Отговор: LG телевизори 2016
operator3
Нов ъпдейт
05.05.20 за моделите LB630-LB870, EC930 от 2014 година.
Dominator
Какво ново има в ъпдейта?
Аз не виждам нищо ново (освен, че не работи LG Store-то, но ако се промени от местоположение за държава за услугите на LG напр. на ***** - работи). Като че ли има някакво минимално подобрение в ускорението при поредица от команди, но може и да си въобразявам.
При мен си работи LG Store-то.
Забелязвам, че са оправили синхронизацията на звука при Bluetooth. При 05.05.01 постоянно се губеше звука на ТВ програмите при пауза, връщане назад или превъртане.
Вероятно, по стар LG обичай, са скапали нещо друго, но засега не съм открил какво. )))
LG OLED55B6V Review: Firmware Update Improves PQ
LG OLED55B6V (B6) 4K OLED TV Review
1) No More 4K Blu-ray Frame Skipping
2) More Accurate PQ EOTF Tracking
3) Finer TruMotion Controls
Being a self-emissive display, the LG OLED55B6V already delivers some of the best SDR (standard dynamic range) images on the market thanks to true blacks, vibrant colours and wide viewing angles. But the latest firmware upgrade has truly enhanced the set’s HDR performance: PQ EOTF tracking was more accurate; shadow and highlight details were better preserved (once the correct settings were applied); and 24fps frame skipping from 4K Blu-ray playback had been fixed.
While some issues remain, these improvements now make LG’s 2016 OLEDs a very credible alternative to flagship FALD (full-array local dimming) LED LCDs for HDR viewing, especially when you take into account OLED’s ultra-precise pixel-level illumination which is completely devoid of haloing/ blooming artefacts, and the B6′s Dolby Vision compatibility.
Above all, this firmware release showed that LG is not resting on its laurels despite owning the best commercially viable large-sized display technology today – the company’s engineers are constantly working on improving picture quality based on constructive feedback from technical reviews and shootout events. Following a recent price drop to below £2000, the LG 55B6V represents incredible value for money given its superb image quality.
Здравейте , въпрос за молко старо TV LG
Имам 22LD320- ZA , много ми се иска да мъ активирам USB порта така че да може да се пускат филми от флашки . Много отдавн бях направил нещо подобно (благодарение на този форум) с едно друго старо LG 32 но не помня ....
Ще помогнете ли ?
БЛАГОДАРЯ
s_toshkov
Ще помогнете ли ?
БЛАГОДАРЯ
H E L P
Подобренията в съответните версии на ъпдейтите.
Firmware - Changelog
Applicable model list
OLED65E6P-C
OLED55E6P-C
OLED65C6P-C
OLED55C6P-C
86UH9550-CA
65UH9500-CA
75UH8550-CA
65UH8500-CA
60UH8500-CA
55UH8500-CA
49UH8500-CA
Release History
[03.10.10]
1. Streamer(English) ?Super? phrases delete
2. Fix AVS+ field stream video broken problem
[03.10.18]
1. To improve China STB HDMI(HDCP Fail)
2. To improve E-Streamer phrases error
[03.15.10]
1.To improve screen white flashing issue
(Phenomenon : Watching TV temporarily white flash occurs on the entire screen)
[04.30.08]
1. Change on Volume UI location
2. YouTube requirement for certification (When the network is not connected)
3. MS CDMi application
4. Changes on LG TV Plus (iOS UAC, Mobile video)
Detailed applicable model list : Please check with reference Tab exactly
* SW information
[04.30.08]
1. Improvement
1) Turn on the B6's TW speaker, when sound mode is standard.
2. Applicable model list
OLED55B6D-Z
OLED55B6J-Z
OLED55B6V-Z
OLED65B6D-Z
OLED65B6J-Z
OLED65B6V-Z
Detailed applicable model list : Please check with reference Tab exactly)
* SW information
79UF770V-ZE
79UF7709-ZE
43UF778V-ZD
49UF778V-ZD
55UF778V-ZD
60UF778V-ZD
65UF778V-ZD
40UF7787-ZD
43UF7787-ZD
49UF7787-ZD
55UF7787-ZD
43UF770V-ZL
49UF770V-ZL
55UF770V-ZL
60UF770V-ZL
65UF770V-ZL
43UF7709-ZL
49UF7709-ZL
55UF7709-ZL
60UF7709-ZL
65UF7709-ZL
40UF7707-ZL
43UF7707-ZL
49UF7707-ZL
55UF7707-ZL
43UF772V-ZW
49UF772V-ZW
55UF772V-ZW
60UF772V-ZW
65UF772V-ZW
70UF772V-ZW
43UF7729-ZW
49UF7729-ZW
55UF7729-ZW
70UF7729-ZW
40UF7727-ZW
43UF7727-ZW
49UF7727-ZW
55UF7727-ZW
43UF776V-ZX
49UF776V-ZX
55UF776V-ZX
60UF776V-ZX
65UF776V-ZX
43UF7769-ZX
55UF7769-ZX
65UF7769-ZX
40UF7767-ZX
43UF7767-ZX
49UF7767-ZX
55UF7767-ZX
40UF771V-ZS
43UF771V-ZS
49UF771V-ZS
55UF771V-ZS
60UF771V-ZS
70UF771V-ZU
Release History
[04.25.05]
