Страница 75 от 110 ПърваПърва ... 2565737475767785 ... ПоследноПоследно
Резултати от 1,111 до 1,125 от общо 1641
Like Tree328Одобрявам
SONY телевизори 2016
    #1111
    Отговор: SONY телевизори 2016
    Спесификации
    Спецификации за ZD9 Series | Телевизори | Sony BG
    KD65ZD9BAEP : 4.999,00 Euro (Sept. 2016) - 1000zones (50x20),
    KD75ZD9BAEP : 7.999,00 Euro (Sept. 2016) -
    KD100ZD9BAEP : 69.999,00 Euro (Nov. 2016) -
    Sony Announces Z9D FALD-LCD UHDTVs - AVS Forum | Home Theater Discussions And Reviews
    Sony UHD TV 2016 - european models
    Product
    Certification UHD
    Premium
    ______________________
    Resolution: 3,840x2,160.
    Color depth: 10-bit.
    Color gamut: Wide, including the ability to show at least 90 percent of the P3 color gamut .
    High dynamic range: Specifically the ability to use SMPTE ST2084's electro-optical transfer function, which Dolby helped create .
    Minimum brightness and contrast ratios: There are two possible minimum specs. A minimum brightness of 1,000 nits, along with a black level of a maximum of 0.05 nits (20,000:1 contrast ratio), or a minimum brightness of 540 nits, along with a black level of a maximum of 0.0005 (1,080,000:1)
    Dolby Vision
    _________________________
    The metadata is graded in each scene so you get different grades throughout the file. Dolby tells us that scene by scene grading is the superior way to grade a movie, which on paper does sound more efficient.
    Standard: Poprietary
    Peak Luminance: Up to 10,000 nits
    Video Bit Depth: 12-bit
    Metadata: Dynamic (scene by scene)
    Software Upgradability: No(SoC hardware-embedded)
    HDR 10
    The metadata is graded and determined, and is then sent at the beginning of the file and covers the entire file. One set of metadata
    Standard: Open
    Peak Luminance: Up to 4,000 nits
    Video Bit Depth: 10-bit
    Metadata: Static (per title)
    Software Upgradability: Yes
    Videopanel
    _____________________________
    Type LCD matrix,
    Bits of color,
    Operating frequency of T-Con board of the panel,
    Curvature,
    Index,
    Anti-reflective filter
    Backlight
    Type backlight
    (Local Dimming zone)
    Type LED
    MEMC
    Backlight Scanning
    Black Frame Insertion
    Pulsе Wide Modulation
    Color Space
    DCI P3 - %
    Rec.2020 - %
    Contrast
    White & Black level
    ANSI
    With local dimming
    Without local dimming
    Viewing angle
    _____________
    Input Lag
    ___________________________________
    Audio
    SoC
    CPU
    GPU
    Software
    OS
    Networks
    Conectors
    ________________
    Tuners
    ______________
    Opportunities for
    calibration
    _________________
    Note
    Product
    ZD9
    100", 75", 65"
    September 2016
    No Informaly No 100" - max -
    75" - max - 2400
    65" - max - 2500cd/m2
    Yes
    SMPTE standarts
    ST2084, ST 2086
    100" - MVA, 10-bit, 120/100Hz
    75" - MVA, 10-bit, 120/100Hz
    65"- MVA, 10-bit , 120/100Hz + BLS
    MCFI - Motion Clarity Frame Interpolation
    BFI - Black Frame Insertion
    Motionflow XR 1200
    100" - FALD, 2541 zones (77x33)
    75" - FALD, 1450 zones (58x25)
    65" - FALD, 798 zones (38x21) ?
    (Blue Led + RG phosphors)
    100" -
    75" -
    65"- DCI P3- % / Rec.2020 -
    (RGB - Led's ??)
    100" -
    75" -
    65" - 8000:1 ??
