Резултати от 1 до 15 от общо 24
Може ли да се избегне ограничението на RapidShare Free
    Aug 2005
    Philippines
    Може ли да се избегне ограничението на RapidShare при теглене без заплащане разбира се. Имаше някаква програма която заобикаляше това ограничение, но не се сещам в момента.
    Благодаря на отзовалите се
  3. Member Аватара на devil
    Jun 2002
    Re: Може ли да се избегне ограничението на RapidShare Free
    Някое от тези?
    Dec 2003
    anonym.to?https://forum.setcombg.com/******************.de/files/xxxxx/dateiname.rar.html
    след върпросителния слагаш линка към RapidShare.
    Oct 2002
    Преинсталирах си Windows и не иска да става с :
    anonym.to?******************.de/files/xxxxx/dateiname.rar.html
    Някои знеали от какво може да се получава така?
    или това:
    Rapidshare Premium Link Generator's
    Hello All You Guyz...Do You Know That We Can Generate Premium Links Which Support Resume, Download Managers, No Waiting, Instant Download Start,High Speeds And All The Other Premium Benifits.
    .de Link Generators
    Www.Proxiez.NetMax No of links you can generate daily : 5
    Www.Rapidhack.NetMax No of links you can generate daily : Unlimited
    Www.Fedho.ComMax No of links you can generate daily : Unknown
    Www.Fastaccess.WsMax No of links you can generate daily : Unknown
    You need To Register Wid them Before You Can Generate Links
    Www.RapidsharePremiumLinkGenerator.Com
    .com Link Generators
    Www.RapidFool.ComMax No of links you can generate daily : Unknown
    Www.Khongbiet.ComMax No of links you can generate daily : Unknown
    Www.Proxiez.NetMax No of links you can generate daily : Unknown
    Generator Is Still Being TestedWww.Rapidlysharing.ComMax No of links you can generate daily : 6
    Www.Rapid-Hook.ComMax No of links you can generate daily : 4
    Www.Freerapidlinks.InfoMax No of links you can generate daily : 4
    Www.Rapidl.ComMax No of links you can generate daily : 3
    Www.RapidRip.ComMax No of links you can generate daily : Unknown
    Www.DownloadMyUpload.Com
    Max No of links you can generate daily : 7
    Www.ComputerAxes.Com
    Max No of links you can generate daily : 2
    Www.PremiumRapid.Com
    Www.Rapidshare.Co.In
    Www.Rapidshack.Us
    Www.Megaez.Com
    Www.Lcheat.Com
    Www.Rapid-Ripping.Com
    Max No of links you can generate daily : 15
    Www.Premium4Me.Com
    Www.Grab-W.Net
    Www.Rapid.Download-Crazy.Com
    Max No of links you can generate daily : 8
    Www.RapidLeech.com
    Www.RSLeecher.Com
    Www.FastLister.Net
    Www.LCheat.Com
    Www.X92.Org
    Www.RsProxy.Info
    Www.RsFox.ComMax No of links you can generate daily : 5
    Www.PremiumLinkz.Info
    Www.Rs43.Com
    Www.DirectRapid.Com
    Www.Dioscurionline.Net
    Www.FreeRapid.Org
    Www.Rapid4All.Com
    Www.RapidLeechers.Com
    Www.Warez-Premium.Org
    Www.Rapidshare2Hell.Co.Nr
    Www.RapidCheat.Com
    Www.NobakWaas.Com
    Www.Adomreg.Com
    Thats The lot, Happy Generating.
    Jan 2005
    Www.RapidCheat.Com - това при мен проработи - трябва да се сложи линка от адресното поле на браузъра, когато е отворена страницата със сравненията между premium и free даунлоуда...т.е. линка на файла де...
    @Compare - +1
    Oct 2002
    Цитат Първоначално публикувано от hihimor
    @Compare - +1
    Разбираш ли си?
    Аз не долавям нещо базикаш ли се помъчил си се да отговориш на въпроса ли
    Нещо ми се виждат нещата ...
    Feb 2003
    @Compare
    Нееднократно сме ти казвали, че така както пишеш темите и въпросите си и Господ не може да те разбере, нека ти сега, да видиш как ни е на нас.
    Толкова ли е сложно, като напишеш един постинг, да дадеш [Предварителен преглед], да го прочетеш и да го коригираш?
    Самолет ли гониш, влак ли, състезание с другарчетата кой по-бързо ще напише темата ли има или е някаква друга причината?
    Oct 2002
    Цитат Първоначално публикувано от Black Adder
    @Compare
    Tъкмо си мислех че си в отпуска малко да разпусна !!
    Ти това ли искаш да ми вращаш охооо що не каза по рано да е повече и по възможностите
    на всеки !Да започваме
    Сега те разбирам поне
    Мислиш ли че мога да застана винаги в противоположната страна и да видя как се чуства всеки .Да не става така ми постави се и ти на мое място да не мислиш че ми е хубаво ти и Fear My,Melone и компания да пишете след всеки мои пост е ми искам малко да разпусна докато си помисля че някои е в отпуска или си клати ... хоп все някои цъфва
    Честно взема да ми липсвате
    Да не си пушил нещо
  11. Senior Member Аватара на ru-boy
    Jan 2000
    Compare, дай го малко по-сериозно, ако ти е възможно де.
    Feb 2007
    програмката, която аз ползвах навремето, се казваше USDownloader
    тя дори поддържаше 20-на такива сървиса и си беше пълноценен даунлоад мениджър - подаваш линковете и забравяш
    проблемът е, че рапидшеър твърде често сменят начина на генериране на картинките си и просто май трябва да следиш за нови версии
  13. Senior Member Аватара на ru-boy
    Jan 2000
    The Grabber 1.4.8
    Обновился грабер Rapidshare.com и Rapidshare.de, на предмет прямой ссылки! Пишите исходный линк, вводите код подтверждения и получаете прямую ссылку, которую можете вставить в менеджер закачек или просто в браузер. Есть модуль для работы через прокси; линк-чекер, который проверит все ссылки на работоспособность перед тем как начать закачивать; поисковик по рапидшаре, "закладки" и т.п.
    http://depositfiles.com/files/1631575
  15. gggggg
    Guest
    Горната програма ако работи, аз трябва да съм трамвай
    Има тонове такива боклуци, които не знам на някой да са му свършили работа
    Jan 2005
    Цитат Първоначално публикувано от Compare
    Разбираш ли си?
    не се "базикам", просто споделих, че съм успял да използвам успешно един от линковете, който си дал, и даже, ако имаше рейтинг, щях да ти го повиша, защото не ми беше хрумвало досега, че има генератори на premium links
    елементарното търсене в гугъл, открива още много подобни - някой работят, други - не; открих такива, които (почти) винаги работят...
    Sep 2003
    The Grabber си работи, но идеята и е да се минава през прокси за да се тегли нов файл и не е много удобно (трябва да се намират работещи проксита).
  18. gggggg
    Guest
    Добре де човек дай да видим тея линкове , които винаги работят..
  1. Отговори: 0
    Последно: 17-01-10, 23:01
  2. Отговори: 13
    Последно: 14-12-09, 13:51
  3. Помощ за забравена парола за достъп до RapidShare
    От stekyman във форум Общ - софтуер
    Отговори: 16
    Последно: 12-04-08, 02:52
  4. rapidshare
    От gonzolito123 във форум Дъра-Бъра
    Последно: 23-06-06, 11:01
