Страница 15 от 79 ПърваПърва ... 513141516172565 ... ПоследноПоследно
Резултати от 211 до 225 от общо 1171
Like Tree214Одобрявам
    #211
    Отговор: LG телевизори (инфо на първа страница)
    https://www.nvidia.com/en-us/geforce...onitors/specs/
    Type Manufacturer Model HDR Size1 LCD Type Resolution Variable Refresh Rate Range Variable Overdrive Variable Refresh Input Driver Needed
    G-SYNC Compatible LG 2019 B9, C9, E9 Yes 55 OLED 3840x2160 (UHD) 40-120Hz No HDMI HDMI VRR Driver
    G-SYNC Compatible LG 2019 B9, C9, E9 Yes 65 OLED 3840x2160 (UHD) 40-120Hz No HDMI HDMI VRR Driver
    G-SYNC Compatible LG 2019 B9, C9 Yes 77 OLED 3840x2160 (UHD) 40-120Hz No HDMI HDMI VRR Driver
    G-SYNC Compatible LG 2019 Z9 Yes 88 OLED 7680x4320 (8K) 40-120Hz No HDMI TV Firmware Update
    G-SYNC Compatible LG 2020 BX, CX, GX Yes 55 OLED 3840x2160 (UHD) 40-120Hz No HDMI 445.51 or newer
    G-SYNC Compatible LG 2020 BX, CX, GX Yes 65 OLED 3840x2160 (UHD) 40-120Hz No HDMI 445.51 or newer
    G-SYNC Compatible LG 2020 BX, CX, GX Yes 77 OLED 3840x2160 (UHD) 40-120Hz No HDMI 445.51 or newer
    G-SYNC Compatible LG 2020 CX Yes 48 OLED 3840x2160 (UHD) 40-120Hz No HDMI 445.51 or newer
    G-SYNC Compatible LG 2020 ZX Yes 77, 88 OLED 7680x4320 (8K) 40-120Hz No HDMI 445.51 or newer
    G-SYNC Compatible LG 2021 B1 4K series Yes 77, 65, 55 OLED 4K 40-120Hz No HDMI 2.1 Upcoming Driver
    G-SYNC Compatible LG 2021 C1 4K series Yes 83, 77, 65, 55, 48 OLED 4K 40-120Hz No HDMI 2.1 Upcoming Driver
    G-SYNC Compatible LG 2021 G1 4K series Yes 77, 65, 55 OLED 4K 40-120Hz No HDMI 2.1 Upcoming Driver
    G-SYNC Compatible LG 2021 Z1 8K series Yes 88, 77 OLED 8K 40-120Hz No HDMI 2.1 Upcoming Driver
    1 - Size (diagonal, inches).
    все още няма информация за новите модели относно поддръжката на Free Sync
    https://www.amd.com/en/products/freesync-tvs
    Този пост е редактиран от hristoslav2; 22-01-21 в 23:35.
  3. Member Аватара на legaltk
    Sep 2012
    #212
    Флашнах с новия Software_File(Version_05.30.10) от 21.01.2021 г. на LG49UK7550MLA.
    За новия фърм пише
    [05.30.10]
    1. Apple AirPlay/HomeKit available in selected countries.
    2. LG Channel has been upgraded and service territory expansion
    Започна много бавно да превключва каналите докато гледам IPTV с STB.
    Мога ли да се върна на предишна версия чрез инсталация от USB и откъде да си намеря файл с предишната версия?
    Този пост е редактиран от legaltk; 31-01-21 в 17:36.
    Apr 2015
    #213
    05.30.10 е
    1) Improved disconnection in certain apps after software update
    05.30.02 е
    1) Apple AirPlay/HomeKit available in selected countries.
    2) LG Channel has been upgraded and service territory expansion.
    Бавното превключване на каналите в твоя случай не зависи ли от приемника?
