Strong / FAQ - на първа страница, мнения, обсъждане
Strong
STRONG Digital TV - Home
STRONG Digital TV - Начало
Местоположение на компанията: United Kingdom
Старт на производството на приемници: 2004
Тип на производителя: собствена продукция
Фърмуер
Software & Documentation
Софтуер & Документация
Strong Digital - Dokumentation Project by ILG Software & BFM Internet-Vertriebs GmbH
https://play.google.com/store/apps/d...Controid&hl=bg
Австралия
Strong Australia - Digital Set Top Box Range
THOMSON
THOMSON
DVB-T:
THOMSON THT501 - ALI 3601 400@Mhz;
THOMSON THT502, 505 - ALI 3801 596@Mhz
DVB-T2:
STRONG 8502/THOMSON THT702 - STiH251 650@Mhz (1200@DMIPS); Flash 8mbit, DDR3-1333 (128mb)
TVNT.net - Le forum de la TNT • [Topic Unique] Thomson THT501 - 502 - 505 - enregistreurs TNT HD : Les adaptateurs pour recevoir la TNT gratuite en SD ou HD
| Strong DVB-T receivers |
Model ........................ | Main Chipset CPU frequency ........................ | Flash Memory ....................... | SDRAM Memory .................... | Tuner Type Frequency Range ............................. | Active Ant Power ............................ | Input Level Range ................................... | ................... | .................... | ................... |
| STR-8102 | ALI M3601
400Mhz | 2Mbits | 4Mbits | | | | | | |
| STR-8106 | ALI M3601
400Mhz | 4Mbits | 64Mbits | | | | | | |
| STR-8112 | ALI M3801
594Mhz | 4Mbits | 64Mbits | | | | | | |
| STR-8113 | ALI M3801
594Mhz | 4Mbits | 128Mbits | | | | | | |
| STR-8115 | ALI M3801 594Mhz | 4Mbits | 64Mbits | | | | | |
Model
CPU frequency
Frequency Range
Какво е BER (Bit Error rate) ?
Bit error rate - Wikipedia, the free encyclopedia
Какво е SNR (Signal to noise ratio) ?
http://bg.wikipedia.org/wiki/%D0%9E%...88%D1%83%D0%BC
Signal-to-noise ratio - Wikipedia, the free encyclopedia
Signal strength
Signal strength - Wikipedia, the free encyclopedia
Signal Strength v Signal Quality
Signal Strength v Signal Quality - Forum
EPG (Electronic Program Guide) - интерактивна услуга в областта на цифровата телевизия и радио, обзпечаваща гъвкавост в цифровото съдържание. Електронният гид, представлява екранно меню изобразяващо разписанието на теле и радио програмите с възможност за интерактивна навигация по време,название, жанр, канал и т.н. с помоща на дистанционното управление.
Electronic Program Guide — Википедия
http://www.etsi.org/deliver/etsi_i_e...300707e01c.pdf
Защо приемниците подреждат програмите по един и същи начин ?
Подреждането на каналите зависи дали LCN функцията е включена или изключена. Това се отнася за всички цифрови приемници. Ако я изключите, подреждането става по реда на приемане. Сегашното подреждане по мултиплексите е зададено като параметър от КРС.
(logical channel numbering) Logical channel number - Wikipedia
Не мога да преименувам програмите.
Не може да преименувате програмите на кирилица!! Имената на програмите се задават от мултиплексите.
OTA (Over-the-air programming) - опция за автоматично ъпдейтване на фърмуера от ефира
Over-the-air programming - Wikipedia, the free encyclopedia
PVR (Personal Video Recorder) - това е потребителско устройство, снабдено със софтуер позволяващ да се записва в цифров формат на USB Flash Drive, HDD, SSD или други локални или мрежови устройства.
Digital video recorder - Wikipedia, the free encyclopedia
DVR (Digital Video Recorder) - устройство предназначено за запис съхраняване и възпроизвеждане на видеоинформация.
Timeshift Channel - изместени във времето телевизионни програми (+1, +2)
Timeshift channel - Wikipedia, the free encyclopedia
Timeshifting - запис на програма на външно устройство, с цел записа да бъде прегледан от консуматора, в определено времево изместване.
