Android TV doesn’t support purchases within the Apple TV app, but when you sign in with your Apple ID, you can find everything you purchased, rented, or subscribed to using the same Apple ID on other devices.
1. On the Android TV home screen, select Search, then search for “Apple TV.”
2. Follow the onscreen instructions to download and install the Apple TV app TV app.
After it’s installed, you can find the Apple TV app in the Apps tab, or you can add it to your Favorites on the home screen.
3. Select the Apple TV app to open it, then sign in with an Apple ID if prompted.
Note: If you don’t already have an Apple ID, you can create one on the Apple ID website. You need only one Apple ID to use Apple TV app services. For more information, see the Apple ID FAQ.
