Резултати от 1 до 15 от общо 18
Like Tree11Одобрявам
FUJITSU ASYG09KXCA & ASYG12KXCA
    Feb 2017
    Здравейте. В очакване на европейския вариант на новата Нокрия за България пускам линк към UK сайта:
    Split Systems (Air Conditioner) : Wall Mounted - Flagship model nocria™X - FUJITSU GENERAL United Kingdom
    Само 2 варианта - 9ка и 12ка, което за мен е леко разочароващо.
    Очаквах да има поне 14ка.
    Спецификациите за сега:
    Specification ASYG09KXCA ASYG12KXCA
    Power source Phase Single-phase Single-phase
    Voltage 230 V 230 V
    Frequency 50 Hz 50 Hz
    Capacity Cooling 2.5 kW(0.6 - 3.5) kW 3.4 kW(0.6 - 5.3) kW
    Heating 3.6 kW (0.6 - 7.1) kW 5.0 kW (0.6 - 9.0) kW
    Input Power Cooling 0.46 kW 0.67 kW
    Heating 0.63 kW 1.02 kW
    EER Cooling 5.45 W/W 5.09 W/W
    COP Heating 5.72 W/W 4.90 W/W
    Pdesign Cooling 2.5 kW 3.4 kW
    Heating (-10°C) 3.4 kW 3.5 kW
    SEER Cooling 8.5 W/W 8.5 W/W
    SCOP Heating (Average) 5.1 W/W 5.1 W/W
    Energy Efficiency Class Cooling A+++ A+++
    Heating A+++ A+++
    Max. Operating Current Cooling 8.5 A 9.0 A
    Heating 14 A 16 A
    Annual Energy Consumption Cooling 103 kWh/a 140 kWh/a
    Heating 934 kWh/a 961 kWh/a
    Moisture Removal 1.1 I/h 1.2 I/h
    Sound Pressure Level Indoor (Cooling) High 46 dB(A) 46 dB(A)
    Middle 42 dB(A) 42 dB(A)
    Low 38 dB(A) 38 dB(A)
    Quiet 28 dB(A) 28 dB(A)
    Indoor (Heating) High 48 dB(A) 48 dB(A)
    Middle 43 dB(A) 43 dB(A)
    Low 39 dB(A) 39 dB(A)
    Quiet 30 dB(A) 30 dB(A)
    Sound Pressure Level Outdoor (Cooling) High 40 dB(A) 44 dB(A)
    Outdoor (Heating) High 41 dB(A) 43 dB(A)
    Sound Power Level Indoor (Cooling) High 58 dB(A) 58 dB(A)
    Indoor (Heating) High 62 dB(A) 62 dB(A)
    Outdoor (Cooling) High 53 dB(A) 57 dB(A)
    Outdoor (Heating) High 57 dB(A) 57 dB(A)
    Air Flow Rate Indoor High 670 m3/h 670 m3/h
    Outdoor High 1,975 m3/h 2,230 m3/h
    Net Dimensions Height 293 mm 293 mm
    Indoor Width 786 mm 786 mm
    Depth 378 mm 378 mm
    Net Dimensions Height 704 mm 704 mm
    Outdoor Width 820 mm 820 mm
    Depth 315 mm 315 mm
    Net Weight Indoor 20 kg (44 lbs) 20 kg (44 lbs)
    Outdoor 41 kg (90 lbs) 41 kg (90 lbs)
    Connection Pipe Diameter Liquid 6.35 mm 6.35 mm
    Gas 9.52 mm 9.52 mm
    Drain Hose Diameter Indoor 13.8 mm 13.8 mm
    Outdoor 15.8 to 16.7 mm 15.8 to 16.7 mm
    Max Pipe Length (Pre Charge) 15 (15) m 15 (15) m
    Max Height Difference 10 m 10 m
    Operation Range Cooling -10 to 43 °CDB -10 to 43 °CDB
    Heating -15 to 24 °CDB -15 to 24 °CDB
    Refrigerant Type R32 R32
    Global Warming Potential 675 675
    Charge 1,300 g 1,300 g
    kokovox одобрява това.
    Ямбол
    Отговор: FUJITSU ASYG09KXCA & ASYG12KXCA
    При тези отоплителни мощности, просто няма смисъл да има модел с 14 и повече в името.
    root666 одобрява това.
    Feb 2017
    12ката ми е малка за хола.
    Ямбол
    Ако тя ти е малка, значи хола ти е бая голям и си за две машини, според мен.
    много добре ,радва ... Фуджицу ще утрепят другите високи класове особено с една прилична цена
    mkukas одобрява това.
    Jul 2004
    Ако може да се разчита на спецификацията излиза че вътрешното тяло е доста шумно особено на ниските степени.
    Дано да има грешка.
    rosswen одобрява това.
  9. Junior Member
    Feb 2017
    Че ще е шумно е ясно - Dual Blaster .То само като им гледам рекламните картинки и ми е шумно.
    Хол, трапезария, кухня, офис, аз в спалня не бих го сложил.
  10. Member Аватара на JOKVN
    Feb 2012
    Само дето на снимката е същото огромно дистанционно като на другите модели
  11. Senior Member Аватара на KI_YOOU
    Nov 2014
    Русе
    Тъй като тази информация е налична повече от година, за мен именно цената е причина това чудо на техниката да не се продава по нашите ширини.
    Aug 2015
    Сев.-Изт. Б-я
    Това чудо от Април ще се продава в България.
  13. Junior Member
    Feb 2017
    Така казват, но ако е вярно и това, че цената ще е около 4000 лв, наистина вече ми е ясно защо не бързат.
    Не виждам как ще се продава на тези цени.
    Aug 2015
    Сев.-Изт. Б-я
    Това не е конспирация, а традиция. Повечето фирми започват да продават новите си модели от април всяка година.
    Plovdiv
    ASHG09KXCA - 4300 лв, ASHG12KXCA - 4700 лв. Честито на новите притежатели.....!!!
    Mega, ivan74 и rosswen харесват това.
  17. Senior Member Аватара на dodo_pv
    Това цената на комплекта за тристайно жилище ли е?
  18. Senior Member Аватара на KI_YOOU
    Nov 2014
    Русе
    Ще ти се..
    Тя 200в 40ка е 4к
  1. Техническа информация за Fujitsu, General Fujitsu и Fuji Electric
    От valen1 във форум Климатици Fujitsu, General Fujitsu, Fuji Electric
    Отговори: 879
    Последно: 01-02-24, 06:13
  2. Избор на климатик , FUJITSU AWYZ14LB/AOYZ14LB VS FUJITSU ASYG12LTCA/AOYG12LTC VS DAIKIN FTXS42K
    От schwepsi във форум Климатици Fujitsu, General Fujitsu, Fuji Electric
    Последно: 07-04-14, 07:27
  3. Новите инвертори на Fujitsu, General Fujitsu и Fuji Electric модели 2011 година
    Отговори: 351
    Последно: 27-10-11, 21:44
  4. Каква е разликата между(Fujitsu, General Fujitsu, Fuji Electric) и кои да избера
    От bat.zdravo във форум Климатици Fujitsu, General Fujitsu, Fuji Electric
    Отговори: 19
    Последно: 28-07-11, 00:38
  5. Доволни ли сте от LGC серията на Fujitsu, Fujitsu General и Fuji Electric
    От dgenov във форум Климатици Fujitsu, General Fujitsu, Fuji Electric
    Отговори: 12
    Последно: 13-07-09, 18:11