Time shifting - Wikipedia, the free encyclopedia
VoD (Video On Demand) - видео по поръчка. Система за индивидуална доставка до абоната на телевизионни програми, филми по цифрова кабелна, сателитна, ефирна телевизионна мрежа с мултимедия сървър в различни контейнери. Може да поръчате филм по всяко време от каталога, при това се поддържат допълнителни функции (превъртане, пауза..).
Video on Demand — Википедия
Pay-Per-View (PPV) - допълнителни платени телевизионни услуги , като потребителят може да плаща само за определени канали или за отделни предавания или филми.
Проблеми с приемника/декодера и техните решения
На някои програми ми насича картината.
Проверете дали ви е включено захранването на активната антена от менюто. Ако е включено, изкарайте инфото за сила и КАЧЕСТВО на сигнала и се поразходете малко из стаята с антената, за да хванете стабилен сигнал. Имайте в предвид, че добрите и лошите положения на антената може да се редуват през 1 педя и да е достатъчно едно леко преместване. Ако не се получи, тогава търсете външна антена. Насочете я към предавателя (виж къде е в твоя район) и я ориентирай с пръчки перпендикулярни на земята.
Не мога да изключа устройството, седи постоянно включено независимо колко отблизо насочвам дистанционното устройството е в постоянно работещ режим. Модела е с с вграден RF модулатор и е свързан с къбел към антенният вход на телевизора.
Невъзможноста да бъде изключен може да е причинена от обратен ток, течащ от антеният вход на телевизора към приемника - обикновенно обърква софтуера и приемника блокира. Най-лесно се разбира като изключите свързващият кабел и рестартирате приемника. След което се опитайте да управлявате приемника с дистанционното-ако всичко е нормално проблема е в телевизора - има пробил кондензатор.
Не чете USB-то, което включих. Отчита, че има USB устройство, защото фукнцията за безопасно изключване на USB е активна.
- форматирайте флашката чрез приемника
- сменете USB флашката с друга.
Strong - поддържат както UTF-8, така и ANSI (CP1251) кодировка на субтитрите.
Strong SRT 8102 PVR+
+ записва директно като MPEG4 TS
+ можe да записва една програма докато гледате друга, но само при условие че двете програми са на един мултиплекс
- липса на бутони за контрол на предния панел
Strong SRT 8105
В комплекта има дистанционно управление, книжка с упътване (няма на БГ, има на руски и повечето EU езици), 2 ААА батерии за дистанционното.
+ подредба, преименуване, заключване на канали
+ USB-то е отпред, USB флаш памет, форматирана във FAT32 я разпознава без проблем,
+ чете всички папки в паметта
+ възпроизвежда .MKV 720p безпроблемно и гладко, също и .MP4 1080p, JPEG с резолюция над 8MP и размер над 3MB, MP3 с битрейт 320kbps. XviD + .srt файл, разпознава плейва относително добре,
+ Функцията на запис е доста прилична. Качеството на записите наистина е добро. Записите по подразбиране са във формат .TS, а минута запис от с резолюция 720x576 е приблизително 13МБ, а 1920x1080 приблизително 60МБ. Функцията Timeshift също не е лоша, пауза в реално време.
+ има две игри , Судоку и Отело
+ Чете субтитри с разширение .SRT
- субтитрите излизат по дразнещ начин, плавно изписване от ляво надясно !
- липса на настройка за големината на субтитрите в менюто, което може да се коригира в самия .srt файл
- дистанционното трябва да е право насочено към декодера за да функционира.
Внимание има два модела 8105!
Само при единият записва ТВ програма и дава възможност едновременно да се гледат други от друг МУКС
Strong SRT 8106
+ има и RF модулатор + всичко останало на 8105
+ наличието на бутони на предния панел
- шрифта на менюто е малко дребен
Strong SRT 8113
+ с RF модулатор - избираш дециметров канал (синтезатор) и всички звукови стандарти G/I/K от менюто.
+ Меню на български,
+ Record/Play на флашка. След ъпдейта от 17-ти 07 чете без проблем Windows 1251 субтитри. Лично изпитано. Преди това се налагаше преконвертиране в UTF-8
+ в комплекта има антенка с магнит и RF кабел, дистанционно и батерии.
