По скоро доставчика на интернет се опитва да ти"намаже ските".Не мисля че телевизора може сам да прави тези работи.За сега вещите правят това което им кажем в бъдеще може да станат по интелигентни от нас.
Светльо
Коментара в ревюто показва куп недостатъци в модела...И това, за сертифициран UHD TV Premium модел :mad:
google translate Fr to Bg
Files played back from the built-in media player in 2016 models
https://www.samsungdforum.com/Tizen/Spec#2016TVSpec
Tizen OS
https://www.samsungdforum.com/Tizen/GetSpecData/
https://www.samsungdforum.com/Tizendevtools/Sdkdownload
https://www.samsungdforum.com/Tizen/Spec#TVModelLineup
https://www.samsungdforum.com/Tizen/...eneralFeatures
Developing Apps for Tizen TV
https://developer.tizen.org/tizen/tv
Year
____Platform
_______Recommended SDK
_________________Seller Office Model Group
_____________________Line Up
___________________________________________________2016  Tizen Tizen TV SDK 2.1.3
16TV_PREMIUM (UHD) 16TV_STANDARD1 (UHD) 16TV_STANDARD2 (FHD)
UKS9500, UKS9000, UKS8500, UKS8000, UKS7500, UKS7000 UKU6500, UKU6400, UKU6300, UKU6100, UKU6000 UK6500, UK6300, UK6200, UK6000, UK5600, UK5500
Samsung European UHD TV 2016  Product____________Certification
UHD
Premium
_____Dolby
Vision
_____HDR
__________________________Videopanel
(type matrix, bit, curvature)
________________________________ Backlight___________________
Dimming Color Space___________________________ Contrast____________________________
Black level
Viewing angle
____________Input
Lag
________SoC
Platform
OS
__________ Ports______________________________ Networks_______________________________ Tuner_________________Picture Accuracy
Out-of-the-Box
(score out of 10)
___________Product KS9800
(curved)
88"
Technically it is a KS9500 – just larger and with a slightly different design.
Yes No Yes HDR10
max-1250 cd/m²88"- SVA,10bit (?), Curvature 4200R
120/100Hz
Moth Eye (anti-reflective filter)FALD, Local Dimming
? zones
Blue Leds (actually white LEDs "boosted" with phosphorus)
PWM Freq,-120/100Hz88"-DCI P3- 96% / Rec.2020-
Quantum Dots88"- 88"- Quad Core
16_DTV_JazzM
Tizen 2,4 OS4 х НDМІ2.0 (АRС,СЕС,МНL)
1 x satelite in(Sub:F-type,female
1 х Ѕаtеlіtе іn(Маіn:F-tуре,fеmаlе)
1 х Аntеnа (RF) (Fеmаlе)
1 х Орtісаl Аudіо Оut
1 х Ex Link (RS 232 C)
1 х СІ+1.3
2 х UЅВ 2.0(DС5 V МАХ500mА)
1 х UЅВ 3.1(DС5 V МАХ900mА)
НІD соntrоllеr
Соmраtіbіlіtу-mоuѕе/kеуbоаrd
Вluеtооth Vеr. 4.0 HIDLan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct, Screen Mirroring
Bluetooth
DLNA(RUI2.0/DTCP-IP/DMP/DMR/DMS)Dual tuners
DVB -T/ T2/C/S/S2
with PVR and PIP function + Timeshift
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKS9800 KS9500
(curved)
78", 65", 55"Yes No Yes HDR10
1000cd/m²
Delta E <1 of all levels of brightness78"- SVA, 10bit (?), Curvature 4200R
65"- SVA, 10bit (?), Curvature 4200R
55"- SVA, 10bit (?), Curvature 4200R
120/100Hz
PWM Freq. - 120/400Hz78"-
65"-
55"-DCI P3- 96% / Rec.2020- 72%
Quantum Dots78"-
65"-
55"-78"-
65"-
55"-78"-
65"- 20.5ms
55"- 20.5msQuad Core
16_DTV_JazzM
Tizen 2,4 OS4 х НDМІ2.0(АRС,СЕС,МНL)
1 х СІ+1.3
НІD соntrоllеr
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
DVB -T/ T2/C/S/S2
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKS9500 KS9000
(curved)
75", 65", 55", 49"Yes No Yes HDR10
max-1000cd/m²75"- SVA or AMVA (),
65"- SVA, 10bit (8-bit+Hi-FRC ?), 4200R
55"- SVA, 10bit (8-bit+Hi-FRC ?), 4200R
49"- SVA, 10bit (8-bit+Hi-FRC ?), 3000R
120/100Hz
Moth Eye (anti-reflective filter)Edge LED - below
(55"- 8 vertical columns of dimmable zones)
PWM Freq,-120/100Hz75"-
65"-
49"-
Quantum Dots75"-
65"-
55"- 2688:1 / 0.039cd/m275"
65"
55"- 20° (cone)
49"75"-
65"- 20.5ms
55"- 20.5ms
49"- 20.5msQuad Core
16_DTV_JazzM
1 х СІ+1.3
НІD соntrоllеr
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
DVB -T/ T2/C/S/S2
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVC9
