| LG Oled UHD TV 2016 - european models |
 Series
Model  ________________ |  Certification UHD
Premium  _______ |  Dolby Vision _______ |  Hybrid Log Gamma
(HLG) ______ |  HDR 10 ____________  In Windows
2/5/10/20/100%  |  Videopanel _________________________  Type LCD matrix,
Bits of color,
(Operating frequency of T-Con board of the panel)
Curvature,
Index,
Screen Uniformity
Anti-reflective filter  |  Backlight __________________  Type backlight
(Local Dimming zone)
Type LED
MEMC
Backlight Scanning
Black Frame Insertion
Pulsе Wide Modulation  |  Measurement
(out of the Box & after calibration) _______________________________  DCI P3 / Rec.2020 / Delta E / Gamma / Temperature  |  Contrast
White & Black level ________________________  ANSI
With local dimming
Without local dimming  |  Viewing angle  ___________ ( ° cone)  |  Motion resolution
_________________________ |  Product _____________ |  Input Lag   _____________  Game mode
by default  |  Audio ____________________________ |  Chassis
Operating Sistem
Board
System on Chip
Central Processing Unit
Graphic Processor Unit
RAM
Software   __________________________ |  Networks   ____________ |  Conectors __________________________________ |  Tuners ________________ |  Media Player __________________ |  Opportunities for
calibration _________________________ |  Note __________________________________________  Pros & Cons  |  Product |
 G6V  (flat)  77", 65"
3D passive interlaced circular polarization with FPR technology |  Yes |  Dynamic optimization scenes via Dolby Vision technology VS10 |  Yes |  77" - max 744cd/m2   65" - max 640cd/m2   HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)   |  77" - LC770LQD-LGxx, WRGB, 10-bit   65" - LC650LQD-LGxx, WRGB, 10-bit   Passive 3D
MCI - Motion Clarity Index - 1000
(MCFI - Motion Clarity Frame Interpolation)
Triple anti-reflective coating
The new pixel structure of the OLED-panel TVs LG OLED65G6V applied. Compared to the previous generation of 4 identical sub-pixels (red, green, blue and white), in the new panels the red subpixel has become a little less, and the blue and white is slightly increased. It was thus able to increase the peak brightness of the new OLED-screen. |  No   No
    |  77" -    65" - 94.14% / x-x  /4.5-1.6 / 2.21-2.2 / 6225-6517K
  |  75" - 1000000:1 /   65" - 1000000:1 / 150cd/m2 / 0.00cd/m2
290cd/m2 in ISF Dark mode     |  77" -   °(cone)   65" -   °(cone)
  |  77" - 600-650[with TruMotion], 300 without   65" - 600-650[with TruMotion], 300 without |  G6V  77", 65" |  77" - 34.0ms /    65" - 33.6ms / |  audio system Harman / Kardon 4.2
Total sound power: 60 W
Four speakers
2 built-in subwoofer: 20W
Dolby Digital Plus
DTS
DTS-HD
Not surprisingly, the sound is very good for a TV. The LG 65G6V comes down low enough in the spectrum since the low mids from 100 Hz are audible. The sound reproduction is excellent between 180 and 1500 Hz. However, we noted an effect of sibilance very disturbing in the treble, which prompted us to reduce the frequency of 10 kHz via the equalizer. Once this small adjustment, the ear is less abused and it is possible to listen to some music on the TV. The large size of the foot could have enabled LG to go one step further with a woofer bigger and a vent that is found on the system sound bars . Finally, the distortion is limited 0.9%. |  Chassis -
