**********************/files/M8BRQFC8/...T2WXX.rar.html
LE32B55* T315HW02 V2,8bit,31.5 inch,16.7M,16:9,0 to +50,12V,AMVA3,72%,31.5 inch,FHD, 4U-Lamp, w/o inverter
(Second Panel : LTF320HA09,SSCZAI,8bit,32inch,16.7M,16:9,0.3635(H)*0.36375(w),0 to +50,12V,SPVA 72%,32 inch FHD)
LE37B55* T370HW02 V,8bit,37 inch,16.7M,16:9,0 to +50,12V,AMVA,72%,37 inch, FHD, 10S-Lamp, w/o inverter
LE40B55* V400H1-L05,8bits,40inch,16.7M,16:9,0 to +50,12V,DJITO, 72%,40 inch,FHD, w/o inverter
(Second Panel : LTF400HA08,SSDZAZ,8bit,40inch,1.67M,16:9, 0.461(H)*0.461(W),0 to +50,12V,SPVA 72%,40inch FHD 60Hz)
LE46B55* V460H1-L06,8bits,46inch,16.7M,16:9,0 to +50,12V,Flip Pixel, 72%,46 inch, FHD
(Second Panel : LTF460HA06,SSEZAV,8bit,46inch,16.7M,16:9,0.53025(H)*0.53025
(W,0 to +50,12V,SPVA 72%,AG3)
LE32B65* T315HW02 V3,8bit,31.5 inch,16.7M,16:9,0 to +50,12V,AMVA3,72%,31.5 inch, FHD,4U-Lamp, w/o inverter, 120Hz(MEMC)
LE37B65* T370HW02 VE,8bit,37 inch,16.7M,16:9,0 to +50,12V,AMVA,72%,37 inch, FHD,10S-Lamp, w/o inverter, 120Hz(MEMC)
LE40B65* LTF400HF09,8bit,40inch,1.07B,16:9,0.46125(H)*0.15375(w,0 to +50,12V,SPVA 72%,40 inch FHD
LE46B65* LTF460HF03,SSEZFT,8bit,46inch,1.07B,16:9,0.53025(H)*0.53025(w,0 to +50,12V,SPVA 75% ZBD,46 inch FHD
LE55B65* V546H1-L01,CM54H11A,10bits,54.6inch,1073.7M,16:9,0 to +50,12V,Flip Pixel,72%,54.6 inch, FHD, 120Hz(MEMC), S/C
LE40B62* V400H1-LH3,CM40H13A,10bits,40inch,1073.7M,16:9,0 to +50,12V,DJITO, 72%,40 inch, FHD, w/o inverter, 120Hz(MEMC)
LE46B62* T460HW03 V5,AU46H35,8bit,46 inch,16.7M,16:9,0 to +50,12V,AMVA3,72%,46 inch,FHD, 20S-Lamp, 120Hz(MEMC)
LE52B62* LTF520HE09,SSNZEI,8bit,52inch,1.06B,16:9,0.6(H)*0.6(w),0 to +50,12V,SPVA72%,FHD 120Hz(AG)
LE40B75* V400H1-LH3,CM40H13A,10bits,40inch,1073.7M,16:9,0 to +50,12V,DJITO, 72%,40 inch, FHD, w/o inverter, 120Hz(MEMC)
LE46B75* T460HW03 V5,AU46H35,8bit,46 inch,16.7M,16:9,0 to +50,12V,AMVA3,72%,46 inch,FHD, 20S-Lamp, 120Hz(MEMC)
LE52B75* LTF520HE09,SSNZEI,8bit,52inch,1.06B,16:9,0.6(H)*0.6(w),0 to +50,12V,SPVA72%,FHD 120Hz(AG)
Първоначално публикувано от adtomov
Привет besny :-)
Не знам как точно следиш този форум, но на няколко пъти съобщих, че кодът SQ01 не е това, което беше. Знам го от ЛИЧНИ наблюдения. По-рано (миналата година), с този код се обозначаваха S-PVA матрици, най-често с 10-битови контролери, нещо, добре познато. Тази година, под този код, Samsung представя като старите, така и една нова матрица, като единствената снимка на това, което съм видял в модела LE-40B750, беше публикувана първо тук:....
Съжалявам, ако съм подвел някой с матрицата но говорим за 40B650
Този форум за твоя информация го следя с четене, т.к. не съм достатъчно компетентен, както явно ти си мислиш, че си, но по писаното точно тук - http://forum.setcom.bg/index.php/topic,37709.40.html между втората и третата картинка пише : "..гледайте да пише SS08 или SQ01 това е S-PVA матрица на Samsung
срещат се В650 с АА02-AUO и В651 с SS08- S-PVA
BN указва матриците за Led Edge подсветка /BN02 в 46B7020/
гледате третия ред -Version- CN, AA, SQ, и т.н. ..."
Отново съжалявам, че съм запомнил правилно както е точно е написано в поста на hristoslav2, защото точно това съблюдавах преди да направя моя избор. При по-голямо желание от твоя страна, за да потвърдя "ЛИЧНИТЕ ТИ НАБЛЮДЕНИЯ" лично ще се обадя до international office на Samsung да сваля съмненията за абривиатурата на матрицата.
Успех!
Първоначално публикувано от besny
... При по-голямо желание от твоя страна, за да потвърдя "ЛИЧНИТЕ ТИ НАБЛЮДЕНИЯ" лично ще се обадя до international office на Samsung да сваля съмненията за абривиатурата на матрицата.
