Страница 2 от 4 ПърваПърва 1234 ПоследноПоследно
Резултати от 16 до 30 от общо 46
Like Tree1Одобрявам
Апаратна калибрация на телевизори
    #16
    Отговор: Апаратна калибрация на телевизори
    Sharp - 85x
    Влизане в сервизното меню и настройки за калибриране.
    (от сервизното ръководство)
    3. Entering and exiting the adjustment process mode
    1) Before entering the adjustment process mode, the AV position RESET in the video adjustment menu.
    2) While holding down the “VOL (–)” and “INPUT” keys at a time, plug in the AC cord of the main unit to turn on the power.
    The letter “<K>” appears on the screen.
    3) Next, hold down the “VOL (–)” and “CH ( )” keys at a time.
    (The “VOL (–)” and “CH ( )” keys should be pressed and held until the display appears.)
    Multiple lines of blue characters appearing on the display indicate that the unit is now in the adjustment process mode.
    When you fail to enter the adjustment process mode (the display is the same as normal startup), retry the procedure.
    4) To exit the adjustment process mode after the adjustment is done, unplug the AC cord from the outlet to make a forced shutdown. (When the
    power was turned off with the remote controller, once unplug the AC cord and plug it again. In this case, wait 10 seconds or so before plugging.)
    CAUTION: Use due care in handling the information described here lest your users should know how to enter the adjustment process mode. If the
    settings are tampered in this mode, unrecoverable system damage may result.
    4. Remote controller key operation and description of display in adjustment process mode
    1) Key operation
    *Input mode is switched automatically when relevant adjustment is started so far as the necessary input signal is available.
    2) Description of display
    Remote controller key Main unit key Function
    CH ( / ) CH ( / ) Moving an item (line) by one (UP/DOWN)
    VOL (+/–) VOL (+/–) Changing a selected item setting (+1/ –1)
    Cursor (UP/DOWN) ————— Turing a page (PREVIOUS/NEXT)
    Cursor (LEFT/RIGHT) ————— Changing a selected line setting (+10/ –10)
    INPUT ————— Input switching (toggle switching)
    ENTER ————— Executing a function
    http://dot-color.com/category/color-gamut-standards/
    Този пост е редактиран от hristoslav2; 31-03-14 в 21:48.
    #17
    Този пост е редактиран от hristoslav2; 30-03-15 в 00:10.
    #19
    #20
    #21
    #22
    Този пост е редактиран от hristoslav2; 29-05-17 в 22:59.
    #24
    CalMAN 2017
    Компанията Portrait Displays пусна система за автоматична калибрация на изображението AutoCal за дисплеи, поддържащи HDR. Тази система влиза в пакет CalMAN 2017. По думите на компанията, системата позволява автоматично оптимизиране на изображението по всички параметри в поддържаните телевизори, сред които са указани QLED-модели Samsung и телевизори Panasonic, излезли през 2017 година. Мартин Фишман (Martin Fishman), един от директорите на компанията, смята, че със системата за калибрация AutoCal зрителите ще могат да видят «всичко, на което са способни техните впечатляващи нови телевизори». В новата система цветовият обхват се изобразява с помощта на триизмерна визуализация. По-рано диаграмите на цветовият обхват се изобразяваха в двуизмерен вариант при едно ниво на светимост. Сега популярността на HDR и високата резолюция изискват по-голяма точност в изобразяване на цветовият обхват — от тук и необходимостта за по-подробен триизмерен модел. Версия CalMAN 2017 поддържа формати HDR10, HLG, а също така работи и с Dolby Vision.
    #25
    Ако някой иска да се занимава професионално, е добре да прочете това
    Display Profiling & Display Calibration Tools Lightspace Calman Argyll
    OLED TV test pack.zip
    HDR10 Aspect Ratio&Sharpness
    Този пост е редактиран от hristoslav2; 28-07-17 в 21:57.
  13. Member Аватара на antovasilev
    Sep 2011
    Плевен
    #26
    А за калибриране на проектори?Някоя фирма в България?
    #27
    https://www.olx.bg/ad/x-rite-1displa...i-ID3ycfO.html
    https://photo-forum.net/index.php?AP...=view&id=39232
    Само дето колориметърът е от среден клас и не знам какъв софтуер ползва. Калибрацията на проектор е много специфична - колориметърът се поставя на статив и се насочва към екрана, гаси се осветлението и се замерва отразената от екрана светлина. Калибрацията е съответно само за използваният в момента екран. При смяна на екрана, трябва да се направи нова калибрация.
    Май колегата е регистриран и тук
    https://forum.setcombg.com/members/mitakabus.html
    #28
    Този пост е редактиран от hristoslav2; 18-08-17 в 19:59.
    #29
    Един от семинарите на ISF
    https://imagingscience.com/wp-conten...-2017-33.3.pdf
    #30
  1. Ръководство за калибрация на телевизор за начинаещи
    От lazarus18 във форум Ремонт, сервиз и калибрация на телевизори
    Отговори: 227
    Последно: 28-10-22, 10:59
  2. Телевизори DSM, NEO?
    Последно: 19-01-16, 23:27
  3. Samsung UE40ES6100 най-добра калибрация.
    От veselinov87 във форум Samsung телевизори
    Последно: 20-04-13, 21:11
  4. Телевизори DSM???
    От dimex във форум Други телевизори
    Отговори: 29
    Последно: 04-02-13, 16:23
  5. телевизори
    Последно: 31-08-12, 07:46