Model - SM5C
Platform - webOS Signage 3.0
Chipset - M16
CPU - ARM Cortex-A53 1.0 GHz Quad Core
RAM - 2.0 GB*
Flash Memory - eMMC 5.0, 8 GB
GPU - ARM MaliT760 Quad Core (550MHz)
Graphic Resolution
App -1920 x 1080 FHD
Video - 1920 x 1080 FHD     |  Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
DLNA |  4 x HDMI2.0a (ARC,CEC,MHL)
1 x Satelite in(Main:F-type,female)
1 x AV Composite In 3.5mm jack
1 x Component in(shared with composite)
1 x RS232C(Mini Jack)
1 x Antena (RF) (Female)
1 x Optical Audio Out
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x USB 3.1 HID controller - Compatibility-mouse/keyboard
1 x R232
Bluetooth 4.0 - audio device (headset or speaker). |  Dual tuners
DVB -T/ T2/C/S/S2
with PVR and PIP function
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
HEVC, VP9 profil 2 |  It supports codecs and containers
Video : VC-1, XviD, H.264/AVC, MJpeg, MPEG1/2/4, HEVC, VP8, VP9, RV30/40
Audio : WMA, MPEG1 Layer I/II/III (MP3), Dolby Digital, Dolby Digital Plus, PCM, LPCM, DVDLPCM, ADPCM, DTS, AAC, HE-AAC AAC LC, AMR-NB et AMR-WB
However, the ISO images of DVD / Blu-ray and native files are not yet supported. |  IRE White balance- 20 Points
Gamma - 10 points
CMS - Yes
ISFccc - Yes (ISF Day & ISF Night)
Copy to All Inputs - Yes
Interestingly, if you choose the “Copy to all inputs” function, the on-screen text makes reference to an LCD Backlight, when it is of course discussing the the [OLED Light] control. Irritatingly, this only copies the basic picture settings. While the 20-point Grayscale/White Balance controls have their own “copy to all” function, the adjustments for the three-axis Color Management system have no such equivalent and have to be manually copied to all of the inputs. That’s six colors with three adjustments each, and 3-4 HDMI inputs plus internal Smart TV features to apply the settings to, which is sure to make calibrators groan. |  Pros:    - + Unique ultra-slim design «OLED on glass"
 - + 10-bit, the OLED panel that supports HDR and Dolby Vision
 - + High quality Ultra HD images
 - + Excellent scaling Full HD images up to 4K
 - + Powerful built-in speakers OLED Surround
 - + Picture Perfect (color temperature and gamma).
 - + Almost infinite contrast.
 - + Excellent 3D rendering.
 - + wide viewing angles.
 - + Responsiveness of the panel.
 - + WebOS 3.0 interface always as responsive and pleasant.
   Minuses:    - - The high price at the start of sales
 - - The absence of mass HDR-content
 - - imposing foot.
 - - audio rendering by default.
Remote control not backlit
    |  G6V   |
 E6V  (flat)  65", 55"   |  Yes |  Dynamic optimization scenes via Dolby Vision technology VS10 |  Yes |  65" - max 655cd/m2   55" - max 596cd/m2   HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)   |  65" - LC650LQD-LGxx, WRGB, 10-bit,   55" - LC550LQD-LFxx, WRGB, 10-bit,   Passive 3D
Double anti-reflective coating |  No   No
  |  65" - 94.5 %   55" - 96.46%
  |  65" - ∞ / 195cd/m2 / 0cd/m2   55" - ∞/-
  |  65" -     °(cone)   55" - 166°(cone)
  |   |  E6V
(flat)65", 55" |  65"- 34.1ms / 63ms   55"- 34.1ms / 63ms
  |  audio system Harman / Kardon 2.2
Sound power: 40 W
Dolby Digital Plus
DTS
DTS-HD |  Chassis - EA62C
Model - SM5C
Chipset - M16