  5. Member Аватара на legaltk
    Sep 2012
    #214
    При моя модел ТВ, който съм посочил по-горе, ъпдейта е както съм го написал - копи-пейст.
    Да, помислих си за приемика, но той е с последния актуален софт от 05.01.2021 и проблема с времето за реакция възникна след ъпдейта на ТВ.
    Това е последната промяна, която съм правил.
    П.п. от 03.02.2021 - с цел да актуализирам информацията искам да кажа, че при мен проблема се оправи от само себе си. Времето за реакция на дистанционното вече е същото като преди и не мисля, че проблема е бил в ъпдейта на LG.
    Този пост е редактиран от legaltk; 03-02-21 в 21:25.
    Jun 2010
    #215
    Същото при мен с CAM на Мсат.Минах на Виваком и тв е вече само монитор.....
    #216
    #217
    The LG G1 OLED TV features an OLED Evo panel which is capable of higher peak brightness than conventional OLEDs. We explain how the OLED panel supplier, LG Display, has achieved 20% higher OLED efficiency and peak brightness in 2021 using a combination of two methods:
    1) The addition of a new green emitting layer, as described by Mr Bob O' Brien of DSCC (Display Supply Chain Consultants) in his interview with Mr Brian Berkeley on the Nanosys Inc. Youtube channel:
    2) Substitution of hydrogen with deuterium (a.k.a. heavy hydrogen) in the blue OLED compound (change of supplier from Idemitsu Kosan to DuPont), as described by the CEO of UBI Research in an interview with The Elec:
    [영상] LG는 어떻게 OLED 휘도를 20% 높였나? - 전자부품 전문 미디어 디일렉
    The Sony A90J & the Panasonic JZ2000 OLED TVs with higher peak brightness may also be using this new OLED panel from LG Display.
    *Note: We misspoke at 7:08 in this video... meant to say thirteen hundred nits, not thirteen thousand nits.
  10. Member Аватара на legaltk
    Sep 2012
    #218
    Цитат Първоначално публикувано от iihtiandar Виж публикацията
    Какво точно имаш предвид за Виваком.
    Те също са с STB, съответно второ дистанционно.
    #219
    UP70
    65UP70006LA.AEEQ - 799 Euro - Juli
    55UP70006LA.AEEQ - 649 Euro - Juli
    50UP70006LA.AEEQ - 529 Euro - Juli
    43UP70006LA.AEEQ - 479 Euro - Juli
    UP76
    43UP76909LE.AEU - 549 Euro - Mai
    UP75
    75UP75009LC.AEU - 1.499 Euro - April
    65UP75009LF.AEU - 949 Euro - April
    55UP75009LF.AEU - 769 Euro - April
    50UP75009LF.AEU - 639 Euro - April
    43UP75009LF.AEU - 529 Euro - April
    UP77
    75UP77009LB.AEU - 1.599 Euro - April
    70UP77009LB.AEU - 1.199 Euro - April
    65UP77009LB.AEU - 1.049 Euro - April
    55UP77009LB.AEU - 829 Euro - April
    50UP77009LB.AEU - 669 Euro - April
    43UP77009LB.AEU - 569 Euro - April
    UP78
    75UP78009LB.AEU - 1.649 Euro - Mai
    65UP78009LB.AEU - 1.099 Euro - April
    55UP78009LB.AEU - 859 Euro - April
    50UP78009LB.AEU - 699 Euro - April
    43UP78009LB.AEU - 589 Euro - April
    UP80
    86UP80009LA.AEU - 2.499 Euro - April
    82UP80009LA.AEU - 2.299 Euro - April
    UP81
    65UP81009LA.AEU - 1.099 Euro - April
    NANO75
    86NANO759PA.AEU - 2.799 Euro - April