Дори средният размер на надписите е достатъчно голям за съчетанието на телевизора и дневната ми. Недостатъкът му е, че не пренася редовете на препинанията, ами направо през думите.
+ Антенката е страшна, при вдигнати щори хваща по-добре от турската ми външна антена с усилвател.
+ Има опция да се настройва времето до изчезване на различните барове и информационни табла по екрана
По дефолт е включено и автоматичното изключване след 3 часа, което може да изключите.
- Телетекстът обаче ми излиза на латиница.
- Когато се влезе в менюто, спира текущия канал, звук и картина.
- Орязва имената на предаванията, като сменя програмите и като се натисне INFO
- Телевизионният справочник е общ за всички програми, няма поотделно, намирам го доста неудобен.
- Много бавно стартира
- Субтитрите. Когато се стартира филмът, тръгват автоматично външните BG субтитри. Обаче не излиза менюто за настройка на субтитрите при натискане на Subtitle, а само информацията 1/1. Т.е. има един файл със субтитри. Освен външните BG, се оказа, че филмът има вградени още 4 езика subs с UTF-8 кодировка. Ако се спре филмът и се стартира отново, БГ субтитрите ги няма, а при натискане на Subtitles се показва Off и при следващите натискания излизат вградените на 4-те езика (1/4; 2/4 и т.н.). Само английските се изобразяват правилно, а френските и испанските някои от специалните им символи излизат на маймуница. За да тръгнат пак БГ, трябва с Exit да се излезе на горно ниво (директория) и да се стартира отново филма.
- Менюто е почти пределно ясно и интуитивно, забележки имам относно подбора на цветове и големината на буквите в менютата.
- Губи си настройките когато е на standby и е имало прекъсване на тока от стана на енергото - премигвания, аварии, профилактики и др. подобни.
+ Може да записва едновременно две програми докато гледате трета. Пъвооткривател на функцията беше eclipse. При това отпада възможността за таймшифт, но аз и без това не я ползвам. Естествено и трите програми трябва да се излъчват на един и същ канал. Единствено забелязах, че ако му настроя на таймера еднакви начални часове за едновремен запис на две програми, има много накъсвания по протежение и на двата записа. Ако записите ги настроя да тръгват с 1 минута разлика си ги записва отлично. Пробвах дали случайно това не е стандартна екстра на приемниците. За целта ползвах един X-Tremer, но уви, не ги може тия номера MSTAR процесора. Всъщност аз си мисля, че вероятно такава способност имат само приемниците с "гъзарски" таймшифт (имащи AUTO режима в който таймшифта записва нон стоп по флашката).
2. Докато гледате запис направен със самия приемник и на екрана по един или друг повод е изобразено инфо барчето, можете да си слагате/махате табчета (репери, индекси) с червения бутон и да прескачате между тях със зеления. Също при изобразено инфо барче, можете с лява и дясна стрелка и ОК също да прескачате до далечна точка в записа. MSAR платформата наместо това си има GOTO бутон в който с цифри въвеждате желаното време.
3. Ако скипнете каналите които не гледате и останат по-малко от 10, то с клавишите PG+ и PG- можете да си изкарвате инфо барчето, вместо да търсите малкото бутонче до копчето за изключване. Ако имате повече от 10 канала, тия два бутона служат за прескачане на 10 канала напред и назад.
Strong Prima VI
+ списъка със записите и е с наименованията на предаванията, а не на програмите от които е записвано, както е при SRT8113. Предполагам всички по-нови от 8113 приемници са така. Ако може нека собствениците им да споделят как са там нещата.
Strong SRT 8115
Hardware: VER1.0.0 / Software: SRT8115-V1.0.6 / 28.05.2013
Подозирам, че SRT 8112 е същият без дисплей и с 3,5mm аудио, вместо RCA/Chinch
Тествах с моно ТВ Panasonic TX-21S1RCP на почти 18 години, свързан с 21pin SCART - SCART кабел по RGB. На място нямаше как да проверя аудио изходите RCA (Chinch) дали работят паралелно. Не съм тествал HDMI и Digital audio по обясними причини.