RAM - 2.0 GB*
Graphic Resolution
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x USB 3.1 HID controller compatibility-mouse/keyboard
1 x R232
DVB - T/T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
HEVC, VP9 profil 2 |   |  IRE White balance - 20 Points
Gamma - 10 points
CMS - Yes
ISFccc - Yes
Copy to All Inputs - Yes |   |  E6V   |
 C6V
(curved)  65", 55"   |  ? |  Dynamic optimization scenes via Dolby Vision technology VS10 |  Yes |  65" - max   55" - 100%  max peak 400cd/m2   HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)   |  65" - LC650LQD-xxxx, WRGB, 10-bit,  Curved   55" - LC550LQD-xxxx, WRGB, 10-bit, Curved   MCI - Motion Clarity Index
(MCFI - Motion Clarity Frame Interpolation)  The LG OLED C6V has a new structure of sub-pixels that differs from that of the LG Signature G6V. |  No   No
    |  65" - 9 %   55" - 9 %
    |  65" - ∞ /   55" - ∞ /
    |  65" -   °(cone)   55" -   °(cone)
    |   |  C6V
(curved)  65", 55"   |  65" -    55" -
    |  audio system Harman / Kardon 4.0
Sound power: 40 W
Dolby Digital Plus |  webOS 3.0
CPU - Quad Core
- |  Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
DLNA |  3 x HDMI2.0a (ARC,CEC,MHL)
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x R232
Bluetooth 4.0 audio device(headset or speaker). |  DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
HEVC, VP9 profil 2 |   |  IRE White balance- 20 Points
Gamma - 10 points
CMS - Yes
ISFccc - Yes
Copy to All Inputs - Yes |   |  C6V   |
 B6V  65", 55"  (no support for 3D)   |  No |  Dynamic optimization scenes via Dolby Vision technology VS10 |  Yes |  65" - max   55" - max   HDR10 compatible
(SMPTE-Standards
ST2084 и ST2086)   |  65" - LC650LQD-xxxx, WRGB, 10-bit   55" - LC550LQD-xxxx, WRGB, 10-bit,
    |  No   No
    |  65" - 9 %   55" - 9 %
    |  65" -   55" -
    |  65" -   55" -
    |   |  B6V  65", 55"
(no support for 3D) |  65" -    55" -
Sound power: 40 W
CPU - Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
WiDi
Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
1 x R232
Bluetooth 4.0 audio device (headset or speaker). |  DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shifting
Gamma - 10 points
CMS - Yes
ISFccc - Yes
Copy to All Inputs - Yes |   |  B6V   |
 | LG LCD Super UHD TV 2016 - european models |
 UH980V  95" |  No |  Yes
VS10 |  Yes |  95" - In HDR max   HDR10 |  95"- IPS, 10-bit, 120/100Hz   Quantum Dots |  Direct Led (W-Led)
Local Dimming |  95" - |  95" - |  95" - |  95" - |  UH980V  95" |  95" - Game mode |  audio system
Harman / Kardon 5.2
Sound power: 80 W
Dolby Digital Plus
ULTRA Surround |  -
Quad Core
webOS 3.0 |  Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
DLNA |  3 x HDMI2.0 (ARC,CEC,MHL)
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Compatibility-mouse/keyboard |  DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
PAP, PBP
PVR, Time Shift
HEVC, VP9 |   |  IRE White balance - 20 Points
Gamma - 10 points
CMS -
ISFccc - |   |  UH980V  95" |
 | LG LCD UHD TV 2016 - european models |
 Series
Model
2/5/10/20/100%  |  Videopanel  _______________________  Type LCD matrix,
Bits of color,
Curvature,
Index,
Screen Uniformity
Anti-reflective filter  |  Backlight ______________  Type backlight
Type LED
MEMC
Backlight Scanning
