Някои случайно да е правил USB мрежа между 2 РС с кабел а-а. Ако е, да каже някакъв софтуер и какви особенности има при този вид мрежи. Предварително ви благодаря.
Student
Student
  <BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>......Now you can connect to any 10, 100, or 10/100Mbps hub or switch without having to open your PC. The EtherFast® 10/100 USB Network Adapter from Linksys allows you to instantly connect to a network from a USB-enabled desktop or notebook PC with Windows 98. The Plug-and-Play compatible device attaches to any USB-enabled PC or hub via a USB Type B receptacle. Connect a standard Category 5 network cable into the other end the EtherFast® 10/100 USB Network Adapter, install the included network software drivers, and go.
You'll be networked in no time. The EtherFast® 10/100 USB Network Adapter is bus-powered -- it draws power from the host PC and requires no external power cords. The 10/100 USB Network Adapter features a maximum of 12Mbps throughput (the maximum throughput supported by USB), easy-to-read LEDs, compact design, a 1-year limited warranty, and free world-class technical support!......<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>more...
<div align=left>FEATURES:
· USB Host to Host Communications
· Network up to 17 PCs
· Meets USB 1.1 Specification
· Windows® 98 & 2000 Compatible
· Connect/Disconnect Without Reboot
· Windows Explorer User Interface
· Supports TCP/IP, IPX/SPX and NetBEUI
· 7 foot Cable Length</div id=left>
http://www.UniBG.org
<font color=blue><u>#longhorn</u></font id=blue>
  d-rRoss dai url za tovq chudo?! Imash li ideq kakva mu e cenata?
Internet Club "ChatHouse" Rousse
  Tova go davam samo za orientacia. Za da se razbere 4e s kbel i buksi samo, nishto niama da stane. Koi ia znae kade e taia firma, ne si spomniam ve4e.
Prosto se obadi na niakoia firma za PC tuka i popitai za tezi raboti...
Ve4e znaesh kvo da pitash -
