| Sony Bravia OLED & LCD TV 2019 Line-up |
 | Class |  MASTER Series |  Mainstream |  MASTER Series 8K |  Mainstream |  Entry |
 | Type |  OLED - UltraHD |  LCD - UltraHD |  LCD - FullHD |
 Series ___________________ |  AG9   __________________ |  AG8   __________________ |  ZG9 __________________ |  XG95
availability in March __________________ |  XG90
availability in March __________________ |  XG85 __________________ |  XG83 __________________ |  XG80
availability in April ___________________ |  WG66 __________________ |
 Models  |  KD-77AG9
KD-65AG9
KD-55AG9  |  KD-65AG8
KD-55AG8  |  KD-98ZG9
KD-85ZG9  |  KD-85XG9505
KD-75XG9505
KD-65XG9505
KD-55XG9505  |  KD-49XG9005  |  XG8599
XG8596
XG8588
XG8577
XG8505  |  KD-49XG8305
KD-43XG8305  |  KD-75XG8005
KD-65XG8005
KD-55XG8005
KD-49XG8005
KD-43XG8005  |  50WG665
50WG660
43WG665
43WG660  |
 | Formats |  55", 65", 77" |  65", 75" |  85", 98" |  55", 65", 75", 85" |  49" |  55", 65", 75", 85" |  43", 49" |  43"", 49",55",65",75" |  43", 50" |
 | Processor |
 | CPU & GPU |  X1 Ultimate Mediatek 5893(5598)
4xARM Cortex |  X1 Extreme   Mediatek 5892(5597)
4xARM Cortex-A73 @ 1500MHz
64-bit ARMv8-A (32-bit mode)
GPU - ARM Mali-G71 Vulkan |  X1 Ultimate Mediatek 5893(5598)
4xARM Cortex |  X1 Ultimate   Mediatek 5893(5598)
4xARM Cortex |  X1 Extreme   MediaTek 5597
GPU - ARM Mali-G71 Vulkan |  X1   Mediatek 5596
4xARM Cortex-A53 @ 1100MHz
GPU - ARM Mali-T860 MP2 |  X1   MediaTek 5596
GPU - ARM Mali-T860 MP2 |  X1   MediaTek |  -   MediaTek |
 | RAM |  4GB |  - |  - |
 | Flash |  16 GB internal memory (approximately 8GB available) + expandable via USB Dongle     |  - |
 | Operation System |  Android 8.0 OREO (update to Android 9.0 Pie) |  Linux kernel ? |
 | Display |
 Manifacturer:
Model:
Type:
Resolution:
Display aspect ratio:
Pixel Format:
Display Colors::
Luminance(cd/m²):
Viewing Angle:
Color Gamut:
Contrast Ratio:
Response speed(ms)
Frame Rate:
Life Time:   |  LG Display
LE650AQD / LE550AQD
AM-OLED, Oxide-WOLED-Color Filter
3840(RG/BW)x 2160, UHD
16:9 (H:V)
RGBW Vertical Stripe
1.07B (8-bit + Dithering)
500 (Typical) 900 max
60/60/60/60 (Typ.) (Left, Right, Up, Down)
97% DCI-P3
150000:1 (Typ.) (Transmissive)
1 (Typ.)(G to G); 8 (Typ.)(MPRT)
120Hz
30K (Typ.) (Hours). After that time, the brightness may drop about 50%.   |  98"(Samsung, LG)
85"(AUO, Innolux)
LCD
7680(RGB)×4320
16:9(H:V)
RGB Vertical Stripe
1.07B (8-bit + FRC)
-- (Typical) -- max
60/60/60/60 (Typ.)
97% DCI-P3
6000:1 (Typ.)
14 (Typ.)(G to G)
100/120Hz
30K (Typ.) (Hours).    |  LCD, Super-MVA
Innolux
LCD
3840(RGB)×2160
16:9(H:V)
RGB Vertical Stripe
1.07B (8-bit + FRC)
500 (Typical) -- max
60/60/60/60 (Typ.)
97% DCI-P3
6000:1 (Typ.)
14 (Typ.)(G to G);
100/120Hz
30K (Typ.) (Hours).    |  MVA
LCD
3840(RGB)×2160,
16:9(H:V)
RGB Vertical Stripe
1.07B (8-bit + FRC)
-- (Typical) -- max
60/60/60/60 (Typ.)
97% DCI-P3
1200:1 (Typ.)
14 (Typ.)(G to G)
100/120Hz
30K (Typ.) (Hours).    |  AMVA3
Acer Unipac Optronics
LCD
3840(RGB)×2160
16:9 (H:V)
RGB Vertical Stripe
1.7B (8-bit + FRC)
-   |  IPS ?