(out of the Box & after Calibration) ___________________  DCI P3 / Rec.2020 / Delta E  |  Contrast
With local dimming
_____________ |  Input Lag   _____________ |  Audio ____________________ |  SoC
CPU
GPU
Software
OS ____________________ |  Networks   ____________ |  Conectors ______________________ |  Tuners ______________ |  Media Player ______________ |  Opportunities for
calibration _________________________ |  Note ____________________________________________  Pros & Cons  |  Product |
 UH955V  86"
Differences in the design of the following model has a black edging UH955V screen, behind the TV also black, UH950V model has a white screen edging with round edges and a white back of the TV.   |  No |  Yes
VS10 |  Yes |  86" - In HDR max   HDR10 |  86" - AS-IPS, 10-bit, 120/100Hz + BLS
LC860EQD-FJF1   Quantum Dots
PMI (Picture Mastering Index) 2700
Motion Interpolation (TruMotion)
True Black Panel |  86" - Edge Led (W-Led)   Vertical Dimming  55" - 12 zones
PWM Freq. - 120/100Hz |  86"- DCI P3 - /Rec.2020 -   Color Prime P |  86" -
    |  86" -   °(cone)
    |   |  UH955V  86" |  86" - Game mode
    |  audio system
Harman / Kardon 5.2
Sound power: 80 W
Dolby Digital Plus
ULTRA Surround |  -
Quad Core
WebOS 3.0 |  Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PAP, PBP
PVR + Time Shift
Gamma - 10 points
CMS -
ISFccc - |   |  UH955V  86" |
 UH950V  65", 55"   |  No |  Yes
VS10 |  yes |  65" - In HDR max   55" - In HDR max   HDR10 |  65" - AS-IPS, 10-bit, 120/100Hz + BLS
LC650EQF-YJF1   55" - AS-IPS, 10-bit, 120/100Hz + BLS
LC550EQH-YJF1   Quantum Dots
True Black Panel Plus |  65" - Edge Led (W-Led)   55" - Edge Led (W-Led)   Vertical Dimming  55" - 12 zones
PWM Freq. - 120/100Hz |  65" - DCI P3   55" - DCI P3   Color Prime P |  65" -   55" -
    |   |  UH950V  65", 55" |  65" - Game mode   55" - game mode
    |  audio system
Harman / Kardon 5.2
Sound power: 80 W
Dolby Digital Plus
ULTRA Surround |  -
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PAP, PBP
PVR + Time Shift
Gamma - 10 points
CMS -
ISFccc - |   |  UH950V  65", 55" |
 UH855V  75" |  No |  Yes
VS10 |  No |  75" - In HDR max   HDR10   |  75"- AS-IPS, 8-bit+Hi-FRC, 120/100Hz + BLS
LC750EQF-FJF1   Quantum Dots
Clear Plus - Flashing backlight (BFI)
True Black Panel |  75" - Edge Led   65" - Edge Led below(W-Led)   60" - Edge Led below(W-Led)   55" - Edge Led below(W-Led)   49" - Edge Led below   Vertical Dimming  55" - 12 zones
PWM Freq. - 120/100Hz |  75" -   65" -   60" -   55"- DCI P3 - 85% /Rec.2020 - 62%   49" -   Color Prime Plus    |  75" -   65" -   60" -   55"- native - 920:1
ANSI 1188:1 / 99.8cd/m2 / 0.084cd/m2 |  75" -    °(cone)   65" -    °(cone)     60" -    °(cone)   55" - 35°(cone)   49" -    °(cone)
    |   |  UH855V  75" |  75" - Game mode   65" - Game mode   60" - Game mode   55" - Game mode   49" - Game mode
    |  audio system
Harman / Kardon 4.2
Sound power: 60 W
Dolby Digital Plus
ULTRA Surround |  -
M16+F16
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
HEVC |   |  IRE White balance - 20 Points
Gamma - 10 points
CMS -
ISFccc - |   |  UH855V  75" |
 UH850V  8507  65", 60", 55", 49" |  No |  Yes
VS10 |  No |  65" - In HDR max 315cd/m2   60" - In HDR max   55" - In HDR max 360cd/m2   49" - In HDR max   cd/m2   HDR10   |  65"- AS-IPS, 8-bit+Hi-FRC, 120/100Hz + BLS