    100" - °
    75" - °
    65" - °
    100" - Game mode
    75" - Game mode
    65" - Game mode
    100" - DOLBY® DIGITAL
    DIGITAL PLUS
    PULSE
    75" - DOLBY® DIGITAL
    DIGITAL PLUS
    PULSE
    65" - DOLBY® DIGITAL
    DIGITAL PLUS
    PULSE
    Android 6.0 Marshmallow
    Board:
    Core architecture:
    CPU:
    GPU:
    RAM:
    Internal storage total space:
    Lan
    Wi-Fi
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    802.11 ac
    WiFi Direct
    DLNA
    Blietooth Ver.4.1
    2 x USB 2.0 (DC 5V MAX 500mA)
    1 x USB 3.0 (DC 5V MAX 900mA)
    1 x Ethernet RJ45
    4 x HDMI 2.0 (ARC, CEC, MHL)
    1 x Satelite In (Main: F-type female)
    1 x Satelite In (Sub: F-type female)
    1 x SCART
    1 x AV Composite In
    1 x AV Component In
    1 x Optical Audio Out (Video+L/R)
    1 x 3.5mm Audio Out (YPbPr+L/R)
    1 x Antena (RF) (female)
    1 x CI+ 1.3
    Twin Tuners
    DVB-C/T2/S2
    DiSEqC version 1.0
    White balance -
    Gamma -
    CMS -
    ISF -
    ZD9
    XD9405
    75"
    наследник на X9405C
    No Informaly No 75"- max - 740cd/m2
    100% window - 360cd/m2
    Yes HDR10
    SMPTE standarts
    ST2084, ST 2086
    75" - AMVA3, 10-bit, 120/100Hz
    BLS - Backlight Scanning
    Motionflow XR 1200
    Semi-mate
    Full Array Local Dimming
    96 zones (12x8)
    PWM Freq. 120/100Hz
    75"- DCI P3- 96% / Rec.2020 - 7
    Quantum Dots +
    75" - (4x4 ANSI) 0.052cd/m2
    75" - 67°
    75" - Game mode 34.9ms / by default 64ms
    Android 5.1.1 Lolipop
    Board:
    Core architecture:
    CPU:
    GPU:
    RAM:
    Lan
    Wi-Fi
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    802.11 ac
    Wi-Fi Direct
    DLNA
    Bluetooth Ver. 4.1
    1 x Ethernet RJ45
    1 x Satelite In (Main: F-type female)-
    1 x SCART
    1 x AV Composite In
    1 x AV Component In
    1 x CI+ 1.3
    Twin tuners
    DVB-C/T2/S2
    DiSEqC version 1.0
    PIP, Timeshift & PVR
    White balance- 2/10 points
    Gamma - 10 points
    CMS - no
    ISF -
    XD94
    XD9305
    65" (64.6), 55"
    наследник на X9305C
    No No 65" - 2%-1045cd/m2(HDR)
    65" - 5%-1153cd/m2(HDR)
    65" - 387cd/m2 (SD)
    55"-2%-987cd/m2(HDR)
    55" - (SD)
    Yes HDR10
    SMPTE standarts
    ST2084, ST 2086
    65" - AMVA3, 8-bit+FRC, 120/100Hz + MCFI
    55" - AMVA3, 8-bit+FRC, 120/100Hz + MCFI
    Semi-mate
    65"- (4 columns x 8 rows) 32 zones
    55"- (4 columns x 7 rows) 28 zones
    Edge led - Left & Right side
    Horizontal Dimming
    PWM Freq. 120/100Hz
    65"- DCI P3- 94.8% / Rec.2020-72%
    55"- DCI P3- 88.0% / Rec.2020-64.2%
    Quantum Dots
    65" - 3334:1/ 0.036cd/m2
    55" - 2600:1/ 0.046cd/m2
    65" - 45°
    55" - 32°
    65" - Game mode 51.0ms/
    55" - Game mode 52.3ms/
    Android TV : 5.1.1 Lolipop
    Board : SVPDTV15
    Core architecture:2x ARM Cortex-A17 (ARMv7)
    Instruction Set : 32-bit ARMv7
    CPU SoC:MediaTek MT5890 dual core
    GPU:ARM Mali T624 triple core
    RAM:1,5GB
    Internal storage total space:8,36GB
    Lan
    Wi-Fi
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    802.11 ac
    Wi-Fi Direct
    DLNA
    Bluetooth Ver. 4.1
    1 x Ethernet RJ45
    1 x SCART
    1 x AV Composite In
    1 x AV Component In
    1 x CI+ 1.3
    Twin tuners
    DVB-C/T2/S2
    DiSEqC version 1.0
    Gamma - 10 points
    CMS - no
    ISF -
    TV can not solve the very first step also correctly (17/255) XD93
    SD85
    (CURVED)
    65", 55"
    наследник на S8505C
    No No 65" - max - 1000cd/m2
