Резултати от 16 до 30 от общо 37
Запис с Неро.
  1. Pat
    Pat е офлайн
    Senior Member Аватара на Pat
    Oct 2003
    #16
    Re: Запис с Неро.
    в директорията ...\Ahead\Nero - има файл "NeroHistory.log". Покажи какво пише в него (разгледай го и копирай само за последния НЕсполучлив запис - лесно ще се оринтираш )
    Oct 2006
    Ботевград
    #17
    Re: Запис с Неро.
    Така изглежда файла след запис на оригинален диск на Неро 5, V 5.5
    Tsvetomir
    Home User
    1A23-0609-4130-2414-6324-1875
    Windows XP 5.1
    IA32
    WinAspi: -
    ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 6:35:34 PM
    Nero Version: 6.6.0.16
    Internal Version: 6, 6, 0, 16b
    (Nero Express)
    Recorder: <SAMSUNG CD-R/RW SW-240B> Version: R402 - HA 0 TA 2 - 6.6.0.16
    Adapter driver: <nvatabus> HA 0
    Drive buffer : 8192kB
    Bus Type : default (0) -> ATAPI, detected: ?
    CD-ROM: <Optiarc DVD RW AD-7173A >Version: 1-01 - HA 0 TA 3 - 6.6.0.16
    === Scsi-Device-Map ===
    DiskPeripheral : ST360021A nvatabus Port 0 ID 0 DMA: Off
    CdRomPeripheral : SAMSUNG CD-R/RW SW-240B nvatabus Port 0 ID 2 DMA: Off
    CdRomPeripheral : Optiarc DVD RW AD-7173A nvatabus Port 0 ID 3 DMA: Off
    CdRomPeripheral : HL5191Q TPQ508Y 1.0 auurjxro Port 3 ID 0 DMA: Off
    === CDRom-Device-Map ===
    SAMSUNG CD-R/RW SW-240B E: CDRom0
    Optiarc DVD RW AD-7173A F: CDRom1
    HL5191Q TPQ508Y G: CDRom2
    AutoRun : 1
    Excluded drive IDs:
    WriteBufferSize: 83886080 (0) Byte
    ShowDrvBufStat : 0
    BUFE : 0
    Physical memory : 1023MB (1048048kB)
    Free physical memory: 536MB (549212kB)
    Memory in use : 47
    Uncached PFiles: 0x0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    29.1.2008
    CD Copy
    10:23:07 PM #1 Text 0 File Burncd.cpp, Line 2948
    JustLink activated
    10:23:07 PM #2 Text 0 File Reader.cpp, Line 127
    Reader running
    10:23:07 PM #3 Text 0 File Writer.cpp, Line 122
    Writer SAMSUNG CD-R/RW SW-240B running
    10:23:07 PM #4 Phase 48 File dlgbrnst.cpp, Line 1832
    Analyzing disc
    10:23:07 PM #5 CDCOPY -1 File CDCopy.cpp, Line 1912
    The CD is copyrighted
    10:23:07 PM #6 Text 0 File CDCopy.cpp, Line 2128
    _Index0_ _______Index1_______ PostPause ___LastBlockOfTrack_
    Track 1: 0 0 ( 0:02.00) 176964 176963 ( 39:21.38)
    Track 2: 176964 177114 ( 39:23.39) 181764 181763 ( 40:25.38)
    Track 3: 181764 181764 ( 40:25.39) 186264 186263 ( 41:25.38)
    10:23:07 PM #7 Text 0 File CDCopy.cpp, Line 840
    Copy options: copy on-the-fly: ON
    read ISRC/MCN: OFF
    use jitter correction: OFF
    data options
    ignore read error: ON write defekt blocks OFF
    read raw data: OFF read r-w subchannel data: OFF
    audio options
    read indexes: OFF read r-w subchannel data: OFF
    source disc does not look like CD Extra
    01. 0 - 177114 = 177114, data (TRM_DATA_MODE1, block size 2048)
    02. 177114 - 181764 = 4650, audio (TRM_AUDIO_NOPRE, block size 2352)
    03. 181764 - 186264 = 4500, audio (TRM_AUDIO_NOPRE, block size 2352)
    10:23:33 PM #8 Text 0 File Burncd.cpp, Line 3233
    Turn on Disc-At-Once, using CD-R/RW media
    10:23:33 PM #9 Text 0 File DlgWaitCD.cpp, Line 270
    Last possible write address on media: 359848 ( 79:59.73)
    Last address to be written: 186263 ( 41:25.38)
    10:23:33 PM #10 Text 0 File DlgWaitCD.cpp, Line 282
    Write in overburning mode: NO (enabled: CD)
    10:23:33 PM #11 Text 0 File DlgWaitCD.cpp, Line 2483
    Recorder: SAMSUNG CD-R/RW SW-240B;
    CDR code: 00 97 26 65; OSJ entry from: CMC Magnetics Corporation
    ATIP Data: ?