LCD
3840(RGB)×2160
16:9 (H:V)
RGB Vertical Stripe
1.07B (8-bit + FRC)
-- (Typical)
60/60/60/60
97% DCI-P3
1200:1 (Typ.)
14 (Typ.)(G to G)
100/120Hz
30K (Typ.) (Hours).    |  -
LCD
3840(RGB)x2160
16:9 (H:V)
RGB Vertical Stripe
LCD
1920(RGB)×1080
16:9 (H:V)
RGB Vertical Stripe
1.07B (8-bit + FRC)
-- (Typical)
60/60/60/60 (Typ.)
97% DCI-P3
?:1 (Typ.)
14 (Typ.)(G to G)
50/60Hz
 | Backlight Type |  OLED is a self-emitting pixels display technology meaning that it controls luminance on the pixel level |  FALD
Backlight Master Drive   |  FALD
85" - ? zones
75" - ? zones
65" - ? zones
55" - ? zones |  FALD
49" - ? zones |  Edge LED
Local Dimming |  Edge LED
Local Dimming |  55, 65, 75" - Direct Led
Global Dimming   43",49" - Edge Led
No Local Dimming |
 | Native Refresh Rate |  48/50/60/100/120Hz (100Hz - PAL / 120Hz - NTSC) |  48/50/60 Hz |
 | Viewing Angle |  - |  - |  X-Wide Angle Filter |  X-Wide Angle Filter
(only in 75" & 85") |  - |
 | Triluminos Display |  No |  Yes
(Blue Leds - PFS (potassium-fluorosilicate) phosphor featuring an extremely narrow red peak - "TRILUMINOS") |  No |
 | MEMC |  MotionFlow XR |  - |  - |
 | Motion Enhancer |  X-Motion Clarity |  ? |  X-Reality Pro |  - |
 | CalMan Calibration Function |  Yes |  No |  Yes |     |  No |
 | Object-based Super Resolution |  Yes |  - |  - |  - |  - |
 | Video Features |
 CineMotion/Film
Mode/Cinema Drive |  -- |  -- |  Yes |  -- |  -- |  -- |  -- |  -- |  -- |
 | 24p True Cinema |  -- |  -- |  -- |  Yes |  -- |  -- |  -- |  -- |  -- |
 | 4:3 Default |  -- |  -- |  -- |  Yes |  -- |  -- |  -- |  -- |  -- |
 | Auto Wide |  -- |  -- |  -- |  Yes |  -- |  -- |  -- |  -- |  -- |
 | Blinking Type |  -- |  -- |  -- |  Line Blinking |  -- |  -- |  -- |  -- |  -- |
 Dual database
processing |  -- |  -- |  -- |  Yes |  -- |  -- |  -- |  -- |  -- |
 Dynamic Contrast
Enhancer |  -- |  -- |  -- |  Yes |  -- |  -- |  -- |  -- |  -- |
 | Face Area Detection |  -- |  -- |  -- |  Yes |  -- |  -- |  -- |  -- |  -- |
 HDR (High Dynamic
Range) compatiblity |  HDR10, Hybrid Log-Gamma, Dolby Vision |  HDR10, HLG |  HLG |
 Live Color™
Technology |  -- |  -- |  -- |  Yes |  -- |  -- |  -- |  -- |  -- |
 Object-based HDR
remaster |  -- |  -- |  -- |  Yes |  -- |  -- |  -- |  -- |  -- |
 | Picture Modes |  Vivid, Standard, Cinema, Game, Graphics, Photo, Custom,  Dolby Vision Bright, Dolby Vision Dark, Netfix calibrated |  -- |  -- |  -- |  -- |
 Precision Color
Mapping |  -- |  -- |  -- |  Yes |  -- |  -- |  -- |  -- |  -- |
 Super Bit Mapping™
4K HDR |  Yes |  -- |  -- |  -- |  -- |
 | Video Processing |  4K X-Reality PRO |  -- |  -- |  -- |  -- |
 | Wide Mode |  Wide Zoom / Normal /
Full / Zoom
Normal / Full1 / Full2
for PC |  -- |  -- |  -- |  -- |
 | Audio |
 | Audio Power Output: |  -- |  -- |  -- |  10W + 10W |  -- |  -- |  -- |  -- |  -- |
 | Bass/Treble/Balance: |  -- |  -- |  -- |  Balance |  -- |  -- |  -- |  -- |  -- |
 | Speaker Confguration: |  -- |  -- |  -- |  2ch/Full Range (Bass
Refex)(25x90mm)x2,
Tweeterx2 |  -- |  -- |  -- |  -- |  -- |
 | Speaker Position: |  -- |  -- |  -- |  Side Back + Down Firing |  -- |  -- |  -- |  -- |  -- |
