Резултати от 1 до 15 от общо 20
PANASONIC TH-42PV80P
    Feb 2008
    Здравейте !
    Видях този модел в каталога на техномаркет , но не пише никакви данни за него - http://www.technomarket.bg/product_d...ct_id=09036466 .
    Това новата серия плазми на панасоник ли са . Някой може ли да даде повече инфо .
    Тези данни ги намерих в нета , надявам се да са вeрни :
    HD Plazma televizor PANASONIC TH-42PV80P
    HD plazma televizor dijagonale 42 incha/107 cm, dinamičkog kontrasta 1:1,000,000 (prirodni kontrast 1:15,000), rezolucije 1024 x 768 pixela i sa 3 HDMI ulaza.
    TH-42PV80 je nasljednik plazme TH-42PV70 - najprodavanije plazme u 2007. i dobitnika EISA nagrade
    Opis:
    TV Tuner
    Tuner Integrated: analog
    Tuning System: PLL synthesizer 100-position auto-search tuner
    CATV Compatibility : Hyper-band Hyper-band
    Broadcast Stereo Reception : NICAM -B, G, I, L, German (A2)
    Teletext Reception : 1000P Level 2.5, FASTEXT/LIST/TOP
    Receiving System : PAL -B/G/H, -I, -D/K: SECAM -B/G, -D/K, L/L'
    Receiving System (AV input): PAL-525/60, SECAM, NTSC, M-NTSC PAL-525/60, SECAM, NTSC, M-NTSC
    Display
    Screen Size: 42" (106 cm) diagonal
    Screen Aspect : 16 : 9 Wide
    Panel : G11 Progressive HD Plasma Display Panel
    Natural Vision Filter
    Progressive Scan
    Number of Pixels : 786,432 (1,024 x 768) pixels
    Colour System: NTSC/PAL/PAL 60Hz/SECAM/M-NTSC
    Applicable PC signals: XGA (SXGA compressed)
    Applicable Scanning Format: 525 (480)/60i, 525 (480)/60p, 625 (576)/50i, 625 (576)/50p, 750 (720)/50p, 750 (720)/60p,1125 (1080)/50i, 1125 (1080)/60i, 1125 (1080)/24p (HDMI only), 1125 (1080)/50p (HDMI only), 1125 (1080)/ 1125 (1080)/
    Contrast Ratio (in dark surroundings): Native: 15,000:1; Dynamic: 1,000,000:1
    Shades of Gradation : 4,096 equivalent steps of gradation
    100 Hz Double Scan
    24p Playback
    3D Colour Management
    Sub Pixel Control
    Motion Pattern Noise Reduction
    C.A.T.S. (Contrast Automatic Tracking System)
    Video Noise Reduction
    3D Comb Filter
    Picture Mode : Dynamic/Normal/Cinema/Eco
    Sound
    Speakers: Full-Range (160 x 42 mm) x 2 (L,R)
    Audio Output : 20 W (10 W x 2), 10% THD
    Sound Mode : Music/Speech
    V-Audio
    Ambience
    Terminals
    SD Memory Card Slot (SDHC Compatible)
    HDMI Input: 3 (rear)
    Composite Video Input AV3: RCA phono type x 1 (front)
    S-Video Input AV3: Mini DIN 4-pin (front)
    Audio Input (for Video) AV3: RCA phono type connectors (L, R) (1 set, front)
    PC Input : Mini D-sub 15-pin x 1 (rear)
    Component Video Input: RCA phono type x 3 [Y , PB, PR] (rear)
    Audio Input (for HDMI, PC, Component): RCA phono type connectors (L, R) (1 set, rear)
    21-Pin Input/Output: AV1: AV In/Out, RGB In, Q-Link (rear)
    AV2: AV In/Out, S-Video In, RGB In, Q-Link (rear)
    Monitor Out: RCA phono type connectors (L, R) (1 set rear)
    Audio Output: Headphone jack (1 front)
    Features
    VIERA Link
    Screen Saver: Wobbling
    Multi Window: PAT
    Q-Link
    Aspect Controls : Auto/16:9/14:9/Just/4:3/Zoom1/Zoom2/Zoom3
    On-Screen Display Languages : 25 languages
    Off Timer : 15/30/45/60/75/90 min
    Child Lock
    General
    Power Supply : AC 220 - 240 V, 50/60Hz
    Power Consumption (Rated): 255 W
    Dimensions W/O stand (W x H x D) : 1,020 x 679 x 95 mm
    Dimensions with stand (W x H x D): 1,020 x 727 x 327 mm
    Weight W/O stand : 26 kg
    Weight with stand : 28 kg
    Operating Temperature : 0°C - 35°C
  3. Moderator
    Aug 2006
    Re: PANASONIC TH-42PV80P
    Да, това е модела. Поне на хартия. Мисля днес да отида да го видя наживо. Дано наистина го има и е включен.
