Ресивера е чисто нов, кашона е отворен само за тестове. Не е купуван от БГ и няма гаранция. Цена 680 лв. В София е, тел. 089 8400228
Ето малко данни:
3D over 4xHDMI® - Easy one cable connectivity from numerous sources to your Full HD TV plus 3D video pass through (from a compatible 3D source)
Dolby® ProLogic IIz - Experience more spacious surround sound with front height channels, for a lifelike soundstage with added depth and dimension
Audio return channel - Hear sound from the TV through your Home Cinema system via HDMI®, without needing a separate optical digital audio cable
HDMI® pass through - Connect multiple home entertainment sources, and your TV will receive the signal even when the receiver is switched off
Video up converter - Built-in upscaler generates a 1080p signal via HDMI® cable for superb picture quality on your HD TV, minimising the number of connections
Sound fields - Choose from 24 different sound fields designed to optimise your home cinema
Graphic User Interface - Onscreen navigation is easy with icons to guide you through set up, while the main video source is displayed
Modern design - Design match your AV receiver with Sony Blu-ray Disc™ players for a great looking set up in your lounge
HD Surround Sound from Blu-ray Disc™ - 8ch Linear PCM for true High Definition sound from Blu-ray Disc™ players, and Digital Audio Assignable
x.v.Colour, Deep Colour and 24p True Cinema - Adjusts picture settings on pass through to make movies look as authentic as the original
DCAC - One-push automatic sound set-up for flexible speaker placement and optimum sound quality
Bi-AMP - Enables two amplifiers to drive each speaker minimising distortion levels and greatly improving sound quality
BRAVIA® Sync - Simple, one touch integrated control over your BRAVIA® TV and other compatible products with only one remote
DIGITAL MEDIA PORT - Connect to and release digital music stored on your WALKMAN® or iPod with these optional accessories
RDS tuner - Built-in tuner with 60 preset stations
Power Output (8O, 1 kHz, THD 1%) 100W + 100W
Dimension 430 x 157.5 x 322
 Новини
 Новини Форум
 Форум Актуално
 Актуално сървър
 сървър
  Отговор с цитат
  Отговор с цитат
