Страница 35 от 36 ПърваПърва ... 2533343536 ПоследноПоследно
Резултати от 511 до 525 от общо 535
Like Tree48Одобрявам
LG телевизори 2016
    #511
    Отговор: LG телевизори 2016
    LG WebOS 3.5 иска да направи гледането на телевизия по магическо(за новите модели, но не за всички)
    LG 웹OS 3.5, 「보는 TV」에서 「즐기는 TV」로 진화 | Social LG전자
    https://www.slashgear.com/lg-webos-3...ical-20468045/
    Кой модел с коя версия, ще научим другият месец тук
    OpenSource Code Distribution
    ЅЈ -(7680х4320 ?) (950, 930, 850, 800)
    UЈ - зa UltrаНD (980, 940, 880, 780, 770, 750, 701, 680, 670, 660, 650, 640, 630, 610)
    LЈ - зa FullНD (650, 620, 610, 600, 570, 550, 500)
    LG 55B6V & LG 55UH770V: SoC Realtek RTD2999
    LG 55UH770V LED LCD television which uses the same Realtek RTD2999 SoC (system-on-chip)...
    source:[hdtvtest.co.uk]
    Fundamentally, the LG OLED55B6 and OLED55E6 use different chipsets: the former carries one from Realtek (RTD2999); whereas the latter features LG’s own in-house solution, as you can see from the sets’ respective service menus:
    LG B6 service menu - последният ред
    LG E6 service menu___LG 1312 SoC which based on Cortex-A53 x 4 (Linux 4.7)
    Realtek
    The Realtek RTD2999 Smart 4K TV System-On-Chip (SoC) is the world’s first TV single-chip controller to integrate Dolby HDR (High Dynamic Range) technology, and greatly increases Video Pixel Quality enhancement to present a vivid entertainment experience with detailed pixel contrast processing.
    The RTD2999 features a built-in quad-core 64-bit ARM CPU and high-performance 3D GPU. It supports the latest H.265 (HEVC) 4k60p 10-bit and VP9 4k60p 10-bit decoding. The versatile I/O device interfaces include HDMI-2.0/HDCP-2.2, Gigabit Ethernet, and USB 3.0/2.0, providing multiple and flexible extension applications.
    source photo:[sipa.gov.tw]
    Този май е един от програмистите на LG
    https://lkml.org/lkml/2016/3/6/293
    https://lkml.org/lkml/2016/3/9/160
    https://patchwork.kernel.org/patch/8515301/
    Този пост е редактиран от hristoslav2; 22-12-16 в 23:06.
    May 2007
    #512
    Вече... горд собственик на LG 49UH7707.....-Невероятно бърза операционна система.....-впечатлен съм! Дори нямах време да го ъпдейтна...заради еуфорията от първото ми впечатление....-ще го отложа за друг ден!!...Просто си пуснах ю-туб и се наслаждавам на качеството! SD каналите от кабелната са кофти...-не съм и очаквал да е нещо различно! Звукът е перфектен....картината на 4K e супер! Сглобка....Полша....-качествена пластмаса и всички необходими in-out комуникации. Тепърва ще го тествам на сателитно приемане и възможности за всеядност към различните формати! С две думи...машината ми изглежда читава! Весели Коледни Празници на всички съфорумци!
    zabadara, kokovox и bobkatagaz харесват това.
    #513
    Чудно...
    43LH5100 - ZE.BEEDLJG: VA panel
    43LH5100 - ZE.BEUWLJG: IPS panel
  5. PSL
    PSL е офлайн
    Member
    Dec 2007
    #514
    Здравейте, утре трябва да се купи един евтин телевизор. 6-700лв, без големи претенции. LG 43LH541V , LG 43LH5100 или SONY KDL-40R450CBAEP.
    Ще се ползва Виваком, HDMI. Благодаря Ви предварително. Хубави празници.
  7. PSL
    PSL е офлайн
    Member
    Dec 2007
    #516
    10X, ХС2. Горе съм сгрешил - SONY KDL-40RD450BAEP ! Г-жата си го е харесала. JVC са много големи. Едва ги навих за 43'. JVC LT-43VF53B LED изглежда прилично, PHILIPS 40PFS5501 LED също, но е +100, SAMSUNG UE-40J5100 LED отдавна ми е фаворит за дизайн. Утре/днес ще ги обходим и ще пиша. JVC отдавна не са Japan, и съм любопитен да ги видя. Още веднъж благодаря за вниманието.
    May 2015
    #517
    Телевизора е LG-UF8507 според вас за гледане вечер кой режим е по-подходящ експерт 1, експерт 2 или кино?
    Цитат Първоначално публикувано от frodo Виж публикацията
    Благодаря така е доста по-добре.
    Този пост е редактиран от hristoslav2; 25-12-16 в 20:44.
  11. Junior Member
    May 2002
    #519
    Здравейте, и Весели празници Имам ползван 42LW579S. Докараха ми го преди 1-2 месеца... Нещо започна да капризничи когато работи и се сменят кадрите с ярки/тъмни, започва да премигва все едно съм му дал контраста на нула. Не затъмнявя напълно картината, а премигва. Много е дразнещо. Не знам как трябва да се настрои картината като най-добра. Ако има някой да даде линк или съвет с настойки, ще съм благодарен. Пипах настройките за картината, динамичния контраст ми е изкл. но не знам дали е от самия телевизор или от другото за което имам съмнения. Захранващия ми контакт. Когато климатика включи или изключи се получава като бърз токов удар към трелевизора. На една мрежа са свързани. Май ще трябва да направя клипче. Някой имал ли е подобни симптоми?
    #520
    Да не е включен еко режима?
    LG Картината е твърде тъмна. | LG Bulgaria
  13. Junior Member
    May 2002
    #521
    Не, изключих го и него след като четох някъде инфо...няма промяна. Тя картината не е тъмна, а премигва. Ще се опитам да кача клип днес.
  15. Junior Member
    Dec 2016
    Pernik
    #522
    Цитат Първоначално публикувано от PSL Виж публикацията
    Те тоя тв съм го пляснал в спалнята от около година и половина,и съм много доволен.....зех го тогава на промоция за 800 кинта...ся са доста по евтини...
    https://www.technomarket.bg/televizo...j5500-09141705
    May 2015
    #523
    Технологията при серията на Samsung JS8500 подобна ли е на OLED при LG? И при тези телевизори на Samsung има ли подсветка?
    Примерно при този Технoмаркет - онлайн магазин
    Според мен трябваше да има отделна тема за OLED технологията.
  17. Member Аватара на Сидеров
    Feb 2016
    #524
    Цитат Първоначално публикувано от artttty Виж публикацията
    Технологията не е подобна, напълно различни са.
    May 2015
    #525
    А има ли посветка при тези модели на Samsung? Мислех че с тази технология Samsung се конкурира с OLED на LG?
  1. Левски - Завръщане | А ПФГ 2015 / 2016
    От kod във форум Спорт
    Последно: 13-11-17, 17:52
  2. Избор на климатик 2016 г.
    Отговори: 3492
    Последно: 01-01-17, 17:50
  3. Квалификации Евро 2016
    От iihtiandar във форум Спорт
    Последно: 10-06-16, 08:03
  4. Телевизори DSM, NEO?
    Последно: 19-01-16, 22:27
  5. телевизори
    Последно: 31-08-12, 06:46