LC650EQF-DJF1   60"- AS-IPS, 8-bit+Hi-FRC, 120/100Hz + BLS
LC600EQF-DJF1   55"- AS-IPS, 8-bit+Hi-FRC, 120/100Hz + BLS
LC550EQH-DJF1   Quantum Dots
    |   |  UH850V  65", 60", 55", 49" |  75" - Game mode   65" - Game mode   60" - Game mode   55" - Game mode   49" - Game mode
    |  audio system
Harman / Kardon 2.2
Sound power: 40 W
Dolby Digital Plus
ULTRA Surround |  -
M16+F16
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
Gamma - 10 points
CMS -
ISFccc - |   |  UH850V  65", 60", 55", 49" |
 UH780V  770/7707  75", 65", 60", 55", 49" |  No |  Yes
VS10 |  No |  75" - In HDR max   65" - In HDR max   60" - In HDR max   55" - In HDR max 341cd/m2   49" - In HDR max   43" - in HDR max   HDR10   |  75"- AS-IPS,  120/100Hz + BLS   65"- AS-IPS, 8-bit+FRC, 120/100Hz+BLS   60"- AS-IPS, 8-bit+FRC, 120/100Hz+BLS   55"- AS-IPS, 8-bit+FRC, 120/100Hz+BLS   49"- AS-IPS, 8-bit+FRC, 120/100Hz+BLS   43"- AS-IPS, 8-bit+FRC, 120/100Hz+BLS   Quantum Dots
PMI (Picture Mastering Index) 2500
Motion Interpolatiom (TruMotion)
Clear Plus - Flashing backlight (BFI) |  75" -   65" - Edge Led below (W-Led)   60" - Edge Led below (W-Led)   55" - Edge Led below (W-Led)   49" - Edge Led below   Vertical Dimming   55" - 6 zones
PWM Freq. - 120/100Hz |  75" -   65" - DCI P3 -   60" - DCI P3 -   55" - DCI P3 - 77.6% /Rec.2020 - 58%   49" - DCI P3 -   Color Prime P |  75" -   65" -   60" -   55"- native - 920:1 /
ANSI 1153:1 / 101.5cd/m2 / 0.088cd/m2 |  75" - ° (cone)   65" -   °(cone)   60" -   °(cone)   55" - 35°(cone)   49" -    °(cone)
    |   |  UH770V  65", 60", 55", 49" |  75" - Game mode   65" - Game mode   60" - Game mode   55" - Game mode 38.1ms / by default 57ms   49" - Game mode
    |   |  K2L
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
HEVC |   |  IRE White balance- 20 Points
Gamma - 10 points
CMS -
ISFccc - |   |  UH770V  65", 60", 55", 49" |
 UH750V  7507  65", 55", 49", 43" |  No |  No |  No |  65" - In HDR max   55" - In HDR max   49" - In HDR max   43" - In HDR max   HDR PROcessing
Convert SDR to HDR
(missing hardware for playback HDR) |  65"- AS-IPS, 8-bit+FRC, 60/50Hz   55"- AS-IPS, 8-bit+FRC, 60/50Hz   49"- AS-IPS, 8-bit+FRC, 60/50Hz   43"- AS-IPS, 8-bit+FRC, 60/50Hz   WRGB structure - resolution 2880x2160 |  65" - Edge Led (W-Led)   55" - Edge Led (W-Led)   49" -   43" -   Local Dimming
PWM Freq. - 120/100Hz |  65" - DCI P3 - 90%/   55" - DCI P3 - 90%/   49" - DCI P3 - 90%/   43" - DCI P3 -   Color prime P |  65" -
55" -
49" -
43" - |  65" -   °(cone)
55" -
49" -
43" - |  65" -
55" -
49" -
43" - |  UH750V  65", 55", 49", 43" |  75" - Game mode   65" - Game mode   55" - Game mode   49" - Game mode 38.1ms / by default 57ms   43" - Game mode
    |  Sound power: 20 W
Dolby Digital Plus
ULTRA Surround |  -
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
HEVC |   |   |   |  UH750V  65", 55", 49", 43" |
 UH700V  7007  70" |  No |  No |  No |  70" - In HDR max   HDR PROcessing
(missing hardware for playback HDR) |  70"- AS-IPS, 8-bit+FRC, 120/100Hz   WRGB structure - resolution 2880x2160   |  70" - Edge Led (W-Led)   Local Dimming
PWM Freq. - 120/100Hz |  70"- DCI P3 - 84%
    |  70" - |  70" - |  70" - |  UH700V  65", 55", 49", 43" |  70" - |  Sound power: 20 W
Dolby Digital Plus
ULTRA Surround |  -
