Hiren's BootCD 7.5
All in one Dos Bootable CD which has all these utilities
Partition ToolsPartition Magic Pro 8.05
Best software to partition hard drive
Acronis Disk Director Suite 9.0
Popular disk management functions in a single suite
Paragon Partition Manager 7.0.1057
Universal tool for partitions
Partition Commander 9.01
The safe way to partition your hard drive,with undo feature
Ranish Partition Manager 2.44
a boot manager and hard disk partitioner.
The Partition Resizer v1.3.4
move and resize your partitions in one step and more.
Smart Fdisk 2.05
a simple harddisk partition manager
SPecial Fdisk 2000
SPFDISK a partition tool.
eXtended Fdisk 0.9.3
XFDISK allows easy partition creation and edition
GDisk 1.1.1
Complete replacement for the DOS FDISK utility and more.
Disk Clone ToolsImageCenter 5.6 (Drive Image 2002)
Best software to clone hard drive
Norton Ghost 8.2
Similar to Drive Image (with usb/scsi support)
Acronis True Image 8.0
Create an exact disk image for complete system backup and disk cloning.
Partition Saver 2.80
A tool to backup/restore partitions.
Antivirus ToolsF-Prot Antivirus 3.16b
Very good virus scanner (with ntfs support and easy to use menu)
McAfee Antivirus 4.40
a virus scanner (with ntfs support and easy to use menu)
Recovery ToolsActive Partition Recovery 3.0
To Recover a Deleted partition.
Active Uneraser 3.0
To recover deleted files and folders on FAT and NTFS systems.
Ontrack Easy Recovery Pro 6.10
To Recover data that has been deleted/virus attack
Winternals Disk Commander 1.1
more than just a standard deleted-file recovery utility
TestDisk 5.8
Tool to check and undelete partition.
Lost & Found 1.06
a good old data recovery software.
DiyDataRecovery Diskpatch 2.1.100
An excellent data recovery software.
Prosoft Media Tools 5.0 v1.1.2.64
Another excellent data recovery software with many other options.
Testing ToolsSystem Speed Test 4.78
it tests CPU, harddrive, ect.
Ad-Aware SE Personal 1.06
find and remove spyware, adware, dialers etc. (a must have tool)
PC-Check 5.50
Easy to use hardware tests
Ontrack Data Advisor 5.0
Powerful diagnostic tool for assessing the condition of your computer
The Troubleshooter 7.02
all kind of hardware testing tool
PC Doctor 3.0
a benchmarking and information tool
Test Cpu/Video/Disk 5.6
a tool to test cpu, video, and disk
Test Hard Disk Drive 1.0
a tool to test Hard Disk Drive
RAM (Memory) Testing ToolsDocMemory 2.2b
RAM Test utility
GoldMemory 5.07
RAM Test utility
Memtest86+ 1.60
PC Memory Test
Hard Disk ToolsHard Disk Diagnostic Utilities
Seagate Seatools Desktop Edition 3.02
Western Digital Data Lifeguard Tools
Western Digital Diagnostics (DLGDIAG) 5.04c
Maxtor PowerMax 4.21
Maxtor amset utility 4.0
Maxtor(or any Hdd) Low Level Formatter 1.1
Fujitsu HDD Diagnostic Tool 6.30
Fujitsu IDE Low Level Format 1.0
Samsung HDD Utility(HUTIL) 1.28
Samsung Disk Diagnose (SHDIAG) 1.28
IBM/Hitachi Drive Fitness Test 4.04
IBM/Hitachi Feature Tool 1.80
Gateway GwScan 3.15
MHDD 4.5
HDD Regenerator 1.51
to recover a bad hard drive
Ontrack Disk Manager 9.57
Disk Test/Format/Maintenance tool.
Norton Disk Doctor 2002
a tool to repair a damaged disk, or to diagnose your hard drive.
Norton Disk Editor 2002
a powerful disk editing, manual data recovery tool.
Active Kill Disk 1.1
Securely overwrites and destroys all data on physical drive.
SmartUDM 2.00
Hard Disk Drive S.M.A.R.T. Viewer.
System Information ToolsAida16 2.12
a system information tool, extracts details of all components of the PC
PCI and AGP info Tool
The PCI System information & Exploration tool.
System Analyser version 5.3j
View extensive information about your hardware
Navrátil Software System Information 0.58.6
High-end professional system information tool
Astra 5.10
Advanced System info Tool and Reporting Assistant
HwInfo 4.9.7
a powerful system information utility
PC-Config 9.33
Complete hardware detection of your computer
SysChk 2.46
Find out exactly what is under the hood of your PC
CPU Identification utility v1.8
Detailed information on CPU
CTIA CPU Information
another CPU information tool
MBR (Master Boot Record) ToolsMBR Work 1.07b
a utility to perform some common and uncommon MBR functions
MBR Tool 2.1.100
backup, verify, restore, edit, refresh, remove, display, re-write...
