| Sony Bravia OLED & LCD TV 2019 Line-up |
 | Class |  Premium - MASTER Series |  Mainstream |  Entry |
 | Type |  OLED - UltraHD |  LCD - UltraHD |
 Series __________________ |  AG7  Continues as a OLED flagship until September when it will be replaced by AG8 ?   _____________________ |  ZF9  Continues as a LCD flagship until September when it will be replaced by ZG9 ? _________________________ |  XG90  Mid March ____________________ |  XG80  late April ____________________ |  XG70  Mid September ____________________ |  XG60  Mid July _____________________ |
 Models  |  KD-65AG7
KD-55AG7  |  KD-75ZF9
KD-65ZF9  |  KD-75XG9005
KD-65XG9005
KD-55XG9005  |  KD-85XG8005
KD-75XG8005
KD-65XG8005
KD-55XG8005  |  KD-75XG7005
KD-65XG7005
KD-55XG7005
KD-49XG7005  |  KD-70WG6005
KD-60XG6005
KD-50XG6005
KD-40XG6005  |
 | Formats |  65", 55" |  65", 75" |  55", 65", 75" |  55", 65", 75", 85" |  49", 55", 65", 75" |  40", 50", 60", 70" |
 | Panel |  OLED(Oxide-WOLED-CF)
Gen. 4.0
LG Display
Support color - 10-bit
3840(WRGB)×2160, UHD
Life time: 15,000hr |  SVA (type MVA)
Samsung Display
3840(RGB)×2160, UHD |  Super UVVA-MVA
Innolux
3840(RGB)×2160, UHD |  AMVA3
Acer Unipac Optronics
Support color -
3840(RGB)×2160, UHD |  AS-IPS-VI
LG Display
Support color -
3840(RGB)×2160, UHD |  ASV
Sharp Display
 | Backlight Type |  OLED is a self-emitting pixels display technology meaning that it controls luminance on the pixel level |  Full-Aray local Dimming  75" - ? zones
65" - 104 zones |  Slim Backlight Drive Pro  75" - ? zones
65" - ? zones
55" - ? zones |  Direct LED |  Direct LED |  Direct LED |
 | Motion Enhancer |  X-Motion Clarity for OLED |  X-Motion Clarity  (Rolling scan) |  X-Motion Clarity  (Rolling scan) |  X-Motion Clarity |  X-Motion Clarity |  - |
 | Processor |  Picture Processor X1 Plus   ??
MediaTek 5599
Platform BRAVIA_ |  Picture Processor X1 Ultimate Mediatek 5893(5598)
4xARM Cortex-A73 @ 1500MHz
64-bit ARMv8-A (32-bit mode)
GPU - ARM Mali-G71 Vulkan
RAM - 4GB
Storage - 16GB
(approximately 6GB available)
Platform BRAVIA_ATV3 |  Picture Processor X1 Ultimate Mediatek 5893(5598)
RAM - 4GB
Storage - 16GB
Platform BRAVIA_ATV3 |  Picture Processor X1 Extreme   ??
Mediatek 5892(5597)
Platform BRAVIA_ATV3 |  Picture Processor X1 Plus   ??
MediaTek 5599
Platform BRAVIA_ |  Picture Processor X1 HDR   ??
