Страница 70 от 75 ПърваПърва ... 20606869707172 ... ПоследноПоследно
Резултати от 1,036 до 1,050 от общо 1122
Like Tree145Одобрявам
Samsung Телевизори 2015
    #1036
    Отговор: Samsung Телевизори 2015
    Новият начин за влизане в сервизно меню - в режим стенд бай, mute 1-8-2, бутона за пускане
    UЕ50ЈU6800: 50D6АU0ТЈ -> D=Іnnоluх , VА, 6=50Нz раnеl
    UЕ55ЈU6800: 55В6АU0ТЈ -> В=ВОЕ, ІРЅ-?, 6=50Нz раnеl
    UЕ60ЈU6800: 60Н6АU0ТЈ -> Н=Ѕhаrр, Vа, 6=50Нz раnеl
    Product Diagonal Resolution Refresh Rate Smart OS Backlight LCD Type Screen Finish Remote 3D Type Curved Wide Color Gamut LC Matrix
    Samsung J4000 28" 32" 720p 50/60 Hz Direct IPS Semi-gloss Basic 28J4100 - LS02
    32J4100 - UD02, 32A6AH1S - Samsung?
    LF07
    Samsung J5000 1080p 50/60 Hz Direct IPS (except 50") Semi-gloss Basic 32J5100 - MS02, 32H6AF0V- AUO
    32J5200 - TS01
    40J5100 - MU02, 40H6AF0V - Sharp
    48J5100 - TU01, 48A6AF0V - Samsung
    Samsung J5500 1080p 50/60 Hz Tizen Direct VA Semi-gloss Basic 32J5500 - ED01, 32B6AF0VJ - Samsung PLS
    40J5510 - HS01, 40H6AF0VJ - Sharp
    40J5530 - HS01, 40H6AF0VJ - Sharp
    48J5530 - ES04, 48B6AF0V - Samsung PLS
    48J5510 - TS01, 48A6AF0VJ - Samsung
    48J5530 - ES04 (PLS)
    50J5500 - DH01, 50R6AF0V
    Samsung J6200 1080p 100/120 Hz Basic Direct VA Semi-gloss Basic 48J6200 - US02
    Samsung J6300 1080p 100/120 Hz Tizen Direct VA Semi-gloss Basic 32J6300 - TD01, 32A1AF0V, T-CON H32A1F610 - Samsung
    40J6330 - VS04, 40A1AF0V, H40A1F608 - ? US03
    55J6300 - DH01, 55R1AF0V
    48J6330 - TS01, 481A1F0V, H48A1F604 - Samsung, US02
    48JU6450 - TH01, 48A6AU0VJ, J48A6U0F9 - Samsung
    40J6690 - TD0140J6590 - TH01, 40A1AF0WJ, J40A1F01D - Samsung
    Ultra HD
    Samsung JU6500 4k 50/60 Hz Tizen Direct VA Semi-gloss Basic 40JU6400 - TD01, 40A6AU0VJ, J40A640F8 - Samsung
    40JU6450 - TD01, 40A6AU0VJ, J40A640F8 - Samsung
    40JU6600 - TD01
    40JU6690 - TD01, 40A6AU0WJ, J40A6U0C9 - Samsung
    Samsung JU6800 4k 50/60 Hz Tizen Direct VA Semi-gloss Basic 55JU6690 - TH01
    Samsung JU7000 4k 100/120 Hz Tizen Direct VA Glossy Smart Active
    Samsung JU7500 4k 100/120 Hz Tizen Direct VA Glossy Smart Active
    UltraHd + Quantum Dots
    Samsung JS7000 50" 4k 50/60 Hz Tizen Direct IPS (only 55") Semi-gloss Basic
    Samsung JS8500 48" 4k 100/120 Hz Tizen Edge VA Glossy Smart Active
    Samsung JS9000 48" 4k 100/120 Hz Tizen Edge VA Glossy Smart Active
    Samsung JS9500 65" 4k 100/120 Hz Tizen Full-Array VA Glossy Smart Active
    Що се отнася до матриците при samsung телевизорите - има едно малко стикерче залепено отстрани отзад или отдолу..Започва с две буквички обозначаващи панела
    Beijing Optoelectronics(BOE) - обикновенно в 4 серия:
    EH..