DiskMan4
all in one tool for cmos, bios, bootrecord and more
BootFix Utility
Run this utility if you get ''Invalid system disk''
MBR SAVE / RESTORE 2.1
BootSave and BootRest tools to save / restore MBR
Boot Partition 2.50
add Partition in the Windows NT/2000/XP Multi-boot loader
Partition Table Doctor 3.0
a tool to repair/modify mbr, bootsector, partition table
Smart Boot Manager 3.7.1
a multi boot manager
Bootmagic 8.0
This tool is for multi boot operating systems
BIOS / CMOS ToolsCMOS 0.93
CMOS Save / Restore Tool
BIOS Cracker 4.6
BIOS password remover (cmospwd)
BIOS Cracker 1.4
BIOS password remover (cmospwc)
BIOS Utility 1.35.0
BIOS Informations, password, beep codes and more.
!BIOS 3.20
a powerfull utility for bios and cmos
DISKMAN4
a powerful all in one utility
UniFlash 1.40
bios flash utility
Kill CMOS
a tiny utility to wipe cmos
MultiMedia ToolsPicture Viewer 1.94
Picture viewer for dos, supports more then 40 filetypes.
QuickView Pro 2.54
movie viewer for dos, supports many format including divx.
MpxPlay 1.15
a small Music Player for dos
Password ToolsActive Password Changer 3.0
To Reset User Password on windows NT/2000/XP/2003 (FAT/NTFS)
Offline NT/2K/XP Password Changer
utility to reset windows nt/2000/xp administrator/user password.
NTPWD
NTFS ToolsNTFS Dos Pro 5.0
To access ntfs partitions from Dos
NTFS 4 Dos 1.4
NTFS Dos 3.02
EditBINI 1.01
to Edit boot.ini on NTFS Partition
Dos File ManagersVolkov Commander 4.99
Dos File Manager with LongFileName/ntfs support
(Similar to Norton Commander)
Dos Command Center 5.1
Classic dos-based file manager.
File Wizard 1.35
a file manager - colored files, drag and drop copy, move, delete etc.
File Maven 3.5
an advanced Dos file manager with high speed PC-to-PC file
transfers via serial or parallel cable
FastLynx 2.0
Dos file manager with Pc to Pc file transfer capability
LapLink 5.0
the smart way to transfer files and directories between PCs.
Mini Windows 3.11
Back to old days, use it as a file manager
Mini Windows 98
Can run from Ram Drive, with ntfs support,
Added 7-Zip which supports .7z .zip .cab .rar .arj .gzip,
.bzip2 .z .tar .cpio .rpm and .deb
Disk Defragmenter, Notepad / RichText Editor,
Image Viewer, .avi .mpg .divx .xvid Movie Player, etc...
Other ToolsGhost Walker 2003.793
utility that changes the security ID (SID) for Windows NT, 2000 and XP
DosCDroast beta 2
Dos CD Burning Tools
Universal TCP/IP Network 5.4
MSDOS Network Client to connect via TCP/IP to a Microsoft based
network. The network can either be a peer-to-peer or a server based
network, it contains 85 different network card drivers
Dos ToolsUSB CD-Rom Driver 1
Standard usb_cd.sys driver for cd drive
Universal USB Driver 2
Panasonic v2.20 ASPI Manager for USB mass storage
Interlnk support at COM1
To access another computer from COM port
Interlnk support at LPT1
To access another computer from LPT port
and too many great dos tools
very good collection of dos utilities
extract.exepkzip.exepkunzip.exeunrar.exerar...
ToolsSpaceMonger 1.4
keeping track of the free space on your computer
Drive Temperature 1.0
Hard Disk Drive temperature meter
Disk Speed1.0
Hard Disk Drive Speed Testing Tool
MemTest 1.0
a Memory Testing Tool
PageDfrg 2.3
System file Defragmenter For NT/2k/XP
Split Join 1.3.3
a Small File Split-Join Tool
Ghost Image Explorer 7.0
to add/remove/extract files from Ghost image file
DriveImage Explorer 5.0
to add/remove/extract files from Drive image file
Drive SnapShot 1.36
creates an exact Disk Image of your system into a file while windows is running.
Active Undelete 5.0
a tool to recover deleted files
Restoration 2.5.14
Startup Control Panel 2.8
a tool to edit startup programs
Startup Monitor 1.02
it notifies you when any program registers itself to run at system startup
IB Process Manager 1.02
a little process manager for 9x/2k, shows dll info etc.
HijackThis 1.99
a general homepage hijackers detector and remover and more
CurrPort 1.07
displays the list of all currently opened TCP and UDP ports on your computer
Unknown Devices 1.2
helps you find what those unknown devices in Device Manager really are
PCI 32 Sniffer 1.1
device information tool (similar to unknown devices)
NewSID 4.10
Double Driver 1.0
Driver Backup and Restore tool