Стайна антена самоделка от два телескопични елемента + антена за дециметров обхват от “Юность” и съответните съгласуващи елементи.
Правил съм паралел с SRT8113, защото само него съм тествал и то при същите условия.
I. Окомплектовка и външен вид:
+ качествена изработка, четливи зелени символи на дисплея
+ за близо 3-те часа работа не загря повече от нормално.
Нямах термометър, но при околна температура около 27 корпусът беше само леко топъл.
+ нямаше прекъсване и пикселизация за това време
+ удобно дистанционно с меки бутони, но е нужно време да се свикне с разположението им
+ в комплекта има батерии за дистанционното
+ упътване на български, гаранция 24м, картата е отпечатана на последната страница на книжката
- упътването е с прекалено дребен, направо ситен шрифт. Много трудно се чете „в оригинал”.
- къс захранващ кабел – само 1м! То бива икономии, но чак толкова...
+ екранни менюта на български, със съвсем малки забележки по съкращенията
- Много голям минус: няма бутон >>І и І<< (next / previous) за разлика от 8113
Може да се ползват други, но поне аз не ги открих нито в описанието, нито по метода проба-грешка. Това е недостатък при ползването на медиа плеера.
- дистанционното трябва да е насочено под малък ъгъл, за да действа. Не съм махнал защитната лента на лицевия панел и може и това да е оказало влияние.
II. Ефирен цифров приемник:
+ В градски условия с почти пряка видимост към предвателя на около 2,5км постигнах качество 97-98% при 74-75 сила на сигнала .
При същите условия Strong SRT8113 постигна 87-88 при 71-72 съответно. С активната антенка не помня колко беше.
Отначало трябва да изберете страна, език и т.н. Аз пробвах и за UK – нямаше проблеми с настройката.
Задължително изберете страна България, за да нямате проблеми със кирилските субтитри на плеера! Иначе излизат с друга кодировка.
+ бързо стартира и превключв каналите
+ Много качествена картина на 21” TV. За звука мога да кажа само, че е ясен.
Телевизорът е моно все пак... По подразбиране е HDMI / Component. За RGB трябва да се избере SCART.
+ Четливо изобразяване на информацията на екрана. Има няколко нива на настройки за прозрачност и време за показването й.
- Няма настройки на картината – яркост, контраст и т.н., както е при 8113. Няма и на звука, както почти всички приемници от този клас.
- Няма Mosaic бутон и функцията за показване на миниатюри на каналите.
Не, че е болка за умиране, но все пак...
- Няма Zoom, както е при SRT8113
III. Media player:
+ има директен бутон на дистанционното File
Тук започват минусите, защото те са свързани главно с навигацията.
- изборът на тип файл (video, audio, снимки, запис) става с последователно натискане на цифров бутон 1, вместо с логичните ляв и дясен навигационен бутон (< >). При SRT8113 се ползва Mosaic, което е същата глупост.
- липсата на >>І и І<< (next / previous) е осезаемо при възпроизвеждане на музика. Дори в екранните указании за навигации липсват.
Уточнявам, че тествах само с един FLAC, който е записан без индекси и паузи м/у песните.
Ще се радвам, ако някой е проверявал с друг тип аудио файлове и ме опровергае!
- Навигацията във всеки тип файл е различна и се ползват цифровите бутони. Трябва да се следи OSD на екрана на ТВ.
+ тествах само с едно MKV/H.264/720p в отделна директория – Svolochi – перфектно работи и възпроизвежда със srt кирилски субтитри.
- субтитрите и видео файла трябва да са с еднакво име, иначе не ги открива
- не поддържа субтитри *.SUB!
+ има три размера субтитри, като на нормален е горе-долу добре на 21”. На мен лично ми се искаше шрифт между нормален и голям.
- ако се забавите повече от 3 секунди, менюто за размера се скрива и остава стандартната функция за регулиране на звука от < >
- поддържа само 3 реда субтитри, пренася двата реда субтитри автоматично, а най-долния го реже
- в някои случаи шрифта става нечетлив, защото не е с черна окантовка
+ има възможност за фон зад субтитрите, от които удивление буди наличието на бял!!! И липсата на полупрозрачен или сив. Единствено черният е някакъв компромис.
