Не е 688, но не е и 288. По скоро е 606
https://forum.setcombg.com/attachmen...id=35479&stc=1
Да,на тазгодишните модели им идва 606 авоматично.На нашите 2019 не.Незнайно защо.Не че има някакво значение.Интересното е че ер660 е миналогодишен модел..хмм.
Другата година, може да се появи негов аналог в Европа
TCL 65R635 review,calibration (North America market)
https://www.youtube.com/watch?v=CSrcV9WtOlsЦитат:
We review the TCL 6-Series 2020 version (R635), featuring:
Mini LED backlighting,
QLED colours,
Dolby Vision & Dolby Atmos support,
as well as Roku TV platform.
Our review sample is the 65-inch TCL 65R635 which retails at $900, but it's also available in 55-inch and 75-inch screen sizes.
Topics covered include:
black-level performance,
local dimming algorithm,
colour accuracy,
motion handling,
video processing,
HDR including Dolby Vision,
as well as gaming including input lag.
https://avclub.gr/forum/showthread.p...post1058594710Цитат:
Display type technology:LCD
VA panel (Vertical Alignment)
100/120Hz with MCFI+backlight flashing
Backlight type: Direct (Full Array mini LED)
Backlight dimming type: local dimming
(local contrast setting: off,low,medium,high)
16 vertical columns x 10 horizontal rows : 160 independently dimmable zones.
Wide Color Gamut:quantum dot colors (aka QLED,QDEF=quantum dot enhancement film)
HDR:
static metadata:HDR10,HLG
dynamic metadata : Dolby Vision,not HDR10+
UHD
Manufactured in China
Native ANSI blacks was 0.03 cd/m2(nits), if peak white was set at 120 cd/m2 .
TCL's local dimming algorithm behaves similarly to Samsung's,preffering to sacrifice some shadow detail and small specular brightness to maintain deep blacks and minimization halation artifacts.On the plus side,this strategy kept top and bottom letterbox bars in cinemascope movies looking dark with minimal light bleed from adjacent bright objects even in challenging hdr movies.However in other low light scenes such as this campfire from "The Revenant" the TCL R635 would dim the subtitles and crush some shadow detail to keep blooming at bay.
DCI-P3 colour gamut coverage : 97.2% uv,
Rec.2020 colour gamut coverage : 79.3%
HDR:Peak Brightness on a 10% window: 1044 cd/m2(nits) , after calibration to D65 white point,
Full-field: 637 cd/m2(nits), after calibration to D65 white point.
За Япония, серията Q815
https://www.displayspecifications.com/bg/news/02f2431
https://www.tcl.com/jp/ja/products.android_tv.html
Q815 изглежда е наследник на европейската C715, но с локално затъмняване (QD, 50Hz, Direct LED)
https://forum.setcombg.com/attachmen...id=35481&stc=1
Здравейте, и аз съм с TCL 55EP660. Сложил съм версия на фирмуер 378 чрез USB. Вчера пробвах ъпдейт през wi-fi и Еthernet (кабелна връзка директно между рутера и телевизира) и не откри никакъв ъпдейт. Явно ще сложа 606 чрез флашка.
не бързай с ъпдейта.В момента почти всеки ден нещо правят ,има 609,вече и R610,скоро и по нова.
Какво дърво в Техномаркета.Чаках С серията а намалиха р615.И защо вдигнаха р715?Игрички
Абсолютно си прав. И аз следя вече доста време да взема C815. Лошото е, че почти всички модели на TCL изчезнаха и от extreme digital, а като гледам и в emag са зле нещата с предлагането и цените на марката. Имам няколко приятели които имат телевизори TCL. Купувани са или от emag или от extreme digital на доста добри цени и е имало предлагане на почти всички модели. Ако някой има инфо какво се случва, да каже?
Най-вероятно по черните петъци из европа са поизчерпали количествата.Не са предполагали че марката ще има такива продажби при дебюта им в европа.
Ха! Интересно! Миналата седмица гледах нещо като видео ревю на една игра (Cyberpunk 2077) в Youtube на 4K и въобще не вървеше добре. Връзката ми е стабилна, телевизора е вързан към нета с LAN, но видето просто не вървеше мазно. Зареждаше си и не спираше, но кадрите бяха ниски. Личеше си си загубата на кадри просто. Може би това е бил проблема. Ще тествам задължително как е сега!
Тя точно тая игра 4К60 май само през крив макаро ги вижда ;)
https://www.youtube.com/watch?app=desktop&v=H_JrZ_roLF4&t=1008s
Чудесно видео онагледяващо основните разлики между различните марки,техните предимства и недостатъци.
От 2 дни smart youtube не работи.Явно са му намерили цаката от гугъл.Но ! Вече има ново още по добро приложение SmartYoutubeNext работещо просто прекрасно ! Hristoslav може да промениш линковете в шапката.