    55" - max - 1000cd/m2
    Yes HDR10
    SMPTE standarts
    ST2084, ST 2086
    65" - AMVA3, (8-bit+FRC), 120/100Hz
    55" - AMVA3, (8-bit+FRC), 120/100Hz
    MCFI - Motion Clarity frame Interpolation
    Semi-mate
    65" - Edge Led (below)
    55" - Edge Led (below)
    (Blue Led)
    Frame Dimming
    65"-
    55"- DCI P3- 85.94%/ Rec.2020-63.7%
    Quantum Dots
    SBM (Super Bit Mapping) which upsample colors in 16-bit internal processing
    65" -
    55" -
    65" - °
    55" - °
    65" - Game mode
    55" - Game mode
    Board : SVPDTV15
    RAM:1,5GB
    Lan
    Wi-Fi
    802.11 b
    802.11 g
    802.11 n
    802.11 ac
    Wi-Fi Direct
    DLNA
    Bluetooth Ver. 4.1
    1 x Ethernet RJ45
    1 x SCART
    1 x AV Composite In
    1 x AV Component In
    1 x CI+ 1.3
    Twin tuners
    DVB-C/T2/S2
    DiSEqC version 1.0
    Gamma - 10 points
    CMS - no
    ISF -
    SD85
    XD85
    (8505, 8577, 8599)
    85", 75", 65", 55"
    копие на миналогодишният X850xC, но с нов дизайн, с IPS панел и без 3D
    No No 85" -
    75" -
    65" -
    55"- Window 2%-369cd/m2
    Limited
    85" - AS-IPS (8-bit+FRC), 120/100Hz
    75" - AS-IPS (8-bit+FRC), 120/100Hz
    65" - AS-IPS (8-bit+FRC), 120/100Hz
    55" - AS-IPS (8-bit+FRC), 120/100Hz
    Semi-mate
    85" - Edge led (below)
    75" - Edge Led (below)
    Quantum Dots (+ Blue Led)
    Frame Dimming associated with a very efficient mode (HDR particularly and especially on IPS panels) ACE (Advanced Contrast Enhancer) or improving advanced contrasts.
    No PWM
    85"-
    75"-
    65"-
    55"- DCI P3- 86% / Rec. 2020 - 63%
    Quantum Dots
    SBM(Super Bit Mapping) which upsample colors in 16-bit internal processing
    85" -
    75" -
    65" -
    55" - native 850:1 / black 0.12cd/m2
    1248:1/ 0.084cd/m2
    85" - °
    75" - °
    65" - °
    55" - °
    85" - Game mode
    75" - Game mode
    65" - Game mode
    55" - Game mode 34.6ms / by default 66.5ms
    As such, the audio rendering is quite above average, nothing special, but the advantage of being powerful enough to offer some serious and good reproduction of dialogue. I also appreciate the presence of a subwoofer output and many settings to improve the audio rendering, an EQ, a virtual surround mode, and especially the presence of Dolby Digital Plus and DTS decoders that can decode audio from MKV with DTS tracks and even send the DTS and Dolby stream Bitstream via HDMI or Optical ARC.
    Subwoofer output (ie that you can also connect a wireless subwoofer Sony SWF-BR100)
    Board : SVPDTV15
    RAM:1,5GB
    Lan
    Wi-Fi
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    802.11 ac
    Wi-Fi Direct
    DLNA
    Bluetooth Ver. 4.1
    1 x Ethernet RJ45
    1 x SCART
    1 x AV Composite In
    1 x AV Component In
    1 x CI+ 1.3
    Twin tuners
    DVB-C/T2/S2
    DiSEqC version 1.0
    Gamma - 10 points
    CMS - no
    ISF -
    In Europe it will exist in three design variants named
    ,KD-XD8505B (black) ,KD-XD8577S (silver) , ,KD-XD8588B (black) ,KD-XD8599B (black).
    What differences between references XD8505, XD8577 and XD8599? Let me be clear: no! This is simply references marketed only to please some signs that make large volumes of sales, so they do not suffer from competition on the Internet. You will probably see a little difference, often on the index of fluidity XR1000 instead of XR800, but these are purely marketing indices. There is no visible difference between a Motionflow XR800 and XR1000.
    XD85
    XD80 - ??
