Тази иновация налична ли е при сегашните модели ? :) Или ще е нещо което ще бъде приложено при производството на бъдещите модели ?
В статията става въпрос за сегашните модели..
LG OLED55C6V : Test complet
Google translate Fr to Bg
Някой пробва ли 05.05.01? Аз съм с 05.00.55 и взе да плаче да ъпдейтвам, но го мисля още. Някой мнение?
https://www.avforums.com/review/lg-c...v-review.12713
https://www.youtube.com/watch?v=n-AHoa-yrKk
LG UH8507 (55UH850V) Test - Super UHD TV, 4K, HDR Dolby Vision - LG - HDTV Centrum Polska
55UH8507: AS-IPS panel RGB, 100 / 120Hz with MCFI (buffer TruMotion: De-Judder and De-Blur)
https://www.facebook.com/LGTV/
Oled E6 и B6 са базирани на едно шаси.
Внимание!
G6/E6 и C6 имат различни Oled панели
G6/E6
http://img1.lesnumeriques.com/test/1...sous-pix-1.jpg
http://www.lesnumeriques.com/tv-tele...0589/test.html
C6 (Curved)
http://img1.lesnumeriques.com/test/12/12797/souspix.jpg
http://www.lesnumeriques.com/tv-tele...2621/test.html
The LG OLED 55C6V has a new structure of sub-pixels that differs from that of the LG Signature 65G6V. Each pixel is always composed of four sub-pixels (one green, one red, one blue and one white), but the red and green sub-pixels are bigger. The white and blue subpixels are always larger in order to improve the maximum brightness of the panel.
LG Oled UHD TV 2016 - european models Product
Serie
______________ Certification UHD______________________
Premium
Resolution: 3,840x2,160 .
Color depth: 10-bit.
Color gamut: Wide, including the ability to show at least 90 percent of the P3 color gamut .
High dynamic range: Specifically the ability to use SMPTE ST2084's electro-optical transfer function, which Dolby helped create .
Minimum brightness and contrast ratios: There are two possible minimum specs. A minimum brightness of 1,000 nits, along with a black level of a maximum of 0.05 nits (20,000:1 contrast ratio), or a minimum brightness of 540 nits, along with a black level of a maximum of 0.0005 (1,080,000:1)
Dolby Vision_______________________________
The metadata is graded in each scene so you get different grades throughout the file. Dolby tells us that scene by scene grading is the superior way to grade a movie, which on paper does sound more efficient.
Standard: Poprietary
Peak Luminance: Up to 10,000 nits
Video Bit Depth: 12-bit
Metadata: Dynamic (scene by scene)
Software Upgradability: No(SoC hardware-embedded)
HDR 10The metadata is graded and determined, and is then sent at the beginning of the file and covers the entire file. One set of metadata
Standard: Open
Peak Luminance: Up to 4,000 nits
Video Bit Depth: 10-bit
Metadata: Static (per title)
Software Upgradability: Yes
Videopanel_____________________________________
Backlight________________________
Dimming Color Space______________________________
Contrast ,________________________________
White & Black level
Viewing Angle
_____________ Input Lag__________________________________
Networks__________________
Ports___________________________
SoC_________
Platform
Software
OS
Tuner_________________
Opportunities for calibration_____________________Product G6V
77", 65"
Yes Dynamic optimization scenes via Dolby Vision technology VS10 77" - In HDR max 744cd/m2
65" - In HDR max 640cd/m2
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
77" - LC770LQD-LGxx, WRGB, 10-bit
65" - LC650LQD-LGxx, WRGB, 10-bit
Passive 3D
MCI - Motion Clarity Indec - 1000
(MCFI - Motion Clarity Frame Interpolation)
Triple anti-reflective coatingNo
No
77"DCI P3 - 95 % / Rec.2020 - 80%
65"DCI P3 - 94.14% / rec.202075" -
65" - ∞ / 150cd/m2 / 0.00cd/m2
290cd/m2 in ISF Dark mode
77" - °(cone)
65" - °(cone)77"- Game mode 34.0ms / by default
65"- Game mode 33.6ms /Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
DLNA4 x HDMI2.0a (ARC,CEC,MHL)
1 x Satelite in(Main:F-type,female)
1 x AV Composite In 3.5mm jack
1 x Component in(shared with composite)
