Здравейте.Колебая се в избора на телевизор.спрял съм се на samsung UE 48J6200 ; LG 43 UF675V и LG 43UH610V.Според вас кой да избера.
http://lgwebos.free.bg/
http://kr.eguide.lgappstv.com/manual...bul/index.html
43LH604V-ZA.BRUDLDU -> A-MVA, 60/50Hz
43LH604V-ZA.BMCDLDU -> A-MVA, 60/50Hz
43LH595V-ZE.BRUDLDU -> A-MVA, 60/50Hz
43LH590V-ZA.BRUDLDU -> A-MVA, 60/50Hz
43LH570V-ZD.BRUDLDU -> A-MVA, 60/50Hz
43LH570V-ZD.BMCDLDU -> A-MVA, 60/50Hz
43LH520V-ZB.BRUDLDU -> A-MVA, 60/50Hz
43LH513V-ZD.BRUDLDU -> A-MVA, 60/50Hz
43LH510V-ZA.BRUDLDU -> A-MVA, 60/50Hz
65G6V: 120/100Hz (TruMotion buffer: De-Judder and De-Blur), WRGB
65C6V: 120/100Hz (TruMotion buffer: De-Judder and De-Blur), WRGB
65UH9500: IPS panel RGB, 120/100Hz, with MCFI (TruMotion buffer: De-Judder and De-Blur)
55UH8507: IPS panel RGB, 120/100Hz, with MCFI (TruMotion buffer: De-Judder and De-Blur)
55UH770V: IPS panel RGB, 120/100Hz, with MCFI (TruMotion buffer: De-Judder and De-Blur)
55UH668V: IPS panel WRGB, 60/50Hz,(TruMotion buffer: only De-Judder an not De-Blur)
55UH664V: IPS panel WRGB, 60/50Hz,(TruMotion buffer: only De-Judder an not De-Blur)
55UH661V: IPS panel WRGB, 60/50Hz,(TruMotion buffer: only De-Judder an not De-Blur).
43UH6500: IPS panel WRGB, 60H/50z,(TruMotion buffer: only De-Judder an not De-Blur)
58UH635V: MVА panel RGB, 60/50Hz,(TruMotion buffer: only De-Judder an not De-Blur)
50UH635V: MVА panel RGB, 60/50Hz,(TruMotion buffer: only De-Judder an not De-Blur)
58UH630V: MVА panel RGB, 60/50Hz,(TruMotion buffer: only De-Judder an not De-Blur)
50UH630V: MVА panel RGB, 60/50Hz,(TruMotion buffer: only De-Judder an not De-Blur)
40UH630V: MVА panel RGB, 60/50Hz,(TruMotion buffer: only De-Judder an not De-Blur)
55UH6150: IPS panel, 60/50Hz,(TruMotion buffer: only De-Judder an not De-Blur)
43UH6100: IPS panel, 60/50Hz,(TruMotion buffer: only De-Judder an not De-Blur)
49UH600V: PMI (Picture Mastering Index) 1000, actually 60/50Hz panel, no regulatory TruMotion.
65UH5500: MVA panel, 60/50Hz
43LH604V: IPS panel, 60/50Hz
55LH5750: MVA panel RGB, 60/50Hz
49LH510V: IPS panel, 60/50Hz
43LH5100: MVA panel, 60/50Hz
43LH510V: IPS panel, 60/50Hz
43LH5000: IPS panel, 60/50Hz
Случи се да си поръчам от черния петък в Емаг телевизор 49UH603V за 600 лв. Понеже нямам много нужда от този телевизор се чудя, дали си заслужава полупката, понеже в коментарите ви чета, че не е много сполучлив модел и не го препоръчвате. Въпроса ми е заслужава ли си тези пари или е много зле телевизора? С какво дистанционно идва?
тест на най-близките му щатски аналози
LG UH5500 Review (50UH5500, 65UH5500)
LG UH6150 Review (55UH6150, 60UH6150, 65UH6150)
Знам, че е един от тези три модела, но кой точно нека пишат собствениците...