    55", 49", 43"
    No No 55" - max -
    49" - max -
    43" - max -
    Limited
    55" - (8-bit+FRC), 60/50Hz
    49" - IPS, (8-bit+FRC), 60/50Hz
    43" - IPS, (8-bit+FRC), 60/50Hz
    49" - Motionflow XR 400
    43" - Motionflow XR 200
    49" - Edge Led (below)
    43" - Edge Led (below)
    55"-
    49"-
    43"-
    55"-
    49"-
    43"-
    55" - °
    49" - °
    43" - °
    55" - Game mode
    49" - Game mode
    43" - Game mode
    20 x 10W Mediatek MT5890
    2xARM Cortex-A17
    ARM mali-624
    Storage - 16GB
    Lan
    Wi-Fi
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    802.11 ac
    Wi-Fi Direct
    DLNA
    Bluetooth Ver.4.1
    2 x USB 2.0 (DС 5V MAX 500mА)
    1 x USB 3.0 (max 0.9A)
    1 х Еthеrnеt RJ45
    4 х НDМІ 2.0 (АRС,СЕС,MHL)
    1 х Ѕаtеlіtе іn(Маіn:F-tуре fеmаlе)->
    1 х ЅСАRТ
    1 х Соmроѕіtе іn (Vіdео+L/R)
    1 х Соmроnеnt іn (YРbРr+L/R)
    1 х Орtісаl Аudіо Оut
    1 х 3.5mm Аudіо Оut
    1 х Аntеnа (RF) (Fеmаlе)
    1 х СІ+1.3
    DVB-C/T2/S2
    DiSEqC version 1.0
    XD80
    SD80
    (curved)
    50"
    наследник на S8005C
    No No 50" - max -
    Limited
    50" - MVA, 8-bit+FRC,
    50" - Edge led (below)
    (Blue Led)
    50" - DCI P3 - 64% / Rec. 2020 -
    50"-
    50" - °
    50" - Game mode
    Mediatek MT5890
    CPU 2xARM Cortex-A17
    ARM Mali-624
    Storage -
    Lan
    Wi-Fi
    802.11 b
    802.11 g
    802.11 n
    802.11 n 5GHz
    802.11 ac
    Wi-Fi Direct
    DLNA
    Bluetooth Ver.4.1
    2 х UЅВ 2.0 (DС5 V МАХ500mА)
    1 х Еthеrnеt RЈ45
    4 х НDМІ2.0 (АRС,СЕС,MHL)
    1 х ЅСАRТ
    1 х 3.5mm Аudіо Оut
    1 х СІ+1.3
    DVB - T/C SD80
    XD75 - ??
    7505
    65"
    No No 65" - 500cd/m2
    Limited
    HDR10
    65" - ? , 8bit + FRC, 120/100Hz
    Mitionflow XR 800
    65" - Direct Led
    65" -
    65" -
    65" - °
    65" - Game mode
    - Mediatek MT5890
    CPU 2xARM Cortex-A17 (32 bits ARMv7)
    GPU Mali T624 3 Core
    Android
    Lan
    802.11 b
    802.11 g
    802.11 n
    Wi-Fi Direc
    DLNA
    1 x Ethernet RJ45
    1 x SCART
    1 x AV Composite In
    1 x AV Component In
    1 x CI+ 1.3
    DVB-T/T2/C/S2 XD75
    XD70 - ??
    55", 49"
    No No 55" -
    49" -
    No
    55" - AS-IPS, 8bit+FRC, 60/50Hz ?
    49" - AS-IPS, 8-bit+FRC, 60/50Hz
    55" - Edge Led
    49" - Edge Led
    55"-
    49"-
    55"-
    49"-
    55" - °
    49" - °
    55" - Game mode
    49" - Game mode
    Lan
    Wi-Fi
    802.11 b
    802.11 g
    802.11 n
    Wi-Fi Direct
    DLNA
    1 x Ethernet RJ45
    1 x SCART
    1 x AV Composite In
    1 x AV Component In
    1 x CI+ 1.3
    XD70
    Sony FullHD TV 2016 - european models
    Product
    __________________
    UHD
    Premium
    Dolby
    Vision
    HDR
    Videopanel
    Backlight & Dimming
    Contrast & Black level
    Color Space
    _____________________________________
    Viewing angle
    (cone)
    _______
    Input Lag
    Audio
    OS
    Board
    System on Chip
    Network
    ________________
    Connectivity
    Tuner
    Opportunities for calibration
    Picture Accuracy
    Out-of-the-Box
    (score out of 10)
    Product
    WD75x
    (750,755,756,757)
    49", 43", 32"
    No No 49" - max -
    43" - max
    32" - max
    No
    49" - 8-bit, Hz
    43" - 8-bit, Hz ?
    32" - 8-bit, Hz ?
