Отговор: Samsung Телевизори 2015
Новият начин за влизане в сервизно меню - в режим стенд бай, mute 1-8-2, бутона за пускане
UЕ50ЈU6800: 50D6АU0ТЈ -> D=Іnnоluх , VА, 6=50Нz раnеl
UЕ55ЈU6800: 55В6АU0ТЈ -> В=ВОЕ, ІРЅ-?, 6=50Нz раnеl
UЕ60ЈU6800: 60Н6АU0ТЈ -> Н=Ѕhаrр, Vа, 6=50Нz раnеl
| Product | Diagonal | Resolution | Refresh Rate | Smart OS | Backlight | LCD Type | Screen Finish | Remote | 3D Type | Curved | Wide Color Gamut | LC Matrix
| Samsung J4000 | 28" 32" | 720p | 50/60 Hz | | Direct | IPS | Semi-gloss | Basic | | | | 28J4100 - LS02
32J4100 - UD02, 32A6AH1S - Samsung?
LF07 | |
| Samsung J5000 | | 1080p | 50/60 Hz | | Direct | IPS (except 50") | Semi-gloss | Basic | | | | 32J5100 - MS02, 32H6AF0V- AUO
32J5200 - TS01
40J5100 - MU02, 40H6AF0V - Sharp
48J5100 - TU01, 48A6AF0V - Samsung | |
| Samsung J5500 | | 1080p | 50/60 Hz | Tizen | Direct | VA | Semi-gloss | Basic | | | | 32J5500 - ED01, 32B6AF0VJ - Samsung PLS
40J5510 - HS01, 40H6AF0VJ - Sharp
40J5530 - HS01, 40H6AF0VJ - Sharp
48J5530 - ES04, 48B6AF0V - Samsung PLS
48J5510 - TS01, 48A6AF0VJ - Samsung
48J5530 - ES04 (PLS)
50J5500 - DH01, 50R6AF0V | |
| Samsung J6200 | | 1080p | 100/120 Hz | Basic | Direct | VA | Semi-gloss | Basic | | | | 48J6200 - US02 | |
| Samsung J6300 | | 1080p | 100/120 Hz | Tizen | Direct | VA | Semi-gloss | Basic | | | | 32J6300 - TD01, 32A1AF0V, T-CON H32A1F610 - Samsung
40J6330 - VS04, 40A1AF0V, H40A1F608 - ? US03
55J6300 - DH01, 55R1AF0V
48J6330 - TS01, 481A1F0V, H48A1F604 - Samsung, US02
48JU6450 - TH01, 48A6AU0VJ, J48A6U0F9 - Samsung
40J6690 - TD0140J6590 - TH01, 40A1AF0WJ, J40A1F01D - Samsung | |
| Ultra HD |
| Samsung JU6500 | | 4k | 50/60 Hz | Tizen | Direct | VA | Semi-gloss | Basic | | | | 40JU6400 - TD01, 40A6AU0VJ, J40A640F8 - Samsung
40JU6450 - TD01, 40A6AU0VJ, J40A640F8 - Samsung
40JU6600 - TD01
40JU6690 - TD01, 40A6AU0WJ, J40A6U0C9 - Samsung | |
| Samsung JU6800 | | 4k | 50/60 Hz | Tizen | Direct | VA | Semi-gloss | Basic | | • | | 55JU6690 - TH01 | |
| Samsung JU7000 | | 4k | 100/120 Hz | Tizen | Direct | VA | Glossy | Smart | Active | | | | |
| Samsung JU7500 | | 4k | 100/120 Hz | Tizen | Direct | VA | Glossy | Smart | Active | • | | | |
| UltraHd + Quantum Dots |
| Samsung JS7000 | 50" | 4k | 50/60 Hz | Tizen | Direct | IPS (only 55") | Semi-gloss | Basic | | | • | | |
| Samsung JS8500 | 48" | 4k | 100/120 Hz | Tizen | Edge | VA | Glossy | Smart | Active | | • | | |
| Samsung JS9000 | 48" | 4k | 100/120 Hz | Tizen | Edge | VA | Glossy | Smart | Active | • | • | | |
| Samsung JS9500 | 65" | 4k | 100/120 Hz | Tizen | Full-Array | VA | Glossy | Smart | Active | • | • | | |
Що се отнася до матриците при samsung телевизорите - има едно малко стикерче залепено отстрани отзад или отдолу..Започва с две буквички обозначаващи панела
Beijing Optoelectronics(BOE) - обикновенно в 4 серия:
EH..
GD..
FP..
ES..
Chi Mei Optoelectronics (в 5 серия)
CD..
CH..
ND..
NH..
CN..
AU Optronics (5-6 серия, диагонали 55-65)
AH..
AS..
AA..
AC..
BH..
MH..
MS..
YH..
Sharp
IS..
HH..
HS..
Samsung
TD..
TH..
TU..
TS..
UD..
UF..
UH..
US..
WH..
SS..
SQ..
Samsung Wall Mount, DLP Color Wheel, TV Lamp, Bulb, Remote Control, Replacement Lamps
Яко мазало както винаги с панелите при моя любим Samsung.
Впечатления от firmware 2790 ?