1.Apply Netflix NRDP 4.2
2. Improve video stop issue in Live Contents of Premium Online.(Italy)
3. Improve the MHP?s no working with HbbTV & MHP stream.
4. Improve the Tricolor satellite channel missing issue. (Russia)
5. Improve the Digiturk (Turksat) fast scan?s no working.(Turkey)
6. Improve the Filbox fast scan?s no working. (Turkey)
7. Improve the Canal Digital EPG?s no working.
8. Apply the VHF 7Mhz and 8Mhz frequency table
9. Change the VHF 8Mhz -> 7Mhz (France)
10. Extend the DVB-C frequency table
[04.25.10]
1.Improve that the contents of Premium Play App are not played
[04.25.45]
1. Change the OTAU SO satellite (Intelsat904 to Kazsat3) - Kazakhstan
* SW information
1. Improvement
1) Apply the DVB-T2 system in Czech
2) To Improve auto-reboot problem with "This app will now restart to free up more memory" phrases during watching Live TV in Spain
3) To Improve automatic channel number changes(over 850 channel) problem during watching Italy Rai channel
43LH630V-ZJ
49LH630V-ZJ
55LH630V-ZJ
32LH604V-ZB
43LH604V-ZB
49LH604V-ZB
55LH604V-ZB
32LH6047-ZB
43LH6047-ZB
49LH6047-ZB
55LH6047-ZB
32LH609V-ZF
43LH609V-ZF
49LH609V-ZF
55LH609V-ZF
43LH604V-ZA
49LH604V-ZA
55LH604V-ZA
43LH590V-ZD
49LH590V-ZD
43LH590V-ZA
49LH590V-ZA
43LH595V-ZE
49LH595V-ZE
32LH595U-ZA
32LH590U-ZE
3. Release History
[03.20.30]
'- To improve WOL wrong action after 96 hours with DC Off status.
[03.20.40]
To improve the EPG PIG screen broken issue over DTV HD signal for 32inch HD module model
[04.30.02]
1. Audio Guidance expansion and dealing with GARI.
2. 16_CIS_local language application on TV OSD (The official language of Azerbaijan, Azerbaijani).
3. Italy_Mediaset Premium LCN (Requirement from Mediaset and Retailer ).
4. Add PID edit and reset functions in the Turkish satellite, TKGS visible list edit menu.
5. Russia Magadan /Sakhalin timezone offset change
6. Fixed DTV no sound in hbbTV channel.
[04.30.20]
1. Apply the DVB-T2 system in Czech
2. To Improve auto-reboot problem with "This app will now restart to free up more memory" phrases during watching Live TV in Spain
3. To Improve automatic channel number changes(over 850 channel) problem during watching Italy Rai channel
Здравейте, много рових из форума (може би недостатъчно), но не намерих никаква информация и мнения за LG LH6047. Моделът е от тази година и се чудя дали да го купя и това ли е най-доброто, което мога да взема при скромен бюджет 600-650 лв.
LH6047 - Full HD LED TV - LG телевизори, Full HD TV с 32 (82cm) размер на екрана, операционна система webOS 3.0 и метален дизайн
Здравейте, получих 55UH8507 тези дни и всичко си беше ок , докато пуснах филм от хард диск, прочетох ревютата за черното при филми на тъмно.Имам стар телевизор, който има такъв недостатък , но не е ''болка'' за мен. Надявам се да обесня проблема си правилно. При движение на курсора на дистанционното се получава вертикална широка линия сиво ( по -светло черно) и като го местя и линията се мести , също при поява на субтитрите и при движение на обектите във филма също подсветката се променя( по черните хоризонтални линии отгоре и отдолу) .Доста е досадно и не знам дали е дефект, липса на настройки или просто модела е така. Ще се ''играя'' още малко, но имам нужда от съвет дали да се опитвам да го опаковам обратно. Поздрави !
От Емага ли го поръча,защото пак го намалиха на 2099лв.Наистина ли е 3д и имали очила вътре в кутията.
GalenaP
Така е щото ползват само една лентичка диоди в долната част , ако изключиш "локалното" ще се оправи , ама черно и IPS без локално е мисия невъзможна ... Пробвай на минимална степен на "локалното" затъмнение и ... гледай тв само фронтално ;)
https://forum.setcombg.com/attachmen...id=21195&stc=1
Да, от емага го поръчах, но на дебелата цена, много ме е яд, тъй като точно 2 дена след като го получих и го свалиха. Та ТВ-то е 3д има си очила. Тъкмо направих снимки на ''проблема'' и му се ядосах още повече , но явно трвбва да го включа пак да си играя.
PS Изключих го локалното, никаква или поне не разбрах за съществена разлика. Ужасна работа, явно не е моя телевизор и марка и ще пътува обратно да се надявам да нямам проблем по връщането... Лека!
GalenaP
Проблема е че подсветката е само в горната и долната част на дисплея, разделена на по 10-12 секции - така имаме вертикално локално затъмняване.
Потърси модел с MVA матрица, при която този проблем е далеч по-малко видим.
https://prohardver.hu/teszt/lg_43lh5..._43lh510v.html
43LH510V: IPS, 50/60Hz panel
https://prohardver.hu/dl/cnt/2016-10...at_2.thumb.jpg
source photo:[prohardver.hu]
Долу горе си оправих картината. Благодаря за съветите, просто ще си оставя мозъка да се адаптира към промяната на ТВ-то. Преди смятах , че е дефект на вече остарелия ми Самсунг, след това , че е от сигнала на булсата,защото го забелязах и при LG-то, а то било Banding и проблема е отново в моя телевизор. Луда работа :) :) :) . Приятен уикенд!