    Motionflow XR 200
    49" - Edge Led
    43" - Edge Led
    32" - Edge Led
    Frame Dimming - BLB
    49" -
    43" -
    32" -
    49" -
    43" -
    32" -
    49"- °
    43"- °
    32"- °
    49" - Game mode
    43" - Game mode
    32" - Game mode
    - - Lan
    Wi-Fi
    802.11 a
    802.11 b
    802.11 g
    802.11 n
    Wi-Fi Direct
    DLNA
    Bluetooth - only 43↑
    2 x USB 2.0 (DC5 V MAX500mA)
    1 x Ethernet RJ45
    2 x HDMI1.4 (ARC,CEC) in 43↑ 4xHDMI
    1 x Satelite in(Main:F-type female) ->
    1 x SCART
    1 x Composite in (Video+L/R)
    1 x Component in (YPbPr+L/R)
    1 x 3.5mm Audio Out
    1 x Antena (RF) (Female)
    1 x CI+1.3
    750 - DVBT/C
    752/753 -
    DVB-T/T2/C
    754/755/756/757/758/759
    DVB-T/T2/C/S/S2
    (+HEVC)
    Analog (PAL,SECAM)
    PVR + Time Shifting
    WD75
    WD6xx
    (600,605,653,655)
    48", 40",
    32"-WXGA
    No No 48" - max
    40" - max
    32" - max 236cd/m2
    No
    48" - MVA, 8-bit, 60/50Hz
    40" - MVA, 8-bit, 60/50Hz
    32" - IPS(AHVA), 8bit, 60/50Hz
    Motionfloe XR 200
    Semy-gloss
    48" - Direct Led / no local dimming
    40" - Direct Led / no local dimming
    32" - Direct Led / no local dimming
    Frame Dimmimg - BLB
    Without Interpolation
    No PWM
    48" -
    40" - 3397:1 / 0.032cd/m2 / 108.7cd/m2
    32" - 955:1 / 0.116cd/m2
    48" -
    40" - DCI P3 XY: 73.93% / DCI P3 UV: 81.54%
    Rec XY 2020: 53.13% / Rec UV 2020: 59.82%
    32" -DCI P3 xy: 76.48 % / DCI P3 uv: 88.70 %
    Rec 2020 xy: 54.88 % / Rec 2020 uv: 58.24 %
    48" - °
    40" - 13°
    32" - 53°
    48" - Game mode
    40" - Game mode 42.3ms / by default 42.4ms
    32" - Game mode 26.0ms / by default
    - - Lan
    Wi-Fi
    802.11 b
    802.11 g
    802.11 n
    Wi-Fi Direct
    DLNA
    Miracast
    1 x Ethernet RJ45
    1 x SCART
    1 x 3.5mm Audio Out
    1 x CI+1.3
    600/650 - DVB-T/C
    653 - DVB - T/T2/C
    605/655
    DVB-T/T2/C/S/S2
    (+HEVC)
    Analog (PAL,SECAM)
    WD60
    RD4xx
    (430,433,435,450,455)
    40", 32"
    No No No 40" - MVA, 8-bit, 60/50Hz
    32" - IPS, 8-bit, 60/50Hz ?
    Motionflow XR 200
    Semy-gloss
    40" - Direct Led
    32" - Direct Led
    40" -
    32" -
    40" -
    32" -
    40" - °
    32" - °
    40" - Game mode 45.0ms /
    32" - Game mode
    - - Lan
    W-Fi
    802.11 b
    802.11 g
    802.11 n
    1 x Ethernet RJ45
    1 x SCART
    1 x 3.5mm Audio Out
    1 x CI+1.3
    400/430/450
    DVB-T/C
    435/455
    DVB-T/T2/C/S2
    (+HEVC)
    Analog (PAL,SECAM)
    WD4xx
    Този пост е редактиран от hristoslav2; 23-07-16 в 23:12.
  3. Junior Member
    Jul 2016
    #1112
    МОга ли да инсталирам приложения за нормален андроид? Искам да си инсталирам TV GO на виваком.
  4. Senior Member Аватара на iveto
    Jan 2013
    Свети Влас
    #1113
    Няма проблем да го инсталираш на телевизора,въпроса е дали ще работи...например HBO GO на телевизори Сони с Андроид не тръгва...поне за сега...
    Frogst одобрява това.
  5. Junior Member
    Jul 2016
    #1114
    Как? Не го намирам в google store
  6. Member Аватара на Сидеров
    Feb 2016
    #1115
    Цитат Първоначално публикувано от Percey Виж публикацията
    https://youtu.be/pfbceDoZDUk
    Надявам се да ти помогне.