AKB73715601
AKB74475481
AKB74475479
LG Oled UHD TV 2016 - european models Series
Model
________________ Certification UHD_______
Premium Dolby Vision_______ Hybrid Log Gamma______
(HLG) HDR 10____________
In Windows
2/5/10/20/100% Videopanel_________________________
Type LCD matrix,
Bits of color,
(Operating frequency of T-Con board of the panel)
Curvature,
Index,
Screen Uniformity
Anti-reflective filter Backlight__________________
Type backlight
(Local Dimming zone)
Type LED
MEMC
Backlight Scanning
Black Frame Insertion
Pulsе Wide Modulation Measurement_______________________________
(out of the Box & after calibration)
DCI P3
Rec.2020
Delta E
Gamma
Temperature Contrast________________________
White & Black level
ANSI
With local dimming
Without local dimming Viewing angle
___________( ° cone) Motion resolution
__________________ Product_____________ Input Lag____________
Game mode
by default Audio_________________________ Chassis__________________________
Operating Sistem
Board
System on Chip
Central Processing Unit
Graphic Processor Unit
RAM
Software
 Networks____________
 Conectors__________________________________ Tuners________________ Media Player__________________ Opportunities for_____________________
calibration Note__________________________________________
Pros & ConsProduct G6V
(flat)
77", 65"
3D passive interlaced circular polarization with FPR technologyYes Dynamic optimization scenes via Dolby Vision technology VS10 Yes 77" max 744cd/m2
65" max 640cd/m2
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
77" - LC770LQD-LGxx, WRGB, 10-bit
65" - LC650LQD-LGxx, WRGB, 10-bit
Passive 3D
MCI - Motion Clarity Index - 1000
(MCFI - Motion Clarity Frame Interpolation)
Triple anti-reflective coating
The new pixel structure of the OLED-panel TVs LG OLED65G6V applied. Compared to the previous generation of 4 identical sub-pixels (red, green, blue and white), in the new panels the red subpixel has become a little less, and the blue and white is slightly increased. It was thus able to increase the peak brightness of the new OLED-screen.No
No
77" -
65" - 94.14%
x-x
4.5-1.6
2.21-2.2
6225-6517K75" - 1000000:1 /
65" - 1000000:1 / 150cd/m2 / 0.00cd/m2
290cd/m2 in ISF Dark mode
77" - °(cone)
65" - °(cone)77" - 600-650[with TruMotion],
300 without
65" - 600-650[with TruMotion],
300 withoutG6V
77", 65"77" - 34.0ms /
65" - 33.6ms /audio system Harman / Kardon 4.2
Total sound power: 60 W
Four speakers
2 built-in subwoofer: 20W
Dolby Digital Plus
DTS
DTS-HD
Not surprisingly, the sound is very good for a TV. The LG 65G6V comes down low enough in the spectrum since the low mids from 100 Hz are audible. The sound reproduction is excellent between 180 and 1500 Hz. However, we noted an effect of sibilance very disturbing in the treble, which prompted us to reduce the frequency of 10 kHz via the equalizer. Once this small adjustment, the ear is less abused and it is possible to listen to some music on the TV. The large size of the foot could have enabled LG to go one step further with a woofer bigger and a vent that is found on the system sound bars . Finally, the distortion is limited 0.9%.Chassis -
Model - SM5C
