Резултати от 1 до 3 от общо 3
Моля за съвет за избор на Flash Drive
    Aug 2005
    Philippines
    Искам да си купя Флашка 4 GB. Моля за съвет каква марка да купя изхождайки от това да бъде бърза и за около 130лв.
    За сега съм се спрял на това - PQI Cool Drive U339 Pro , но не успявам да го намеря в наличност.
    Data Transfer Rate - tops at 25MB/sec read and 17MB/sec write at sustained sequential speeds
    Благодаря Ви предварително и очаквам помощ.
    Description Performance, Quality, Compact Compact futuristic design in metallic casing
    The PQI Cool Drive U339 Pro also comes with USB Notebook – Personal File Manager software which is design for data security and easy management of your personal data featuring
    *Portable email
    *Portable personal backup
    *Portable IE favorites / Web account
    *File synchronization center
    *Portable secure / Zip doc and
    *Host lock.
    Remarks: software for Windows system only.
    U339 Pro with USBNotebook will available on 8/1
    Part Number - BB23-XXX1-01XX
    Interface - USB 2.0
    Capacity - 256MB~4GB
    Write Protect - Yes
    OS Supported - Windows ME, 2000, XP, Mac 10.1 or above
    Power Supply - DC 3.3/5V±10%
    Power Consumption - Read <100mA , Write <100mA, Standby <70mA, Unconfiguration <70mA, Suspend <0.5mA
    Dimensions - 68 x 19 x 9 mm (2.68 x 0.75 x 0.35 in)
    Weight - 12 g (0.03 lb)
    Environment - Operating Temperature: 0 to 65℃, Non-Operating Temperature: -20℃ to 75℃
    Other Information - Important!! Please make sure the driver matches the part number on your pen drive before you download.
    Software AP System Requirements One of following operation systems: Windows 98/98SE/Windows ME/Windows 2000/Windows XP
    The advertised memory capacity of this device represents unformatted capacity. Please note that once formatted and due to variations in flash module block limitations, the functional storage space will be lower than the advertised capacity.
    Nov 2003
    Re: Моля за съвет за избор на Flash Drive
    Значи за 130 лева най-вероятно трудно ще може да се препоръча някакво друго устройство с капацитет 4 GB, което да е точно толкова бързо. Аз съм доволен от устройствата на Apacer и Kingston като бързина и като здравина на изработката. Става въпрос за HT203 (което вече не се предлага май) и Kingston Data Traveller Elite.
    Въпросният продукт на PQI U339 PRO го ползвахме известно време във фирмата за работа - няколко пъти дневно пренос на данни - запис презапис. Беше с обем 2 GB. Бързо е, но недостатък е нестабилната изработка. Колегата го носеше на връзката с ключовете си. Разхлопа се много и вече не може да се ползва, компютърът не го разпознава. При предявяването на искане за гаранцията казаха, че повредата била механична и не го уважиха. А в интерес на истината USB накрайника мърдаше напред назад още веднага след покупката. Не бих го препоръчал на никого.
    Кингстъна макар и пластмасов и очукан до немай къде, се оказа желязно устройство.
    HT203 е бързо и здраво устройство. След изпиране продължава да работи , но цената както се вижда е малко по-висока.
    Oct 2006
    Ботевград
    Още един глас в подкрепа на Apacer. От две години ползвам само че 256MB и за сега нямам забележки.
  1. Избор на климатик - моля за съвет
    От Jikata във форум Климатици Fujitsu, General Fujitsu, Fuji Electric
    Отговори: 73
    Последно: 13-10-14, 18:38
  2. Избор на климатик. Моля за съвет!
    От HYordanov във форум Всичко за климатиците
    Отговори: 10
    Последно: 17-09-12, 14:16
  3. моля за съвет при избор на климатик
    От shper във форум Всичко за климатиците
    Отговори: 19
    Последно: 22-07-11, 22:42
  4. Избор на USB Flash Drive
    От iv_div_tiger във форум Общ - хардуер
    Отговори: 11
    Последно: 29-04-08, 11:14
  5. Проблем с USB Flash Drive
    От didko във форум Общ - хардуер
    Последно: 17-02-06, 13:49