Mediatek 5892(5597)
 | X-tended Dynamic Range PRO |  Pixel Contrast Booster
(Contrast ANSI: ∞:1) |  XDR Contrast 14K
(Contrast ANSI: 1700:1) |  XDR Contrast 10K
(Contrast ANSI: 4400:1) |  XDR Contrast 8K
(Contrast ANSI: 3500:1) |  XDR Contrast 6K
(Contrast ANSI: 900:1) |  No Local Dimming
(Contrast ANSI: 3000:1) |
 | Viewing Angle |  - |  X-Wide Angle |  - |  X-Wide Angle PRO |  - |
 | IMAX Enchanted |  YES |  - |
 Dolby Vision  (HDR10 / HDR HLG) |  YES |  - |
 | Triluminos Display |  - |  YES
(Blue Leds - PFS (potassium-fluorosilicate) phosphor featuring an extremely narrow red peak - "TRILUMINOS") |
 | Native Refresh Rate |  48/50/60/100/120Hz |  48/50/60 Hz |
 | AUDIO |   |  AUDIO POWER OUTPUT: 10W+10W
BASS/TREBLE/BALANCE: BALANCE
SPEAKER CONFIGURATION: 2CH, FULL RANGE (25X90MM) X 2
SPEAKER POSITION: DOWN FIRING
SPEAKER TYPE: BASS REFLEX |   |   |   |   |
 | AUDIO FEATURES |   |  ARC OUTPUT FORMAT: TWO CHANNEL LINEAR PCM: 48 KHZ 16 BITS, DOLBY DIGITAL, DOLBY DIGITAL PLUS, DTS
ADVANCED AUTO VOLUME: YES
ALTERNATE AUDIO (DIGITAL): YES
AUTO SURROUND: YES
CLEAR PHASE: YES
DTS AUDIO FORMAT SUPPORT: DTS DIGITAL SURROUND
DOLBY AUDIO FORMAT SUPPORT: DOLBY DIGITAL, DOLBY DIGITAL PLUS, DOLBY PULSE, DOLBY AC-4
HDMI INPUT AUDIO FORMAT: 5.1 CHANNEL LINEAR PCM: 32/ 44.1 /48/ 88.2 /96/ 176.4/ 192KHZ 16/ 20/ 24BITS, DOLBY DIGITAL, DOLBY DIGITAL PLUS, DTS, DOLBY ATMOS
S-MASTER: S-MASTER DIGITAL AMPLIFIER
SIMULATED SURROUND SOUND: S-FORCE FRONT SURROUND
SOUND MODES: STANDARD,DIALOG,CINEMA,MUSIC,SPORTS,DOLBY AUDIO |   |   |   |   |
 | CONVENIENCE FEATURES |   |  APPLICATION STORE: YES (GOOGLE PLAY STORE)
AUTO PICTURE MODE: YES
AUTO SHUT-OFF: YES
CHANNEL BLOCK (WITH PASSWORD): YES (ANALOG & DIGITAL)
CHROMECAST BUILT-IN: YES
ON-SCREEN CLOCK: YES
ON/OFF TIMER: YES
PARENTAL CONTROL: YES
SHOW/HIDE CHANNELS: YES (DIGITAL & ANALOG)
SLEEP TIMER: YES
VOICE SEARCH: YES
I-MANUAL: YES |   |   |   |   |
 HDMI   |  HDMI v.2.1 (HDMI 1/2/3/4) |  HDMI v.2.0b (HDMI 1/2/3) |
 HDCP  (copy protection) |  HDCP v.2.3 (for HDMI 1/2/3/4) |  HDCP 2.2
 Auto Low Latency Mode (ALLM)  Gaming Boost Mode |  15 ms
Extremely Low Input Lag |  20 ms
Low Input Lag |  High Quality Picture Enchancer |  20 ms
Anti aliasing & Low Input Lag |  15 ms
Extremely Low Input Lag |   |
 HDMI-CEC   |  YES |  - |
 HDMI-VRR  variable refresh rate |  YES |  - |
 eARC  return audio to an audio device via HDMI in high resolution |  YES
(support Lip Sync Correction, Uncompressed 7.1 & 5.1, Dolby TrueHD, Dolby Atmos, DTS: X) |  - |
 | HDMI PC Input Formats: |  - |  640X480 (31.5KHZ,60HZ),
800X600 (37.9KHZ,60HZ),
1024X768 (48.4KHZ,60HZ),
1280X1024 (64.0KHZ,60HZ),
1152X864 (67.5KHZ,75HZ),
1600X900 (55.9KHZ,60HZ),
1680X1050 (65.3KHZ,60HZ),
1920X1080 (67.5KHZ,60HZ) |   |  - |  - |  - |
 | HDMI Signal: |  - |  4096X2160P(24,50,60HZ), 3840X2160P(24,25,30,50,60HZ), 1080P(30,50,60,100,120HZ),
1080/24P, 1080I(50,60HZ),
720P(30,50,60HZ), 720/24P, 480P |  4096X2160P(24,50,60,100,120HZ), 3840X2160P(24,25,30,50,60,100,120HZ), 1080P(30,50,60,100,120HZ),
720P(30,50,60HZ), 720/24P, 480P |  - |  - |  - |
 | USB |  USB 2.0 (Type A)(x2) [speed up to 480Mbps]