На H7000 серията не виждам никаква разлика.
satmann
Мдааа...., наскоро инсталирах уж последната версия на фърмуера за моя F6400 - 2112.4, като при него всичко си работи - има само промени в Смарт хъба и странно, но за пръв път телевизора започна да се изключва около 10-15 секунди след натискане на червения бутон на дистанционното...! Не знам, дало този ефект е само при мен, но днес гледам, че на сайта за поддръжка има "НОВ" фърмуер от 6.11.2015, като това е предишната версия - : 2111.1. Същевременно при онлайн проверката за нова актуализация не дава нищо и това е нормално - тази версия е по-ниска. Както и да е реших да пробвам - свалих Версия : 2111.1 от сайта, но при опит да я инсталирам, съвсем очаквано не се инсталира.....!? От Самсунг продължават да ни изненадват!:BigGrin
40 F6400 Smart Interaction 3D Full HD LED TV (UE40F6400AWXXH) | ПОДДРЪЖКА | SAMSUNG България
Darkness1
satmann отиди си в менюто на поддръжка-самодиагностика-нулиране. След като си нулираш телевизора ще изчезне проблема и със забавеното изключване.п.п. Запиши си настройките на картината, защото ще се нулира всичко!!! Лек ден
Darkness1, ако този съвет е от личен опит със същия проблем, тогава го приемам. Макар, че ме съмнява да се оправи по този начин. Все пак ще изчакам да излезе нов фърмуер, защото връщането към заводски настройки е лесно, но аз имам много инсталирани приложения, повечето външни, които не са в смърт - хъба и не ми се занимава пак да ги инсталирам и настройвам. :BigGrin
satmann
Да от личен опит е след консултация със "инжинерите" от Самсунг. Старнно , когато си въведох наново настройките и си вкарах профила на телевизора след 5 дни започна пак да се изключва за 10-15 сек!!! В началото беше Ок. Пак се оплаках в сасмунг и казаха че ще мислят))):thumbdn:
Така и предполагах....TEST, Явно затова са сложили на сайта предишния софт. Ще чакаме да "мислят"...
zieek
Има повече приложения/игри в смарт хъба. Друго не съм забелязал.
Real
Refresh Rate | Samsung
Piqture Quality Index | LG
Picture Mastering Index | Sony
MotionFlow | Panasonic
Real Motion Rate
Backlight Motion Rate | Philips
Picture Motion Rate | Sharp
Active motion |
50 Hz | 50 (1080p)
100 (1080p)
200 (1080p)
400 (1080p)
800 (4k)
900 (4k)
1000 (4k)
1200 (4k) | 100 (1080p)
300 (1080p)
400 (1080p)
450 (1080p)
800 (1080p)
700 (4k)
900 (4k)
1000 (4k)
1300 (4k) | 100 (1080p)
200 (1080p)
200 (4k) | 200 RMR (1080p)
400 RMR (1080p)
100 BMR (1080p)
200 BMR (1080p)
200BMR (4k) | 100 (1080p)
200 (1080p)
400 (4k)
700 (4k)
800 (4k) | 100 (720p)
100 (1080p)
200 (1080p) |
| 100 Hz | 800 (1080p)
1300 (4k)
1400 (4k)
1900 (4k) | 900 (1080p) ??
1500 (4k)
1600 (4k) | 800 (1080p)
900 (1080p)
1000 (1080p)
900 (4k)
1000 (4k) | 400 BMR (1080p)
800 BMR (4k)
1000 BMR (4k)
1600 BMR (4k) | 500 (1080p)
800 (1080p)
1400 (4k)
1800 (4k) | 400 (1080p) |
200 Hz* | 2000 (4k)
2400 (4k) | 2000 (4k)
2300 (4k) | 1200 (4k) | 2000 (4k 2014)
3000 (4k 2014) | 2400 (4k) | 800 (1080p)
800 (4k) |
Собствениците на миналогодишен модел, могат да проверят модела на видеопанела поставен в техният модел телевизор на този сайт
http://partsoutlet.ru/shop.php?cid=356
Някой може ли да каже откъде мога да намеря матрица за UE40D6500 , че след 3-4 години ползване се скапа. Чичо гугъл не можа да намери или аз не търся правилно.
Матрицата еhttps://forum.setcombg.com/attachmen...id=18236&stc=1
а проблема е
https://forum.setcombg.com/attachmen...id=18237&stc=1
Не съм техник, но според мен матрицата е наред, а проблемът е в T-con борда.
LSJ400HV01-S
Във форума има регистрирани 2-ма Тв техници. Единият е Galactika
http://www.galacticaservice.com/
ъпдейт на ревю
https://www.avforums.com/review/sams...0-review.11268
https://www.youtube.com/watch?v=fiReAq1H5s8
Здравейте на всички!С нов Самсунг съм от няколко дни UE55JU6400 и пробвах различни настройки на картината но това което намирам е само за настройки в режим ФИЛМ а мен не ме удоволетворява като качество няма ли настройки в режим стандарт или естестевен защото аз гледам предимно телевизия.Благодаря ви предварително!
Darkness1
С новия софт версия: 2113 от 20.11.2015 г. телевизорът започна да изключва нормално! :thumbsup:
И аз ходих по веригите, гледах, тествах и накрая.... Поръчах от миналата година модел 55HU7590 :) Нещо J серията не ме грабна......
satmann
Здравей, би ли споделил какви приложения извън предложените в смарт хъба позваш и от къде се намират ? Благодаря.