    И ако наистина го пускат на такава цена може модела да има още по-голям успех.
  4. Moderator
    Aug 2005
    Цената е убиец
    А дали ще има Full HD версия 42PY80? Като гледам тази цена, която е супер за мен, то другият би трябвало да е под 3000лв!
  6. Moderator
    Aug 2006
    Днес ходих да го гледам наживо. За съжаление младежа, с който си имаме приказка го нямаше и нямах дистанционното да си поиграя както искам, но ми хареса. На външен вид са го барнали повече от PV70. По-високия контраст си личи, макар да го бяха пуснали на Dinamic и идваше повече отколкото ми харесва на мен.
    Естествено, че ще има и Full HD модели, но кога и за колко пари....?
  7. Moderator
    Aug 2005
    А дали ще има 37" вариант?Не мога да намеря инфо,на сайта на панасоник 1во,че го няма този модел и 2ро няма никакви 37" http://www2.panasonic.com/webapp/wcs...rBy=partnumber .
    Въпреки че когато настъпи момента за покупката ,ако няма 37 ще се прежаля с 42
  9. Junior Member
    Feb 2008
    малка корекция на цената направиха - от 1899 на 1979 лв.
  10. Junior Member
    Feb 2008
    Цитат Първоначално публикувано от Vanquished
    Да , още днес вериятно ще има в ТМ цариградско шосе - модела е PANASONIC TH-37PV80P и ще е 1829 лева .
    http://www.technomarket.bg/product_d...ct_id=09036695
  11. Moderator
    Aug 2005
    Супер,днес сутринта гледах и го нямаха,явно днес са го получили,тамън се чудех кога ще се пръкне ,че братята хървати вече го имат.
  12. Moderator
    Aug 2006
    150 лв по-малко от 42". Не виждам смисъла.
  13. Moderator
    Aug 2005
    И аз точно това се чудя,но ме е страх 42" да не е прекалено голям,ще се гледа м/у 2.5-3.5м предимно двд и цифрова тв.
    Jun 2007
    За разстоянието хич не се двоуми,аз гледам 42" PV70 от 2,5м. и като изключим първият ден на адаптиране,всичко е на 6.Даже ми е малък вече и следващият ще е поне 50"Айде като го вземеш,чакаме обстойно ревю с първи впечатления!
    Някой има ли наблюдения дали при 42PV80 са премахнали стъклото,дали не е с clear filter като при LG например.
  17. Junior Member
    Feb 2008
    Появи се и по-евтиния модел PANASONIC TH-42PV8P
    Ето и данни за него - http://panasonic.ro/Produse/Televizo...42pv8/657.html
    Apr 2008
    добре де кво ше рече Applicable Scanning Format: 525 (480)/60i, 525 (480)/60p, 625 (576)/50i, 625 (576)/50p, 750 (720)/50p, 750 (720)/60p,1125 (1080)/50i, 1125 (1080)/60i, 1125 (1080)/24p (HDMI only), 1125 (1080)/50p (HDMI only), 1125 (1080)/ 1125 (1080)/ не разбирам мн и затова питам тва не означава ли че може да приема сигнал 1080p?
  1. Panasonic FZ38 или предходен модел ...до Panasonic FZ10 ?
    От udoto във форум Фото и видеокамери
    Последно: 12-07-12, 23:41
  2. panasonic cs-a90ke и panasonic cu-e90ke. Къде е вярното им местонахождение?
    От lzxcvbnm във форум Въпроси свързани с монтажа
    Отговори: 23
    Последно: 27-11-11, 17:00
  3. Данни за климатици PANASONIC CS/CU-PE12CKE и PANASONIC CS/CU-PE9CKE
    От dimkaraganchev във форум Климатици Panasonic, National
    Отговори: 26
    Последно: 07-03-11, 19:35
  4. 42PV80P спешно!!! проблем
    От bopkata във форум Телевизори
    Отговори: 10
    Последно: 22-03-09, 12:47
  5. Panasonic TH-42PV80P FULL HD или не е ?
    От 99ufo99 във форум Panasonic телевизори
    Последно: 22-05-08, 09:38