USB 3.1 Gen 1 (Type A) [speed up to 5Gbps] |  - |
 | USB playback codecs: |  - |  MPEG1:MPEG1/ MPEG2PS: MPEG2/MPEG2TS (HDV,AVCHD):MPEG2,
AVC/ MP4 (XAVCS):AVC , MPEG4 ,HEVC/AVI :XVID, MOTINJPEG/ ASF(WMV): VC1/ MOV:AVC, MPEG4,
MOTIONJPEG/ MKV: XVID,AVC, MPEG4, VP8. HEVC/WEBM: VP8/3GPP: MPEG4, AVC/ MP3 /ASF (WMA) /WAV /MP4AAC / FLAC / JPEG WEBM:VP9/AC4/OGG/AAC/ARW(SCREEN NAIL ONLY) |  MPEG1:MPEG1/ MPEG2PS: MPEG2/MPEG2TS (HDV,AVCHD):MPEG2, AVC/ MP4 (XAVCS):AVC , MPEG4 ,HEVC/AVI :XVID, MOTINJPEG/ ASF(WMV): VC1/ MOV:AVC, MPEG4, MOTIONJPEG/ MKV: XVID,AVC, MPEG4, VP8. HEVC/WEBM: VP8/3GPP: MPEG4, AVC/ MP3 /ASF (WMA) /WAV /MP4AAC / FLAC / JPEG WEBM:VP9/AC4/OGG/AAC/ARW(SCREEN NAIL ONLY) |  - |  - |  - |
 | Bluetooth v.4.2 |  Bluetooth compatible with A2DP / AVRCP / HIDP / HOGP / SPP profiles  HIDP (Human Interface Device Profile) - Mouse / Keyboard Connectivity
HOGP (Low Energy Consumption)
SPP (Serial Port Profile)
A2DP (Advanced Audio Distribution Profile) - stereo audio
AVRCP (A/V Remote Control Profile) - AV remote control |  - |
 LAN
(Ethernet / RJ-45)  - Wi-Fi |  1 (bottom)
10BASE-T / 100BASE-TX Connector (The connection speed of the network may vary depending on the operating environment.)
10BASE-T / 100BASE-TX communication speed and quality are not guaranteed for this TV. ) Wi-Fi network 802.11 compatible a / b / g / n / ac (wireless discussion protocols)
Wi-Fi Frequency 2.4GHz / 5GHz
Compatible network: Wi-Fi Direct ™ (without router) • Miracast |  - |
 | Codecs for Home Network: |  - |  MPEG1: MPEG1/ MPEG2PS: MPEG2 /
MPEG2TS (HDV,AVCHD): MPEG2, AVC /
MP4(XAVC S): AVC, MPEG4, HEVC /
 AVI: XVID, MOTINJPEG /
AS F (WMV): VC1/
MOV : AVC, MPEG4, MOTIONJPEG /
 MKV:XVID, AVC, MPEG4, VP8. HEVC /
WEBM:VP8 / 3GPP:MPEG4,AVC /
MP3/ASF (WMA)/ LPCM/WAV/MP4AAC/FLAC/
JPEGMPEG1:MPEG1/MPEG2PS:MPEG2/
MPEG2TS(HDV,AVCHD):MPEG2,AVC/
AVI :XVID, MOTINJPEG/ ASF(WMV) :VC1 /
MOV: AVC ,MPEG4, MOTIONJPEG /
MKV :XVID ,AVC ,MPEG4, VP8. HEVC /
WEBM :VP8/ 3GPP :MPEG4 ,AVC /
MP3 /ASF (WMA)/
LPCM/WAV/MP4AAC/FLAC/JPEG  WEBM:VP9/AC4/OGG/AAC/ARW(SCREEN NAIL ONLY) |  MPEG1: MPEG1/ MPEG2PS: MPEG2 /
AS F (WMV): VC1/
MP3 /ASF (WMA)/
LPCM/WAV/MP4AAC/FLAC/JPEG  WEBM:VP9/AC4/OGG/AAC/ARW(SCREEN NAIL ONLY) |  - |  - |  - |
 | OS |  Android 8.0 OREO |  - |
 | Internet Browser: |  Vewd (Not Pre-Installed) Opera TV is now Vewd. |
 DLNA:  (home network feature) |  HOME NETWORK CLIENT, HOME NETWORK RENDERER (Digital Media Player / Digital Media Renderer)  (Digital Living Network Alliance) Founded in 2003 as the Digital Home Working Group, the DLNA (www.dlna.org) sets guidelines for using the Universal Plug and Play (UPnP) protocol to transfer and stream media between computers, mobile devices and home theater equipment. |
 Smartfone Connectivity:   |  Chromecast built-in
Video & TV SideView (iOS/Android) |
 Screen Mirroring:  (Miracast) |  YES (only for B2B purpose) |
 Netflix calibrated mode   |  YES |  - |
 | Remote control(s): |  - |  RMF-TX220E |  RMF-TX310E
Bluetooth communication |  - |  - |  - |
 Design:   Frame color:   Color / Base Type: |   |  BRAVIA / MASTER Series   Black   Black
Chevron Bipolar Base |   |   |   |  - |
