кой Virtual CD за XP?
    Apr 2001
    Пробвах се с 3.0.8 и ми се скапа ХР-то. Едвам го върнах към живот. Изобщо има ли версия, която да работи под ХР?
    <center></center>
    Dec 2000
    Az polzwam Virtual Drive 2000 Pro 5.0 na Far Stone Tech. Bachka si idealno s XP.
    May 2001
    kato podhvana temata za VD2000, dai url za dl. ( za retail , ne demoto)
    Apr 2001
    Взех си Virtual CD 4.0.2
    НЯкой да има сериал за него?
    <center></center>
    Jul 2001
    pip4owe ne se zanimawajte s taq qlowa programa VCD
    otidete na google i tyrsete Daemon Toolz Homepage
    i si smyknete Daemon Toolz
    moje da zarejda powe4eto ISO, BIN i t.n. formati direktno i mojte da si prawite do 5-6 drives bez da se bezpokoite 4e shte vi preebe sistemata
    pod XP ba4ka perfektno
    Jul 2001
    Аз ползвам Paragon CD-Rom Emulator и съм много доволен, може да се дръпне от http://www.fosi.da.ru
    ,$$ ш ,$$э' `э$$, ш $$,
    ,$o, $$, ,$$' Paragon CD-ROM Emulator 2000 v2.03 `$$, ,$$ ,o$,
    ш `$$ `$$эш [ RETAIL ] шэ$$' $$' ш
    $$ ъщщД--Д--Д-w-Д--Д--Дщщъ $$
    ,$$' ъъщщъъщщ--Д--Д--==юр DiZCRiPTiON рю==--Д--Д--щщъъщщъ `$$,
    $$P date....................: 10 nov 2001 4$$
    $$' diskz...................: 01 `$$
    $$ type....................: util $$
    $$ OS......................: winALL $$
    $$ New features in 2.03: $$
    $$ • Windows Media codec support; $$
    $$ • Windows XP support. $$
    $$ The CD Emulator has two main functions: $$
    $$ a) The creation of CD images and virtual CD-ROM drives . $$
    $$ b) Serving CD-based applications using CD images in virtual $$
    $$ CD-ROM drives. (The memory-resident portion of CD Emulator). $$
    $$ CD Emulator makes it possible to work with CDs and CD-ROM drives $$
    $$ without having the CDs and CD-ROM drives being physically present at $$
    $$ all times. They need to be available only during the copy process of $$
    $$ a CD image to a hard drive. $$
    $$ Benefits of using CD Emulator: $$
    $$ - Run CD applications without the physical presence of the original CD $$
    $$ - Works using virtual CD-ROM drive(s). $$
    $$ - Allows access to (the data of) multiple CD’s simultaneously, despite $$
    $$ only one CD-ROM drive being present. $$
    $$ - Installable as a virtual server in a local area network. $$
    $$ - All virtual CD’s and their applications are available at all times. $$
    $$ - Access to virtual CD’s (installed on the hard drive) is significantly$$
    $$ faster (up to 10 or 20 times) than the original CD’s. $$
    $$ - Lightning-quick switching from one CD to another (as opposed to $$
    $$ manual switching of a data CD in a CD-ROM drive). $$
    $$ - No more “hunting around” for misplaced CDs. $$
    $$ -Works with multiple “CD’s” at once, whether a real CD or drive is $$
    $$ present or not. $$
    One Ring to rule them all
    One Ring to find them
    One Ring to bring them all
    and in the darkness bind them
    "J.R.R.Tolkien"
    Feb 2001
    Taka i taka se zagovori za skapvane na Windows XP ta nqkoi da e podkaral Neroto pod Xp,pri men iz4eznaha CD-to i zapisva4kata mi(ima li nqkakuv na4in da go opravq bez da trqbva da go preinstaliram - backup nqmam)
    Dec 2000
    Ami az maj towa deto go imam go teglih ot tehniqt si site. I posle... ti si znaesh . Ne znam da ima drugo.
    Feb 2001
    Ako ti prqbva serial za neq probvaj F3X07010020
    Jul 2001
    Shamare, smeni si ASPI driverite na XP. shtoto po prinzip nqma
    pyk ako pak ne stane si preinstalliralj Neroto 6MB e v kraq na kraishtata
    Feb 2001
    Ne6to ne moga da te razbera Mr.Meth za ASPI dr(moje bi ima6 predvid ACPI)Mejdudrugoto ve4e si preinstal XP-to i pove4e nqma da napravq taq gre6ka da instaliram nero(mejdudrugoto e 10,8MB - poslednata versiq 5511)
    Apr 2001
    Изтеглих си VirtualCD 4.0.2
    Харесва ми. Дръпнах го директно от сайта на производителя. Ако некой иска да го пробва ето и сериал:
    H460-6B3B-2C7D-07EF
    Маха 30-дневния лимит
    <font color=red>EVIL DRIVES THIS WORLD</font id=red>
    Jan 2001
    Днес похвалиха FantomCD. Не бях го чувал, а и по принцип не ползвам такива софтове. Ама може да е добър.
    За Неро - няма проблем с нищо под ХР. Никакъв ACPI не ти трябва, слагал съм го, сега съм без него -> няма разлика: всичко бачка супер. Последната версия е 11,1МВ. Само дето от 5.5.1.1 имаше поне 7-8 още. НАЙ-последната е 5.5.5.1. Бачка с кейген-а от старите версии...
    _________________
    A Steve Morse Fan!!!
  17. Тук е от
    Dec 2001
    При мен Virtual CD 4.0.1 под XP си конвертира контейнерите правени от Virtual CD-Rom 1.0 под МЕ и после не желае да ги чете. Знае ли някой защо?
    Apr 2001
    И на мен тва ми се случи с една игра. Обаче другите ги конвертира добре. Най-добре си направи нов image.
  1. Virtual CD за Mac
    От glarus във форум Общ - софтуер
    Последно: 22-03-11, 21:11
  2. Virtual Memory
    От DENITO във форум Общ - софтуер
    Отговори: 15
    Последно: 29-04-10, 14:04
  3. Virtual Dub и ffdshow
    От varbancho във форум Общ - софтуер
    Последно: 06-03-06, 12:29
  4. Virtual CD
    От fred във форум Общ - софтуер
    Последно: 26-10-02, 21:59
