Страница 14 от 89 ПърваПърва ... 412131415162464 ... ПоследноПоследно
Резултати от 196 до 210 от общо 1324
Like Tree257Одобрявам
    #196
    Отговор: Samsung телевизори 2020 (инфо на първа страница)
    Samsung QE75Q950TS review
    We review the Samsung Q950TS flagship 8K QLED TV with "Infinity Screen" design & Object Tracking Sound Plus (OTS+) speakers. Topics covered include contrast performance, local dimming, colour accuracy, motion handling, video processing, HDR, as well as input lag for gaming.
    Our review sample is the 75-inch Samsung QE75Q950TS, model number QE75Q950TSTXXU which is the UK 3-pin-plug version.
    QE75Q950TS: VA + viewing angle compensation film (tweaked from last year),RGB - vertical stripe,+antiglare filter.
    Native ANSI blacks was 0.073 cd/m2(nits), if peak white was set at 120 cd/m2 with local dimming set to Low.
    with local dimming set to Standard (the relevant zones switched off) ,Native ANSI blacks was 0.001 cd/m2(nits), if peak white was set at 120 cd/m2.
    Local dimming could not switch off from user menu.
    F.A.L.D. : 30 vertical columns x 16 horizontal rows = 480 dimming zones.
    Samsung local dimming algorithm continues to favor minimizing blooming or haloing artifacts and keeping letterbox bars inky black,but shadow detail would also be slightly crashed compared to reference,and there were some backlight flunctuations.
    Up close we are talking less than 5" away the Samsung Q950TS exhibited a mosquito net effect at certain shades due to the use of sub pixel rendering to widen the viewing angle .Whether this technique still reproduces true 8K resolution is up for debate ,but at least the effect was not visible from normal viewing distance ,which begs the question "Is there any point for 8K resolution if you are going to watch a 75" screen from 10 feet away?"
    For HDR ,peak brightness measured 1504 cd/m2 (nits) on a 10% window after calibration to D65 white point and 375 cd/m2 (nits) full field.
    DCI-P3 color gamut coverage :96% uv (aka QLED=quantum dot enhancement film)
    #197
    #198
    Apr 2019
    #199
    Нещо 7 серия и TU8005 мисля беше модела много тъмнее екрана,нещо контраста хич го няма а уж кристал дисплей.
    Jan 2011
    Плевен
    #200
    Днес след дъжда ме удари нещо и ТВ не светва не разбрах дали от кабелната или от контакта стана проблема. Модела е 2019г. В гаранция. Има ли вариант да не я зачетат?
  7. Junior Member
    Jan 2003
    #201
    Цитат Първоначално публикувано от raij Виж публикацията
    Ако е стопен вътре и е ясно откъде е дошъл токовият удар, със сигурност няма да ти признаят гаранцията
    #202
    raij
    Вероятно е изгорял мейн борда. Ако няма видими следи по платката може и да го сервизират. Другият вариант е да съдиш кабелният си оператор. Преди това, си прочети договора с него.
    При гръмотевични бури, когато ползвате външна антена или въздушна мрежа на кабелният ви оператор, е желателно, да си изключите телевизора от двете мрежи докато премине бурята.
    #203
    Samsung QE55Q74TA review
    https://geex.x-kom.pl/recenzje/samsu...matryca-120hz/
    I tested the TV in hardware version No. 1 (Version No: 01).
    QE55Q74T (QE70T series):
    panel: 55A1AU7RT from service menu ,Samsung Display
    VA - RGB ,vertical stripe
    Edge(bottom) LED LCD,global frame dimming,
    Wide Color Gamut WCG (aka QLED,quantum dot enhancement film)
    100/120Hz + MCFI
    Made in Hungary
    ...As in the 65Q74T, the remote control is made of metal, and this is where the Q74T series differs from the "ordinary" Q70T (the one with a plastic remote)...
    ...When it comes to luminance, the TV was clearly brighter than the 55Q64T, because in full screen mode I measured the following values:
    default 223 cd / m ^ 2 (65Q74T: 254 cd / m ^ 2),
    maximum: 463 cd / m ^ 2 (65Q74T: 557 cd / m ^ 2).
    The recommended brightness level for SDR home theater (approx. 120 cd / m ^ 2) is set to brightness at 17/50.
    As you can see, 55Q74T has lower luminance than 65Q74T. This was also confirmed in HDR mode.
    In the HDR mode on the 10% board, the maximum luminance after three minutes of measurement was 478 cd / m ^ 2.
    HDMI - 4
    USB - 2
    Ethernet - 1
    Optical - 1
    Headphone - 0
    Bluetooth - yes
    Summary
    Well, no need to beat around the bush. The Samsung 55Q74T is a successful all-round TV suitable for both TV and home cinema, sports and games. This TV set has high contrast, high sharpness of moving images (120Hz matrix) and above-average HDR, which are features of a mid-range TV. In short, I recommend it.
  11. Junior Member
    Jul 2009
    #204
    Здравейте. Трябва ми вашето професионално мнение. В момента сме с телевизор Samsung UE55MU7000 , но ще трябва да го сменим с 50 инчов , защото ни идва големичък. Спрели сме дена тези моделчета и ми е интересно има ли съществена разлика между тях :
    Samsung UE50TU7002
    Samsung UE50TU8002
    Samsung UE50TU8502
    Искаше ми се да имат ДТС кодек също , но са ги премахнали, а моя има всичките.
    Ще съм много благодарен на отзовалите се.Ако имате нещо друго да предложите като вариант съм насреща да ви изслушам
    Бюджета е макс 1000лв че и по малко.
    #205
  13. Junior Member
    Jul 2009
    #206
    С една дума еднакви са ?
    #207
    Не. 8500 се различава - погледни линка със сравнението горе - разликите са в бежово.
    Samsung QN43LS05T "The Sero TV" review
    https://www.rtings.com/tv/reviews/samsung/the-sero
    Този пост е редактиран от hristoslav2; 28-08-20 в 15:35.
    #208
    Цитат Първоначално публикувано от bozko76 Виж публикацията
    не само ти се оплакваш от това.
    https://forum.ixbt.com/topic.cgi?id=62:23189:43#43
    RU7300/7100 по замервания е 287 cd/m²
    https://www.rtings.com/tv/tools/comp...&threshold=0.1
    RU8000/8500 по замервания е 330-340 cd/m²
    миналогодишният NU8000 е 509 cd/m²
    #209
    Samsung пуска по-достъпни Q700T 8K LCD телевизори
    https://www.flatpanelshd.com/news.ph...&id=1598865200
    (Direct Full Array 12x)
    https://www.samsung.com/uk/tvs/qledt...E65Q700TATXXU/
    Sep 2020
    #210
    Здравейте, обмислям да си закупя 43 инчов телевизор SAMSUNG QE-43Q60T. Моля за вашето мннение, тъй като не съм много запознат по темата.
    Благодаря предварително!
    Поздрави
  1. Samsung телевизори 2019
    Отговори: 493
    Последно: 29-01-20, 07:06
  2. Samsung телевизори 2017
    Отговори: 1079
    Последно: 01-01-18, 05:34
  3. Samsung телевизори 2016
    Отговори: 821
    Последно: 01-01-17, 16:42
  4. Samsung Телевизори 2015
    Отговори: 1121
    Последно: 02-01-16, 08:17
    Последно: 21-10-14, 22:00
