Отговор: SONY телевизори 2020
Аз си направих такава симулация с фотошоп. Полезно приложение ако работи коректно. Ще го тествам.
П.С.
Греда, сваляйте от тук:
https://www.apkmirror.com/apk/sony-e...-apk-download/
Sent from my SM-N975F using Tapatalk
https://uploads.tapatalk-cdn.com/202...9a07212799.jpg
SONY KD48A9BU - £1699.00 (само за сравнение LG OLED48CX е £1499.00)
https://www.rgbdirect.co.uk/Products.../SONY/KD48A9BU
На тези цени жалко за очаквания размер! Да си ги гледат самички!!
Sony 65X9000H (в Европа - 65XH9000)
https://post.smzdm.com/p/ag875ded/
превод
https://translate.google.bg/translat...%2Fag875ded%2F
X9500H (в Европа XH9500)
https://post.smzdm.com/p/andlq4g0/
Sony 8K 75Z8H (в Европа 75ZH8)
https://post.smzdm.com/p/alpwln7g/
| Sony Android TV (EU) - Platform |
| Platform & SoC | 2020 | 2019 | 2018 | 2017 | 2016 | 2015 |
Model: BRAVIA VH1
SoC: MediaTek MT5895 (aka S900)
Installed RAM: 3 GB
Core Architecture: 4x ARM Cortex-A73
CPU Clock: 1800MHz
GPU Renderer: ARM Mali-G52
Storage: 16 GB
OpenGL ES: 3.2
Android 32-bit (9.0 Pie)
Supports HDMI 2.1 (48Gbps) , HDCP 2.3, USB 3.0 | HX9299 - 4K HDR X1
HX9288 - 4K HDR X1
HX9096 - 4K HDR X1
HX9077 - 4K HDR X1
HX9005 - 4K HDR X1 | | | | | |
Model: BRAVIA 4K UR3
SoC: MediaTek MT5893 (aka MT5598)
Instaled RAM: 2.5 GB
Core Arhitecture: 4x ARM Cortex-A73
CPU Clock: 1032-1500MHz
GPU Renderer: ARM Mali-G71
Storage: 16 GB
OpenGL ES: 3.2
Android 32-bit (9,0 Pie)
Support: HDMI 2.0b (18Gbps), HDCP 2.2, USB 3.0 & 2.0 | Oled A89,A87,A85 - X1 Ultimate
ZH8 (8K) - X1 Ultimate
XH9505 (85-55") - X1 Ultimate
HX8588 - 4K HDR X1
HX8577 - 4K HDR X1
HX8505 - 4K HDR X1
HX8196 - 4K HDR X1
HX8096 - 4K HDR X1
HX8077 - 4K HDR X1 | | | | | |
Model: BRAVIA 4K UR2
Installed RAM: 2.5 GB
Storage: 16 GB
OpenGL ES: 3.2
Android 32-bit (8 Oreo)
Supports HDMI 2.0b (18Gbps), HDCP 2.2, USB 3.0 & 2.0 | HX9505 (49") - X1 Ultimate | ZG9 - X1 Ultimate
Oled AG9 - X1 Ultimate
XG9505 - X1 Ultimate
XG8599 - 4K HDR X1
XG8596 - 4K HDR X1
XG8588 - 4K HDR X1
XG8577 - 4K HDR X1
XG8505 - 4K HDR X1 | | | | |
Model: BRAVIA 4K UR1
Installed RAM: 4 GB
CPU Clock: 1500MHz
Storage: 16 GB
OpenGL ES: 3.2
Android 32-bit (8.0 Oreo)
Support: HDMI 2.0b (18Gbps) HDCP 2.2, USB 3.0 & 2.0 | | AG8 - X1 Ultimate | AF9 - X1 Ultimate
ZF9 - X1 Ultimate | | | |
Model: BRAVIA 4K ATV3
SoC: MediaTek MT5891 (aka 5596)
Installed RAM: 2 GB
Core Architecture: 4x ARM Cortex-A53
CPU Clock: 1100 MHz
GPU Renderer: ARM Mali-T860 MP2
GPU Cores: 2
Storage: 8 GB
OpenGL ES: 3.2
System: 4.9.51 ()
SDK: 26
Android 32-bit (6.0 Marshmallow - 8.0 Oreo) | | XG9005 - X1 Extreme
XG8399 - 4K X1
XG8396 - 4K X1
XG8388 - 4K X1
XG8377 - 4K X1
XG8305 - 4K X1
XG8196 - 4K X-Reality Pro
XG8096 - 4K X-Reality Pro | AF8 - X1 Extreme
XF9005 - X1 Extreme
XF8596 - 4K HDR X1
XF8505 - 4K HDR X1
XF8305 - 4K HDR X1
XF8005 - 4K X-Reality Pro | | | |
Model: BRAVIA 4K ATV2
Installed RAM: 2 GB
CPU Clock: 1100 MHz
GPU Cores: 2
Storage: 8 GB
OpenGL ES: 3.
