Виж нивото и качеството на сигнала какво е на този от менюто. Може да имаш калпава връзка в някой сплитер. Това е първото, което бих проверил.
бихте ли ми казали как да си настроя компа към сони 55 HF9005,от начало всичко тръгна перфекто после всичко се скапа.пробвах какво ли не.
мерси за "помоща",помогнах си сам.
п.с.-по принцип тука положението е малко като да чакаш от умрял писмо;)
това зависи от настройките на видеокартата
HDMI PC Input Format
640 x 480 @31.5kHz, 60Hz
800 x 600 @37.9kHz,60Hz
1024 x 768 @48.4kHz,60Hz
1280 x 1024 @64.0kHz,60Hz
1152 x 864 @67.5kHz,75Hz
1600 x 900 55.9kHz,60Hz
1680 x 1050 @65.3kHz,60Hz
1920 x 1080 @67.5kHz,60Hz
HDMI Signal
4096x2160p(24,60Hz),
3840x2160p(24,30,60Hz),
1080p(30,60Hz),
1080/24p, 1080i(60Hz),
720p(30,60Hz), 720/24p,
480p, 480i
https://www.valueelectronics.com/upl..._Specsheet.pdf
Sony, сега уж имат по-мощен Soc Ultimate X1, но продължават да инсталират профил DV с ниска латентност...
Sony A9F OLED TV - Page 5 - Blu-ray Forum
Blu-ray Forum - View Single Post - Sony A9F OLED TV
Blu-ray Forum - View Single Post - Sony A9F OLED TVЦитат:
Sony had always planned on implementing Dolby Vision HDR in the low latency standard. They are doing that so there TVs are ready for Dolby Vision HDR gaming. The delay was due to Dolby Vision testing and certification, which is common for all Dolby Vision devices.
Regarding Panasonic's UB820/UB824 I've been told they will be Dolby Vision low latency capable.
It's not "DV-lite" as it's just a newer version (not stripped down, as the nickname would suggest; just not backwards compatible) with the main benefit of lower latency.
It's understandable that people who've invested in older Dolby Vision hardware would act dismissive of it. If possible, I'd like to see hardware support both the older version and the newer low latency version sometime soon in the future, though.
Panasonic UB820/UB9000 w/HCX video processor & dynamic conversion adjustment - Page 34 - Blu-ray ForumЦитат:
Sorry, rushing off to my dear friends funeral service so just a short answer at this moment.
Yes, Sony's A9F and Z9F will use the same DV low latency standard.
Panasonic UB820/UB9000 w/HCX video processor & dynamic conversion adjustment - Page 44 - Blu-ray Forum
Panasonic UB 820, UB 9000 и Pioneer UDP-LX500 също ще бъдат съвместими с този последен потребителски профил.
SONY AF9
30/07/18 - AutoCal
https://www.youtube.com/watch?v=xFx5_8M02C8
索尼发布「画谛」系列电视 A9F / Z9F,打造高端旗舰级视听影音体验_搜狐科技_搜狐网
https://new.qq.com/cmsn/20180816/20180816040798.html
Sony представя MASTER сериите 4K HDR телевизори
http://https://www.kaldata.com/хардуер/sony-представя-master-сериите-4k-hdr-телевизори-291325.html/amp
Sony KD-A1 ,чете файла с най-голям битрейт, но леко насича в началото при големият контраст - Jellyfish Bitrate Test Files
После, на синята сцена е плавно.