1 x RS232C(Mini Jack)
1 x Antena (RF) (Female)
1 x Optical Audio Out
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x USB 3.1 HID controller
Compatibility-mouse/keyboard
Bluetooth 4.0H15 64-bit
Quad Core
webOS 3.0Dual tuners
DVB -T/ T2/C/S/S2
with PVR and PIP function
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
HEVC, VP9 profil 2IRE White balance- 20 Points
Gamma - 10 points
CMS - Yes
ISFccc - Yes
Copy to All Inputs - YesG6V
E6V
(flat)
65", 55"
Yes Dynamic optimization scenes via Dolby Vision technology VS10 65" - In HDR max 655cd/m2
55" - In HDR max 596cd/m2
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
65" - LC650LQD-LGxx, WRGB, 10-bit,
55" - LC550LQD-LFxx, WRGB, 10-bit,
Passive 3D
MCI - Motion Clarity Index
Double anti-reflective coatingNo
No65" DCI P3 xy - 94.5 %
55" DCI P3 - 96.46%65" - ∞ / 195cd/m2 / 0cd/m2
55" - ∞/-65" - °(cone)
55" - 166°(cone)65"- Game mode 34.1ms / by default 63ms
55"- Game mode 34.1ms / by default 63msLan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
DVB - T/T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
HEVC, VP9 profil 2IRE White balance - 20 Points
Gamma - 10 points
CMS - Yes
ISFccc - Yes
Copy to All Inputs - YesE6V
C6V
(curved)
65", 55"
? Dynamic optimization scenes via Dolby Vision technology VS10 65" - In HDR max
55" - In 100% window HDR max peak 400cd/m2
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
65" - LC650LQD-xxxx, WRGB, 10-bit, Curved
55" - LC550LQD-xxxx, WRGB, 10-bit, Curved
The LG OLED C6V has a new structure of sub-pixels that differs from that of the LG Signature G6V.No
No
65" DCI P3 - 9 %
55" DCI P3 - 9 %
65" - ∞ /
55" - ∞ /
65" - °(cone)
55" - °(cone)
65" - Game mode
55" - Game mode
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
DLNA3 x HDMI2.0a (ARC,CEC,MHL)
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Bluetooth 4.0-
Quad Core
webOS 3.0DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
Gamma - 10 points
CMS - Yes
ISFccc - Yes
Copy to All Inputs - YesC6V
B6V
65", 55"
(no support for 3D)
No Dynamic optimization scenes via Dolby Vision technology VS10 65" - In HDR max
55" - In HDR max
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
No
No
65" DCI P3 - 9 %
55" DCI P3 - 9 %
65" -
55" -
65" -
55" -
65" - Game mode
55" - Game mode
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Bluetooth 4.0-
Quad Core
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
Gamma - 10 points
CMS - Yes
ISFccc - Yes
Copy to All Inputs - YesB6V
LG LCD Super UHD TV 2016 - european models Product UHD
Premium
______________________Dolby
Vision
__________HDR
_________________Videopanel
___________________________________Backlight
DimmingColor Space
____________________________Contrast &
Black level
_______________Viewing Angle
____________Input Lag
_____Networks
__________________Ports
___________________SoC
Platform
Software
OS
_____Tuner
______________ Opportunities for calibration_____________________Product UH980V
95"No Yes
VS1095" - In HDR max
HDR1095"- IPS, 10-bit, 120/100Hz
Quantum DotsDirect Led (W-Led)
Local Dimming95" - 95" - 95" - 95" - Game mode Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
DLNA3 x HDMI2.0 (ARC,CEC,MHL)
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Compatibility-mouse/keyboard-
Quad Core
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shift
HEVC, VP9IRE White balance - 20 Points
Gamma - 10 points
CMS -
ISFccc -UH950V
95"LG LCD UHD TV 2016 - european models Product UHD
Premium
_____Dolby
Vision
_____HDR
DimmingColor Space
Black level
_____Networks
Platform
Software
OS
_____Tuner
______________ Opportunities for calibration____________________Product UH955V
86"
UH950V
65", 55"
Differences in the design of the following model has a black edging UH955V screen, behind the TV also black, UH950V model has a white screen edging with round edges and a white back of the TV.