 | AUDIO |  Acoustic Surface Audio+
Support for Dolby Atmos will be provided through a future software update |  Acoustic Surface Audio |  Acoustic Multi Audio
TV Centre speaker Mode
Support for Dolby Atmos will be provided through a future software update |  Acoustic Multi Audio
2+2 speakers |  Acoustic Multi Audio
2 + 2 speakers |  Acoustic Multi Audio
2 speakers |  - |  - |
 | Audio Features |
 | Advanced Auto Volume: |  Yes |  -- |  -- |  -- |  -- |  -- |
 | Alternate Audio (Digital): |  Yes |  -- |  -- |  -- |  -- |  -- |
 | ARC Output Format : |  -- |  -- |  -- |  Two channel linear PCM:
48 kHz 16 bits,Dolby
Digital,Dolby Digital
Plus,DTS |  -- |  -- |  -- |  -- |  -- |
 | Auto Surround: |  Yes |  -- |  -- |  -- |  -- |  -- |
 | Clear Phase: |  Yes |  -- |  -- |  -- |  -- |  -- |
 Digital audio out
(Optical) format: |  -- |  -- |  -- |  Two channel linear PCM:
Digital,DTS |  -- |  -- |  -- |  -- |  -- |
 Dolby audio format
support: |  -- |  -- |  -- |  Dolby Audio (Dolby
Digital, Dolby Digital Plus,
Dolby AC-4) |  -- |  -- |  -- |  -- |  -- |
 DTS audio format
support: |  DTS Digital Surround |  -- |  -- |  -- |  -- |  -- |
 HDMI Audio Return
Channel(ARC): |  Yes (eARC)return audio to an audio device via HDMI in high resolution
(support Lip Sync Correction, Uncompressed 7.1 & 5.1, Dolby TrueHD, Dolby Atmos, DTS: X) |  -- |  -- |  -- |
 HDMI input Audio
format: |  5.1 channel linear PCM:
32 / 44.1/ 48/ 88.2/96/ 176.4/ 192kHz 16/20/24bits, Dolby Digital, Dolby Digital Plus, DTS |  -- |  -- |  -- |  -- |  -- |
 Simulated Surround
Sound: |  -- |  -- |  -- |  S-Force Front Surround |  -- |  -- |  -- |  -- |  -- |
 | S-Master: |  S-Master Digital Amplifer |  -- |  -- |  -- |  -- |
 | Sound Modes: |  -- |  -- |  -- |  Standard, Dialog,
Cinema, Music ,Sports,
Dolby Audio |  -- |  -- |  -- |  -- |  -- |
 | Convenience Features |
 | Application Store: |  Yes (Google Play Store) |  -- |
 | Auto Picture Mode: |  Yes |  -- |  -- |  -- |
 | Auto Shut-of: |  Yes |  -- |  -- |  -- |
 Channel Block (with
password): |  Analog & Digital |  -- |  -- |  -- |  -- |
 | Chromecast built-in: |  Yes |  -- |  -- |  -- |  -- |
 | HDMI-CEC: |  Yes |  -- |  -- |  -- |  -- |
 | i-Manual: |  Yes |  -- |  -- |  -- |
 | On/Of Timer: |  Yes |  -- |  -- |  -- |  -- |
 | On-Screen Clock: |  Yes |  -- |  -- |  -- |  -- |
 | Parental Control: |  Yes |  -- |  -- |  -- |  -- |
 | Show/Hide Channels: |  Yes (Digital & Analog) |  -- |  -- |  -- |  -- |
 | Sleep Timer : |  Yes |  -- |  -- |  -- |  -- |
 | Text Input Language: |  -- |  -- |  -- |
 USB drive format
support: |  Yes (Supported File
System: FAT16/FAT32/
exFAT/NTFS) |  -- |  -- |  -- |
 | USB playback codecs: |  MPEG1: MPEG1/
MPEG2PS: MPEG2/
MPEG2TS (HDV,AVCHD): MPEG2,AVC /
MP4 (XAVC S): AVC ,MPEG4,HEVC /
AVI: Xvid, MotinJpeg/
ASF(WMV): VC1/
MOV:AVC, MPEG4, MotionJpeg/
MKV: Xvid, AVC,MPEG4, VP8.HEVC /
WEBM: VP8/
3GPP: MPEG4, AVC /MP3 /ASF (WMA) /WAV/ MP4AAC / FLAC /
JPEG WEBM: VP9/ AC4/ogg/AAC/ ARW(Screen nail only) |  -- |  -- |
 | Voice Search: |  Yes*
*Hands Free feature(Builtin Mic) availability depends on language and may need sofware update.