Platform - webOS Signage 3.0
Chipset - M16
CPU - ARM Cortex-A53 1.0 GHz Quad Core
RAM - 2.0 GB*
Flash Memory - eMMC 5.0, 8 GB
GPU - ARM MaliT760 Quad Core (550MHz)
Graphic Resolution
App -1920 x 1080 FHD
Video - 1920 x 1080 FHD
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
DLNA4 x HDMI2.0a (ARC,CEC,MHL)
1 x Satelite in(Main:F-type,female)
1 x AV Composite In 3.5mm jack
1 x Component in(shared with composite)
1 x RS232C(Mini Jack)
1 x Antena (RF) (Female)
1 x Optical Audio Out
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x USB 3.1 HID controller - Compatibility-mouse/keyboard
1 x R232
Bluetooth 4.0 - audio device (headset or speaker).Dual tuners
DVB -T/ T2/C/S/S2
with PVR and PIP function
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
HEVC, VP9 profil 2It supports codecs and containers
Video : VC-1, XviD, H.264/AVC, MJpeg, MPEG1/2/4, HEVC, VP8, VP9, RV30/40
Audio : WMA, MPEG1 Layer I/II/III (MP3), Dolby Digital, Dolby Digital Plus, PCM, LPCM, DVDLPCM, ADPCM, DTS, AAC, HE-AAC AAC LC, AMR-NB et AMR-WB
However, the ISO images of DVD / Blu-ray and native files are not yet supported.IRE White balance- 20 Points
Gamma - 10 points
CMS - Yes
ISFccc - Yes (ISF Day & ISF Night)
Copy to All Inputs - Yes
Interestingly, if you choose the “Copy to all inputs” function, the on-screen text makes reference to an LCD Backlight, when it is of course discussing the the [OLED Light] control. Irritatingly, this only copies the basic picture settings. While the 20-point Grayscale/White Balance controls have their own “copy to all” function, the adjustments for the three-axis Color Management system have no such equivalent and have to be manually copied to all of the inputs. That’s six colors with three adjustments each, and 3-4 HDMI inputs plus internal Smart TV features to apply the settings to, which is sure to make calibrators groan.Pros:
- + Unique ultra-slim design «OLED on glass"
 - + 10-bit, the OLED panel that supports HDR and Dolby Vision
 - + High quality Ultra HD images
 - + Excellent scaling Full HD images up to 4K
 - + Powerful built-in speakers OLED Surround
 - + Picture Perfect (color temperature and gamma).
 - + Almost infinite contrast.
 - + Excellent 3D rendering.
 - + wide viewing angles.
 - + Responsiveness of the panel.
 - + WebOS 3.0 interface always as responsive and pleasant.
Minuses:
- - The high price at the start of sales
 - - The absence of mass HDR-content
 - - imposing foot.
 - - audio rendering by default.
Remote control not backlit
G6V
E6V
(flat)
65", 55"
Yes Dynamic optimization scenes via Dolby Vision technology VS10 Yes 65" - max 655cd/m2
55" - max 596cd/m2
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
65" - LC650LQD-LGxx, WRGB, 10-bit,
55" - LC550LQD-LFxx, WRGB, 10-bit,
Passive 3D
Double anti-reflective coatingNo
No65" - 94.5 %
55" - 96.46%65" - ∞ / 195cd/m2 / 0cd/m2
55" - ∞/-65" - °(cone)
55" - 166°(cone)E6V
(flat)65", 55"65"- 34.1ms / 63ms
55"- 34.1ms / 63msaudio system Harman / Kardon 2.2
Sound power: 40 W
Dolby Digital Plus
DTS
DTS-HDChassis - EA62C
Model - SM5C
Chipset - M16
RAM - 2.0 GB*
Graphic Resolution