Rec.2020 settings are not correctKS9000 KS8000
55"-2% window max 1410cd/m2
55"-100% window max 490cd/m2
-max 1355cd/m2
75"- SVA or AMVA
120/100Hz
Moth Eye (anti-reflective filter)Edge LED - below,
65"-
55"-DCI P3- 93% / Rec.2020- 70%
49"-
Quantum Dots75"-
65"-
55"- ANSI 6820:1 /0.014cd/m2
white - 95.48cd/m2
49"-75"-
65"-
55"- 20° (cone)
49"-75"- 20.9ms
65"- 20.8ms
55"- 20.7ms
49"- 20.7msQuad Core
16_DTV_JazzM
1 х СІ+1.3
НІD соntrоllеr
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
DVB -T/ T2/C/S/S2
with PVR and PIP function + Tmeshift
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKS8000 KS7500
(curved)
65", 55", 49", 43"Yes? No Yes HDR10
55"-max 1185cd/m² - 1600cd/m2
43"- AMVA3, 10bit (8-bit+FRC), 3000R
120/100Hz
PWM Freq,-120/100Hz65"-DCI P3- / Rec.2020-
49"-DCI P3- / Rec.2020-
43"-DCI P3- / Rec.2020-
Quantum Dots65"-
55"- ANSI 4000:1/ 0.03-0.043cd/m2
2600:1 /0.046cd/m2/120cd/m2
49"-
43"-65"-
55"- 30° (cone)
49"-
43"-65"- 21,8ms
55"- 21.7ms
49"-
43"-Quad Core
16_DTV_JazzM
1 х СІ+1.3
НІD соntrоllеr
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
Bluetooth, Screen Mirroring
DVB -T/ T2/C/S/S2
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCVertical Blooming
Variable depth of black in HDR mode
Sometimes black in HDR mode is approximately 0.20cd/m², which is comparable to the black level of the panel IPS!KS7500 KS7000
65", 60", 55", 49"Yes ? No Yes HDR10
max-1000cd/m²65"- VA, 10bit (8-bit+FRC ?),
60"- VA, 10bit (8-bit+FRC ?),
55"- VA, 10bit (8-bit+FRC ?),
49"- VA, 10bit (8-bit+FRC ?),
60/50Hz (120/100Hz in USA?)
60"-DCI P3- / Rec.2020-
Quantum Dots65"-
60"-
55"- ANSI 8761:1 /0.016cd/m2
white 116.8cd/m2
49"-
65"-
60"-
55"- 20° (cone)
49"-65"-
60"-
55"-
49"-Quad Core
16_DTV_JazzM
1 х СІ+1.3
НІD соntrоllеr
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
DLNA(RUI2.0/DTCP-IP/DMP/DMR/DMS)DVB - T/T2/C/S/S2
with PVR function
DiSEqC version 1.0
Analog (PAL,SECAM)
Sometimes black in HDR mode is approximately 0.20 CD / m², which is comparable to the black level of the panel IPS!KS7000 KU6600
(curved)
65", 55", 49", 43"No No compatible 65"-VA, 8-bit, ?, 4200R
55"-VA, 8-bit, 60/50Hz, Curvature 4200R
49"-VA, 8-bit, 60/50Hz, Curvature 3000R
43"-VA, 8-bit, 60/50Hz, Curvature 3000R
Edge Led
55"-
49"-
43"-65"-
55"-
49"-
43"-65"-
55"-
49"-
43"-65" -
55" -
49" -
43" --
16_DTV_JazzL
1 х RS 232 (C)
1 х СІ+1.3
НІD соntrоllеr
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA(RUI2.0/DTCP-IP/DMP/DMR/DMS)DVB -T/ T2/C/S/S2
with PVR function
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKU6600 KU6500
(curved)
78", 65", 55", 49", 43"No No compatible 78"- VA,
65"- VA, 8-bit, ?, 4200R
55"- VA, 8-bit, 60/50Hz, Curvature 4200R
49"- VA, 8-bit, 60/50Hz, Curvature 3000R
43"- VA, 8-bit, 60/50Hz, Curvature 3000R
Edge Led
( or Direct Led ??)
PWM Freq,-120/100Hz78"-
65"-
55"-
49"-
43"-78"-
65"-
55"-
49"-
43"-78"-
65"-
55"-
49"-
43"-78" -
65" -
55" -
49" -
43" --
16_DTV_JazzL
1 х RS 232 (C)
1 х СІ+1.3
НІD соntrоllеr
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
with PVR function
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKU6500 KU6400
65", 55", 49", 43", 40"No No compatible 65"- VA, 8-bit, ?Hz
40"- VA, 8-bit, 60/50HzEdge Led
NO Local Dimming
55"-
49"-
43"-
40"-65"-
55"-
49"-
43"-
40"-65"-
55"-
49"-
43"-
40"-65" -
55" -
49" -
43" -
40" --
16_DTV_JazzL
Tizen 2,4 OSВluеtооth Vеr. 4.0 HID Lan
a/b/g/n/ac
Wi-Fi Direct
DLNA
DVB - T/T2/C/S/S2
with PVR function
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKU6400 KU6100
(curved)
65", 55", 49", 43", 40"No No compatible 65"- VA, 8-bit, ?Hz, 4200R
55"- VA, 8-bit, 6050/Hz, Curvature 4200R
40"- VA, 8-bit, 60/50Hz, Curvature 3000REdge Led
NO Local Dimming
PWM Freq,-120/100Hz-
16_DTV_JazzL
a/b/g/n
Wi-Fi Direct
DLNA
DVB -T/ T2/C
Analog (PAL,SECAM)
HEVCKU6100 KU6000
70", 65", 60", 55", 50", 49", 43", 40"No No compatible 70"- VA, 8-bit, ?Hz
65"- VA, 8-bit, ?
