Google mnogo ne si naiasno s protokolite pich
Purvo ne mojem da govorim za takava mreja poneje ne mojesh da poluchavash internet bez da konfigurirash default GW DNS i IP v sushtata podmreja.
Vtoro v network neighborhood niama da vidish nito edin computer ako niamash file and printer sharing a tova e edinstvenia protokol za koito ne vidiah da pishesh!!!
Drugoto e che broadcastite kogato ima default GW se prashtat kum nego a kogato tam ima i router minavat prez nego.
Tova mojesh da go vidish elementarno s Commview prosto gledash kakvo stava na portove 137 138 139 !!!!
I posledno da ti obiasnia principa na broadcastite:
Ima 4 vida broadcast v mreja i tova sa:
B-node(broadcast)-B-node uses broadcast NetBIOS name queries for name registration and resolution. B-node has two major problems: (1) Broadcasts disturb every node on the network, and (2) Routers typically do not forward broadcasts, so only NetBIOS names on the local network can be resolved.
P-node (peer-peer)-P-node uses a NetBIOS name server (NBNS), such as a WINS server, to resolve NetBIOS names. P-node does not use broadcasts; instead, it queries the name server directly.
M-node (mixed)- M-node is a combination of B-node and P-node. By default, an M-node functions as a B-node. If an M-node is unable to resolve a name by broadcast, it queries a NBNS using P-node.
H-node(hybrid)- H-node is a combination of P-node and B-node. By default, an H-node functions as a P-node. If an H-node is unable to resolve a name through the NBNS, it uses a broadcast to resolve the name.
Tova mojesh da si go prochetesh v helpa na win2000 i shte te posuvetvam sledvashtia put kato izkazvash mnenie otnosno mreji konsultirai se purvo s niakoi administrator a sled tova procheti helpa!!!!
Променено от Ivan на 31/08/2001 17:19:38
