | - | - | Direct LED | 350cd/m2
HDR 10, HLG | 72% | 50" 6162 |
| 49" 6162 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 3840x2160 | RGB | 60/50Hz | Frame Dimming | - | - | Direct LED | 350cd/m2
HDR 10, HLG | 72% | 49" 6162 |
| 43" 6162 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 3840x2160 | RGB | 60/50Hz | Frame Dimming | - | - | Direct LED | 350cd/m2
HDR 10, HLG | 72% | 43" 6162 |
| 5362 series |
32" 5362 | a-si TFT S-IPS (Beijing opto Electronics) | 8-bit | 1920x1080 | RGB | 60/50Hz | Frame Dimming | [- | - | Direct LED | 280 cd/m2 | 72% | 32" 5362 |
| 5302 series |
| 49" 5302 | a-si TFT IPS (Beijing Opto Electronics) | 8-bit | 1920x1080 | RGB | 60/50Hz | Frame Dimming | - | - | Edge LED | 280 cd/m2 | 72% | 49" 5302 |
| 43" 5302 | a-si TFT S-IPS (LG Display) | 8-bit | 1920x1080 | RGB | 60/50Hz | Frame Dimming | - | - | Edge LED | 280 cd/m2 | 72% | 43" 5302 |
| 32" 5302 | a-si TFT H-IPS (Beijing Opto Electronics) | 8-bit | 1366x768 | RGB | 60/50Hz | Frame Dimming | - | - | Edge LED | 280 cd/m2 | 72% | 32" 5302 |
| 4232 series |
22" 4232 | a-si TFT H-IPS (Beijing Opto Electronics) | 8-bit | 1920x1080 | RGB | 60/50Hz | - | - | - | Edge LED | 280 cd/m2 | 72% | 22" 4232 |
| 4132 series |
| 49" 4132 | a-si TFT IPS (Beijing Opto Electronics) | 8-bit+FRC | 1920x1080 | RGB | 60/50Hz | - | - | - | Direct LED | 280 cd/m2 | 72% | 49" 4132 |
| 43" 4132 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 1920x1080 | RGB | 60/50Hz | - | - | - | Direct LED | 280 cd/m2 | 72% | 43" 4132 |
| 32" 4132 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 1920x1080 | RGB | 60/50Hz | - | - | - | Direct LED | 280 cd/m2 | 72% | 32" 4132 |
| 32" 4132 | a-si TFT H-IPS (Beijing Opto electronics) | 8-bit+FRC | 1366x768 | RGB | 60/50Hz | - | - | - | Direct LED | 280 cd/m2 | 72% | 32" 4132 |
| 4112 series |
43" 4112 | a-si TFT S-IPS (LG Display) | 8-bit+FRC | 1920x1080 | RGB | 60/50Hz | - | - | - | Edge LED | 260cd/m2 | 72% | 43" 4112 |
32" 4112 | a-si TFT MVA (Samsung Display Corporation) | 8-bit | 1366x768 | RGB | 60/50Hz | - | - | - | Edge LED | 230 cd/m2 | 72% | 32" 4112 |
| 4032 series |
| 32" 4032 | a-si TFT H-IPS (Beijing Opto Electronics) | 8-bit | 1366x768 | RGB | 60/50Hz | - | - | - | Edge LED | 280 cd/m2 | 72% | 32" 4032 |
| 24" 4032 | a-si TFT H-IPS (Beijing Opto Electronics) | 8-bit | 1920x1080 | RGB | 60/50Hz | - | - | - | Edge LED | 280 cd/m2 | 72% | 24" 4032 |
| 24" 4032 | a-si TFT H-IPS (Beijing Opto Electronics) | 8-bit | 1366x768 | RGB | 60/50Hz | - | - | - | Edge LED | 280 cd/m2 | 72% | 24" 4032 |
| 4022 series |
24" 4022 | a-si TFT H-IPS (Beijing Opto Electronics) | 8-bit | 1920x1080 | RGB | 60/50Hz | - | - | - | Edge LED | 250 cd/m2 | 72% | 24" 4022 |
24" 4022 | a-si TFT H-IPS (Beijing Opto Electronics) | 8-bit | 1366x768 | RGB | 60/50Hz | - | - | - | Edge LED | 250 cd/m2 | 72% | 24" 4022 |
| 22" 4022 | a-si TFT H-IPS (Beijing Opto Electronics) | 8-bit | 1366x768 | RGB | 60/50Hz | - | - | - | Edge LED | 250 cd/m2 | 72% | 22" 4022 |