60"- VA, 8-bit, ?
50"- VA, 8-bit, 60/50Hz
NO Local Dimming
PWM Freq,-120/100Hz70"-
65"-
60"-
55"-
50"-
49"-
43"-
40"-70"-
65"-
60"-
55"-
50"-
49"-
43"-
40"-70"-
65"-
60"-
55"-
50"-
49"-
43"-
40"-70" -
65" -
60" -
55" -
50" -
49" -
43" -
40" --
16_DTV_JazzL
a/b/g/n
Wi-Fi Direct
DLNA
DVB - T/T2/C
with PVR function
Analog (PAL,SECAM)
HEVCKU6000 Samsung FHD TV 2016  Product____________Certification
UHD
Premium
_____Dolby
Vision
_____HDR
Dimming Color Space___________________________ Contrast & Black level____________________________
Viewing angle
____________Input
Lag
________SoC
Platform
OS
Out-of-the-Box
(score out of 10)
___________Product K6500
55", 49", 40"No No No 55"- VA, 8-bit, 120/100Hz
49"- VA, 8-bit, 120/100Hz
40"- VA, 8-bit, 120/100HzEdge Led - -
16_DTV_HawkM
a/b/g/n
Wi-Fi Direct
DLNA
DVB -T/ T2/C
with PVR function
Analog (PAL,SECAM)K6500 K6300
(curved)
49"-
40"- VA, 8bit, 120/100HzEdge Led - -
16_DTV_HawkM
a/b/g/n
Wi-Fi Direct
DLNA
BluetoothDVB - T/T2/C
Analog (PAL,SECAM)K6300 K6000
70",65", 60",55", 50", 43", 40"No No No 60"- VA, 8-bit, 60/50Hz
55"-
50"-
43"-
40"- VA, 8bit, 60/50 HzEdge Led - -
16_DTV_HawkM
a/b/g/n
Wi-Fi Direct
DLNA
Analog (PAL,SECAM)K6000 K5600 No No No 55" -
49" -
40" - VA, 8bit, 60/50Hz
32" -Edge Led - -
16_DTV_HawkMВluеtооth Vеr. 4.0 HID Lan
a/b/g/n
Wi-Fi Direct
DLNA
DVB - T/T2/C
Analog (PAL,SECAM)K5600 K5500
55", 49", 40", 32"No No No 55" -
49" -
40" - VA, 8-bit, 60/50Hz
32" -Edge Led - -
16_DTV_HawkM
a/b/g/n
Wi-Fi Direct
DLNA
DVB - T/T2/C
Analog (PAL,SECAM)K5500 K5100 No No No - VA, 8bit, 60/50Hz Edge Led - Вluеtооth Vеr. 4.0 HID Lan
a/b/g/n
Wi-Fi Direct
DLNA
DVB - T/T2/C
Analog (PAL,SECAM)K5100
USA model Europe model Забележки за европейските модели KS9800
Curved
FALDKS9800
Curved
FALD9800 технически е същият като 9500 - разликата е само в размера и дизайна KS9500
Curved
Edge LedKS9500
Curved
FALDKS9000
Flat
Edge LedKS9000
Curved
Edge LedЗаради промяната в подсветката на моделите, се променя името на функцията
Peak Illuminator Pro вместо Ultimate.KS8500
Curved
Edge LedNo KS8500
in EuropeKS8000
Flat
Edge LedKS8000
Flat
Edge LedNo KS7500
in USAKS7500
Curved
Edge LedЗа разлика от миналата година, тази година серия 7000 е с извит панел и e SUHD - с квантови точки.(и май с 60/50Hz панел)
Разликата спрямо по-скъпата серия 8000 е, че серията 7000 не разполага с двоен тунер, има по-малки говорители.
Moth Eye филтърът на Samsung е доста далеч от този на Philips, но резултатите все още са много добри.
Samsung са имали лошата идея да се поставят хромирана рамка. Най-лошото е, че тази рамка не е изравнена с екрана, тя е като малък блистер в долната част на телевизора. Светлината от панела се отразява в хрома около екрана, което може да затрудни тези, които обичат да гледат филмите си в пълен мрак! Същото важи и за краката!
За минуси, локалното затъмняване произвежда много лек Blooming, предимно вертикален. Аз съм доста разочарован от качеството на черното при съдържание HDR. Логично, HDR трябва правилно да доведе до подобрение в тъмните сцени,но това тек сетава точно обратното. Дълбочината на черното в HDR е доста променлива, но дори и когато няма ярък обект в тъмните сцени, липсва дълбоко черно, особено на черните ленти..
Най-невероятното нещо е, че ако вземем една и съща сцена, тя ще бъде по-смесени в HDR, въпреки че HDR сцена не предлага по-висок светлинен връх. Понякога черното в HDR сцените е около 0.20 cd/m², което е сравнимо с нивото на черното на панел IPS! Дори и в ярки сцени, черните ленти се появяват в сиво.No KS7000
in USAKS7000
Flat
Edge LedUE KS6600
Curved
Edge ledняма квантови точки
няма хардуер за HDR - може да чете HDR данни, но не и да ги възпроизвеждаKU7500 KU7000 KU6600 KU6500 KU6500 KU6400 KU6300
То не е само в тоя , май тоя сертификат се оказа като нашите сертификати "честна фирма" ;) - аз като ти писах, преди че има още хляб да изядат , докато се наложат и уточнят стандартите , явно не е било случайно :cool: .