No Yes
VS1086" - In HDR max
65" - In HDR max
55" - In HDR max
HDR1086" - AS-IPS, 10-bit, 120/100Hz + BLS
LC860EQD-FJF1
65" - AS-IPS, 10-bit, 120/100Hz + BLS
LC650EQF-YJF1
55" - AS-IPS, 10-bit, 120/100Hz + BLS
LC550EQH-YJF1
Quantum Dots
PMI (Picture Mastering Index) 270086" - Edge Led (W-Led)
65" - Edge Led (W-Led)
55" - Edge Led (W-Led)
Vertical Dimming
55" - 12 zones
PWM Freq. - 120/100Hz86"- DCI P3 - /Rec.2020 -
65" - DCI P3
55" - DCI P3
Color Prime P86" -
65" -
55" -
86" - °(cone)
65" - °(cone)
55" - °(cone)
86" - Game mode
65" - Game mode
55" - game mode
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
WebOS 3.0DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR + Time Shift
Gamma - 10 points
CMS -
ISFccc -UH955V
UH950V
86", 65", 55"UH850V
75", 65", 60", 55", 49"No Yes
VS1075" - In HDR max
65" - In HDR max 315cd/m2
60" - In HDR max
55" - In HDR max 360cd/m2
HDR10
75"- AS-IPS, 8-bit+Hi-FRC, 120/100Hz + BLS
LC750EQF-FJF1
65"- AS-IPS, 8-bit+Hi-FRC, 120/100Hz + BLS
LC650EQF-DJF1
60"- AS-IPS, 8-bit+Hi-FRC, 120/100Hz + BLS
LC600EQF-DJF1
55"- AS-IPS, 8-bit+Hi-FRC, 120/100Hz + BLS
LC550EQH-DJF1
Quantum Dots
PMI (Picture Mastering Index) 270075" - Edge Led
65" - Edge Led below(W-Led)
60" - Edge Led below(W-Led)
55" - Edge Led below(W-Led)
49" - Edge Led below
Vertical Dimming
55" - 12 zones
PWM Freq. - 120/100Hz75" -
65" -
60" -
55"- DCI P3 - 85% /Rec.2020 - 62%
49" -
Color Prime Plus
75" -
65" -
60" -
55"- native - 920:1
ANSI 1188:1 / 99.8cd/m2 / 0.084cd/m275" - °(cone)
65" - °(cone)
60" - °(cone)
55" - 35° (cone)
49" - °(cone)
75" - Game mode
65" - Game mode
60" - Game mode
55" - Game mode
49" - Game mode
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
M16+F16
Quad Core
Analog (PAL,SECAM)
PVR + Time Shift
HEVCIRE White balance - 20 Points
Gamma - 10 points
CMS -
ISFccc -UH850V
75", 65", 60", 55", 49"UH780V
UH770V
65" - In HDR max
60" - In HDR max
55" - In HDR max 341cd/m2
49" - In HDR max
43" - in HDR max
HDR10
75"- AS-IPS, 120/100Hz + BLS
65"- AS-IPS, 8-bit+FRC, 120/100Hz+BLS
60"- AS-IPS, 8-bit+FRC, 120/100Hz+BLS
55"- AS-IPS, 8-bit+FRC, 120/100Hz+BLS
49"- AS-IPS, 8-bit+FRC, 120/100Hz+BLS
43"- AS-IPS, 8-bit+FRC, 120/100Hz+BLS
Quantum Dots
PMI (Picture Mastering Index) 2500
Clear Plus - Flashing backlight (BFI)75" -
65" - Edge Led below (W-Led)
60" - Edge Led below (W-Led)
55" - Edge Led below (W-Led)
Vertical Dimming
55" - 6 zones
65" - DCI P3 -
60" - DCI P3 -
55" - DCI P3 - 77.6% /Rec.2020 - 58%
49" - DCI P3 -
Color Prime P
75" -
65" -
60" -
55"- native - 920:1 /
ANSI 1153:1 / 101.5cd/m2 / 0.088cd/m275" - ° (cone)
65" - °(cone)
60" - °(cone)
55" - 35°(cone)
49" - °(cone)
75" - Game mode
65" - Game mode
60" - Game mode
55" - Game mode 38.1ms / by default 57ms
49" - Game mode
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Compatibility-mouse/keyboardK2L