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
HEVC |   |   |   |  UH700V  65", 55", 49", 43" |
 UH670V  65", 55", 49", 43" |  No |  No |  No |  65" - In HDR max   55" - In HDR max   49" - In HDR max   43" - In HDR max   HDR PROcessing
Convert SDR to HDR
(missing hardware for playback HDR) |  65"- AS-IPS, 8-bit+FRC, 60/50Hz   55"- AS-IPS, 8-bit+FRC, 60/50Hz   49"- AS-IPS, 8-bit+FRC, 60/50Hz   43"- AS-IPS, 8-bit+FRC, 60/50Hz   WRGB structure - resolution 2880x2160   |  65" - Edge Led (W-Led)   55" - Edge Led (W-Led)   49" - Direct Led (W-Led)   43" - Direct Led (W-Led)   Local Dimming
PWM Freq. - 120/100Hz |  65"- DCI P3 - 84%   55"- DCI P3 - 84%   49"- DCI P3 - 84%   43"- DCI P3 -   Color Prime P |  65" -
55" -
49" -
43" - |  65" -
55" -
49" -
43" - |  65" -
55" -
49" -
43" - |  UH670V  65", 55", 49", 43" |  65" -
55" -
49" -
43" - |  audio system
Harman / Kardon 2.0
Sound power: 20 W
Dolby Digital Plus
ULTRA Surround |  -
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
DLNA |  3 x HDMI2.0 (ARC,CEC)
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
HEVC |   |   |   |  UH670V  65", 55", 49", 43" |
 UH660V  668/664/661  65", 55", 49", 43" |  No |  No |  No |  65" - In HDR max   55" - In HDR max   49" - In HDR max   43" - In HDR max   HDR PROcessing
Convert SDR to HDR
PWM Freq. - 120/100Hz |  65"- DCI P3 - 84%   55"- DCI P3 - 84%   49"- DCI P3 - 84%   43"- DCI P3 -   Color Prime Pro |  65" -
55" -
49" -
43" - |  65" -
55" -
49" -
43" - |  65" -
55" -
49" -
43" - |  UH660V  65", 55", 49", 43" |  65" -
55" -
49" -
Harman/Kardon 2.0 - only in model 668
Sound power: 20 W
Dolby Digital Plus
ULTRA Surround |  -
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
Wi-Fi Direct
WiDi / Miracast
1 x 3.5mm Audio Out
1 x CI+1.3
2 x USB 2.0
Analog (PAL,SECAM)
PVR + Time Shift
HEVC |   |   |   |  UH660V  65", 55", 49", 43" |
 UH650V  6507  65", 60", 55", 49", 43" |  No |  No |  No |  65" - LC   60" -   55" -   49" -   43" -   HDR PROcessing
Convert SDR to HDR
(missing hardware for playback HDR) |  65"- AS-IPS, 8-bit+FRC, 60/50Hz   60"- AS-IPS, 8-bit+FRC, 60/50Hz   55"- AS-IPS, 8-bit+FRC, 60/50Hz   49"- AS-IPS, 8-bit+FRC, 60/50Hz   43"- AS-IPS, 8-bit+FRC, 60/50Hz   WRGB structure - resolution 2880x2160 |  65" - Edge Led (W-Led)   60" - Edge Led (W-Led)   55" - Edge Led (W-Led)   49" - Direct Led (W-Led)   43" - Direct Led (W-Led)   PWM Freq. - 120/100Hz |  65"- DCI P3 -   60" - DCI P3 -   55" - DCI P3 - 84%   49" - DCI P3 - 84%   43" - DCI P3 -   Color Prime Pro |  65" -
60" -
55" -
49" -
43" - |  65" -
60" -
55" -
49" -
43" - |  65" -
60" -
55" -
49" -
43" - |  UH650V  65", 60", 55", 49", 43" |  65" -
60" -
55" -
49" -
43" - |  Sound power: 20 W
Dolby Digital Plus
ULTRA Surround |  -
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 ac
WiDi / Miracast
DLNA
Bluetooth |  3 x НDМІ2.0 (ARC,CEC,MHL)
Соmроnеnt іn 1 (ѕhаrеd wіth соmроѕіtе)
1 x RЅ232С (Міnі Јасk)
USB 2.0 x 2
1 x Antena (RF)
1 x CI+ 1.3 |  DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
PVR + Time Shift
HEVC |   |   |   |  UH650V  65", 60", 55", 49", 43" |
 UH635V  58", 50",
UH630V
40"   |  No |  No |  No |  58" -   50" -   40" -   HDR PROcessing
Convert SDR to HDR
(missing hardware for playback HDR) |  58"- MVA ?, 8-bit, 60/50Hz   50"- MVA ?, 8-bit, 60/50Hz   40"- MVA ?, 8-bit, 60/50Hz