Please check Sony support page for further information;  https://www.sony.net/tv-hf-ww/ |  -- |  -- |  -- |  -- |  -- |
 | Inputs and Outputs |
 4K 60P High-Quality
formats |  - |  - |  HDMI IN1, IN2, IN3, IN4
ports for 4K(up to 6Gbps)
signal |  - |  - |  - |  - |  - |
 Analog Audio Input(s)
(Total) |  - |  - |  1 (1Side Analog
Conversion) |  - |  - |  - |  - |  - |
 Bluetooth profle
support |  Version 4.2 - compatible HID/HOGP/SPP/A2DP/AVRCP profiles
HIDP (Human Interface Device Profile) - Mouse / Keyboard Connectivity
HOGP (Low Energy Consumption)
SPP (Serial Port Profile)
A2DP (Advanced Audio Distribution Profile) - stereo audio
AVRCP (A/V Remote Control Profile) - AV remote control |  - |  - |  - |
 Composite Video
Input(s) |  - |  1 (Side) |  - |  - |
 | Digital Audio Output(s) |  1 (Bottom) |  - |  - |  - |  - |
 | Ethernet Connection(s) |  1(Bottom)
10BASE-T / 100BASE-TX Connector (The connection speed of the network may vary depending on the operating environment.)
10BASE-T / 100BASE-TX communication speed and quality are not guaranteed for this TV. ) |  - |
 | HDCP |  HDCP2.3(for
HDMI1/2/3/4) |  - |  - |  - |  - |
 | HDMI inputs total |  4 x v.2.0b (1Side,3Bottom)- no VRR, QMR |  - |  4 x v.2.0b (1Side,3Bottom)- no VRR, QMR |  - |  - |  - |  - |
 | HDMI Signal |  4096x2160p (24,60Hz),
3840x2160p (24,30,60Hz),
1080p (30,60,120Hz),
1080/24p, 1080i (60Hz),
720p (30,60Hz), 720/24p,
480p |  - |  - |  - |  - |
 | HDMI™ PC Input |  640 x 480 (31.5kHz,60Hz),
800 x 600 (37.9kHz,60Hz),
1024x768 (48.4kHz,60Hz),
1280x1024 (64.0kHz,60Hz),
1152x864 (67.5kHz,75Hz),
1600x900 (55.9kHz,60Hz),
1680x1050 (65.3kHz,60Hz),
1920x1080 (67.5kHz,60Hz) |  - |  - |  - |  - |
 | Headphone Output(s) |  1 (Side) |  - |  - |
 | RF Connection Input(s) |  1 (Bottom) |  - |
 | RS-232C Input(s) |  1 |  - |  - |  - |  - |
 | USB Port(s) |  - |  - |  2 (Side) / 1 (Bottom)
USB 2.0 (Type A)(x2) [speed up to 480Mbps]
USB 3.1 Gen 1 (Type A) [speed up to 5Gbps] |  - |  - |
 | Network Features |
 Codec for Home
Network |  MPEG1: MPEG1/
MPEG2PS :MPEG2 /
MPEG2, AVC/ MP4(XAVC
S): AVC, MPEG4, HEVC/
ASF (WMV): VC1/
MOV: AVC, MPEG4,
MotionJpeg/ MKV: Xvid,
AVC, MPEG4, VP8.HEVC/
WEBM: VP8/ 3GPP:
MPEG4, AVC /MP3/ ASF
(WMA) /LPCM /WAV /
MP4AAC /FLAC/ JPEG |  - |  - |  - |  - |
 | DLNA |  HOME NETWORK CLIENT, HOME NETWORK RENDERER (Digital Media Player / Digital Media Renderer)
(Digital Living Network Alliance) Founded in 2003 as the Digital Home Working Group, the DLNA (www.dlna.org) sets guidelines for using the Universal Plug and Play (UPnP) protocol to transfer and stream media between computers, mobile devices and home theater equipment. |  - |
 | Internet Browser: |  Vewd (Not Pre-Installed) Opera TV is now Vewd. |  - |
 Screen
mirroring(Miracast™) |  YES (only for B2B purpose) MHL 3.0 |  - |
 | Wi-Fi |  Wi-Fi network 802.11 compatible a / b / g / n / ac , Wi-Fi Frequency 2.4GHz / 5GHz
Compatible network: Wi-Fi Direct ™ (without router)  |  - |  - |
 | Auto Low Latency Mode (ALLM) |  15 ms
Extremely Low Input Lag |  20 ms
Low Input Lag |  - |  - |  - |  - |  - |     |
 HDMI-VRR
variable refresh rate |  YES |  - |  - |
 Smartfone Connectivity:   |  Chromecast built-in
Video & TV SideView (iOS/Android) |  - |
 | Remote control(s): |  new remote |  - |  new remote |  - |  - |  - |  - |  - |
 Design:   Frame color:   Color / Base Type: |  - |  - |  - |  - |  - |  - |  - |  - |