Quad Core
Analog (PAL,SECAM)
PVR + Time Shift
HEVCIRE White balance- 20 Points
Gamma - 10 points
CMS -
ISFccc -UH770V
65", 60", 55", 49"UH750V
65", 55", 49", 43"No No 65" - In HDR max
55" - In HDR max
49" - In HDR max
43" - In HDR max
HDR PROcessing
Convert SDR to HDR
(missing hardware for playback HDR)65"- AS-IPS, 8-bit+FRC, 60/50Hz
55"- AS-IPS, 8-bit+FRC, 60/50Hz
49"- AS-IPS, 8-bit+FRC, 60/50Hz
43"- AS-IPS, 8-bit+FRC, 60/50Hz
WRGB structure
49" -
43" -
Local Dimming
PWM Freq. - 120/100Hz65" - DCI P3 - 90%/
55" - DCI P3 - 90%/
49" - DCI P3 - 90%/
43" - DCI P3 -
Color prime P65" -
55" -
49" -
43" -65" - °(cone)
55" -
49" -
43" -65" -
55" -
49" -
43" -Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
Analog (PAL,SECAM)
PVR + Time Shift
HEVCUH750V
65", 55", 49", 43"UH700V
70"No No 70" - In HDR max
HDR PROcessing
(missing hardware for playback HDR)70"- AS-IPS, 8-bit+FRC, 120/100Hz
WRGB structure ?
70" - Edge Led (W-Led)
Local Dimming
PWM Freq. - 120/100Hz70"- DCI P3 - 84%
70" - 70" - 70" - Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
Analog (PAL,SECAM)
PVR + Time Shift
HEVCUH700V
65", 55", 49", 43"UH670V
55" - In HDR max
49" - In HDR max
43" - In HDR max
HDR PROcessing
Convert SDR to HDR
WRGB structure
49" - Direct Led (W-Led)
43" - Direct Led (W-Led)
Local Dimming
PWM Freq. - 120/100Hz65"- DCI P3 - 84%
55"- DCI P3 - 84%
49"- DCI P3 - 84%
43"- DCI P3 -
Color Prime P65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -65" -
55" -
49" -
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
DLNA3 x HDMI2.0 (ARC,CEC)
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
Analog (PAL,SECAM)
PVR + Time Shift
HEVCUH670V
65", 55", 49", 43"UH660V
55" - In HDR max
49" - In HDR max
43" - In HDR max
HDR PROcessing
Convert SDR to HDR
WRGB structure
Local Dimming
55"- DCI P3 - 84%
49"- DCI P3 - 84%
43"- DCI P3 -
Color Prime Pro65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -65" -
55" -
49" -
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Quad Core
Analog (PAL,SECAM)
PVR + Time Shift
HEVCUH660V
65", 55", 49", 43"UH650V
65", 60", 55", 49", 43"No No 65" - LC
60" -
55" -
49" -
43" -
HDR PROcessing
Convert SDR to HDR
60"- AS-IPS, 8-bit+FRC, 60/50Hz
WRGB structure
60" - Edge Led (W-Led)
60" - DCI P3 -
55" - DCI P3 - 84%
49" - DCI P3 - 84%
43" - DCI P3 -
60" -
55" -
49" -
43" -65" -
60" -
55" -
49" -
43" -65" -
60" -
55" -
49" -
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 ac
WiDi / Miracast
DLNA
Bluetooth3 x НDМІ2.0 (ARC,CEC,MHL)
Соmроnеnt іn 1 (ѕhаrеd wіth соmроѕіtе)
1 x RЅ232С (Міnі Јасk)
USB 2.0 x 2
1 x Antena (RF)
1 x CI+ 1.3-
Quad Core
Analog (PAL,SECAM)
PVR + Time Shift
HEVCUH650V
65", 60", 55", 49", 43"UH635V
58", 50",
UH630V
40"
No No 58" -
50" -
40" -
HDR PROcessing
Convert SDR to HDR
(missing hardware for playback HDR)58"- MVA ?, 8-bit, 60/50Hz
