  New LG RGBW 4K Ultra HD LCD Line Sparks Debate | HD Guru
			A new entry level 4K Ultra HD LCD TV line LG Electronics dropped in the U.S. market two weeks ago has started to create a stir over how to define 4K UHD resolution.
LG’s new UF6800 LED LCD TV series, which includes 55- and 65-inch screen sizes, features a controversial new LCD panel that uses a white sub-pixel, along with the standard Red, Green and Blue (RGB) sub-pixels that make up each pixel, in order to produce a lower-cost 4K Ultra HD LCD TV.
Critics, who contacted HD Guru about the new sets, say the additional white sub-pixel reduces the number of RGB sub-pixels in the 3840 pixel count across the screen, and the set therefore fails to comply with the Consumer Electronics Association’s (CEA’s) terminology for 4K Ultra HD minimum performance attributes...
   HDR Still Not Happening At Retail | HD Guru
 TEST : LG UF8507 / UF8527 / UF850V 55" Ultra HD - LG - HDTV Centrum Polska
55UF8507: panel W-Ledtype S-IPS,( Contrast: 900:1) 50 Ηz
 Sony X90C review - FlatpanelsHD
KD-65X9005C: S-IPS panel (ANSI contrast: 662: 1, Black level: 0.198 cd/m2), 100Hz with MCFI + flashing backlight.
 TEST : Philips PUS 7600 48" Android TV Ultra HD - PHILIPS - HDTV Centrum Polska
Philips 48PUS7600/12 chassis QV15.1E LA, panel W-Led type MVA , (Contrast: 4500:1, Black level: 0.03 cd/m2)100Hz with MCFI + flashing backlight.
 http://hdtvpolska.com/MEGATEST/philis7600/56.jpg
 Panasonic TX-65CR852B (CR852/ CR850) Review
  Мани не пускай телевизори Филипс, че като ги гледам ми иде да си продам Сонито и да си взема Филипс. Philips 48PUS7600 ма като гледам, че е скромните 2600 лв. ... :D
  Малко са хубавите неща в Philips PUS7600...
 | Разделителна способност и размер |  3840x2160, 55" |
 | Тип видеопанел |  a-Si TFT-LCD тип. MVA, с подсветка Edge W-LED, |
 | Опресняване на матрицата: |  100/120Hz |
 | Нативен контраст (без гаснене и мигане): |  4 500:1 |
 | Контраст при филми: |  средно: 4 600:1,  max: 5 200:1,  min: 4 000:1 |
 | Максимална яркост след калибриране |  350cd/m2 |
 | Отражения от екрана: |  средни, екран тип сатен |
 | Грешки в цветовете след калибриране |  Средна dE: 1,1 , максимална dE: 2,9 |
 | Резолюция в подвижно изображение |  1080 хоризонтални ТВ линии с подобрители,
300 хоризонтални ТВ линии без подобрители |
 | Input Lag |  83ms в режим игра, 103ms в стандартен режим |
 | Цветна резолюция (PC - 4:4:4) |  Не |
 | Правилно боравене с кадрите |  24Hz Да, 50Hz Да, 60Hz Да |
 | Поддръжка на 10 битов цвят |  Не |
 | Поддръжка на резолюция от 3840x2160 @ 60Hz  4:2:0 |  Да |
 | Поддръжка на резолюция от 3840x2160 @ 24Hz  4:4:4 |  Не |
 | Поддръжка на резолюция от 3840x2160 @ 60Hz  4:4:4 |  Не |
 | Тест за възпроизвеждане на SAT UHD TV канал |  Не |
 | Поддръжка за файлове UHD кодек HEVC |  Да |
 | Поддръжка на YouTube 4K |  Да |
 | Съвместим с HDCP 2.2 |  няма данни |
Относно подчертаното в таблицата
 Philips PUK7100 PUS7100 im Test - AUDIO VIDEO FOTO BILD
НЕVС вeчe e дocтъпeн зa интepнeт cъдъpжaниe и чpeз UЅВ, нo в мoмeнтa нe и зa caтeлитният тyнep.(зa cepии 6400,7100,7600)
  Дали има хубави неща в LG 65UG8709 ??????