Video - 1920 x 1080 FHDLan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x USB 3.1 HID controller compatibility-mouse/keyboard
1 x R232
DVB - T/T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
HEVC, VP9 profil 2IRE White balance - 20 Points
Gamma - 10 points
CMS - Yes
ISFccc - Yes
Copy to All Inputs - YesE6V
C6V
(curved)
65", 55"
? Dynamic optimization scenes via Dolby Vision technology VS10 Yes 65" - max
55" - 100% max peak 400cd/m2
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
65" - LC650LQD-xxxx, WRGB, 10-bit, Curved
55" - LC550LQD-xxxx, WRGB, 10-bit, Curved
The LG OLED C6V has a new structure of sub-pixels that differs from that of the LG Signature G6V.No
No
65" - 9 %
55" - 9 %
65" - ∞ /
55" - ∞ /
65" - °(cone)
55" - °(cone)
C6V
(curved)
65", 55"
65" -
55" -
audio system Harman / Kardon 4.0
Sound power: 40 W
Dolby Digital PluswebOS 3.0
CPU - Quad Core
-Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
DLNA3 x HDMI2.0a (ARC,CEC,MHL)
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x R232
Bluetooth 4.0 audio device(headset or speaker).DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
HEVC, VP9 profil 2IRE White balance- 20 Points
Gamma - 10 points
CMS - Yes
ISFccc - Yes
Copy to All Inputs - YesC6V
B6V
65", 55"
(no support for 3D)
No Dynamic optimization scenes via Dolby Vision technology VS10 Yes 65" - max
55" - max
HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)
No
No
65" - 9 %
55" - 9 %
65" -
55" -
65" -
55" -
B6V
65", 55"
(no support for 3D)65" -
55" -
Sound power: 40 W
CPU - Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x R232
Bluetooth 4.0 audio device (headset or speaker).DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
Gamma - 10 points
CMS - Yes
ISFccc - Yes
Copy to All Inputs - YesB6V
LG LCD Super UHD TV 2016 - european models UH980V
95"No Yes
VS10Yes 95" - In HDR max
HDR1095"- IPS, 10-bit, 120/100Hz
Quantum DotsDirect Led (W-Led)
Local Dimming95" - 95" - 95" - 95" - UH980V
95"95" - Game mode audio system
Harman / Kardon 5.2
Sound power: 80 W
Dolby Digital Plus
ULTRA Surround-
Quad Core
webOS 3.0Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
DLNA3 x HDMI2.0 (ARC,CEC,MHL)
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Compatibility-mouse/keyboardDVB-T/T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shift
HEVC, VP9IRE White balance - 20 Points
Gamma - 10 points
CMS -
ISFccc -UH980V
95"LG LCD UHD TV 2016 - european models Series
Model
Premium
 Dolby Vision_______
In Windows
Type LCD matrix,
Bits of color,
Curvature,
Index,
Screen Uniformity
Type backlight
Type LED
MEMC
Backlight Scanning
(out of the Box & after Calibration)
DCI P3 / Rec.2020 / Delta E Contrast________________________
White & Black level
ANSI
With local dimming
__________________Product
 Audio____________________ SoC____________________
CPU
GPU
Software
OS Networks____________
 Conectors______________________ Tuners______________ Media Player______________ Opportunities for_____________________
calibration Note____________________________________________
Pros & ConsProduct UH955V
86"
Differences in the design of the following model has a black edging UH955V screen, behind the TV also black, UH950V model has a white screen edging with round edges and a white back of the TV.
