Продавам SONY STR-DG710/B 6.1 channel A/V Receive
Купен от Sony център преди 1.3 година в перфектно състояние пълен комплект книжки документи кабели дистанционно микрофон за калибровка
Цена: 250лв.
София. за друг град изпращам с куриер.
GSM: 0886477737
AV ресивър с добър запас на мощност 6x100W/8ohms. Вградени са всички необходими декодери за този клас.
DCAC акустична калибровка на съраунд полетата с микрофон в комплекта. 2xIn/1xOut HDMI интерфейси.
DMPORT за връзка с MP3 плеъри, iPod, опция Bluetooth®, Wi-Fi. Оптимизиран за Blu-ray и други HD източници на AV сигнали.
A/V синхронизация за Plasma/LCD телевизори.
Fatures :
* 6.1 channel A/V Receiver delivers the Full HD 1080 experience to your Home Theater System
* Powerful HDMITM connectivity allows for uncompressed 1080p video to pass through directly to your HDMITM capable television
* Put yourself in the middle of the action with Dolby Digital Prologic II / DTS and DTS Neo II/24/96 EX Decoding
* Optimised for HD Sources
* AM / FM tuner with RDS and 30 station pre-set
* DCAC - one-push automatic sound set-up for flexible speaker placement and optimum sound quality
* Comes with Sony's DIGITAL MEDIA PORT connector - possibility to connect a DIGITAL MEDIA PORT to release digital music stored on your PC, mp3 player or Bluetooth® mobile phone
* A/V Sync for perfect sound and image synchronisation with flat panel TVs
* Digital Cinema Sound for a true "at the movies" experience
* 2 HDMITM inputs
Technical specifications :
Amplifier:
* 8 Ohms 1kHz: 100 W + 100 W
* (8 Ohms 1kHz) THD: 1%
* 8 Ohms 20-20kHz: 85 W + 85 W
* (8 Ohms 20-20kHz) THD: 0.09%
* Number of amp. channels: 5.1ch
* Bi-AMP: NO
* Type: Analog
* 4 Ohm / 8 Ohm Switching: NO (8 Ohm only)
* DSP: Sharc
* Equalizer (F / C / Sur / Sur B) Bass, Mid, Treble: B,T / NO / NO / NO
* Subwoofer X`Over: 13 points (40-160 Hz)
* Analog Direct: YES
* Pureness Control: NO
* Sound Field Program (Movie): 3
* Sound Field Program (Music): 4
* Sound Field Program (A.F.D): 5
* Sound Field Program (2ch): 1
* Sound Field Program (Headphone): 3
* Personal AUDIO Enhancer: YES
* Cinema Studio EX. A / B / C mode: YES
* Speaker Selector: A
* Speaker Terminal: Front (Screw) / Others (Push)
* Headphone Out: YES (Gold)
I/Os:
* Front Input: NO
* DIGITAL MEDIA PORT: 1
* IX (Wi-Fi): Optional
* Bluetooth®: Optional
* WM: Optional
* iPod®: Optional
* Audio In (Incl. TV CEC) / Out (excl. tuner) / TV (CEC): 2 / 0 / NO
* A / V In / Out (S-Video I / O): Including Front AV: 2 / 1 (0 / 0) + V1 / 0
* Monitor Out (S-Video Out): 1 (0)
* Component Video In / Out (Pass through): 2 / 1
* Phono (MM): NO
* Multi-ch In: NO
* Pre Out: SW x1
* Digital In / Out: NO
* HDMITM: YES (2 In x 1 Out)
* Opt. IN / OUT / TV (CEC): inc Front & TV (CEC): 2 / 0 / NO
* Coax.: 1 / 0
Decoding Format:
* Dolby Digital / DTS: YES / YES
* Dolby Prologic: YES
* Dolby Prologic II: YES
* Dolby Prologic IIx: NO
* Dolby Dual Mono: YES
* 96k / 24 Bit PCM: YES
Tuner:
* RDS: YES
* Preset Channel (FM / AM): TTL60 (30 / 30)
* Station Name: YES
* Auto Tuning: YES
* Direct Tuning: YES (RM)
Video Features:
* HDMITM Repeater: NO
* HDMITM Quality 1080p: YES
* HDMITM Quality 1080/24p: YES
* A / V SYNC (Variable / Fixed): YES (Fixed)
* Time (msec): 60
* Sampling Frequency (Up to 192kHz / 96kHz / 48kHz): 48kHz
DCAC (Digital Cinema Auto Calibration):
* DCAC (DSP / UCOM): BRONZE
* Mic (STEREO / MONO): MONO
General:
* Sleep Timer: YES
* Pin Jack: Nickel
* AC Outlet (Switched): NO
Dimensions & Weight :
* Dimension (W x H x D) (mm): 430 x 157.5 x 318
* Weight (Kg): 7.7