50"- MVA ?, 8-bit, 60/50Hz
40"- MVA ?, 8-bit, 60/50Hz
58" - Edge Led (W-Led)
50" - Edge Led (W-Led)
40" - Edge Led (W-Led)
PWM Freq. -58" - DCI P3 - 90%
50" - DCI P3 - 90%
40" - DCI P3 -
Color Prime Plus58" -
50" -
40" -58" -
50" -
40" -58" -
50" -
40" -Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 ac
WiDi / Miracast
DLNA
1 x Соmроnеnt іn(ѕhаrеd wіth соmроѕіtе)
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3-
Quad Core
Analog (PAL,SECAM)
PVR + Time Shift
HEVCUH630V
58", 50", 40"
UH620V
60" -
55" -
49" -
43" -
HDR PROcessing
(missing hardware for playback HDR)65"- S-IPS, 8-bit, 60/50Hz
60"- S-IPS, 8-bit, 60/50Hz
55"- S-IPS, 8-bit, 60/50Hz
49"- S-IPS, 8-bit, 60/50Hz
43"- S-IPS, 8-bit, 60/50Hz
WRGB structure
Local Dimming
PWM Freq. -65" - DCI P3
55" - DCI P3
49" - DCI P3
43" - DCI P3 -
65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -65" -
55" -
49" -
Wi-Fi (only 802.11 n)
WiDi / Miracast
WiFi Direct
DLNAHDMI x (HDCP2.2)
1- ARC,
1 - Compatible 4K@60p and HDR 422
1 x USB 2.0-
Analog (PAL,SECAM)
PVR + Time Shift
HEVCUH620V
65", 60", 55", 49", 43"UH610V
55" -
49" -
43" -
HDR PROcessing
WRGB structure
65" -
49" -
43" -
PWM Freq. -65" - DCI P3 -
55" -
49" -
43" -
65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -65" -
55" -
49" -
Wi-Fi (only 802.11.n)
WiDi / Miracast
DLNA3 x НDМІ2.0 (ARC,CEC,MHL)
RЅ232С (Міnі Јасk)
2 x USB 2.0-
Analog (PAL,SECAM)
HEVCUH610V
65", 55", 49", 49", 43"UH600V
No No No 65" - S-IPS, 8-bit, 60/50Hz
60" - S-IPS, 8-bit, 60/50Hz
55" - S-IPS, 8-bit, 60/50Hz
49" - S-IPS, 8-bit, 60/50Hz
43" - S-IPS, 8-bit, 60/50Hz
WRGB structure
60" - Edge Led
49" - Edge Led (W-Led)
PWM Freq. -65" -
60" -
55" -
49" -
43" -
65" -
60" -
55" -
49" -
43" -65" -
60" -
55" -
49" -
43" -65" -
60" -
55" -
49" -
WiDi / Miracast
DLNA
Bluetooth (only 49-65")3 x НDМІ2.0 (ARC,CEC,MHL)
1 x Соmроnеnt іn (ѕhаrеd wіth соmроѕіtе)
1 x USB 2.0-
WebOS 2.0
DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
EVC - only 49-65"UH600V
65", 60", 55", 49"LG FHD & HDReady TV 2016 - european models Product UHD
Premium
_____Dolby
Vision
__________HDR
___________________
DimmingColor Space
Black level
_____________Input Lag
_____Networks
___________________________SoC
Platform
Software
OS
_________Tuner
_________________ Opportunities for calibration_____________________Product LH660
55", 49", 43"No No No 55" - IPS, 8-bit, 120/100Hz
49" - IPS, 8-bit, 120/100Hz
43" - IPS, 8-bit, 120/100Hz
49" -
PWM Freq. -55" -
49" -
43" -
55" -
49" -
43" -55" -
49" -
43" -55" -
49" -
43" -Lan
WiDi / Miracast
DLNAx HDMI 1.4
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3-
Analog (PAL,SECAM)
HEVCLH660
55", 49", 43",LH640
55", 49", 43"No No No 55" - IPS, 8-bit, ? Hz
49" - IPS, 8-bit,
43" - IPS, 8-bit,
PWM Freq. -55" -
49" -
43" -
55" -
49" -
43" -
55" -
49" -
43" -