No Yes
VS10Yes 86" - In HDR max
HDR1086" - AS-IPS, 10-bit, 120/100Hz + BLS
LC860EQD-FJF1
Quantum Dots
PMI (Picture Mastering Index) 2700
Motion Interpolation (TruMotion)
True Black Panel86" - Edge Led (W-Led)
Vertical Dimming
55" - 12 zones
PWM Freq. - 120/100Hz86"- DCI P3 - /Rec.2020 -
Color Prime P86" -
86" - °(cone)
UH955V
86"86" - Game mode
audio system
Harman / Kardon 5.2
Sound power: 80 W
Dolby Digital Plus
ULTRA Surround-
Quad Core
WebOS 3.0Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PAP, PBP
PVR + Time Shift
Gamma - 10 points
CMS -
ISFccc -UH955V
86"UH950V
65", 55"
No Yes
VS10Yes 65" - In HDR max
55" - In HDR max
HDR1065" - AS-IPS, 10-bit, 120/100Hz + BLS
LC650EQF-YJF1
55" - AS-IPS, 10-bit, 120/100Hz + BLS
LC550EQH-YJF1
Quantum Dots
True Black Panel Plus65" - Edge Led (W-Led)
55" - Edge Led (W-Led)
Vertical Dimming
55" - 12 zones
PWM Freq. - 120/100Hz65" - DCI P3
55" - DCI P3
Color Prime P65" -
55" -
65" - °(cone)
55" - °(cone)
UH950V
65", 55"65" - Game mode
55" - game mode
audio system
Harman / Kardon 5.2
Sound power: 80 W
Dolby Digital Plus
ULTRA Surround-
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PAP, PBP
PVR + Time Shift
Gamma - 10 points
CMS -
ISFccc -UH950V
65", 55"UH855V
75"No Yes
VS10No 75" - In HDR max
HDR10
75"- AS-IPS, 8-bit+Hi-FRC, 120/100Hz + BLS
LC750EQF-FJF1
Quantum Dots
Clear Plus - Flashing backlight (BFI)
True Black Panel75" - Edge Led
65" - Edge Led below(W-Led)
60" - Edge Led below(W-Led)
55" - Edge Led below(W-Led)
49" - Edge Led below
Vertical Dimming
55" - 12 zones
PWM Freq. - 120/100Hz75" -
65" -
60" -
55"- DCI P3 - 85% /Rec.2020 - 62%
49" -
Color Prime Plus
75" -
65" -
60" -
55"- native - 920:1
ANSI 1188:1 / 99.8cd/m2 / 0.084cd/m275" - °(cone)
65" - °(cone)
60" - °(cone)
55" - 35°(cone)
49" - °(cone)
UH855V
75"75" - Game mode
65" - Game mode
60" - Game mode
55" - Game mode
49" - Game mode
audio system
Harman / Kardon 4.2
Sound power: 60 W
Dolby Digital Plus
ULTRA Surround-
M16+F16
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
HEVCIRE White balance - 20 Points
Gamma - 10 points
CMS -
ISFccc -UH855V
75"UH850V
8507
65", 60", 55", 49"No Yes
VS10No 65" - In HDR max 315cd/m2
60" - In HDR max
55" - In HDR max 360cd/m2
49" - In HDR max cd/m2
HDR10
65"- AS-IPS, 8-bit+Hi-FRC, 120/100Hz + BLS
LC650EQF-DJF1
60"- AS-IPS, 8-bit+Hi-FRC, 120/100Hz + BLS
LC600EQF-DJF1
55"- AS-IPS, 8-bit+Hi-FRC, 120/100Hz + BLS
LC550EQH-DJF1
Quantum Dots
Vertical Dimming
55" - 12 zones
65" -
60" -
49" -
Color Prime Plus
75" -
65" -
60" -
55"- native - 920:1
65" - °(cone)
60" - °(cone)
55" - 35°(cone)
49" - °(cone)
UH850V
65", 60", 55", 49"75" - Game mode
65" - Game mode
60" - Game mode
55" - Game mode
49" - Game mode
audio system
Harman / Kardon 2.2
Sound power: 40 W
Dolby Digital Plus
ULTRA Surround-
M16+F16
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
Gamma - 10 points
CMS -
ISFccc -UH850V
65", 60", 55", 49"UH780V
770/7707
75", 65", 60", 55", 49"No Yes
65" - In HDR max
60" - In HDR max
55" - In HDR max 341cd/m2
49" - In HDR max
43" - in HDR max
HDR10
75"- AS-IPS, 120/100Hz + BLS
