baron14
Не знам дали модела има настройки за смяна на часовият пояс - провери и ако има настрой го на - GMT+2
baron14
Благодаря колега baron14. Порових се в менюто и намерих къде да кирилизирам субтитрите, не ми трябва никаква смяна на кода, чете си ги перфектно без голямо "Е", но доколкото разбрах това е и при доста други модели. Има и опция за увеличаване на субтитрите :ole
Sharp Aquos LC-60LE635E ревю
http://www.lesnumeriques.com/tv-tele...2284/test.html
http://www.av-online.hu/tv-monitor/s...d-lcd-tv_221/1
Sharp
lcd TVsLE830E
·····················LE730E
·····················LE635E
·····················LE630E
·····················LE530E
·····················LE510E
·····················LE430E
·····················Diagonal 40, 46, 52, 60 40, 46 60 32, 40, 46 32, 40 19, 22, 24, 32, 40 19, 22, 26, 32 Resolution (1920 x 1080) (1920 x 1080) (1920 x 1080) (1920 x 1080) (1920 x 1080) 19"(1366 x 768), 40", 32", 24"(1920 x 1080) 19", 26", 32"(1366 x 768), 22" (1920 x 1080) 3D Yes Yes No No No No No 3D emiter integrated integrated No No No No No 2D-3D Yes Yes No No No No No Display LE830 LE730 LE635 LE630 LE530 LE510 LE430 Becklight Edge LED Edge LED Edge LED Edge LED Edge LED Edge LED Edge LED RGBY / Sub pixel control / High speed LCD Yes/Yes/Yes No/No/No No/No/No No/No/No No/No/No No/No/No No/No/No X-gen Panel Yes Yes Yes Yes No No No Dejuddering Yes(HD/SD) Yes(HD/SD) Yes(HD/SD) Yes(HD/SD) No No No Scanning Backlight 200hz/100Hz Yes/Yes No/Yes No/Yes No/Yes No/Yes No/No No/No Receiving Sistem LE830 LE730 LE635 LE630 LE530 LE510 LE430 Tuner Analogue/ DVB-T/C/S/S2 Analogue/ DVB-T/C/S2 Analogue/ DVB-T/C/S/S2 Analogue/ DVB-T/C/S2 Analogue/ DVB-T/C Analogue/ DVB-T/C Analogue/ DVB-T/C Audio Sistem LE830 LE730 LE635 LE630 LE530 LE510 LE430 Digital audio amplifer Yes Yes Yes Yes No No Yes Automatic volume level control / Clear voice Yes/Yes Yes/Yes Yes/Yes No/No Yes/No Yes/No Yes/No Surround Yes Yes Yes Yes No No Yes Dolby digital plus Yes Yes Yes Yes Yes yes Yes Output power 15Wx2 + 15W subwoofer 5Wx2 + 15W subwoofer 10Wx2 5Wx2 + 10W subwoofer 8Wx2 40",32"-6Wx2, 24",22",16"-2.5Wx2 32"-10Wx2, 26"-5Wx2, 22"-3Wx2 Videotext LE830 LE730 LE635 LE630 LE530 LE510 LE430 TOP Text/FLOF Text/List Text/Text memory capasity Yes/Yes/Yes/2000 Yes/Yes/P/1000 Yes/Yes/Yes/2000 Yes/Yes/-/1200 Yes/-/Yes/1000 Yes/Yes/-/1000 Yes/Yes/-/1000 Multimedia / Network LE830 LE730 LE635 LE630 LE530 LE510 LE430 Aquos Link Yes -(HDMI-CEC) Yes -(HDMI-CEC) - - - Time Shift/PVR Yes/No No/Yes Yes/No Yes/No Yes/Yes Yes/Yes No/No USB Video Player/ Photo Viewer/ Music Player Yes/Yes/Yes Yes/Yes/Yes Yes/Yes/Yes Yes/Yes/Yes Yes/Yes/Yes Yes/Yes/Yes Yes/Yes/Yes DivX Playback DivX plus HD DivX HD DivX plus HD No DivX DivX DivX plus HD DLNA Yes Yes Yes Yes No No No Wi-Fi Yes Option Yes Option No No No Aquos Net + / Net Function Yes/No No/Yes Yes/No Yes/No No/No No/No No/No Hbb TV No Yes No Yes No No No Skype ready Yes No No No No No No Interfaces LE830 LE730 LE635 LE630 LE530 LE510 LE430 Scart Yes Yes Yes Yes Yes(2) Yes(2) Yes S-Video/ Video cinch/ Component No/Yes/Yes No/Yes/Yes No/Yes/Yes No/Yes/Yes No/Yes/Yes No/Yes/Yes No/Yes/Yes HDMI-Input 4 4 4 3 2 2 2 USB 3 3 3 1 40"-2/ 32"-1 40"-2/ 32",24", 22", 19"-1 1 Headphone(3.5mm) / Digital audio out Yes/Yes Yes/Yes Yes/Yes Yes/Yes Yes/Yes Yes/Yes Yes/Yes Ethernet/ PC analog input/ RS-232C Yes/Yes/Yes Yes/Yes/Yes Yes/Yes/Yes Yes/Yes/No No/Yes/No No/Yes/No No/Yes/Yes
LE320 е произведен в Тайван - не знам кой е производителя.
до всички знаещи sharp lc40lx630e не вади субтитри дори и в домашна мрежа от лаптоп изчетох форума за това дърво а вече го купих помагаите
Ползвай компютъра за плейър - свържи ги с HDMI кабел.Цитат:
Първоначално публикувано от cahdiho
Ревю на Sharp 70LE835E
http://www.flatpanelshd.com/review.p...&id=1330691169
с кабел става но оказва се че 1500лв и не може да се гледа в дом мрежа 40лх630е помагаите лаерлеса е филирс pta 01
_________________________________________________[color=red]слети поредни публикации на: [time]1330872771[/time]_________________________________________________
nikoi li ne nqma 603e pi6ete + - golqma sopa
Модела си има DLNA - ти пропускаш нещоЦитат:
DLNA media player for Video / Photo / Music- • / • / •
http://www.sharp-cee.com/cps/rde/xch...v-products.htm
Инсталира ли си DLNA сървър на компа и кой точно ?
https://forum.setcombg.com/index.php/topic,46043.0.html
прочети и този пост
https://forum.setcombg.com/index.php...html#msg461392
@hristoslav2 LE630 наистина ли хваща сателит?
LE632 хваща сателит. LE630 има само DVB-T/C
Явно ще важи за моделите излизащи в края на годината.Цитат:
Първоначално публикувано от Momchil
Новите модели на руският сайт /640, 740, 840/
http://www.sharp.ru/cps/rde/xchg/ru/...televizory.htm
Явно да. Само да не се получи, като с LG, които прескочиха с една година внедряването на DTS. Разгеле, тази година ще имат и те, но ще видим дали при всичките модели.
Sharp
LC-42LE540U- $TBA
LC-46-LE540U-$1099.99
LC-52LE640U-$1599.99
LC-60LE640U-$1899.99
LC-70LE640U-$2999.99
LC-60LE745U-$2299.99
LC-70LE745U-$3499.99
LC-60LE847U-$2799.99
LC-70LE847U-$3799.99
LC-60LE945U-$3499.99
LC-70LE945U-$4499.99
LC-80LE844U-$6499.99
Тук може да намерите настройки за модел LE820
http://forums.hdtvtest.co.uk/index.p...ic,6405.0.html