    10:23:33 PM #12 Text 0 File DlgWaitCD.cpp, Line 448
    >>> Protocol of DlgWaitCD activities: <<<
    10:23:33 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 838
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 (1 - Data (mode 1))
    2 indices, index0 (150) not provided
    original disc pos #0 + 176964 (176964) = #176964/39:19.39
    not relocatable, disc pos for caching/writing not required/not required, no patch infos
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 176964 blocks [SAMSUNG CD-R/RW SW-240B]
    1: TRM_AUDIO_NOPRE (2 - Audio)
    original disc pos #177114 + 4650 (4650) = #181764/40:23.39
    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 4650 blocks [SAMSUNG CD-R/RW SW-240B]
    2: TRM_AUDIO_NOPRE (3 - Audio)
    2 indices, index0 (0) provided
    original disc pos #181764 + 4500 (4500) = #186264/41:23.39
    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 4500 blocks [SAMSUNG CD-R/RW SW-240B]
    10:23:33 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 1051
    Prepare recorder [SAMSUNG CD-R/RW SW-240B] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 3:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 362729472, ISRC ""
    2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 362729472 363082272 374019072, ISRC ""
    3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 374019072 374019072 384603072, ISRC ""
    DAO layout:
    __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
    -150 | lead-in | 0 | 0x41 | 0x00
    -150 | 1 | 0 | 0x41 | 0x00
    0 | 1 | 1 | 0x41 | 0x00
    176964 | 2 | 0 | 0x01 | 0x00
    177114 | 2 | 1 | 0x01 | 0x00
    181764 | 3 | 0 | 0x01 | 0x00
    181764 | 3 | 1 | 0x01 | 0x00
    186264 | lead-out | 1 | 0x01 | 0x00
    10:23:33 PM #15 Phase 36 File dlgbrnst.cpp, Line 1832
    Burn process started at 4x (600 KB/s)
    10:23:33 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2654
    Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
    10:23:33 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2654
    Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #177114): write at #177114
    10:23:33 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2654
    Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #181764): write at #181764
    10:23:33 PM #19 Text 0 File Mmc.cpp, Line 16924
    StartDAO : CD-Text - Off
    10:23:33 PM #20 Text 0 File Mmc.cpp, Line 21708
    Set BUFE: JustLink -> ON , JustSpeed : ON
    10:23:33 PM #21 Text 0 File Mmc.cpp, Line 17211
    CueData, Len=56
    41 00 00 14 00 00 00 00
    41 01 00 10 00 00 00 00
    41 01 01 10 00 00 02 00
    01 02 00 00 00 27 15 27
    01 02 01 00 00 27 17 27
    01 03 01 00 00 28 19 27
    01 aa 01 01 00 29 19 27
    10:35:03 PM #22 Text 0 File WriterStatus.cpp, Line 116
    <SAMSUNG CD-R/RW SW-240B > start writing Lead-Out at LBA 186264 (2D798h), lenght 0 blocks
    10:35:04 PM #23 Text 0 File ThreadedTransfer.cpp, Line 228
    all writers idle, stopping conversion
    10:35:56 PM #24 Phase 37 File dlgbrnst.cpp, Line 1832
    Burn process completed successfully at 4x (600 KB/s)
    Existing drivers:
    File 'Drivers\nvatabus.sys': Ver=5.10.2600.0446 built by: WinDDK, size=79360 bytes, created 6/3/2004 4:40:46 AM (Adapter driver for rec)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
    ====== *** Nero-Burning Rom, History File *** ======
    Oct 2006
    Ботевград
    #18
    Re: Запис с Неро.
    Някой ще "декодира" ли какво не му изнася на моето Неро.
  5. Pat
    Pat е офлайн
    Oct 2003
    #19
    Re: Запис с Неро.
    По горе някъде ти казаха да махнеш тази отметка. Освен това задай място където да се прави имидж файла! Дай повече информация за диска който искаш да копираш - какъв е? Пробвай да го копираш като използваш само записвачката първо като четец, а след това като записвачка.
    Защо на CD_ROM устройствата им е изключен DMA?
    Aug 2006
    #20
    Re: Запис с Неро.