65"- AS-IPS, 8-bit+FRC, 120/100Hz+BLS
60"- AS-IPS, 8-bit+FRC, 120/100Hz+BLS
55"- AS-IPS, 8-bit+FRC, 120/100Hz+BLS
49"- AS-IPS, 8-bit+FRC, 120/100Hz+BLS
43"- AS-IPS, 8-bit+FRC, 120/100Hz+BLS
Quantum Dots
PMI (Picture Mastering Index) 2500
Motion Interpolatiom (TruMotion)
Clear Plus - Flashing backlight (BFI)75" -
65" - Edge Led below (W-Led)
60" - Edge Led below (W-Led)
55" - Edge Led below (W-Led)
Vertical Dimming
55" - 6 zones
65" - DCI P3 -
60" - DCI P3 -
55" - DCI P3 - 77.6% /Rec.2020 - 58%
49" - DCI P3 -
Color Prime P75" -
65" -
60" -
55"- native - 920:1 /
ANSI 1153:1 / 101.5cd/m2 / 0.088cd/m275" - ° (cone)
65" - °(cone)
60" - °(cone)
55" - 35°(cone)
49" - °(cone)
UH770V
65" - Game mode
60" - Game mode
55" -
Game mode 38.1ms / by default 57ms
49" - Game mode
K2L
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
HEVCIRE White balance- 20 Points
Gamma - 10 points
CMS -
ISFccc -UH770V
65", 60", 55", 49"UH750V
7507
65", 55", 49", 43"No No No 65" - In HDR max
55" - In HDR max
49" - In HDR max
43" - In HDR max
HDR PROcessing
Convert SDR to HDR
(missing hardware for playback HDR)65"- AS-IPS, 8-bit+FRC, 60/50Hz
55"- AS-IPS, 8-bit+FRC, 60/50Hz
49"- AS-IPS, 8-bit+FRC, 60/50Hz
43"- AS-IPS, 8-bit+FRC, 60/50Hz
WRGB structure - resolution 2880x216065" - Edge Led (W-Led)
49" -
43" -
Local Dimming
PWM Freq. - 120/100Hz65" - DCI P3 - 90%/
55" - DCI P3 - 90%/
49" - DCI P3 - 90%/
43" - DCI P3 -
Color prime P65" -
55" -
49" -
43" -65" - °(cone)
55" -
49" -
43" -65" -
55" -
49" -
43" -UH750V
65", 55", 49", 43"75" - Game mode
65" - Game mode
55" - Game mode
49" -
43" - Game mode
Sound power: 20 W
Dolby Digital Plus
ULTRA Surround-
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
HEVCUH750V
65", 55", 49", 43"UH700V
7007
70"No No No 70" - In HDR max
HDR PROcessing
(missing hardware for playback HDR)70"- AS-IPS, 8-bit+FRC, 120/100Hz
70" - Edge Led (W-Led)
Local Dimming
PWM Freq. - 120/100Hz70"- DCI P3 - 84%
70" - 70" - 70" - UH700V
65", 55", 49", 43"70" - Sound power: 20 W
Dolby Digital Plus
ULTRA Surround-
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
HEVCUH700V
65", 55", 49", 43"UH670V
55" - In HDR max
49" - In HDR max
43" - In HDR max
HDR PROcessing
Convert SDR to HDR
49" - Direct Led (W-Led)
43" - Direct Led (W-Led)
Local Dimming
PWM Freq. - 120/100Hz65"- DCI P3 - 84%
55"- DCI P3 - 84%
49"- DCI P3 - 84%
43"- DCI P3 -
Color Prime P65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -UH670V
65", 55", 49", 43"65" -
55" -
49" -
43" -audio system
Harman / Kardon 2.0
Sound power: 20 W
Dolby Digital Plus
ULTRA Surround-
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
DLNA3 x HDMI2.0 (ARC,CEC)
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
HEVCUH670V
65", 55", 49", 43"UH660V
668/664/661
55" - In HDR max
49" - In HDR max
43" - In HDR max
HDR PROcessing
Convert SDR to HDR
50"↑ Local Dimming65" - Edge Led (W-Led)
50"↑ Local Dimming
55"- DCI P3 - 84%
49"- DCI P3 - 84%
43"- DCI P3 -
Color Prime Pro65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -UH660V
55" -
49" -
43" -audio system
Harman/Kardon 2.0 - only in model 668
Sound power: 20 W
Dolby Digital Plus
ULTRA Surround-
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
