:thumbsup:
:thumbsup:
Съдейки по датата на производство, техниците са ти поставили панел последно поколение за модели 2016.
Искам да те помоля да се свържеш с техниците - ако имаш такава възможност и да ги попиташ, за кой ISO стандарт са говорили и да ми пишеш.
Този ли?
https://en.wikipedia.org/wiki/ISO_13406-2
LG 55UH770V (UH770V/ UH7700) Review
55UH770V: six separately dimmable zones
Motion resolution: Up to 900 with [TruMotion] engaged; 300 otherwise,(TruMotion/User-deblur and dejudder settings)
Calibrated black level (4 x 4 ANSI): 0.087 cd/m2
85% of DCI-P3 colour gamut
Macro photo of subpixel layout confirming RGB IPS-type LCD matrix
http://www.hdtvtest.co.uk/image/uhdt...V/subpixel.jpg http://www.hdtvtest.co.uk/image/uhdt...0V/thermal.jpg
Conclusion
LG has improved a number of things on the UH770V compared with previous LED LCD offerings from the company. The TV’s native black level was the deepest yet we’ve measured from an IPS LCD panel, though still not a patch on most VA LCDs, let alone self-emissive displays like plasma and OLED televisions. The 55UH770 could be also calibrated to highly accurate levels; backlight management was better than previous iterations (at least in SDR); and input lag had been cut down to allow for more responsive gaming.
But at the end of the day, the LG 55UH770V’s Achilles’ Heel was always going to be the limited contrast performance of IPS screen technology, especially as the industry marches relentlessly towards HDR. The display’s shallower black level meant that its backlight engine had to work much harder to produce convincing blacks and HDR brightness at the same time, resulting in seriously distracting vertical blooming and luminance fluctuations. Throw in frame-skipping problem during 4K Blu-ray playback, and we think there are better alternatives on the market albeit at slightly higher prices, such as the Panasonic DX750, or better yet, the Samsung KS7000 (review pending). Of course, if budget isn’t an issue, by all means go for one of LG’s outstanding OLEDs.
Ривю на LG OLED65B6P
LG OLED65B6P: E6 OLED 4K Smart TV w/ webOS 3.0 | LG USA
Може да си пуснете български субтитри:
https://www.youtube.com/watch?v=H8c86HOBAD4
Здравейте LG 43LH630V с 100Hz или 50Hz матрица е.
60/50Hz.
LH660/650 май са 100Hz.
Иначе на сайта им е изписано какво ли не...
http://www.lg.com/bg/televizori/lg-43LH630V
LG 43LH630V - FULL HD - Smart TV - LED TV - LG Česká republika
Херцовете в скобите се отнасят за TruMotion
LH630- PMI900: (100Hz)
LH6047-PMI900: (100Hz)
LH590- PMI450: (100Hz)
LH570- PMI450: (100Hz)
LH560- PMI400: (50Hz)
LH540- PMI300: (50Hz)
LH510- PMI300: (50Hz)
Scott Wilkinson and Robert Heron recap the calibration process of Leo Laporte's LG OLED TV.
https://www.youtube.com/watch?v=sBDun9fbEWU
source video:[you tube - TWiTHomeTheaterGeeks]
някой има ли впечатления от 43UH668V и всъщност по какво се отличава от 43UH661V
stg888
Само разликите
UH661 - Frame colors: dark and black metal
UH668 - audio Harman/Kardon 2.0, Magic Sound Tuning, Voice recognition via remote control, gesture control via remote control, Magic Remote, Frame colors: Metal and Black
LG UH9500 Review (65UH9500, 86UH9500)
65UH9500:IPS panel RGB structure,100/120Hz with MCFI.
in Europe - 65UH950V
благодаря, пчоти бях решил да е панасононик 40ds630e и тоя се появи на около 980 лв и сега мисля
Ето ти сравнение на UH661, UH664, UH668
Comparaison des produits s
Здравейте, новия пс4 го дават да възпроизвежда 4К. Та въпроса ми е дали моето 49 uf 8507 ще се справи?
В какъв смисъл да се справи ?
Ами след като е 4К дисплей , щом му подадеш такъв (4К) сигнал би трябвало да го изобрази :) - в случая ще се явява само монитор .
LG 55UH664V: wrażenia, opinie i specyfikacja | RTVmaniaK.pl
50/60Hz panel
55UH664V:IPS panel,RGB+W Pixel Structure,RGBW UHD subpixel arrangement.
A pixel consists according to LG from the combinations RGB, WRG, BWR or GBW.
http://i.rtings.com/images/reviews/u...xels-small.jpg
http://i.rtvmaniak.pl/rtvmaniak/2016/10/9.jpg
http://i.rtvmaniak.pl/rtvmaniak/2016/10/5-1-medium.jpg
http://www.rtvmaniak.pl/wp-content/u...V-6-medium.jpg
source photos:[rtvmaniak.pl]