    Dec 2013
    #1116
    Цитат Първоначално публикувано от iveto Виж публикацията
    Особеното при "HBO GO" е, че работи само през WiFi. Не знам как е при Sony - пробвал ли си, ако изключиш ЛАН кабела? При мен на бокса се получава, но неприятното е, че качеството не е задоволително (което е обяснимо, защото качеството на картината се определя автоматично според качеството на връзката, а през WiFi, не е като през ЛАН)
    Този пост е редактиран от Frogst; 22-07-16 в 22:08.
  9. Junior Member
    Jul 2016
    #1117
    Благо даря на Iveto и Сидеров. Засега успях да инсталирам приложението на булсат и работи . Качеството не е много добро. С tv go не съм пробвал, защото не мога да му сваля апк файла. Някой ако успее да го свали може да го качи някъде.
    успях с apkpure но образа нещо е завъртян иначе върви
  10. Senior Member Аватара на iveto
    Jan 2013
    Свети Влас
    #1118
    Цитат Първоначално публикувано от Frogst Виж публикацията
    През бокса ти тръгва,защото е лицензиран за HBO GO...Sony и Philips android телевизори нямат лиценз за него...обаче..през смартфона и таблета го каствам към телевизора без проблем с доста приемливо качество....само за проба разбира се....не че го гледам,даже въобще не ме вълнува...
    Dec 2013
    #1119
    Не е лицензиран бокса, а и мисля че няма боксове лицензирани за HBO GO. Политика на компанията..
    Ти пробва ли през WiFi дали тръгва?
    П.П.
    Хм, тук пише друго:https://help.hbogo.com/hc/en-us/arti...on-Android-TV-
    Би трябвало да тръгне на Сони, а имало и лицензирани боксове.
    Този пост е редактиран от Frogst; 23-07-16 в 01:13.
  12. Junior Member Аватара на martinov83
    Nov 2015
    #1120
    Много лесно се преработват приложения за телевизора през смартфона с приложението App Cloner (apk download). Само включвам "Leanback launcher support", изпращам го с ES File Explorer към телевизора и след като го инсталирам, се появява в списъка с приложенията. Няма нужда от друг Launcher.
  13. Senior Member Аватара на iveto
    Jan 2013
    Свети Влас
    #1121
    П.П.
    Да,знам какво пише там,но мисля че важи само за американските модели....На MINIX плеярите също са лицензирани за HBO GO...между другото сега си спомних че успях да го подкарам на телевизора едно време...но само за малко,може да е било някакво демо,защото при следващи опити забиваше яко....да само през Wi FI върви...така е...
    #1122
    Пробвай VLC player...чете всичко без проблем....
    Верно VLC-то се справи най-добре - всички УХД клипове възпроизведе коректно , даже и HDR маркираните , само на "японката" и на един тестов нощен клип на Панасоник зацикли и насичаше .
    Абе за гледане на някоя серия от сериал нямам кой знае какви претенции .
    Сложих и другите приложения дето ми прати , някои обаче са почти невъзможни за ползване само с дист. у-е , добре че имах една мишка под ръка
    Sony KD-65XD7505 : TV Ultra HD/4K Direct LED, Motionflow XR 800, HDR10 et Android TV
    Този пост е редактиран от svetlio1; 23-07-16 в 17:31.
  16. Senior Member Аватара на iveto
    Jan 2013
    Свети Влас
    #1123
    Да,приложенията искат мишка или клавиатура...можеш да си свалиш на смартфона Sony Tv side View ,върши чудесна работа...и да пробваш с него..
  17. Senior Member Аватара на svetlio1
    #1124
    Да , свалил съм го, ама нещо не ми откри тв , а не ми се занимаваше - по-лесно стана с мишката .
  18. Junior Member
    Jul 2016
    #1125
    Може ли да попитам има ли го въобще някъде в БГ телевизора от края на поста ти.
  1. Избор на климатик 2016 г.
    Отговори: 3492
    Последно: 01-01-17, 18:50
  2. Квалификации Евро 2016
    От iihtiandar във форум Спорт
    Последно: 10-06-16, 09:03
  3. SONY телевизори 2015
    Отговори: 866
    Последно: 02-01-16, 08:36
  4. Отговори: 0
    Последно: 25-10-10, 12:26
  5. Отговори: 4
    Последно: 27-05-08, 08:30