HEVCUH660V
65", 55", 49", 43"UH650V
6507
65", 60", 55", 49", 43"No No No 65" - LC
60" -
55" -
49" -
43" -
HDR PROcessing
Convert SDR to HDR
60"- AS-IPS, 8-bit+FRC, 60/50Hz
60" - Edge Led (W-Led)
50"↑ Local Dimming65"- DCI P3 -
60" - DCI P3 -
55" - DCI P3 - 84%
49" - DCI P3 - 84%
43" - DCI P3 -
60" -
55" -
49" -
43" -65" -
60" -
55" -
49" -
43" -65" -
60" -
55" -
49" -
43" -UH650V
65", 60", 55", 49", 43"65" -
60" -
55" -
49" -
43" -Sound power: 20 W
Dolby Digital Plus
ULTRA Surround-
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 ac
WiDi / Miracast
DLNA
Bluetooth3 x НDМІ2.0 (ARC,CEC,MHL)
Соmроnеnt іn 1 (ѕhаrеd wіth соmроѕіtе)
1 x RЅ232С (Міnі Јасk)
USB 2.0 x 2
1 x Antena (RF)
1 x CI+ 1.3DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
PVR + Time Shift
HEVCUH650V
65", 60", 55", 49", 43"UH635V
58", 50",
UH630V
40"
No No No 58" -
50" -
40" -
HDR PROcessing
Convert SDR to HDR
(missing hardware for playback HDR)58"- S-MVA(Innolux) ?, 8-bit, 60/50Hz
50"- S-MVA(Innolux) ?, 8-bit, 60/50Hz
40"- S-MVA ?, 8-bit, 60/50Hz
RGB
50"↑ Local Dimming58" - Edge Led (W-Led)
50" - Edge Led (W-Led)
40" - Edge Led (W-Led)
PWM Freq. -58" - DCI P3 - 90%
50" - DCI P3 - 90%
40" - DCI P3 -
Color Prime Plus58" -
50" -
40" -58" -
50" -
40" -58" -
50" -
40" -UH630V
58", 50", 40"58" -
50" -
40" -Sound power: 20 W
Dolby Digital Plus
ULTRA Surround-
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 ac
WiDi / Miracast
DLNA
1 x Соmроnеnt іn(ѕhаrеd wіth соmроѕіtе)
2 x USB 2.0
1 x Antena (RF)
Analog (PAL,SECAM)
PVR + Time Shift
HEVC
UH630V
58", 50", 40"
UH620V
6257/6207
60" -
55" -
49" -
43" -
HDR PROcessing
(missing hardware for playback HDR)65"- S-IPS, 8-bit, 60/50Hz
60"- S-IPS, 8-bit, 60/50Hz
55"- S-IPS, 8-bit, 60/50Hz
49"- S-IPS, 8-bit, 60/50Hz
43"- S-IPS, 8-bit, 60/50Hz
WRGB structure - resolution 2880x216060" - Edge Led (W-Led)
Local Dimming
PWM Freq. -65" - DCI P3
55" - DCI P3
49" - DCI P3
43" - DCI P3 -
65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -UH620V
65", 60", 55", 49", 43"Sound power: 20 W
Dolby Digital Plus
ULTRA Surround-
Wi-Fi (only 802.11 n)
WiDi / Miracast
WiFi Direct
DLNAHDMI x (HDCP2.2)
1- ARC,
1 - Compatible 4K@60p and HDR 422
1 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
HEVC
UH620V
65", 60", 55", 49", 43"UH610V
6157/6107
55" -
49" -
43" -
HDR PROcessing
49" -
43" -
PWM Freq. -65" - DCI P3 -
55" -
49" -
43" -
65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -65" -
55" -
49" -
43" -UH610V
65", 55", 49", 49", 43"65" -
55" -
49" -
Dolby Digital Plus
ULTRA Surround-
Wi-Fi (only 802.11.n)
WiDi / Miracast
DLNA3 x НDМІ2.0 (ARC,CEC,MHL)
RЅ232С (Міnі Јасk)
2 x USB 2.0
1 x Antena (RF)
Analog (PAL,SECAM)
PVR
HEVC
UH610V
65", 55", 49", 49", 43"UH600V
No No No No 65" - S-IPS, 8-bit, 60/50Hz
60" - S-IPS, 8-bit, 60/50Hz
55" - S-IPS, 8-bit, 60/50Hz
49" - S-IPS, 8-bit, 60/50Hz
43" - S-IPS, 8-bit, 60/50Hz
True Black Panel65" - Edge Led (W-Led)
60" - Edge Led
49" - Edge Led (W-Led)
PWM Freq. -65" -
60" -
55" -
49" -
43" -
65" -
60" -
55" -
49" -
43" -65" -
60" -
55" -
49" -
43" -65" -
60" -
55" -
49" -
43" -UH600V
65", 60", 55", 49"-
WebOS 2.02 x HDMI1.4 No support 4K!