    GD..
    FP..
    ES..
    Chi Mei Optoelectronics (в 5 серия)
    CD..
    CH..
    ND..
    NH..
    CN..
    AU Optronics (5-6 серия, диагонали 55-65)
    AH..
    AS..
    AA..
    AC..
    BH..
    MH..
    MS..
    YH..
    Sharp
    IS..
    HH..
    HS..
    Samsung
    TD..
    TH..
    TU..
    TS..
    UD..
    UF..
    UH..
    US..
    WH..
    SS..
    SQ..
    Samsung Wall Mount, DLP Color Wheel, TV Lamp, Bulb, Remote Control, Replacement Lamps
    Този пост е редактиран от hristoslav2; 17-11-15 в 16:50.
    soon одобрява това.
    #1037
    Яко мазало както винаги с панелите при моя любим Samsung.
    Dec 2010
    #1038
    Впечатления от firmware 2790 ?
  5. Pat
    Pat е офлайн
    Senior Member Аватара на Pat
    Oct 2003
    #1039
    На H7000 серията не виждам никаква разлика.
    Aug 2010
    #1040
    Цитат Първоначално публикувано от satmann Виж публикацията
    Мдааа...., наскоро инсталирах уж последната версия на фърмуера за моя F6400 - 2112.4, като при него всичко си работи - има само промени в Смарт хъба и странно, но за пръв път телевизора започна да се изключва около 10-15 секунди след натискане на червения бутон на дистанционното...! Не знам, дало този ефект е само при мен, но днес гледам, че на сайта за поддръжка има "НОВ" фърмуер от 6.11.2015, като това е предишната версия - : 2111.1. Същевременно при онлайн проверката за нова актуализация не дава нищо и това е нормално - тази версия е по-ниска. Както и да е реших да пробвам - свалих Версия : 2111.1 от сайта, но при опит да я инсталирам, съвсем очаквано не се инсталира.....!? От Самсунг продължават да ни изненадват!
    40 F6400 Smart Interaction 3D Full HD LED TV (UE40F6400AWXXH) | ПОДДРЪЖКА | SAMSUNG България
    Цитат Първоначално публикувано от Darkness1 Виж публикацията
    satmann отиди си в менюто на поддръжка-самодиагностика-нулиране. След като си нулираш телевизора ще изчезне проблема и със забавеното изключване.п.п. Запиши си настройките на картината, защото ще се нулира всичко!!! Лек ден
    Darkness1, ако този съвет е от личен опит със същия проблем, тогава го приемам. Макар, че ме съмнява да се оправи по този начин. Все пак ще изчакам да излезе нов фърмуер, защото връщането към заводски настройки е лесно, но аз имам много инсталирани приложения, повечето външни, които не са в смърт - хъба и не ми се занимава пак да ги инсталирам и настройвам.
    troll4o одобрява това.
    Dec 2014
    #1041
    Да от личен опит е след консултация със "инжинерите" от Самсунг. Старнно , когато си въведох наново настройките и си вкарах профила на телевизора след 5 дни започна пак да се изключва за 10-15 сек!!! В началото беше Ок. Пак се оплаках в сасмунг и казаха че ще мислят)))
    satmann одобрява това.
    Aug 2010
    #1042
    Така и предполагах....TEST, Явно затова са сложили на сайта предишния софт. Ще чакаме да "мислят"...
  10. Junior Member
    Feb 2015
    #1043
    Цитат Първоначално публикувано от zieek Виж публикацията
    Има повече приложения/игри в смарт хъба. Друго не съм забелязал.