- няма възможност за промяна на цвета на субтитрите.
- има възможност за изместване на субтитрите по вертикала.
- може да се премества по време напред-назад с извикване от бутон
- друг голям минус: не запомня точката, до която е натиснат Stop при филми. Или поне при двата, с които тествах беше така.
Когато тествах SRT8113, не поддържаше кирилица и нямах време за проба на цветове, фонове и т.н. Затова и не мога да направя сравнение с него, за съжаление!
+ чете FLAC, BMG, JPEG и позволява въртене на снимките.
Малко странно отново (с левия бутон <), но поне го има.
IV. Time shift & Record, HDD: има директен бутон
Тествах с флашка само, NTFS – работи без проблем. Не съм пробевал да я форматирам на 8115, но в упътването пише, че може само на FAT.
Записва в TS, максималния обнем на файла не го знам. Моята флашка се оказа бавна, според 8115 и не можах да тествам Time Shift.
При директния запис нямаше проблем, има добра индикация на параметрите.
Strong SRT 8115 установих още неща:
1. За 4:3 TV трябва да се зададе формат 4:3LB, а не Auto, за да се изобразяват коректно каналите с WSS и филмите на плеера. В нашия ефир това е само K1 HD, за съжаление.
2. Навигационните бутони нагоре и надолу само при възпроизвеждане на видео могат да се ползват за NEXT / Previous. Филмите бяха два само, но и в двете посоки бутоните работеха.
На MP3 само местят курсора. Възможно е да работят при създаден playlist, но не ми остана време да пробвам как става това.
3. Flash паметта ми от 4GB се разпознава като 3GB
4. Както и очаквах, субтитрите на Normal са много - 43 символа на ред, а на Big (менюто кой знае защо е на английски) са 32. Опитно съм установил след много загубено време по корекция на МТК DVD players, че оптималният шрифт е Arial Narrow с черен кант (или полупрозрачен фон) и брой на символите до 36 на ред. Т.е. някъде между двете посочени настройки.
Small въобще не го гледах, защото е прекалено ситен. Може би са до 60 символа на ред.
5. Изобразява коректно имената на папките на кирилица CP1251, но не и кирилските символи в имената на файловете.
6. При възпроизвеждане на видео файл информационната лента е прекалено голяма - същата, като при смяна на ТВ канала. Индицира се само текущото време и цялостната продължителност на филма. Не може да се покаже оставащото време.
strong 8115: При превключване на програмите, обикновено за кратко стои един правоъгълен „прозорец“ с информация за канала – какви кодеци се използват, някакъв progress bar, който няма нищо общо нито с Signal quality, нито с Signal strength, дали е в някой Favorite списък и т.н. Заедно с това има и част от EPG-то – текущото предаване/филм и следващото. Е, именно тези двете последните нямат нищо общо с действителните. Нещо повече – часът на тези предавания има огромно разминаване с реалния. Самото меню EPG обаче си е наред – като се отвори за всичките програми си показва точно информацията. Часът (по-точно часовия пояс, тъй като часът си го „хваща“ от сигнала предполагам) е настроен вярно
Отговор: Strong / FAQ - на първа страница, мнения, обсъждане
Мисля, че за 8113 "- Когато се влезе в менюто, спира текущия канал, звук и картина." и "- Докато се правят настройките спира да приема (спира звукът), няма настройки на полупрозрачно поле в-у образа. " са едно и също казано с различни думи.
Отговор: DVB-T приемник / FAQ - на първа страница, избор, мнения
*.SRT и да е с еднакво име с видео файла.
Има нов FW за Strong 8115 от днес на официалната страница: http://www.strong.tv/bg/products/rec...ition/srt-8115
Последният ред ми е най-интересен, но до другата седмица няма да мога да го проверя.
Software version 1.1.2 from 14.11.2013
The following improvements were realised since the last software verison:
• France SD/HD simulcast: After a re-scan all old channels will be deleted
• Amendments for the Italian and French OSD
• New function to backup and load channellist data
Нов update и за 8113:
Software version 4.3 from 22.10.2013:
Following improvements were realised since the previous Software version:
• Some more points considered for compliance to Hungarian specs
• Support of subpage selection in TXT added
• Audio priority added
• Subtitles priority correctly followed
• Now&Next in EPG information added
• Corrected and added the age in EPG screens
• Week navigation in EPG following to Hungarian specs
Надявам се да ми остане време да го пробвам през почивните дни!
