Пробвах се с 3.0.8 и ми се скапа ХР-то. Едвам го върнах към живот. Изобщо има ли версия, която да работи под ХР?
<center>http://www.artistcollaboration.com/u...Untitled-1.gif</center>
Az polzwam Virtual Drive 2000 Pro 5.0 na Far Stone Tech. Bachka si idealno s XP.
kato podhvana temata za VD2000, dai url za dl. ( za retail , ne demoto)
Взех си Virtual CD 4.0.2
НЯкой да има сериал за него?
pip4owe ne se zanimawajte s taq qlowa programa VCD
otidete na google i tyrsete Daemon Toolz Homepage
i si smyknete Daemon Toolz
moje da zarejda powe4eto ISO, BIN i t.n. formati direktno i mojte da si prawite do 5-6 drives bez da se bezpokoite 4e shte vi preebe sistemata
pod XP ba4ka perfektno
http://members.home.net/mattbender/WuLogoAni.gif
Аз ползвам Paragon CD-Rom Emulator и съм много доволен, може да се дръпне от http://www.fosi.da.ru
,$$ ш ,$$э' `э$$, ш $$,
,$o, $$, ,$$' Paragon CD-ROM Emulator 2000 v2.03 `$$, ,$$ ,o$,
ш `$$ `$$эш [ RETAIL ] шэ$$' $$' ш
$$ ъщщД--Д--Д-w-Д--Д--Дщщъ $$
,$$' ъъщщъъщщ--Д--Д--==юр DiZCRiPTiON рю==--Д--Д--щщъъщщъ `$$,
$$P date....................: 10 nov 2001 4$$
$$' diskz...................: 01 `$$
$$ type....................: util $$
$$ OS......................: winALL $$
$$ New features in 2.03: $$
$$ • Windows Media codec support; $$
$$ • Windows XP support. $$
$$ The CD Emulator has two main functions: $$
$$ a) The creation of CD images and virtual CD-ROM drives . $$
$$ b) Serving CD-based applications using CD images in virtual $$
$$ CD-ROM drives. (The memory-resident portion of CD Emulator). $$
$$ CD Emulator makes it possible to work with CDs and CD-ROM drives $$
$$ without having the CDs and CD-ROM drives being physically present at $$
$$ all times. They need to be available only during the copy process of $$
$$ a CD image to a hard drive. $$
$$ Benefits of using CD Emulator: $$
$$ - Run CD applications without the physical presence of the original CD $$
$$ - Works using virtual CD-ROM drive(s). $$
$$ - Allows access to (the data of) multiple CD’s simultaneously, despite $$
$$ only one CD-ROM drive being present. $$
$$ - Installable as a virtual server in a local area network. $$
$$ - All virtual CD’s and their applications are available at all times. $$
$$ - Access to virtual CD’s (installed on the hard drive) is significantly$$
$$ faster (up to 10 or 20 times) than the original CD’s. $$
$$ - Lightning-quick switching from one CD to another (as opposed to $$
$$ manual switching of a data CD in a CD-ROM drive). $$
$$ - No more “hunting around” for misplaced CDs. $$
$$ -Works with multiple “CD’s” at once, whether a real CD or drive is $$
$$ present or not. $$
One Ring to rule them all
One Ring to find them
One Ring to bring them all
and in the darkness bind them
"J.R.R.Tolkien"
Taka i taka se zagovori za skapvane na Windows XP ta nqkoi da e podkaral Neroto pod Xp,pri men iz4eznaha CD-to i zapisva4kata mi(ima li nqkakuv na4in da go opravq bez da trqbva da go preinstaliram - backup nqmam)
Ami az maj towa deto go imam go teglih ot tehniqt si site. I posle... ti si znaesh :). Ne znam da ima drugo.
Ako ti prqbva serial za neq probvaj F3X07010020
Shamare, smeni si ASPI driverite na XP. shtoto po prinzip nqma
pyk ako pak ne stane si preinstalliralj Neroto 6MB e v kraq na kraishtata:)
Ne6to ne moga da te razbera Mr.Meth za ASPI dr(moje bi ima6 predvid ACPI)Mejdudrugoto ve4e si preinstal XP-to i pove4e nqma da napravq taq gre6ka da instaliram nero(mejdudrugoto e 10,8MB - poslednata versiq 5511)
Изтеглих си VirtualCD 4.0.2
Харесва ми. Дръпнах го директно от сайта на производителя. Ако некой иска да го пробва ето и сериал:
H460-6B3B-2C7D-07EF
Маха 30-дневния лимит :)
<font color=red>EVIL DRIVES THIS WORLD</font id=red>
Днес похвалиха FantomCD. Не бях го чувал, а и по принцип не ползвам такива софтове. Ама може да е добър.
За Неро - няма проблем с нищо под ХР. Никакъв ACPI не ти трябва, слагал съм го, сега съм без него -> няма разлика: всичко бачка супер. Последната версия е 11,1МВ. Само дето от 5.5.1.1 имаше поне 7-8 още. НАЙ-последната е 5.5.5.1. Бачка с кейген-а от старите версии...
_________________
A Steve Morse Fan!!!
При мен Virtual CD 4.0.1 под XP си конвертира контейнерите правени от Virtual CD-Rom 1.0 под МЕ и после не желае да ги чете. Знае ли някой защо?
И на мен тва ми се случи с една игра. Обаче другите ги конвертира добре. Най-добре си направи нов image.
