Пробвах се с 3.0.8 и ми се скапа ХР-то. Едвам го върнах към живот. Изобщо има ли версия, която да работи под ХР?
<center></center>
<center></center>
Az polzwam Virtual Drive 2000 Pro 5.0 na Far Stone Tech. Bachka si idealno s XP.
kato podhvana temata za VD2000, dai url za dl. ( za retail , ne demoto)
Взех си Virtual CD 4.0.2
НЯкой да има сериал за него?
<center></center>
pip4owe ne se zanimawajte s taq qlowa programa VCD
otidete na google i tyrsete Daemon Toolz Homepage
i si smyknete Daemon Toolz
moje da zarejda powe4eto ISO, BIN i t.n. formati direktno i mojte da si prawite do 5-6 drives bez da se bezpokoite 4e shte vi preebe sistemata
pod XP ba4ka perfektno
Аз ползвам Paragon CD-Rom Emulator и съм много доволен, може да се дръпне от http://www.fosi.da.ru
,$$ ш ,$$э' `э$$, ш $$,
,$o, $$, ,$$' Paragon CD-ROM Emulator 2000 v2.03 `$$, ,$$ ,o$,
ш `$$ `$$эш [ RETAIL ] шэ$$' $$' ш
$$ ъщщД--Д--Д-w-Д--Д--Дщщъ $$
,$$' ъъщщъъщщ--Д--Д--==юр DiZCRiPTiON рю==--Д--Д--щщъъщщъ `$$,
$$P date....................: 10 nov 2001 4$$
$$' diskz...................: 01 `$$
$$ type....................: util $$
$$ OS......................: winALL $$
$$ New features in 2.03: $$
$$ • Windows Media codec support; $$
$$ • Windows XP support. $$
$$ The CD Emulator has two main functions: $$
$$ a) The creation of CD images and virtual CD-ROM drives . $$
$$ b) Serving CD-based applications using CD images in virtual $$
$$ CD-ROM drives. (The memory-resident portion of CD Emulator). $$
$$ CD Emulator makes it possible to work with CDs and CD-ROM drives $$
$$ without having the CDs and CD-ROM drives being physically present at $$
$$ all times. They need to be available only during the copy process of $$
$$ a CD image to a hard drive. $$
$$ Benefits of using CD Emulator: $$
$$ - Run CD applications without the physical presence of the original CD $$
$$ - Works using virtual CD-ROM drive(s). $$
$$ - Allows access to (the data of) multiple CD’s simultaneously, despite $$
$$ only one CD-ROM drive being present. $$
$$ - Installable as a virtual server in a local area network. $$
$$ - All virtual CD’s and their applications are available at all times. $$
$$ - Access to virtual CD’s (installed on the hard drive) is significantly$$
$$ faster (up to 10 or 20 times) than the original CD’s. $$
$$ - Lightning-quick switching from one CD to another (as opposed to $$
$$ manual switching of a data CD in a CD-ROM drive). $$
$$ - No more “hunting around” for misplaced CDs. $$
$$ -Works with multiple “CD’s” at once, whether a real CD or drive is $$
$$ present or not. $$
One Ring to rule them all
One Ring to find them
One Ring to bring them all
and in the darkness bind them
"J.R.R.Tolkien"
Taka i taka se zagovori za skapvane na Windows XP ta nqkoi da e podkaral Neroto pod Xp,pri men iz4eznaha CD-to i zapisva4kata mi(ima li nqkakuv na4in da go opravq bez da trqbva da go preinstaliram - backup nqmam)
Ami az maj towa deto go imam go teglih ot tehniqt si site. I posle... ti si znaesh. Ne znam da ima drugo.
Shamare, smeni si ASPI driverite na XP. shtoto po prinzip nqma
pyk ako pak ne stane si preinstalliralj Neroto 6MB e v kraq na kraishtata
Ne6to ne moga da te razbera Mr.Meth za ASPI dr(moje bi ima6 predvid ACPI)Mejdudrugoto ve4e si preinstal XP-to i pove4e nqma da napravq taq gre6ka da instaliram nero(mejdudrugoto e 10,8MB - poslednata versiq 5511)
Изтеглих си VirtualCD 4.0.2
Харесва ми. Дръпнах го директно от сайта на производителя. Ако некой иска да го пробва ето и сериал:
H460-6B3B-2C7D-07EF
Маха 30-дневния лимит
<font color=red>EVIL DRIVES THIS WORLD</font id=red>
Днес похвалиха FantomCD. Не бях го чувал, а и по принцип не ползвам такива софтове. Ама може да е добър.
За Неро - няма проблем с нищо под ХР. Никакъв ACPI не ти трябва, слагал съм го, сега съм без него -> няма разлика: всичко бачка супер. Последната версия е 11,1МВ. Само дето от 5.5.1.1 имаше поне 7-8 още. НАЙ-последната е 5.5.5.1. Бачка с кейген-а от старите версии...
_________________
A Steve Morse Fan!!!
При мен Virtual CD 4.0.1 под XP си конвертира контейнерите правени от Virtual CD-Rom 1.0 под МЕ и после не желае да ги чете. Знае ли някой защо?
И на мен тва ми се случи с една игра. Обаче другите ги конвертира добре. Най-добре си направи нов image.