8113 v.4.3 - работи коректно:
- с бутоните PG+ / PG- последователно се избира subpage в нарастваща или намаляваща последователност. Обаче трябва да се изчака да се сменят автоматично и да бъдат изписани на реда най-отдолу, което е меко казано странно. Вдясно от надписа AUTO, на което не можах да повлияя по никакъв начин. Иначе и той се избира със последователно натискане на PG+ / PG- и става от бял -червен, като subpage номера.
Ако някой е намерил друг начин, нека сподели!
В TXT с бутон ОК се сменя прозрачността на фона. Винаги е в/у картината, като единият междинен се вижда като размазан.
• Now&Next in EPG information added - това работи
Променен е леко EPG екрана.
Останалите функции не разбрах какво вършат, въпреки, че имам тестови файлове със няколко аудио потока и субтитри.
Остава бъга със вградените субтитри и външните такива - трябва излизане от Media player-а, ако преди това е пускан филм с вградени субтитри.
Gena_bs
Мен EPG екрана приятно ме изненада, че вече не сменя канала като се разхождаш из програмата. Не знам до колко е полезно детайлното инфо за сегашното и следващото предаване в EPG екрана. И въобще, детайлната информация да се вади с дребното INFO бутонче. Преди това ставаше с ОК ако не се лъжа, но сега той служи за смяна на канала.
Gena_bs
Само на челна стойка дето не му застанах, след новия фирмуер само първия път видях външните субтитри. От там насетне само вградените признава. Флашки сменях, приемника рестартирах. Интересно как след префлашване в първия момент уж пазеше подредбата на каналите, но после я загуби. Подобно на нулиранията при пикове от енергото, като му се стори че целостта на данните за настройките е нарушена и си ги ресетва всички за по-сигурно.
Приемници - Еифирни - Висока Резолюция - SRT 8108
Пробвах тази машинка и е супер бърза, качествена картина, бг субтитри и отваряща основните рипове. Може би най-доброто към момента на най-ниска цена. В момента в промоция от 38 лв. Без забележка от всякъде!
Въпрос към всички притежатели на ефирни цифрови декодери STRONG и конкретно за модел: 8108 някой пробвал ли е да направи ЪПДЕЙТ и станал ли е успешен? След проверка в менюто за информация на версията отразило ли си е, че има инфо с новата версия?
P.S. USB флашката преди ъпдейта в какво трябва да е форматирана: FAT32 или NTFS ?
soon
Да аз упдейтвах моя, бързо и лесно става, флашката трябва да е FAT или FAT32!
Оправени са много проблеми!
И аз реших да ъпдейтна моя srt8108, само че спря тока и сега е мъртвец.
Някакви предложения какво да правя? Дали мога да направя нещо като няма никакви портове по него или да го връщам в техномаркет и да се надявам да ми го оправят или сменят.
Ами направи се на ударен :BigGrin и кажи че както си работел и спрял . Не им давай обяснения какво си направил - кой ще се занимава да го ремонтира , ще го подхвърлят и готово .
Май и аз на този вариант съм се спрял, ще видим дали ще стане.
А някой знае ли дали ще може да се върне в друг магазин от веригата, а не точно в магазина от който е купен.
Трябва да може да се върне във всеки един магазин от веригата.
Да върнах го в друг магазин и след две седмици ми го върнаха префлашнат. В протокола от сервиза пишеше проблем с firmware-а, ама не са правили на въпрос, че съм виновен за това.
А реших да правя ъпдейта защото при смяна на канала изкарваше едно и също инфо за всички канали.
Сега всичко е наред.
Успех на всички.
При модел SRT 8108 вече 2 пъти се случва от приемника както си върви и се появява надпис "автоматично обновяване на каналите" - след което премигва и вече са налични само 4 канала (произволно избрани), а другите са изтрити. След като се пресканира отново се появяват всичките 11 телевизии. Къде е проблема?