    И аз съм с две записвачки на РС-то и наскоро при опит за запис с НЕРО нито една от двете не потегли нормално да записва CD, а записват image file в HDD-то.
    Чекването на use multiple recorders реши проблема.
    Oct 2006
    Ботевград
    #21
    Re: Запис с Неро.
    Вече на трети компютър се появи моят проблем. Като помисля последно съм качвал няколко версии на GTA San Andreas и Daemon tools на тези компютри. На последният компютър не е имало ъпдейти на WIN - а, защото на него няма интернет. Пробвах всички възможности предложени от Вас, но уви никакви успехи не постигам. Накрая май ще инсталирам друга програма за запис на CD. Как е възможно само аз да имам този проблем?
    Feb 2003
    #22
    Re: Запис с Неро.
    Добре де, разкара ли всички програми дето се мешат на СД-тата, примерно тоя Daemon tools трети път го споменаваш, а не казваш дали след деинсталацията има ефект?
    Също така не казваш, дали са на 1 кабел и двете писачки
    Oct 2006
    Ботевград
    #23
    Re: Запис с Неро.
    Daemon tools съм го деинсталирал, но няма ефект. Двете писачки са на един кабел били винаги. Едната е мастер, а другата слейв. На другото IDE е HDD - то. На другия компютър пък има само едно CD RW. Не знам защо показва, че DMA е изключено. На HDD е на 5, а на CD - тата на 2.
    Aug 2006
    #24
    Re: Запис с Неро.
    Цитат Първоначално публикувано от fanta orange
    P.S.
    Лично не виждам смисълът от две записвачки на един компютър!
    Явно двамата с roumen68 ви гони някоя мега мания!
    Утре ще взема да си качна 4,за да не изоставам от модата муахахахаха
    Едната ми е външна, с USB, от времето когато бях само с лаптоп и ми трябваше бърза записвачка. Та сега и двете са активни, макар че на месеца я запиша 1 диск, я не
    Oct 2006
    Ботевград
    #25
    Re: Запис с Неро.
    Аз също се защитавам. Едната ми е CD от 2003 г., а другата е DVD от миналата година. Да я продам първата няма смисъл пък с две се по лесно копират дискове.
    May 2002
    #26
    Re: Запис с Неро.
    Тоя проблем само при презапис ли се получава? В смисъл откакто датира проблема записвал ли си от HDD?
    Oct 2006
    Ботевград
    #27
    Re: Запис с Неро.
    Когато записвам от HDD-то дава грешки при проверката, но има запис, докато при презапис от какъвто и да е диск на диск дава грешки. Накрая следва "аборт" и при четене диска е празен и излиза съобщение, че WIN-а не може да го прочете. Диска физически е набразден, а същото се получава и при симулативен запис. Някаква програма или груба грешка правя, защото трите ми компютъра съм "заразил" с проблема.
    May 2002
    #28
    Re: Запис с Неро.
    Ти направо ни смая. Тава да не е някакъв нов вирус пуснат от големите разпространители на музика и филми. Не, сериозно. На мен нищо не ми идва наум. Да не се понасят двете у-ва хардуерно ли , какво ли. Пробвай ако намериш някое друго у-во (вземи назаем от приятел) и пробвай. Тука и другите , дето разбират доста повече от мен са дали акъл и щом не става - лоша работа , бих казал по-скоро странна.
    Oct 2006
    Ботевград
    #29
    Re: Запис с Неро.
    На единият компютър е само едно CD и то е и записващо. Засега остава само една игра да е направила белята. Ще я изтрия, но тя сигурно се е загнездила на много места.
  18. Member Аватара на panevdd
    Jul 2003
    #30
    Re: Запис с Неро.
    Опитай така:
    1. Деинсталираш Daemon Tools и всякакъв друг софтуер за емулация (ако има такъв);
    2. Деинсталираш SPTD драйвера - сваляш си SPTD v1.55 от тук, стартираш го, избираш бутона Uninstall и потвърждаваш;
    3. Почистваш останалите в регистъра записи, свързани с емулация на дискови устройства - с помощта на XP_CD-DVD-Fix.
  1. проблем с неро
    От didka_bandidka5558 във форум Общ - софтуер
    Последно: 04-05-14, 23:50
  2. Грешка при запис с НЕРО
    От Pat във форум Общ - софтуер
    Отговори: 17
    Последно: 31-07-07, 17:58
  3. Проблем при запис с Неро
    От Sunny във форум Общ - софтуер
    Отговори: 13
    Последно: 08-04-04, 17:07
  4. Неро Проблем
    От SpUd3r във форум Общ - софтуер
    Последно: 05-04-04, 19:34