Май догодина , освен да задължат всичкото LCD искащо HDR Ultra(UHD Premium всъщност) сертификат да бъде с директ ЛЕД и някакво минимално количество димиращи зони , то и да въведат практикат на Долби - чипче (лицензирано разбира се) отговарящо за процеса ;)
Това го научи от мене :) още преди 5 месеца коментирах сертификата и това, че Сони се отказват да сертифицират моделите си..
Бих искал да попитам моделът Samsung UEххJ6200 колко hz е?
До колкото успях да намеря мнения и коментари е въпрос на късмет каква матрица ще ми се падне, от където и качеството на картината.
Какви са общите впечатления от него, предимства, недостатъци.
Благодаря предварително.
J6300 и J6300 - 120/100Hz
Според собственици на UE55KS7000 и UE55KS7002 модела ползва самсунгски панел на 100 Hz - 55A1MU0QK
http://www.avsforum.com/forum/166-lcd-flat-panel-displays/2387466-official-samsung-ks8000-ks8500-owners-thread-14.html#post43695338
http://forum.avmania.e15.cz/download...a59b&mode=view
Някой би ли споделил калибрация на Н6200 ,че като го актуализирах с 2820 стана едно замазано. Направо кошмар с тия ъпдейтеити ,само развалят
How to decrypt indication of Videopanel in service menu - example Type 55A1MU0QK ?
Как да разшифровате обозначението на видеопанела в сервизното меню - пример Type 55A1MU0QK ?
55 - Diagonal in Inches (размер)
A - Vendor (производител)
- A - Samsung Display
 - D - CMO (Chimei Innolux /Chilin/)
 - L - AUO (AU Optronics)
 - R - AUO (AU Optronics)
 - I - CPT (Chunghwa Picture Tube)
 - Р - CMI (Chimei Innolux)
 - Н - Sharp Display
 - S - Sharp / (Samsung China ?)
 - B - Beijing Optoelectronics
1 - Panel frequency (честота на опресняване на матрицата)
- 6 - 50 (60Hz)
 - 1 - 100 (120Hz)
 - 2 - 200 (240Hz) -[100Hz matrix + Scanning Backlight -> Strobe Effect]
M - Panel coating (покритие на панела)
- M - Moth Eye Filter
 - A - AntiGlare
 - U - Ultra Clear
U - Resolution (резолюция)
- F - FullHD,
 - H - HD ready,
 - U - Ulthra HD
0 - Generation panel (Поколение панел) Panel 1st/2nd (1st=0, 2nd=1…)
- 0 -
 - 1 -
 - 2 -
 - 9 -
Q - BLU (BackLight Unit) - (тип подсветка)
- C - CCFL (cold catode fluorescent lamp)
 - L - LED,
 - D - Direct LED,
 - E - Edge LED,
 - V - Vertical Edge LED (above and below) / Two side Edge led,
 - S - Side by side LED (left & right) / Single side LED,
 - EH - Even horizontal,
 - RH - Rounded horizontal,
 - Q - Quantum Dots,
K - Model Year (година на модела)
- K - 2016,
 - J - 2015,
 - H - 2014,
UHD
Premium
_____Dolby
Vision
_____HDR
_________________________________________ Backlight___________________
Black level
Viewing angle
_____________Input
Lag
________SoC
Platform
OS
Out-of-the-Box
(score out of 10)
(curved)
88"
Yes No Yes HDR10
max-1250 cd/m²88"- SVA,10bit ?, 120/100Hz, Curvature 4200R
? zones
Quantum Dots88" - 88" - Quad Core
16_DTV_JazzM
1 х СІ+1.3
НІD соntrоllеr
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
DVB -T/ T2/C/S/S2
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKS9800 KS9500
(curved)
1000cd/m²
Delta E <1 of all levels of brightness78"- SVA, 10bit ?, 120/100Hz, Curvature 4200R
65"- SVA, 10bit ?, 120/100Hz, Curvature 4200R
55"- SVA, 10bit ?, 120/100Hz, Curvature 4200R
65"-
Quantum Dots78" -
65" -
55" -78" -
65" -
55" -78" -
65" - 20.5ms
55" - 20.5msQuad Core
16_DTV_JazzM
1 х СІ+1.3
НІD соntrоllеr
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
DVB -T/ T2/C/S/S2
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKS9500 KS9000
(curved)
65"- SVA, 10bit (8-bit+Hi-FRC ?), 120/100Hz, 4200R
55"- SVA, 10bit (8-bit+Hi-FRC ?), 120/100Hz, 4200R