Успех!
Да, има такова желание. С нетърпение очакваме публикациите. Който може - да помогне. Само имай пред вид вида на субпикселите на матрицата от линка.
върни се 2 поста назад- дал съм файл със сервизното меню на шаси N68 Samsung-новите модели
както сам ще видиш някои модели имат резервен 2-ри вариант за LCD панел
между другото преди седмица бях чел че на пазара има недостиг на стъклен субстрат-стъклените листи 0,7мм от които се правят матриците-така че може би разнообразието от матрици в един и същи модел е причинено от този недостиг-самсунг е принуден да купува матрици/панели/откъдето намери
hristoslav2, какво ще кажеш за това, което ти написах за възможните алтернативи :
http://forum.setcom.bg/index.php/top...html#msg363308
Ето затова вярвам на Samsung дотолкова, колкото видят моите очи.
този от AVFORUMS -дали е имало разлика в изписаното на стикера отстрани и показанията в сервизното меню ??
няма доказателство-трябва да постне снимки и на двете за да докаже
самсунг ако си спомняш и миналата година слагаха каквото имат налично в моделите си
надявам се изписаното на стикера да съвпада с монтираното /иначе егати компанията/ :)
Hristoslav2, Тази матрица я видях със с собствените си очи (под лупа), веке я има из цела BG, ПРИ КОД SQ01, трябва ли да напомням, пред всички, публикациите (във форума), в които съм ти казал че съм видял нова матрица с този код????
Мммм? Или ти, като модератор, ще ги изтриеш. ??
дай да сменим темата че само спамим тук/пък и едва ли е интересно на всички останали/
http://www.led-tv-prices.co.uk/sharp...-lcd-tv-r.html
ето тук колегите италианци коментират новита шарпове
http://www.avmagazine.it/forum/archi.../t-139967.html
а тук колегите от германия правят същото
http://www.hdtv-space-forum.de/sharp...s-t3596.0.html
тук са англичаните
http://www.avforums.com/forums/lcd-t...tv-series.html
всички обсъждат новите неща -само ние с теб си обсъждаме някакви си матрици :)
а тук колегите американци обсъждат явно любимият ти Samsung LNxxB750 :)
http://www.avsforum.com/avs-vb/showthread.php?t=1142350
По тъпи от англичаните не съм виждал :D
....всички обсъждат новите неща -само ние с теб си обсъждаме някакви си матрици :)
Трябва да има и такива като нас - много добре го знаеш. МНОГО други имат полза от това. И не забравяй, че все някой ще диша в гърба. Ако не аз, то някой друг.
P.S. Предполагам, че колегите съфорумци ще ни простят малкия спор off-topic
Първоначално публикувано от qbadabaduuu
те и американците са си същите
http://www.avsforum.com/avs-vb/forumdisplay.php?f=166
Някой може ли да ми обясни защо никъде не откривам в тех. хар-ки на ТВта какъв е нативният/статичен/ контраст.Примерно при покупката на моя телевизор - SAMSUNG LE-32A557 не можаха да ми кажат какъв е контраста/статичният/.Да не говорим че и обявеният динамичен контраст от 35000:1 не отговаря на истината - 15000:1.
Благодаря!
Много моля някой от разбирачите тук да ми обясни разликите между следните два модела на Philips:
42PFL5604 - 1,649.00 лв. и 42PFL5624 - 1,699.00 лв. И двата ги има в местния ТП, но ги няма в местния ТМ.
Май, че ще се наложи да взема един от тях, ако не ми доставят поръчания LG 42LH4000. Впрочем, казаха ми, че е бил доставен, миналия четвъртък, но е бил с дефект като са го пуснали - с една червена линия отдолу и веднага поръчали друг.Ама аз минавайки в петък за справка бях толкова загорял :yikes за ТВ същата вечер, че след 2 часа чудене дали да чакам нова доставка - вдигнах ръка и посочих с пръст последния 42PFL7404 казвайки: 'Вземам го". Донесоха кашона и започнаха да го разкачат и.... като вадеха антенния кабел, буксата на антенния вход остана на кабелааа... :god, т.е. се откърти... :081: По-голяма каръщина от туй не бях преживявал признавам си... :016: Неописуемо е!!!
Та май ако не стане пак доставката или има проблеми - остават ми само тия 2 модела приемливи 42PFL5604 - 1,649.00 лв. и 42PFL5624 - 1,699.00 лв. и искам да знам раликите между тях. За 42PFL5624 - 1,699.00 лв. ми казаха, че е модел специално за България, но нищо повече. тръгнах да ровя в нета, ама намирам инфо само на полски и то без технически характеристики, камо ли сравнения :). Та дайте рамо, моля ви!
Пич, извинявай, но мисля, че е тъпо да категоризираш така хората, при положение, че в техния форум има доста богата информация от потребители сменили по няколко телевизора! Е, сигурно трудно ще откриеш съвет от професионалист продавач- консултант да си гледаш телевизора на "студено", но това е друга тема! :))
kaloman
Едиснтвено англичаните се обаждат и казват че телевизорите не работят а те не са ги настройли.
Казах конкретно за Philips че бялото е най реално при "студено" но явно ти ги разбираш нещата. Да ти дам телефона на някой от търговските на Philips да ги светнеш и тях какво предлагат?
stekyman
Philips:
42PFL5604 - 1,649.00 лв. и 42PFL5604 - 1,699.00 лв.
Този от 1,699.00 лв да не би да е 42PFL5624?
