Netgear XAVT5601 3 Kit 500 Mbps Powerline Adapter with 3 pieces
2. Допълнителна информация
Чисто нов комплект 3 броя, купуван от Германия, неразопакован!
Продавам го на цената на която го взех. Предоставя връзката между компютрите по линията на електричеството в дома със скорост 500мегабита.
!!!ЦЕНАТА Е ТВЪРДА!!!
The kit provides fast access to the local network from the power outlet and should with his 3 adapters enough for a start. There is of course also with expandable additional adapters . The bandwidth of up to 500 Mbit / s can be applications such as HDTV , several HD/3D-Video-Streams , streaming multimedia and multiplayer games too. Of course, the transfer speed is also dependent on the in-house power supply. To use the device without complicated installation or similar is required, can be quickly and easily check the link quality at each outlet.Also very pleasing on the Netgear system: The adapter itself off automatically when not in useand consume less than 0.5W in standby mode . Additional guzzlers brings you here so certainly not into the house.
3. Състояние и гараниця
Чисто нови, неразопакавани.
170лв, без бартери!
София, изпращане по Еконт
0885 277727
7. Снимки:
...Добавете тук.....