сега и на руски
https://www.youtube.com/watch?time_continue=647&v=zzu-Qjeeb6Y
Подсветка на XE9000
55XE9005 (15x7=105 светодиода)
http://forum.ixbt.com/post.cgi?id=at...596:3285:1.jpg
65XE9005 (15x9=135 светодиода)
http://forum.ixbt.com/post.cgi?id=at...596:3285:2.jpg
75XE9005 (16x12=192 светодиода)
http://forum.ixbt.com/post.cgi?id=at...596:3285:3.jpg
количеството зони е указано на платката за подсветката (LD xx)
http://forum.ixbt.com/post.cgi?id=at...596:3287:1.jpg
Sony Master Series event: Everything about the X1 Ultimate processor (MediaTek 5893)
https://www.4kfilme.de/sony-master-s...ate-prozessor/
https://www.4kfilme.de/wp-content/up...-prozessor.jpg
Sony ZF9: 4K HDR TV with X1 Ultimate processor and FALD
https://www.4kfilme.de/sony-zf9-4k-h...ssor-und-fald/
https://www.4kfilme.de/wp-content/up...oid-8-oreo.jpgЦитат:
...Anyone expecting a direct successor to the ZD9 will probably be disappointed. Rather, the ZF9 should be considered as a stand-alone model and is probably after a look at the data sheet rather an improved XF90 . In the quasi predecessor ZD9 about 630 dimming zones were used, in the current model, there are only 104 dimming zones. Both devices are a direct LED backlight (FALD)...
Sony AF9: 4K OLED with Pixel Contrast Booster and X1 Ultimate processor
https://www.4kfilme.de/sony-af9-4k-o...ate-prozessor/
https://www.4kfilme.de/wp-content/up...rueckseite.jpg
Много се бях настроил за тоя ZF9, но с тия 104 зони... не знам какво да очаквам, а цената му е под 6000 лв за 65' и не знам дали си заслужава. Да чакам CES 2019? Нещо по-добро от Q9FN в LCD сегмента има ли в момента?
Sony анонсира Oreo за телевизори ATV2 платформа базирана на MT5891, но не и за ATV1 базирана на MT5890. Philips обяви актуализирането на телевизори, базирани на MT5890, докато Sony не го прави..
Гугъл изпраща софтуера на поредната версия, а от Сони го оптимизират за съответният чипсет - Android Sony Edition.Цитат:
“The plan is to update all 2018 and 2017 models to Oreo within CY [calendar year] 2018. In addition, some models from the 2016 range will also be updated, however we can’t confirm model numbers at this stage. Timings for updates may vary between models”.
Гугъл не позволява да се пипа интерфейса!
Има няколко версии на платформите, на които са базирани телевизорите. Всяка една използва различни Mediatek SOC чипсети.
Една платформа се използва в две поредни години - в моделите излизащи през втората половина на едната игодина и после в моделите излизащи през първата половина на следващата година.
ATV - AndroidTV
https://sonyeu1.i.lithium.com/t5/ima...al?v=1.0&px=-1
ATV1 Plattform - модели от втората половина на 2015 година (X90C, X85C, S85C, X83C, S80C, W85C, W80C, W75C) и модели от първата половина на 2016 (XD94, XD93, XD85)
Produkt: BRAVIA_ATV1_4K_EU Equipment: BRAVIA 4K CPU: MediaTek MT5890 (aka MediaTek 5595)
ATV2 Plattform - модели от втората половина на 2016 година (ZD9, XD80, XD75, XD70) и модели от първата половина на 2017 (A1, XE94, XE93, XE90, XE85)
Produkt: BRAVIA_ATV2_4K_EU Equipment: BRAVIA 4K GB ATV3 CPU: MediaTek MT5891 (aka MediaTek 5596)
ATV3 Plattform - модели от втората половина на 2017 година () и модели от първата половина на 2018 (AF8, XF90, XF85, XF83)
Produkt: BRAVIA_ATV3_4K-EU Equipment: BRAVIA 4K GB ATV3 CPU: MediaTek MT5891 (aka MediaTek 5596)
UR1 Plattform - модели от втората половина на 2018 година (AF9, ZF9) и модели от първата половина на 2019 година
Produkt: BRAVIA_UR1_4K_EU Equipment: BRAVIA 4K CPU: MediaTek 5893 (aka MediaTek 5598)
MediaTek 5598
ARM Cortex-A73
CPU Cores-4
CPU Frequency 1500 MHz
GPU ARM Mali-G71
RAM - 4GB
Storage - 16GB
https://sonyeu1.i.lithium.com/t5/ima...e?v=1.0&px=999
Спецификациите с около 3GB RAM и почти 6GB Flash отговарят на този показател
https://gfxbench.com/device.jsp?benc...testgroup=info
Така че масовото съхранение се намалява още повече.