System: 3.10.79 (1.6.0.26.02.1.00)
SDK: 24
Android 32-bit (6.0 Marshmalloe - 7.0 Nougat) | | | | A1 - X1 Extreme
XE9405 - X1 Extreme
XE9305 - X1 Extreme
XE9005 - 4K HDR X1
XE8505 - 4K HDR X1 | ZD9 - X1 Extreme
XD8305 - 4K X-Reality pro
XD8099 - 4K X-Reality Pro
XD8088 - 4K X-Reality Pro
XD8077 - 4K X-Reality Pro
XD8005 - 4K X-Reality Pro
SD8005 - 4K X-Reality Pro
XD7505 - 4K X-Reality Pro
XD7005 - 4K X-Reality Pro
XD7004 - 4K X-Reality Pro | |
Device: SVP-DTV15
Product: SVP4KDTV15_EU
Model: BRAVIA 4K 2015 ATV1
SoC: MediaTek MT5890 (aka 5595)
Installed RAM: 1.5 GB
Core Architecture: 2x ARM Cortex-A17 + 2xARM Cortex-A7
CPU Clock: 1100 MHz
GPU Renderer: ARM Mali-T624
Storage: 8 GB
OpenGL ES: 3.1
System: 3.10.79 (3.865)
SDK: 23
Android 32-bit (5.0 Lollipop - 7.0 Nougat) | | | | XE8099 - 4K X-Reality Pro
XE8096 - 4K X-Reality Pro
XE8088 - 4K X-Reality Pro
XE8077 - 4K X-Reality Pro | XD9405 - 4K X1
XD9305 - 4K X1
XD8505 - 4K X1 | X9005C - 4K X-Reality Pro
X8505C - 4K X-Reality Pro
S8505C - 4K X-Reality Pro
X8305C - 4K X-Reality Pro
S8005C - 4K X-Reality Pro
W850C - X-Reality Pro
W807C - X-Reality Pro
W805C - X-Reality Pro
W800C - X-Reality Pro
W756C - X-Reality Pro
W755C - X-Reality Pro |
Следващата година 2021, моделите A9(Oled), XI9500 ще преминат на платформа VH1 (MediaTek S900), като ще се появи и друга нова платформа VH2, базирана на същият процесор за модели XI9000, XI8500
Sony е възможно да добавят и нова платформа с MediaTek MT5670, за модели XI8300, XI8100, XI8000, X7000
https://www.mediatek.com/blog/mt5670...rt-tvs-with-ai
Sony 55XH8096 е с IPS-Pro панел, различен от S-IPS панела на Sony KD-65XG8505 от миналата година.
https://www.lesnumeriques.com/tv-tel...7745/test.html
Последно съм виждал този тип матрица преди 6 години, в модели WT50/DT50 на Panasonic(държаха правата и произвеждаха такива панели). Най-добрият зрителен ъгъл за IPS матрица.
https://forum.setcombg.com/attachmen...id=34142&stc=1
http://www.personal.kent.edu/~mgu/LCD/ips.htm
http://www.mcplive.cn/index.php/article/index/id/12753
https://www.tftcentral.co.uk/article...logies.htm#ver
8K Sony 75Z8H цялостно сравнение с Samsung Q900R и Sony X9500H
https://www.bilibili.com/video/BV1zk...656c61746564.2
Технологията IPS-Pro преди 10-на години беше на Hitachi Displays https://www.barcohealthcare.jp/solut...technology.pdf, после я продадоха на Matsushita.
Сравнявал съм ги едно време с други типове и наистина визуално се открояват. Слагаха ги само в най-скъпите модели на Panasonic.
По-скоро е някой PLS/ADS от Самсунг, отколкото IPS-Pro ... освен ако някои китайци не са изкупили заводите и технологията от Панасоник ... ама от доста време не са правени такива и ми е малко съмнително .
Интересно ще е да видим какво пише на панела.
IPS панелите са доста по-хубави от сегашните . Въпросът е , че имат ниска скорост и за да стигнат нивото на сегашните / 0.2 м/сек примерно/ , стават много скъпи.
Би било доста интересно, ако Sony ползват IPS-Pro.
hristoslav2
Поправка - оказа се вариант на PLS(Plane-to-Line Switching).
Това са два различни класа телевизори единия е 50Hz другия е 100Hz и е флагмана на Сони
Ganelon
това са два различни класа телевизори - с различна матрица, подсветка...
https://www.displayspecifications.co...ison/3dd1fd689
Sony KD55XH8096 test