    #1044
    Real
    Refresh Rate
    Samsung
    Piqture Quality Index
    LG
    Picture Mastering Index
    Sony
    MotionFlow
    Panasonic
    Real Motion Rate
    Backlight Motion Rate
    Philips
    Picture Motion Rate
    Sharp
    Active motion
    50 Hz
    50 (1080p)
    100 (1080p)
    200 (1080p)
    400 (1080p)
    800 (4k)
    900 (4k)
    1000 (4k)
    1200 (4k)
    100 (1080p)
    300 (1080p)
    400 (1080p)
    450 (1080p)
    800 (1080p)
    700 (4k)
    900 (4k)
    1000 (4k)
    1300 (4k)
    100 (1080p)
    200 (1080p)
    200 (4k)
    200 RMR (1080p)
    400 RMR (1080p)
    100 BMR (1080p)
    200 BMR (1080p)
    200BMR (4k)
    100 (1080p)
    200 (1080p)
    400 (4k)
    700 (4k)
    800 (4k)
    100 (720p)
    100 (1080p)
    200 (1080p)
    100 Hz 800 (1080p)
    1300 (4k)
    1400 (4k)
    1900 (4k)
    900 (1080p) ??
    1500 (4k)
    1600 (4k)
    800 (1080p)
    900 (1080p)
    1000 (1080p)
    900 (4k)
    1000 (4k)
    400 BMR (1080p)
    800 BMR (4k)
    1000 BMR (4k)
    1600 BMR (4k)
    500 (1080p)
    800 (1080p)
    1400 (4k)
    1800 (4k)
    400 (1080p)
    200 Hz*
    2000 (4k)
    2400 (4k)
    2000 (4k)
    2300 (4k)
    1200 (4k) 2000 (4k 2014)
    3000 (4k 2014)
    2400 (4k) 800 (1080p)
    800 (4k)
    Собствениците на миналогодишен модел, могат да проверят модела на видеопанела поставен в техният модел телевизор на този сайт
    http://partsoutlet.ru/shop.php?cid=356
    Този пост е редактиран от hristoslav2; 19-11-15 в 19:15.
    #1045
    Някой може ли да каже откъде мога да намеря матрица за UE40D6500 , че след 3-4 години ползване се скапа. Чичо гугъл не можа да намери или аз не търся правилно.
    Матрицата е
    а проблема е
    #1046
    Не съм техник, но според мен матрицата е наред, а проблемът е в T-con борда.
    LSJ400HV01-S
    Във форума има регистрирани 2-ма Тв техници. Единият е Galactika
    http://www.galacticaservice.com/
    ъпдейт на ревю
    https://www.avforums.com/review/sams...0-review.11268
    https://www.youtube.com/watch?v=fiReAq1H5s8
    Този пост е редактиран от hristoslav2; 20-11-15 в 16:40.
  15. Junior Member
    Sep 2008
    #1047
    Здравейте на всички!С нов Самсунг съм от няколко дни UE55JU6400 и пробвах различни настройки на картината но това което намирам е само за настройки в режим ФИЛМ а мен не ме удоволетворява като качество няма ли настройки в режим стандарт или естестевен защото аз гледам предимно телевизия.Благодаря ви предварително!
    Aug 2010
    #1048
    С новия софт версия: 2113 от 20.11.2015 г. телевизорът започна да изключва нормално!
    Aug 2005
    #1049
    И аз ходих по веригите, гледах, тествах и накрая.... Поръчах от миналата година модел 55HU7590 Нещо J серията не ме грабна......
  18. Junior Member Аватара на troll4o
    Aug 2013
    #1050
    Здравей, би ли споделил какви приложения извън предложените в смарт хъба позваш и от къде се намират ? Благодаря.
  1. Toshiba телевизори (инфо на първа страница)
    От hristoslav2 във форум Toshiba телевизори
    Отговори: 162
    Последно: 06-09-25, 18:08
  2. LG телевизори 2015
    Отговори: 467
    Последно: 02-01-16, 08:02
  3. SONY телевизори 2015
    Отговори: 866
    Последно: 02-01-16, 07:36
  4. Philips телевизори 2015
    Отговори: 426
    Последно: 02-01-16, 07:21