Графичното представяне на Mali G71 се е удвоило в сравнение с Mali T860 на ATV2. CPU е Quad Core ARM Cortex A73, който вече е повече от два пъти по-бърз от A53 и също така идва с около 35% по-висока тактова честота.
Тъй като сега може да се осмелим да пробваме една или друга игра, трябва да се надяваме, че разширението на външната памет чрез USB ще бъде най-накрая използваемо и MediaTek ще поправят грешките (вижте тук). 6GB Flash не е достатъчна..
Сега платформата ATV3 изглежда е най-накрая това, което ATV1 би трябвало да бъде от самото начало (с изключение на разширението за масово съхранение), като приемем, че MediaTek накрая са поправили безбройните бъгове.. Предполагам, че ATV3 ще получи нов фърмуер, а ATV2 ще изпита малки корекции на грешките от тази точка, точно както при прехода от ATV1 към ATV2.
СORE UR1 най-накрая получава актуално и поддържано 4.9.51 Linux Kernel ядро.
Любопитно, дали ATV2 ще получи актуализация или ще остане на вече не поддържаната 3.10er, която беше базовата линия за Android 4 KitKat преди 5 години.
Защо ли това не ме учудва?
Както и въобще използването в TV на MTK процесори, толкова недолюбвани в телефоните.
https://www.sony.bg/electronics/supp...icles/00202206
Актуализация на фърмуерa за Android TV на Sony от 2016 – 2018 г. (XD70, XD75, XD80, SD80, XD83, ZD9, XE80, XE83, XE85, XE90, XE93, XE94, A1, XF75, XF80, XF83, XF85, XF87, XF90 и AF8 Series) – 5 септември 2018 г.
Имаме удоволствието да Ви съобщим, че ще бъде издадена нова актуализация на фърмуера (6.562) директно на Вашия телевизор на 5 септември 2018 г. и ще бъде разпространявана постепенно през месеца.
Този нов фърмуер допълнително ще подобри работните показатели на телевизора благодарение на следните надстройвания:
- Подобрява яркостта на картината при специфичен набор от обстоятелства
- Подобрена съвместимост с приложението Home Theatre Control
- Поддържа UHD HDR за поточно предаване на живо с BBC iPlayer
- Подобрява яркостта на картината за Hybrid Log Gamma (HLG) за режим с наситени цветове*
ЗАБЕЛЕЖКА: За пълния списък с функции и предимства или за изтегляне на този фърмуер, моля, отидете на специфичната за Вашия телевизор продуктова страница.
Препоръчителният начин да получите тази актуализация е да се уверите, че настройката Автомат. изтегляне на софтуер на Вашия телевизор е зададена на ВКЛ. След което Вашият телевизор трябва да получи автоматично обновяване през следващите седмици.
Можете също да изтеглите фърмуера от европейския сайт за поддръжка и да актуализирате телевизора чрез USB устройство с флаш памет.
Sony винаги взима предвид обратната връзка на потребителите, като се стреми към нововъведения и цялостно качество на продуктите.
[Приложими серии на модели телевизори]
Някой с XE8577 пробвал ли е новия софт и има ли нещо което да си заслужава ъпдейта?
Аз го сложих на моя. Не виждам някаква промяна в качеството на картината. За момента имам чувството, че малко лагва в менютата.
Привет на всички!Интересува ме,от чисто любопитство,дали телевизорите на "Сони",които се продават в Германия,са с различно качество от тези,продавани тук?
Питам,понеже заминавам да живея в Германия,и се чудя дали да си нося тв-то от тук,или там да си купя нов?