49"- SVA, 10bit (8-bit+Hi-FRC ?), 120/100Hz, 3000R
65"-
49"-
Quantum Dots75" -
65" -
55" - 2688:1 / 0.039cd/m275" -
65" -
55" - 20° (cone)
49" -75"-
65" - 20.5ms
55" - 20.5ms
49" - 20.5msQuad Core
16_DTV_JazzM
1 х СІ+1.3
НІD соntrоllеr
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
DVB -T/ T2/C/S/S2
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVC9
-max 1355cd/m2
75"- SVA or AMVA
120/100Hz
65"-
49"-
Quantum Dots75" -
65" -
55" - ANSI 6820:1 /0.014cd/m2
white - 95.48cd/m2
49" -75" -
65" -
55" - 20° (cone)
49" -75" - 20.9ms
65" - 20.8ms
55" - 20.7ms
49" - 20.7msQuad Core
16_DTV_JazzM
1 х СІ+1.3
НІD соntrоllеr
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
DVB -T/ T2/C/S/S2
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKS8000 KS7500
(curved)
65" - SVA, 10bit (8-bit+Hi-FRC ?), 4200R
55" - SVA, 10bit (8-bit+Hi-FRC ?), 4200R
49" - SVA, 10bit (8-bit+Hi-FRC ?), 3000R
43" - AMVA3, 10bit (8-bit+FRC), 3000R
120/100Hz
Quantum Dots65" -
55" - ANSI 4000:1/0.03-0.043cd/m2
49" -
43" -65" -
55" - 30° (cone)
49" -
43" -65" - 21,8ms
55" - 21.7ms
49" -
43" -Quad Core
16_DTV_JazzM
1 х СІ+1.3
НІD соntrоllеr
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DVB -T/ T2/C/S/S2
DiSEqC version 1.0
Analog (PAL,SECAM)
max-1000cd/m²65" - SVA, 10bit (8-bit+FRC ?), 120/100Hz
60" - SVA, 10bit (8-bit+FRC ?), 120/100Hz
55" - SVA, 10bit (8-bit+FRC ?), 120/100Hz
49" - SVA, 10bit (8-bit+FRC ?), 120/100Hz
Quantum Dots65" -
60" -
55" - ANSI 8761:1 /0.016cd/m2
white 116.8cd/m2
49" -
65" -
60" -
55" - 20° (cone)
49" -65" -
60" -
55" -
49" -Quad Core
16_DTV_JazzM
1 х СІ+1.3
НІD соntrоllеr
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
with PVR function
DiSEqC version 1.0
Analog (PAL,SECAM)
(curved)
65", 55", 49", 43"No No compatible 65" - SVA, 8-bit, ?Hz, 4200R
55" - SVA, 8-bit, 60/50Hz, Curvature 4200R
49" - SVA, 8-bit, 60/50Hz, Curvature 3000R
43" - SVA, 8-bit, 60/50Hz, Curvature 3000R
Edge Led
55"-
49"-
43"-65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -65" -
55" -
49" -
43" --
16_DTV_JazzL
1 х RS 232 (C)
1 х СІ+1.3
НІD соntrоllеr
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
with PVR function
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKU6600 KU6500
(curved)
78", 65", 55", 49", 43"No No compatible 78" - VA,
65" - VA, 8-bit, Hz?, 4200R
55" - VA, 8-bit, 60/50Hz, Curvature 4200R
49" - VA, 8-bit, 60/50Hz, Curvature 3000R
43" - VA, 8-bit, 60/50Hz, Curvature 3000R
Edge Led
( or Direct Led ??)
65"-
55"-
49"-
43"-78" -
65" -
55" -
49" -
43" -78" -
65" -
55" -
49" -
43" -78" -
65" -
55" -
49" -
43" --
16_DTV_JazzL
1 х RS 232 (C)
1 х СІ+1.3
НІD соntrоllеr
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
with PVR function
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKU6500 KU6400
65", 55", 49", 43", 40"No No compatible 65" - VA, 8-bit, ?Hz
40" - VA, 8-bit, 60/50HzEdge Led
NO Local Dimming
55"-
49"-
43"-
40"-65"-
55"-
49"-
43"-
40"-65"-
55"-
49"-
43"-
40"-65" -
55" -
49" -
43" -
40" --
16_DTV_JazzL
a/b/g/n/ac
Wi-Fi Direct
DLNA
DVB - T/T2/C/S/S2
with PVR function
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKU6400 KU6100
(curved)
65", 55", 49", 43", 40"No No compatible 65" - VA, 8-bit, ?Hz, 4200R
55" - VA, 8-bit, 6050/Hz, Curvature 4200R
40" - VA, 8-bit, 60/50Hz, Curvature 3000REdge Led
NO Local Dimming
16_DTV_JazzL
a/b/g/n
Wi-Fi Direct
DLNA
DVB -T/ T2/C
Analog (PAL,SECAM)
HEVCKU6100 KU6000
70", 65", 60", 55", 50", 49", 43", 40"No No compatible 70" - VA, 8-bit, ?Hz
65" - VA, 8-bit, ?
60" - VA, 8-bit, ?