    |  58" - Edge Led (W-Led)   50" - Edge Led (W-Led)   40" - Edge Led (W-Led)   PWM Freq. - |  58" - DCI P3 - 90%   50" - DCI P3 - 90%   40" - DCI P3 -   Color Prime Plus |  58" -
50" -
40" - |  58" -
50" -
40" - |  58" -
50" -
40" - |  UH630V  58", 50", 40" |  58" -
50" -
40" - |  Sound power: 20 W
Dolby Digital Plus
ULTRA Surround |  -
Quad Core
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 ac
WiDi / Miracast
DLNA
1 x Соmроnеnt іn(ѕhаrеd wіth соmроѕіtе)
2 x USB 2.0
1 x Antena (RF)
Analog (PAL,SECAM)
PVR + Time Shift
HEVC   |   |   |   |  UH630V  58", 50", 40"   |
 UH620V  6257/6207  65", 60", 55", 49", 43" |  No |  No |  No |  65" -   60" -   55" -   49" -   43" -   HDR PROcessing
(missing hardware for playback HDR) |  65"- S-IPS, 8-bit, 60/50Hz   60"- S-IPS, 8-bit, 60/50Hz   55"- S-IPS, 8-bit, 60/50Hz   49"- S-IPS, 8-bit, 60/50Hz   43"- S-IPS, 8-bit, 60/50Hz   WRGB structure - resolution 2880x2160 |  60" - Edge Led (W-Led)   55" - Edge Led (W-Led)   49" - Direct Led (W-Led)   43" - Direct Led (W-Led) Local Dimming  PWM Freq. - |  65" - DCI P3   55" - DCI P3   49" - DCI P3   43" - DCI P3 -
    |  65" -
55" -
49" -
43" - |  65" -
55" -
49" -
43" - |  65" -
55" -
49" -
43" - |  UH620V  65", 60", 55", 49", 43" |   |  Sound power: 20 W
Dolby Digital Plus
ULTRA Surround |  -
Wi-Fi (only 802.11 n)
WiDi / Miracast
WiFi Direct
DLNA |  HDMI x (HDCP2.2)
1- ARC,
1 - Compatible 4K@60p and HDR 422
1 x USB 2.0 |  DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
PVR + Time Shift
HEVC   |   |   |   |  UH620V  65", 60", 55", 49", 43" |
 UH610V  6157/6107  65", 55", 49", 43" |  No |  No |  No |  65" -   55" -   49" -   43" -    HDR PROcessing
(missing hardware for playback HDR) |  65"- S-IPS, 8-bit, 60/50Hz   55"- S-IPS, 8-bit, 60/50Hz   49"- S-IPS, 8-bit, 60/50Hz   43"- S-IPS, 8-bit, 60/50Hz   WRGB structure - resolution 2880x2160 |  65" -   55" - Edge Led (W-Led)   49" -   43" -   PWM Freq. - |  65" - DCI P3 -   55" -   49" -   43" -
    |  65" -
55" -
49" -
43" - |  65" -
55" -
49" -
43" - |  65" -
55" -
49" -
43" - |  UH610V  65", 55", 49", 49", 43" |  65" -
55" -
49" -
Dolby Digital Plus
ULTRA Surround |  -
Wi-Fi (only 802.11.n)
WiDi / Miracast
DLNA |  3 x НDМІ2.0 (ARC,CEC,MHL)
RЅ232С (Міnі Јасk)
2 x USB 2.0  |  DVB-T/T2/C/S/S2
Analog (PAL,SECAM)
PVR
HEVC   |   |   |   |  UH610V  65", 55", 49", 49", 43" |
 UH600V  65", 60", 55",  49", 43"   |  No |  No |  No |  No |  65" - S-IPS, 8-bit, 60/50Hz   60" - S-IPS, 8-bit, 60/50Hz   55" - S-IPS, 8-bit, 60/50Hz   49" - S-IPS, 8-bit, 60/50Hz   43" - S-IPS, 8-bit, 60/50Hz   True Black Panel |  65" - Edge Led (W-Led)   60" - Edge Led   55" - Edge Led (W-Led)   49" - Edge Led (W-Led)   43" - Direct Led (W-Led)   PWM Freq. - |  65" -   60" -   55" -   49" -   43" -
    |  65" -
60" -
55" -
49" -
43" - |  65" -
60" -
55" -
49" -
43" - |  65" -
60" -
55" -
49" -
43" - |  UH600V  65", 60", 55", 49" |   |   |   |   |   |   |   |   |   |  UH600V  65", 60", 55", 49" |
 Series
Bits of color,
Curvature,
Index,
Screen Uniformity
Type LED
MEMC
Backlight Scanning
With local dimming
by default  |  Audio ____________________________ |  Operating Sistem
Board
System on Chip
RAM
calibration _________________________ |  Note ___________________________________________  Pros & Cons  |  Product |