55" -
49" -
43" -Lan
WiDi / Miracast
DLNAx HDMI 1.4
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3-
Analog (PAL,SECAM)
HEVCLH640
55", 49", 43"LH600
55", 49", 43", 32"No No No 55" - IPS, 8-bit, 60/50Hz
49" - IPS, 8-bit, 60/50Hz
43" - IPS, 8-bit, 60/50Hz
32" - IPS, 8-bit, 60/50Hz
32" - Direct Led (W-Led)
PWM Freq. -55" -
49" -
43" -
32" -
55" -
49" -
43" -
32" -
55" -
49" -
43" -
32" -
55" -
49" -
43" -
32" -
Lan
WiDi / Miracast
DLNAx HDMI 1.4
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3-
Analog (PAL,SECAM)
HEVCLH600
55", 49", 43", 32"LH590/595
49", 43", 32"No No No 49" - IPS, 8-bit, 60/50Hz
43" - MVA, 8-bit, 60/50Hz
49" -
43" -
32" -
49" -
43" -
32" -
49" -
43" -
32" -
49" -
43" -
32" -
49" -
43" -
32" -
Lan
WiDi / Miracast
DLNA
x HDMI 1.4
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3-
Analog (PAL,SECAM)
LH590
49", 43", 32"LH570
32" - IPS, 8-bit, 60/50Hz49" -
43" -
-Lan
WiDi / Miracast
DLNA
x HDMI 1.4
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3WebOS 3.0 DVB-T/T2/C/S/S2
Analog (PAL,SECAM)LH570
49", 43", 32"LH560
43"No No No 43" - IPS, 8-bit, 60/50Hz
43" -
- Lan
WiDi / Miracast
DLNA
x HDMI 1.4
2 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3-
WebOS 2.0DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
LH560 LH540
LH541
32" - IPS, 8-bit, 60/50Hz55" - Edge Led (W-Led)
43" - Edge Led (W-Led)- x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3-
NoDVB-T/T2/C/S/S2
Analog (PAL,SECAM)LH540
49", 43", 32"LH530
49" , 43"
43" - IPS, 8-bit, 60/50Hz49" - Direct Led (W-Led)
43" -- 1 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3DVB-T/T2/C/S/S2
Analog (PAL,SECAM)LH530 LH510
(LH5100)
49", 43", 32"
32" - IPS, 8-bit, 60/50hz49"- Direct Led (W-Led)
43"- Direct Led (W-Led)
32"- Direct Led (W-Led)- 1 x USB 2.0
1 x Antena (RF)
1 x CI+ 1.3-
NoDVB-T/C
Analog (PAL,SECAM)
(43, 49" + T2/S2)LH510 LH500
43", 32"No No No 43" - IPS, 8-bit, 60/50Hz
32" - IPS, 8-bit, 60/50Hz43"- Direct Led (W-Led)
1 x Antena (RF)
1 x CI+ 1.3-
NoDVB- T2/C LH500
Относно 05.05.01-от три-четири дни съм с този ъпдейт на телевизор LG55LB700V и не мога да си позная телевизора! Първото ми впечатление беше,че така наречената "вялост " на картината изчезна,цветовете са в пъти по-ярки,картината е като "гланцирана",при глдане на мачовете от европейското движението на топката и футболистите е много по-гладко-с изключен трумоушън съм (ползвам сателитна телевизия на виваком).Най-важната за мен разлика открих на вторият ден-изчезнаха напълно леките сенки в четирите ъгъла на екрана! За уеб ос не мога да кажа нищо защото не го ползвам, но влизането в менютата и смяната на входовете е значително по-бързо.Не съм специалст и това което описвам е възможно да е стого субективно,но това виждам на екрана.Надявм се да съм бил полезен. Ако се сетя или установя още нещо ще пиша пак.