50" - VA, 8-bit, 60/50Hz
NO Local Dimming
65"-
60"-
55"-
50"-
49"-
43"-
40"-70"-
65"-
60"-
55"-
50"-
49"-
43"-
40"-70"-
65"-
60"-
55"-
50"-
49"-
43"-
40"-70" -
65" -
60" -
55" -
50" -
49" -
43" -
40" --
16_DTV_JazzL
a/b/g/n
Wi-Fi Direct
DLNA
DVB - T/T2/C
with PVR function
Analog (PAL,SECAM)
UHD
Premium
_____Dolby
Vision
_____HDR
Viewing angle
____________Input
Lag
________SoC
Platform
OS
Out-of-the-Box
(score out of 10)
55", 49", 40"No No No 55" - VA, 8-bit, 120/100Hz
49" - VA, 8-bit, 120/100Hz
40" - VA, 8-bit, 120/100HzEdge Led - -
16_DTV_HawkM
a/b/g/n
Wi-Fi Direct
DLNA
DVB -T/ T2/C
with PVR function
(curved)
55", 49", 40"No No No 55" - 8-bit, 120/100Hz
16_DTV_HawkM
a/b/g/n
Wi-Fi Direct
DLNA
70",65", 60",55", 50", 43", 40"No No No 60" - VA, 8-bit, 60/50Hz
55" - 8-bit, 60/50Hz
50" - 8-bit, 60/50Hz
40" - VA, 8-bit, 60/50 HzEdge Led - -
16_DTV_HawkM
a/b/g/n
Wi-Fi Direct
DLNA
32" -Edge Led - -
a/b/g/n
Wi-Fi Direct
DLNA
DVB - T/T2/C
55", 49", 40", 32"No No No 55" - VA, 8-bit, 60/50Hz
32" -Edge Led - -
16_DTV_HawkM
a/b/g/n
Wi-Fi Direct
DLNA
DVB - T/T2/C
a/b/g/n
Wi-Fi Direct
DLNA
DVB - T/T2/C
Аз гледам на 48h6500 с ето такива настройки с първия ъпдейт за тази серия телевизори T-MST14DEUC_2119.5. Ако гледаш на режим "Стандарт" стават и за H6200.
Peжим Cтaндapт
фoн 14
ĸoнтp. 74
яpĸocт 44
ocтp. 39
цвят 48
нюaнc 350/450
Paзмep ĸapтинa- Πoбepи в eĸpaнa
динaмичeн ĸoнтpacт - cлaбo
чepeн тoн - пo-тъмeн
цвeтoвa oбл - Авто
бaл.бялo/2 тoчĸи -
Ч-изм. +16
З-изм.+16
С-изм.+19
Ч-усилване +7
З-усилване +10
С-усилване +9
гaмa +3
цвeтoви тoн - cтaндapтeн
цифpoв изглeд -авто
МРЕG филтъp - cлaбo
peжим филм - aвтo 2
Моtіоn Рluѕ - гладка
Оптимизатор черно -Слабо
Благодаря ти много:thumbup
Малко допълнение към таблицата.
Процесорът в повечето модели е EXYNOS - на Samsung. Точният модел не го знам все още..
https://en.wikipedia.org/wiki/Exynos
Samsung Semiconductor Global Official Website
Smart TV - Consumer Device | Samsung Semiconductor Global Website
Samsung Exynos Processor | Fast and Efficient Mobile Processor
UHD
Premium
_____Dolby
Vision
_____HDR
Dimming Color Space___________________________ Contrast____________________________________
White & Black level
Viewing angle
_____________Input
Lag
________SoC
CPU
GPU
Platform
OS
_____________ Ports______________________________ Networks_______________________________ Tuner_________________Picture Accuracy
Out-of-the-Box
(score out of 10)
(curved)
88"
Yes No 88" - max-1250 cd/m²
Yes HDR1088"- SVA,10bit ?, 120/100Hz, Curvature 4200R
Moth Eye (anti-reflective filter)88" - FALD,
? - Local Dimming zones
Quantum Dots88" - 88" - EXYNOS
ARMv7
Cortex-A7
Quad Core 1.2GHz
16_DTV_JazzM
Tizen 2,4 OS2 x USB 2.0
1 x USB 3.1
1 x Ethernet RJ45
4 x HDMI 2.0 (ARC, CEC,MHL)
1 x Satelite In (Main: F-type female)
1 x Satelite In (Sub:F-type female)
1 x AV Composite In 3.5mm jack
1 x V Component In 3.5mm jack
1 x Optical Audio Out
1 x RS 232 C
1 x Antena (RF) (female)
1 x CI+ 1.3Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
DVB -T/ T2/C/S/S2
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKS9800 KS9500
(curved)
78", 65", 55"Yes No 78" - max 1000cd/m²
65" - max
55" - max
Yes HDR10
Moth Eye (anti-reflective filter)78" - FALD
65" - FALD
55" - FALD
65"-
Quantum Dots78" -
65" -
55" -78" -
65" -
55" -78" -
65" - 20.5ms
55" - 20.5ms
EXYNOS
ARMv7
Quad Core
1.2GHz
16_DTV_JazzM
1 x USB 3.1
1 x Ethernet RJ45
1 x RS 232 C
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
DVB -T/ T2/C/S/S2
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKS9500 KS9000
(curved)
75", 65", 55", 49"Yes No 75" - max-1000cd/m2
65" - max-1000cd/m2
55" - max-1000cd/m²
Yes HDR1075"- SVA or AMVA (),
49"- SVA, 10bit ?, 120/100Hz, Curvature 3000R
65"-
49"-
Quantum Dots75" -
65" -
75" -
65" -
55" - 20° (cone)
49" -
75"-
65" - 20.5ms
55" - 20.5ms
49" - 20.5ms
EXYNOS
ARMv7
Quad Core
1.2Ghz
16_DTV_JazzM