  В Германия или в Австрия ще пазаруваш ? :) Питам понеже у нас се предлага LG 65UG870V
 LG 65UG8709 | LG Deutschland
 http://www.hifi-forum.de/index.php?a...e&forum_id=145
 | Разделителна способност и размер |  3840x2160, 65" |
 | Тип видеопанел |  a-Si TFT-LCD тип. S-IPS, с подсветка Edge W-LED, |
 | Нативен контраст (без гаснене и мигане): |  900:1 |
 | Контраст при филми: |  средно: 1 300:1,  max: 2 500:1,  min: 750:1 |
 | Максимална яркост след калибриране |  250cd/m2 |
 | Грешки в цветовете след калибриране |  Средна dE: 1,3 , максимална dE: 2,4 |
 | Резолюция в подвижно изображение |  300 хоризонтални ТВ линии без подобрители |
 | Input Lag |  32ms в режим игра, 40ms в стандартен режим |
 | Цветна резолюция (PC - 4:4:4) |  Да при връзка с PC |
 | Поддръжка на 10 битов цвят |  Да |
 | Поддръжка на резолюция от 3840x2160 @ 24Hz  4:4:4 |  Да |
 | Поддръжка на резолюция от 3840x2160 @ 60Hz  4:4:4 |  Да |
 | Тест за възпроизвеждане на SAT UHD TV канал |  Да |
 | Съвместим с HDCP 2.2 |  Да |
 To enable chroma 4:4:4, set the icon of the input to PC. For 4k @ 60hz @ 4:4:4, also enable UHD Deep Color.
  В Германия, 2010 си купих LG с Опресняване на матрицата: 50Hz  в София и реших пак LG, но едва ли сте е този. Трябва ми разумен модел без OLED.......
  Не робувай на марки. Кое не ти харесва в UG8790 ? Държиш ли на извит телевизор?
  няма логика 2010 да е 50Hz Опресняване на матрицата и 2015 същата ( не мога да разбера дали е 50 или 100), всъщност ми направи отлично впечатление, гледах около 15 минути Аватар 3Д с пасивни очила на него. Малко е скъп 2650 евро, не е задължително да е извит
  Лесно е
 Kaĸ дa пpoвepя, дaли LG тeлeвизopът ми e 100Нz?
Aĸo в нacтpoйĸитe нa пapaмeтъpa зa изoбpaжeниe ТruМоtіоn, имa фyнĸция Dе-Вlur, знaчи тeлeвизъpът e 100Нz, aĸo тaзи фyнĸция я нямa, тo тeлeвизopът e 50Нz.
 LG 2015 TVs: Reviews and Prices
 LG - Artykuły - Articles - HDTV Centrum Polska
  Всъщност ми трябва съвет за избор на нов добър телевизор, без да изпадам в купуване на някакви рекламни трикове примерно OLED или 4k, за които няма излъчване на контент по никой канал и не могат да се ползват
  Всъщност от какво разстояние ще го гледаш и дали под ъгъл?
 Този, малък ли е?
  не е под ъгъл, около 3,5 метра
  60H7000 е идеален за целта. Понеже питаш за реалните херци - 200Hz.
  Сравнявайки LG 65UG8709 срещу SAMSUNG UE-60H7000, 200Hz. на SAMSUNG са сериозно предимство, а LG също има някои добри страни примерно новата WebOS 2.0.Опитвам се да направя генерално сравнение на двата за да разбера накъде да тръгна
  Samsung UE-65JU7000 - Tizen OS
Panasonic TX-65CX800 - Firefox OS
От коя верига в Германия ще го купуваш?