Колега, да не си слънчасал нещо от жената? Нещата, за които говориш няма как да станат с "ъпдейт" на софтуера - подобрение и обработка на картината.
Колега,не съм специалист както съм и написал в поста,не случайно съм отбелязал,че нещата са субективни.Споделям какво ми е направило впечатление,възможно е и да се заблуждавам. А що се отнася до софтуера -той е доста свързан с обработката на картината.За жената няма да коментирам,че и тя се рови тука и после.......!
Хаха, чудя се какво общо има с жената, а пък то аз вместо жегата съм написал жената... Много съм зле, ще ме извиняваш за неволната грешка.
Внушаваш си. Двете описани от теб промени са софтуерно невъзможни. Има някакви промени в настройката на яркостта и контраста, което води до субективно усещане..
По плавна картина може да имаш само с включена функция за генериране на междинни кадри.
За промяна във второто е нужна смяна на типа подсветка.
А пък аз, за съжаление, не си внушавам, че след последния FW update картината се влоши значително.
Става въпрос за моделите 2015 на YouTube, калпавите филми и SD каналите на ефирната ТВ. За HD тези дефекти ги няма или не съм ги забелязал още.
Появиха се едни назъбвания на наклонениете линии и контури, хоризонтални линии на логото и надписите на новините. Даже ми се струва, че картината загуби от контраста си. Панелъте е IPS LG.
Подобни дефекти имаше на СКАТ с външен цифров приемник, свързан със Scart към 21" кинескопен НЕО в една квартира.
Просто съм потресен!
Имам предишния FW, но не ми се рискува с downgrade.
Заслужава ли си да купя http://www.technopolis.bg/bg/TV/TV-L...HD-LED/p/16206 ?
Благодаря предварително!
Взимай андроид тв,не се занимавай с Webos глупости орязан!
След ъпдейта направили връщане към заводските настройки ?
В момента телевизорът ти има проблем с деинтерлейсинга - събирането на два презредови кадъра в един прогресивен.
https://en.wikipedia.org/wiki/Deinterlacing
Логото се излъчва на отделен Alpha канал, а образуването на хоризонтални линии около логото или надписите е предизвикано от някакъв проблем в софта отговарящ за наслагването.
При всяко стартиране на телевизора(или ъпдейт) има вероятност от неправилно зареждане на софта - за това пробвай да рестартираш телевизора.
Благодаря!
Днес го изключих за пореден път от захранване за около 6 часа и нещата май се пооправиха.
До момента не съм имал такива проблеми с FW Update. След зареждане на софта винаги го изключвах от контакта. Ама сега го преместих на друго място и достъпът до разклонителя е труден.
Освен това след update-та забелязах промени в настройките на картината, които бях задал. Което не би трябвало да се случва, но е факт.
Следващият път май наистина ще му направя hardware reset.