1 x USB 2.0
1 x Antena (RF)DVB-T2/C/S2
Analog (PAL, SECAM)UH600V
65", 60", 55", 49"Series
Model
In Windows
Type LCD matrix,
Bits of color,
Curvature,
Index,
Screen Uniformity
Type backlight
Type LED
MEMC
Backlight Scanning
DCI P3 / Rec.2020 / Delta E / Gamma / Temperature Contrast________________________
White & Black level
ANSI
With local dimming
Game mode
by default Audio_________________________ Operating Sistem_________________________
Board
System on Chip
RAM
Software
Pros & ConsProduct
UH5500 е по-скоро аналог на UH630/635 серията с VA панели .:Drinks:
И все пак за тая цена заслужава ли си, защото това най-много ме вълнува или да го пусна да се продава...
Е какво толкова му мислиш , като дойде ще го видиш - ако ти хареса си го оставяш , ако не - продаваш , няма да си вътре - 600лв за нов 49" 4К тв все ще се намери кой да ти даде :) .
Тъкмо и ще дадеш мнение във форума - като е за питане преди покупка са много , ама после впечатления/ревюта рядко някой пуска .:Drinks:
Прав си :)
Здравейте!!!
Здраввйте, от 2 дена съм собсвеник на LG 43UH668V - за сега като за начало не е лош телевизора но все още го разучавам и искам да питам едно нещо. Аз съм на кабелна цифрова телевизия с каммодул и ме интересува при пълно сканиране има опция сляпо търсене. Какво точно означава това.
ЩЕ МОГА ЛИ ОТ ВЪНШНА ПАМЕТ ДА ГЛЕДАМ НОВОПОЯВИЛИТЕ СЕ КОМПРЕСИРАНИ 4К ХЕВК ФОРМАТ В ,,ЗАМУНДА" ФИЛМИ НА LG UH 8507? БЛАГОДАРЯ ВИ!!!
Би трябвало да можеш , какъв е смисъла от 4К в 10ГБ, след като аз обикновено свалям 30гб и нагоре в 1080р - нямам представа:)
Понеже този HEVK 265 компресира дори 8к видеа и би трябвало да е успешен. Така съм чел за него. Но нямам представа как изглежда такъв филм защото тв-то ми
и компа са слабички. Другия вариант е нова видео карта към предстоящия ми LG UH 8507 за да гледам 4к видеа. В Замунда има и един 4к филм, който е 130Gb!
А за новия ми UH 8507 пише, че е със HDR-SUPER и DOLBY VISION. Но DOLBY VISION се сваля подобно на upgreade. Може ли да ми кажеш нещичко за този модел...
Би трябвало с вградения плеър в ЛГ да нямаш проблеми с подобни файлове .
п.п. Виж вече в тоя 130гб може вече да "усетиш силата" на UHD филм - тия по 12-13ГБ вероятно са на нивото на стриймваните услуги - колкото и да е добър кодека не може да се очакват чудеса в подобен размер.
Здравеите!!! Ако кача 3д филм на usb ще мога ли да го гледам на ЛГ UH 8507?
Здравейте. Имам външен хард диск https://www.senetic.bg/product/WDBFJK0040HBK-EESN Ще мога ли спокойно да го ползвам на UH 8507? И двата продукта пристигат във вторник. Ровя се навсякъде и незнам дали съм направил успешни покупки. Притеснявам се и за проверката на работещите часове на телевизора-незнам как става-пълна лудница съм. Умолявам за ПОМОООЩ...