1 x USB 3.1
1 x Ethernet RJ45
4 x HDMI 2.0 (ARC, CEC, MHL)
1 x RS 232 C
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
DVB -T/ T2/C/S/S2
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVC9
75", 65", 55", 49"Yes No 65" - max
-max 1355cd/m2
49" - max
Yes HDR10
75"- SVA or AMVA
Moth Eye (anti-reflective filter)75" - Edge LED - below
65" - Edge Led
49" - Edge Led
65"-
49"-
Quantum Dots75" -
65" -
white - 95.48cd/m2
49" -
75" -
65" -
55" - 20° (cone)
49" -
75" - 20.9ms
65" - 20.8ms
55" - 20.7ms
49" - 20.7ms
EXYNOS
ARMv7
Quad Core
1.2GHz
16_DTV_JazzM
1 x USB 3.1
1 x Ethernet RJ45
1 x RS 232 C
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
DVB -T/ T2/C/S/S2
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKS8000 KS7500
(curved)
65", 55", 49", 43"Yes? No 65" - max
55" - max 1185cd/m² - 1600cd/m2
49" - max
Yes HDR1065" - SVA, 10bit (8-bit+Hi-FRC ?), 120/100Hz, 4200R
55" - SVA, 10bit (8-bit+Hi-FRC ?), 120/100Hz, 4200R
49" - SVA, 10bit (8-bit+Hi-FRC ?), 120/100Hz, 3000R
43" - AMVA3, 10bit (8-bit+FRC), 120/100Hz, 3000R
Moth Eye (anti-reflective filter)65" - Edge LED - below
49" -
43" -
Quantum Dots65" -
49" -
43" -
65" -
55" - 30° (cone)
49" -
43" -
65" - 21,8ms
55" - 21.7ms
49" -
43" -
EXYNOS
ARMv7
Quad Core
1GHz
16_DTV_JazzM
1 x USB 3.1
1 x Ethernet RJ45
1 x RS 232 C
1 x CI+ 1.3
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DVB -T/ T2/C/S/S2
DiSEqC version 1.0
Analog (PAL,SECAM)
65", 60", 55", 49"Yes ? No 65" - max-1000cd/m²
60" - max-1000cd/m2
55" - max-1000cd/m2
49" - max-1000cd/m2
Yes HDR1065" - SVA, 10bit (8-bit+FRC ?), 120/100Hz
Moth Eye (anti-reflective filter)65" - Edge Led - below
60" - Edge Led - below
(55"- Edge led - below
49"' - Edge Led - below
Quantum Dots65" -
60" -
55" - ANSI 8761:1 / 116.8cd/m2 / 0.016cd/m2
49" -
65" -
60" -
55" - 20° (cone)
49" -
65" -
60" -
55" -
49" -
EXYNOS
ARMv7
Quad Core
1GHz
16_DTV_JazzM
1 x USB 3.1
1 x Ethernet RJ45
3 x HDMI 2.0 (ARC, CEC)
1 x RS 232 C
1 x CI+ 1.3
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth ver. 4.0
with PVR function
DiSEqC version 1.0
Analog (PAL,SECAM)
Sometimes black in HDR mode is approximately 0.20cd/m², which is comparable to the black level of the panel IPS!KS7000 KU6600
(curved)
65", 55", 49", 43"No No Compatible 65" - SVA, 8-bit, ?Hz, Curvature 4200R
65" - Edge led
55" - Edge Led
49" - Edge Led
43" - Edge Led
55"-
49"-
43"-
65" -
55" -
49" -
43" -
65" -
55" -
49" -
43" -
65" -
55" -
49" -
43" -
16_DTV_JazzL
1 x USB 3.1
1 x Ethernet RJ45
1 x RS 232 C
1 x CI+ 1.3
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth ver. 4.0
Wi-Fi Direct
with PVR function
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKU6600 KU6500
(curved)
78", 65", 55", 49", 43"No No Compatible 78" - VA, ?, ?, Curvature 4200R
65" - VA, 8-bit, Hz?, Curvature 4200R
78" - Direct led
65" - Direct Led
55" - Direct Led
49" - Direct Led
43" - Direct Led
65"-
55"-
49"-
43"-
78" -
65" -
55" -
49" -
43" -
78" -
65" -
55" -
49" -
43" -
78" -
65" -
55" -
49" -
43" -
16_DTV_JazzL
1 x Ethernet RJ45
4 x HDMI 2.0 (ARC, CEC)
1 x CI+ 1.3
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 ac
Bluetooth ver. 4.0
Wi-Fi Direct
with PVR function
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKU6500 KU6400
65", 55", 49", 43", 40"No No Compatible 65" - VA, 8-bit, ?Hz
65" - Edge Led
55" - Edge Led
49" - Edge Led
43" - Edge Led
40" - Edge Led
NO Local Dimming
55"-
49"-
43"-
40"-
65"-
55"-
49"-
43"-
40"-
65"-
55"-
49"-
43"-
40"-
65" -
55" -
49" -
43" -
40" -
16_DTV_JazzL
1 x Ethernet RJ45
1 x CI+ 1.3Lan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 ac
Bluetooth ver. 4.0 HID
Wi-Fi Direct
DLNA
DVB - T/T2/C/S/S2
with PVR function
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKU6400 KU6300
(curved)
55" - max 440cd/m265" - VA, 8-bit, 60/50Hz, Curvature 4200R
40" - VA, 8-bit, 60/50Hz, Curvature 3000R65" - Led
55" - Direct Led ?