    75NANO759PA.AEU - 1.699 Euro - April
    65NANO759PA.AEU - 1.199 Euro - Mai
    55NANO759PA.AEU - 899 Euro - April
    NANO77
    55NANO779PA.AEU - 899 Euro - Mai
    NANO79
    65NANO799PB.AEU - 1.299 Euro - August
    55NANO799PB.AEU - 949 Euro - August
    NANO80
    75NANO809PA.AEU - 1.999 Euro - April
    65NANO809PA.AEU - 1.349 Euro - April
    55NANO809PA.AEU - 999 Euro - April
    NANO86
    86NANO869PA.AEU - 3.499 Euro - April
    75NANO869PA.AEU - 2.199 Euro - April
    65NANO869PA.AEU - 1.599 Euro - April
    55NANO869PA.AEU - 1.149 Euro - April
    NANO91
    86NANO919PA.AEU - 3.999 Euro - April
    75NANO919PA.AEU - 2.499 Euro - April
    65NANO919PA.AEU - 1.799 Euro - April
    55NANO919PA.AEU - 1.299 Euro - Mai
    QNED91
    86QNED919PB.AEU - 6.999 Euro - Juni
    75QNED919PB.AEU - 4.599 Euro - Juni
    65QNED919PB.AEU - 2.499 Euro - Juli
    QNED99
    86QNED999PB.AEU - 9.999 Euro - Mai
    75QNED999PB.AEU - 6.999 Euro - Mai
    65QNED999PB.AEU - 4.999 Euro - Juli
    LG 4K OLED серия B1:
    OLED77B19LA.AEU - 4.999 Euro - April
    OLED65B19LA.AEU - 2.699 Euro - April
    OLED55B19LA.AEU - 1.799 Euro - April
    LG 4K OLED серия C1:
    OLED83C17LA.AEU - 7.999 Euro - Juni
    OLED77C17LB.AEU - 5.299 Euro - April
    OLED65C17LB.AEU - 2.799 Euro - April
    OLED55C17LB.AEU - 1.999 Euro - April
    OLED48C17LB.AEU - 1.649 Euro - April
    LG 4K OLED Evo G1 серия:
    OLED77G19LA.AEU - 6.499 Euro - April
    OLED65G19LA.AEU - 3.499 Euro - April
    OLED55G19LA.AEU - 2.399 Euro - April
    LG 8K OLED серия Z1:
    OLED88Z19LA.AEU - 29.999 Euro - Mai
    OLED77Z19LA.AEU - 19.999 Euro - Mai
    https://www.computerbase.de/2021-02/...r-2021-preise/
    https://www.areadvd.de/tests/special...en-und-preise/
    http://webos-forums.ru/post128763.ht...f125a9#p128763
    http://www.hifi-forum.de/viewthread-145-8708.html
    Този пост е редактиран от hristoslav2; 12-02-21 в 01:25.
    brave одобрява това.
  12. Junior Member
    #220
    https://www.technopolis.bg/bg/Televi...K-OLED/p/10281
    Това е стария модел нали така?
    #221
    LG OLED77ZX9LA - модел 2020
    LG OLED77Z19LA - модел 2021
    Този пост е редактиран от hristoslav2; 11-02-21 в 20:21.
  15. Junior Member
    #222
    Видях малко след като го написах,но не можех да го изтрия
    #223
    В първи пост на темата е описано как се разчита моделният код за трите групи телевизори.
    Подчертах разликата в горният си пост за да е по-ясно.
  17. Junior Member
    Nov 2017
    гр. Левски
    #224
    Здравейте телевизора ми е LG 49sj810 versia 05.80.60 има ли как да се сложи по нова версия ня софтуеара за този модел от тази най вече за да имам на apple appsa за филми, благодаря предварително.
    #225
    Отговори: 1323
    Последно: 28-06-26, 22:03
  2. Отговори: 117
    Последно: 12-06-21, 00:44
  3. TCL 2020
    Последно: 02-06-20, 05:33
  4. Евровизия 2020
    Последно: 14-03-20, 21:22
  5. Честита Нова 2020
    От kod във форум Дъра-Бъра
    Последно: 01-01-20, 15:58