49" -
43" -
40" -
NO Local Dimming
PWM Freq,-120/100Hz65" -
55" -
49" -
43" -
40" -
65" -
55" - 4508:1 /108.2cd/m2 / 0.024cd/m2
49" -
43" -
40" -
65" -
55" -
49" -
43" -
40" -
65" -
55" - 19.8ms
49" -
43" -
40" -
16_DTV_JazzL
1 x Ethernet RJ45
1 x CI+ 1.3Lan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 ac
Wi-Fi Direct
DLNA
DVB -T/ T2/C
Analog (PAL,SECAM)
HEVCKU6300 KU6100
(curved)
65", 55", 49", 43", 40"No No Compatible 65" - VA, 8-bit, ?Hz, Curvature 4200R
40" - VA, 8-bit, 60/50Hz, Curvature 3000R65" - Edge Led
55" -
49" -
43" -
40" -
NO Local Dimming
55" -
49" -
43" -
40" -
65" -
55" -
49" -
43" -
40" -
65" -
55" -
49" -
43" -
40" -
65" -
55" -
49" -
43" -
40" -
16_DTV_JazzL
1 x Ethernet RJ45
1 x CI+ 1.3Lan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
Bluetooth
Wi-Fi Direct
DLNA
DVB -T/ T2/C
Analog (PAL,SECAM)
HEVCKU6100 KU6000
70", 65", 60", 55", 50", 49", 43", 40"No No Compatible 70" - VA, 8-bit, ?Hz
65" - VA, 8-bit, ?
60" - VA, 8-bit, ?
40" - VA, 8-bit, 60/50Hz70" - Edge Led
65" - Edge Led
60" - Edge Led
55" - Edge Led
50" - Edge Led
49" - Edge Led
43" - Edge Led
40" - Edge Led
NO Local Dimming
65"-
60"-
55"-
50"-
49"-
43"-
40"-
70"-
65"-
60"-
55"-
50"-
49"-
43"-
40"-
70"-
65"-
60"-
55"-
50"-
49"-
43"-
40"-
70" -
65" -
60" -
55" -
50" -
49" -
43" -
40" -
16_DTV_JazzL
1 x Ethernet RJ45
1 x CI+ 1.3Lan
a/b/g/n
Wi-Fi Direct
DLNA
DVB - T/T2/C
with PVR function
Analog (PAL,SECAM)
UHD
Premium
_____Dolby
Vision
_____HDR
Viewing angle
____________Input
Lag
________SoC
Platform
OS
Out-of-the-Box
(score out of 10)
40" - VA, 8-bit, 120/100Hz55" - Edge Led
49" - Edge Led
40" - Edge Led
55" -
49" -
40" -
55" -
49" -
40" -
55" -
49" -
40" -
55" -
49" -
40" -
16_DTV_HawkM
a/b/g/n
Wi-Fi Direct
DLNA
DVB -T/ T2/C
with PVR function
(curved)
55", 49", 40"No No No 55" - , 8-bit, 120/100Hz
49" - , 8-bit, 120/100Hz
49" - Edge led
40" - Edge Led55" -
49" -
40" -
55" -
49" -
40" -
55" -
49" -
40" -55" -
49" -
40" --
16_DTV_HawkM
a/b/g/n
Wi-Fi Direct
DLNA
70",65", 60",55", 50", 43", 40"No No No 70" -
55" - , 8-bit, 60/50Hz
50" - , 8-bit, 60/50Hz
43" - , 8-bit, 60/50Hz
40" - VA, 8-bit, 60/50 Hz70" - Edge Led
60" - Edge Led
55" - Edge Led
50" - Edge Led
43" - Edge Led
40" - Edge Led70" -
65" -
60" -
55" -
50" -
43" -
40" -70" -
65" -
60" -
55" -
50" -
43" -
40" -70" -
65" -
60" -
55" -
50" -
43" -
40" -70" -
65" -
60" -
55" -
50" -
43" -
40" --
16_DTV_HawkM
a/b/g/n
Wi-Fi Direct
DLNA
55", 49", 40", 32"No No No 55" - 8-bit, 60/50Hz
49" - , 8-bit, 60/50Hz
32" - 8-bit, 60/50Hz55" - Edge Led
49" - Edge Led
40" - Edge Led
32" - Edge Led55" -
49" -
40" -
32" -55" -
49" -
40" -
32" -55" -
49" -
40" -
32" -55" -
49" -
40" -
32" --
16_DTV_HawkM
-Вluеtооth Vеr. 4.0 HID Lan
a/b/g/n
Wi-Fi Direct
DLNA
DVB - T/T2/C
55", 49", 40", 32"No No No 55" - , 8-bit, 60/50Hz
32" - , 8-bit, 60/50Hz55" - Edge Led
49" - Edge Led
40" - Edge Led
32" - Edge Led55" -
49" -
40" -
32" -55" -
49" -
40" -
32" -55" -
49" -
40" -
32" -55" -
49" -
40" -
32" --
16_DTV_HawkM
a/b/g/n
Wi-Fi Direct
DLNA
DVB - T/T2/C
40"No No No 40" - VA, 8bit, 60/50Hz 40" - Edge Led 40" - 40" - 40" - Вluеtооth Vеr. 4.0 HID Lan
a/b/g/n
Wi-Fi Direct
DLNA
DVB - T/T2/C
